root/radiance/ray/src/util/rmtxop.c
Sat Aug 2 20:37:52 2025 UTC (12 days, 11 hours ago) by greg
Diff to previous 2.42
fix(rcomb,rmtxop): Allow -c and -C file paths starting with '.'
Sat Apr 19 03:58:00 2025 UTC (3 months, 3 weeks ago) by greg
CVS Tags: rad6R0
Changes since 2.41: +3 -1 lines
Diff to previous 2.41
fix(rmtxop): Missed error test in last change
Fri Apr 18 23:59:03 2025 UTC (3 months, 3 weeks ago) by greg
Changes since 2.40: +22 -5 lines
Diff to previous 2.40
Fri Apr 4 22:47:56 2025 UTC (4 months, 1 week ago) by greg
Diff to previous 2.39
fix(rmtxop,rcomb): Minor fixes to auto-typing, preferring native output
Fri Apr 4 18:18:06 2025 UTC (4 months, 1 week ago) by greg
Changes since 2.38: +7 -1 lines
Diff to previous 2.38
feat(rcomb,rmtxop): Added warning when 32-bit results written as 64-bit
Fri Apr 4 18:06:48 2025 UTC (4 months, 1 week ago) by greg
Changes since 2.37: +1 -5 lines
Diff to previous 2.37
Fri Apr 4 01:48:25 2025 UTC (4 months, 1 week ago) by greg
Changes since 2.36: +2 -5 lines
Diff to previous 2.36
perf(rmtxop): Changed rmx_transpose() call to do in-situ operation on square matrices
Fri Mar 28 00:06:36 2025 UTC (4 months, 2 weeks ago) by greg
Changes since 2.35: +3 -1 lines
Diff to previous 2.35
refactor: Made MAXCOMP redefinable and common between rmatrix tools
Fri Nov 8 17:52:26 2024 UTC (9 months ago) by greg
Changes since 2.34: +16 -16 lines
Diff to previous 2.34
fix(rcomb,rmtxop): Fix to matrix deallocation
Wed Aug 21 01:09:25 2024 UTC (11 months, 3 weeks ago) by greg
Changes since 2.33: +2 -2 lines
Diff to previous 2.33
fix(rcomb,rmtxop): Fixing compile error with const array type
Thu May 16 18:59:19 2024 UTC (14 months, 4 weeks ago) by greg
Changes since 2.32: +1 -2 lines
Diff to previous 2.32
fix: Made use of resolu.h more consistent and reliable
Tue Dec 19 16:09:20 2023 UTC (19 months, 3 weeks ago) by greg
Diff to previous 2.31
fix(rmtxop,rcomb): Added checks for "xyz" and "rgb" format output
Tue Dec 19 00:39:03 2023 UTC (19 months, 3 weeks ago) by greg
Changes since 2.30: +26 -9 lines
Diff to previous 2.30
feat(rmtxop,rcomb): Added lower-case versions of component outputs w/o efficacy conversions
Fri Dec 8 00:12:31 2023 UTC (20 months, 1 week ago) by greg
Changes since 2.29: +3 -4 lines
Diff to previous 2.29
fix(rmtxop,rmtxcomb): Eliminated the option of spectral output with 3 components
Sun Dec 3 03:44:42 2023 UTC (20 months, 1 week ago) by greg
Diff to previous 2.28
fix(rmtxop): Corrected wavelength split output based on reference input
Sun Dec 3 02:28:33 2023 UTC (20 months, 1 week ago) by greg
Changes since 2.27: +8 -7 lines
Diff to previous 2.27
fix(rmtxop): Corrected scalar post-multiplying component transform
Sat Dec 2 00:42:21 2023 UTC (20 months, 1 week ago) by greg
Changes since 2.26: +89 -20 lines
Diff to previous 2.26
feat(rmtxop): Added -c _file_ and -C options for specifying color spaces
Fri Dec 1 02:05:00 2023 UTC (20 months, 2 weeks ago) by greg
Changes since 2.25: +10 -11 lines
Diff to previous 2.25
refactor(rmtxop): Changed rmatrix library interface for by row matrix output
Wed Nov 29 18:57:10 2023 UTC (20 months, 2 weeks ago) by greg
Diff to previous 2.24
fix(rmtxop): compile error
Wed Nov 29 18:56:28 2023 UTC (20 months, 2 weeks ago) by greg
Changes since 2.23: +8 -4 lines
Diff to previous 2.23
feat(rmtxop): Added 'A' symbolic component for average of all channels
Tue Nov 28 16:36:50 2023 UTC (20 months, 2 weeks ago) by greg
Changes since 2.22: +5 -13 lines
Diff to previous 2.22
fix(rmtxop): Eliminated redundant error messages
Mon Nov 27 22:04:45 2023 UTC (20 months, 2 weeks ago) by greg
Changes since 2.21: +216 -35 lines
Diff to previous 2.21
feat(rmtxop): Added symbolic transforms to -c option and made -s apply after any such transform, so both may be used simultaneously
Tue Nov 21 01:30:20 2023 UTC (20 months, 3 weeks ago) by greg
Changes since 2.20: +3 -1 lines
Diff to previous 2.20
Wed Mar 23 00:58:35 2022 UTC (3 years, 4 months ago) by greg
Diff to previous 2.19
fix(rmtxop): Made error reporting consistent regardless of concatination direction
Thu Jan 21 17:47:07 2021 UTC (4 years, 6 months ago) by greg
Diff to previous 2.18
docs: formatting of option reminder
Tue Jan 19 23:32:00 2021 UTC (4 years, 6 months ago) by greg
Changes since 2.17: +12 -6 lines
Diff to previous 2.17
Sat Dec 28 18:05:14 2019 UTC (5 years, 7 months ago) by greg
Changes since 2.16: +1 -2 lines
Diff to previous 2.16
Mon Aug 12 20:38:19 2019 UTC (6 years ago) by greg
Changes since 2.15: +11 -8 lines
Diff to previous 2.15
Added warning about divide-by-zero to matrix information header
Mon Aug 12 16:55:24 2019 UTC (6 years ago) by greg
Changes since 2.14: +10 -4 lines
Diff to previous 2.14
Fixed argument parsing issue and added further explanations to man page
Mon Aug 12 02:26:46 2019 UTC (6 years ago) by greg
Changes since 2.13: +21 -9 lines
Diff to previous 2.13
Mon Aug 12 01:20:26 2019 UTC (6 years ago) by greg
Changes since 2.12: +246 -107 lines
Diff to previous 2.12
Mon Aug 27 23:03:05 2018 UTC (6 years, 11 months ago) by greg
Changes since 2.11: +16 -16 lines
Moved transpose operation later to save memory with -c (transform) reduction
Mon Aug 28 15:59:46 2017 UTC (7 years, 11 months ago) by greg
Changes since 2.10: +25 -6 lines
Thu Aug 18 17:57:57 2016 UTC (8 years, 11 months ago) by greg
Changes since 2.9: +3 -4 lines
Sun Mar 6 01:13:18 2016 UTC (9 years, 5 months ago) by schorsch
Wed Jul 22 04:47:51 2015 UTC (10 years ago) by greg
Changes since 2.7: +1 -4 lines
Moved some file settings around to improve logic
Fri Jan 23 01:03:17 2015 UTC (10 years, 6 months ago) by greg
Minor fix
Tue Dec 16 20:21:46 2014 UTC (10 years, 8 months ago) by greg
Fixed output format for ASCII from ASCII inputs
Thu Sep 18 23:20:12 2014 UTC (10 years, 10 months ago) by greg
CVS Tags: rad4R2P2
Changes since 2.4: +3 -7 lines
Took out unreliable call to ftell()
Tue Aug 5 21:45:05 2014 UTC (11 years ago) by greg
CVS Tags: rad4R2P1
Changes since 2.3: +8 -1 lines
Added missing _O_BINARY setting for Windows
Sat Aug 2 17:10:43 2014 UTC (11 years ago) by greg
Sat May 31 19:21:21 2014 UTC (11 years, 2 months ago) by greg
CVS Tags: rad4R2
Changes since 2.1: +10 -22 lines
Bug fixes
Sat May 31 05:02:37 2014 UTC (11 years, 2 months ago) by greg
