root/radiance/ray/src/util/glare.h
Thu May 1 16:42:06 2008 UTC (15 years, 11 months ago) by greg
CVS Tags: HEAD, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Diff to previous 2.6 , to selected 1.6
Fri Jan 2 12:51:54 2004 UTC (20 years, 3 months ago) by schorsch
Changes since 2.5: +16 -4 lines
Diff to previous 2.5 , to selected 1.6
Ansification.
Changes since 2.4: +5 -5 lines
Diff to previous 2.4 , to selected 1.6
Fri Jun 27 11:32:12 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 2.3: +17 -3 lines
Diff to previous 2.3 , to selected 1.6
Continued ANSIfication.
Changes since 2.2: +1 -4 lines
Diff to previous 2.2 , to selected 1.6
Tue May 25 14:54:05 1993 UTC (30 years, 11 months ago) by greg
Diff to previous 2.1 , to selected 1.6
reduced linearity of splittable source
Tue Nov 12 17:19:16 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 1.17 , to selected 1.6
Tue Apr 30 16:24:08 1991 UTC (33 years ago) by greg
Changes since 1.16: +4 -1 lines
Diff to previous 1.16 , to selected 1.6
Mon Apr 22 10:28:10 1991 UTC (33 years ago) by greg
Diff to previous 1.15 , to selected 1.6
changed definition of hscale() macro
Fri Apr 19 17:41:02 1991 UTC (33 years ago) by greg
Changes since 1.14: +4 -7 lines
Diff to previous 1.14 , to selected 1.6
Fri Apr 12 10:28:39 1991 UTC (33 years ago) by greg
Changes since 1.13: +6 -1 lines
Diff to previous 1.13 , to selected 1.6
minor changes and bug fixes
Wed Apr 10 15:59:04 1991 UTC (33 years ago) by greg
Diff to previous 1.12 , to selected 1.6
Wed Apr 3 15:43:53 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.11: +0 -2 lines
Diff to previous 1.11 , to selected 1.6
removed DEBUG flag
Thu Mar 28 16:27:23 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.10: +3 -0 lines
Diff to previous 1.10 , to selected 1.6
added warning message for insufficient data
Thu Mar 21 17:11:48 1991 UTC (33 years, 1 month ago) by greg
Diff to previous 1.9 , to selected 1.6
Wed Mar 20 13:47:38 1991 UTC (33 years, 1 month ago) by greg
Diff to previous 1.8 , to selected 1.6
switched on DEBUG
Wed Mar 20 11:56:42 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.7: +5 -0 lines
Diff to previous 1.7 , to selected 1.6
added routines to absorb too-small glare sources
Tue Mar 19 17:31:35 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.6: +2 -0 lines
Diff to previous 1.6
added -t option for setting glare threshold
Revision 1.6 - (view) (download) (annotate) - [selected]
Tue Mar 19 11:11:18 1991 UTC (33 years, 1 month ago) by greg
Diff to previous 1.5
increased accuracy of source values
Tue Mar 19 09:08:17 1991 UTC (33 years, 1 month ago) by greg
Diff to previous 1.4 , to selected 1.6
changed resolution
Mon Mar 18 16:06:51 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.3: +4 -3 lines
Diff to previous 1.3 , to selected 1.6
Mon Mar 18 15:06:30 1991 UTC (33 years, 1 month ago) by greg
Diff to previous 1.2 , to selected 1.6
fixed orientation of theta
Mon Mar 18 14:32:15 1991 UTC (33 years, 1 month ago) by greg
Diff to previous 1.1 , to selected 1.6
bug fixes and enhancements
Mon Mar 18 12:15:39 1991 UTC (33 years, 1 month ago) by greg
Diff to selected 1.6
