root/radiance/ray/src/util/getfile3.6.tcl
Revision 2.11
Wed Oct 26 20:06:17 2011 UTC (12 years, 7 months ago) by greg
FILE REMOVED
Made a few updates to trad
CVS Tags: rad3R5, rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0
Mon Jul 24 13:31:22 1995 UTC (28 years, 10 months ago) by greg
changed -geometry specification to -width -height
Thu Dec 1 10:14:56 1994 UTC (29 years, 6 months ago) by greg
Changes since 2.7: +5 -4 lines
fixed bug where transient directory changes failed
Wed Nov 30 16:47:00 1994 UTC (29 years, 6 months ago) by greg
Changes since 2.6: +6 -0 lines
fixed directory window view so as to give priority to end of path name
Wed Nov 30 16:04:39 1994 UTC (29 years, 6 months ago) by greg
fixed error for empty directories
Fri Oct 28 20:14:43 1994 UTC (29 years, 7 months ago) by greg
Changes since 2.4: +8 -1 lines
added local grab to some getfile procedure
Revision 2.4 - (view) (download) (as text) (annotate) - [selected]
Fri Oct 28 17:17:18 1994 UTC (29 years, 7 months ago) by greg
Changes since 2.3: +9 -10 lines
fixed problems with size on different screens (sort of)
Fri Oct 28 10:57:37 1994 UTC (29 years, 7 months ago) by greg
made it so empty field in directory entry equals home directory
Fri Oct 28 10:43:36 1994 UTC (29 years, 7 months ago) by greg
fixed size defaults for smaller dispaly
Thu Oct 27 15:56:10 1994 UTC (29 years, 7 months ago) by greg
Diff to selected 2.4
Links to HEAD: (view) (download) (as text) (annotate)
