root/Development/ray/src/util/genBSDF.pl
Fri Sep 19 16:39:27 2025 UTC (6 weeks ago) by greg
Changes since 2.97: +2 -2 lines
Diff to previous 2.97 , to selected 2.76
fix(genBSDF): Added missing space in Windows isotropic tensor tree command
Wed Sep 17 18:34:21 2025 UTC (6 weeks, 2 days ago) by greg
Changes since 2.96: +6 -7 lines
Diff to previous 2.96 , to selected 2.76
fix(genBSDF): Undid debug configuration accidentally checked in earlier
Thu Jun 19 22:03:37 2025 UTC (4 months, 1 week ago) by greg
CVS Tags: rad6R0
Changes since 2.95: +7 -6 lines
Diff to previous 2.95 , to selected 2.76
fix(rmtxop): In-core transpose wasn't working for square matrices(!)
Fri Apr 4 18:06:48 2025 UTC (6 months, 3 weeks ago) by greg
Changes since 2.94: +2 -2 lines
Diff to previous 2.94 , to selected 2.76
Wed Apr 2 00:55:27 2025 UTC (7 months ago) by greg
Changes since 2.93: +21 -36 lines
Diff to previous 2.93 , to selected 2.76
feat(genBSDF): Added support for -r "-cs M" to employ M spectral samples
Sun Dec 8 18:16:28 2024 UTC (10 months, 3 weeks ago) by greg
Changes since 2.92: +2 -3 lines
Diff to previous 2.92 , to selected 2.76
fix(genBSDF): Undid last change, since calcs must happen in RGB, anyway
Sun Dec 8 17:36:32 2024 UTC (10 months, 3 weeks ago) by greg
Changes since 2.91: +3 -2 lines
Diff to previous 2.91 , to selected 2.76
feat(genBSDF): Added spectral MGF conversion with -C option
Fri Jan 5 18:04:28 2024 UTC (21 months, 3 weeks ago) by greg
Changes since 2.90: +2 -2 lines
Diff to previous 2.90 , to selected 2.76
fix(genBSDF): Enforce the fact that spectral sampling is currently unsupported
Fri Sep 22 18:01:32 2023 UTC (2 years, 1 month ago) by greg
Changes since 2.89: +2 -4 lines
Diff to previous 2.89 , to selected 2.76
style: removed unused variable
Wed Mar 2 21:15:18 2022 UTC (3 years, 8 months ago) by greg
Changes since 2.88: +2 -1 lines
Diff to previous 2.88 , to selected 2.76
fix(genBSDF): Added error message for +mgf with +geom and no input file
Mon Jan 24 17:49:32 2022 UTC (3 years, 9 months ago) by greg
Diff to previous 2.87 , to selected 2.76
fix(genBSDF): mistyped variable name in last change
Sun Dec 12 20:32:21 2021 UTC (3 years, 10 months ago) by greg
Changes since 2.86: +2 -2 lines
Diff to previous 2.86 , to selected 2.76
fix(genBSDF): re-instated reciprocity averaging for isotropic TT transmission
Wed May 6 00:36:28 2020 UTC (5 years, 5 months ago) by greg
Diff to previous 2.85 , to selected 2.76
I was wrong about being wrong before, again...
Tue May 5 22:35:58 2020 UTC (5 years, 5 months ago) by greg
Changes since 2.84: +3 -3 lines
Diff to previous 2.84 , to selected 2.76
Removed unnecessary (and incorrect) isotropic sampling constraint
Fri Jan 17 17:33:48 2020 UTC (5 years, 9 months ago) by greg
Changes since 2.83: +7 -5 lines
Diff to previous 2.83 , to selected 2.76
Switched to zipper sampling in isotropic tensor tree to preserve peaks
Mon Jun 10 13:58:49 2019 UTC (6 years, 4 months ago) by greg
Changes since 2.82: +3 -3 lines
Diff to previous 2.82 , to selected 2.76
More careful version of fix to isotropic sampling
Sun Jun 9 20:52:13 2019 UTC (6 years, 4 months ago) by greg
Changes since 2.81: +11 -5 lines
Diff to previous 2.81 , to selected 2.76
Randomize plane sampling for isotropic tensor tree distributions
Fri Nov 30 19:51:30 2018 UTC (6 years, 11 months ago) by greg
Changes since 2.80: +2 -2 lines
Diff to previous 2.80 , to selected 2.76
Removed superfluous opiton from oconv command
Thu Apr 19 17:02:13 2018 UTC (7 years, 6 months ago) by greg
Changes since 2.79: +4 -3 lines
Diff to previous 2.79 , to selected 2.76
Better fix for zero ray contributions using +C option and tensor tree output
Tue Apr 17 18:11:17 2018 UTC (7 years, 6 months ago) by greg
Diff to previous 2.78 , to selected 2.76
Mon Jun 19 03:45:57 2017 UTC (8 years, 4 months ago) by greg
Diff to previous 2.77 , to selected 2.76
Fixed second typo in same line(!)
Thu Jun 8 15:37:15 2017 UTC (8 years, 4 months ago) by greg
Diff to previous 2.76
Fixed typo.
Revision 2.76 - (view) (download) (annotate) - [selected]
Wed May 31 17:25:21 2017 UTC (8 years, 5 months ago) by greg
Changes since 2.75: +6 -3 lines
Diff to previous 2.75
Tue Feb 14 07:06:55 2017 UTC (8 years, 8 months ago) by greg
Changes since 2.74: +8 -8 lines
Diff to previous 2.74 , to selected 2.76
Fixed quoting errors for -t3 on Unix
Tue Feb 7 19:53:59 2017 UTC (8 years, 8 months ago) by greg
Changes since 2.73: +4 -4 lines
Diff to previous 2.73 , to selected 2.76
More consistent use of warnings
Tue Jan 31 23:13:17 2017 UTC (8 years, 9 months ago) by greg
Changes since 2.72: +3 -8 lines
Diff to previous 2.72 , to selected 2.76
Fixed issue with warning on recovery file under Windows
Fri Oct 14 00:54:22 2016 UTC (9 years ago) by greg
Diff to previous 2.71 , to selected 2.76
Mon Sep 19 16:28:21 2016 UTC (9 years, 1 month ago) by greg
Changes since 2.70: +12 -3 lines
Diff to previous 2.70 , to selected 2.76
Minor readability improvements
Mon Sep 19 16:20:08 2016 UTC (9 years, 1 month ago) by greg
Changes since 2.69: +43 -35 lines
Diff to previous 2.69 , to selected 2.76
Fixes to recovery option -- was not building wrapBSDF command correctly
Fri Sep 16 22:42:42 2016 UTC (9 years, 1 month ago) by greg
Changes since 2.68: +2 -1 lines
Diff to previous 2.68 , to selected 2.76
Fix for unlikely case where first rfluxmtx has not happened before recovery
Fri Sep 16 20:01:29 2016 UTC (9 years, 1 month ago) by greg
Diff to previous 2.67 , to selected 2.76
Removed stray unused variable
Fri Sep 16 19:47:41 2016 UTC (9 years, 1 month ago) by greg
Changes since 2.66: +29 -27 lines
Diff to previous 2.66 , to selected 2.76
Fixes to last feature addition
Fri Sep 16 17:54:56 2016 UTC (9 years, 1 month ago) by greg
Changes since 2.65: +131 -81 lines
Diff to previous 2.65 , to selected 2.76
Thu Aug 18 15:09:29 2016 UTC (9 years, 2 months ago) by greg
Diff to previous 2.64 , to selected 2.76
Fixed warning about device being far beind Z==0 plane
Wed Jul 13 00:51:17 2016 UTC (9 years, 3 months ago) by greg
Changes since 2.63: +9 -3 lines
Diff to previous 2.63 , to selected 2.76
Tue Feb 9 23:05:26 2016 UTC (9 years, 8 months ago) by greg
Diff to previous 2.62 , to selected 2.76
Rob G's fix for Git Bash error
Mon Feb 8 00:51:32 2016 UTC (9 years, 8 months ago) by greg
Changes since 2.61: +2 -2 lines
Diff to previous 2.61 , to selected 2.76
Fixed single-quote in wrapBSDF command, which fails under Windows
Wed Aug 26 02:27:09 2015 UTC (10 years, 2 months ago) by greg
Diff to previous 2.60 , to selected 2.76
Minor correction to error message
Fri May 29 08:13:46 2015 UTC (10 years, 5 months ago) by greg
Diff to previous 2.59 , to selected 2.76
Corrected error in last change
Fri May 29 07:45:48 2015 UTC (10 years, 5 months ago) by greg
Changes since 2.58: +2 -7 lines
Diff to previous 2.58 , to selected 2.76
Fri May 29 07:22:33 2015 UTC (10 years, 5 months ago) by greg
Changes since 2.57: +2 -1 lines
Diff to previous 2.57 , to selected 2.76
Added missing character type to XML header
Thu Apr 2 17:42:46 2015 UTC (10 years, 7 months ago) by greg
Diff to previous 2.56 , to selected 2.76
Minor fix to usage message
Wed Apr 1 01:38:35 2015 UTC (10 years, 7 months ago) by greg
Changes since 2.55: +16 -15 lines
Diff to previous 2.55 , to selected 2.76
Fixes for Klems & tensor tree coordinate orientations
Fri Mar 27 18:58:06 2015 UTC (10 years, 7 months ago) by greg
Changes since 2.54: +14 -10 lines
Diff to previous 2.54 , to selected 2.76
Wed Mar 25 22:50:48 2015 UTC (10 years, 7 months ago) by greg
Changes since 2.53: +9 -13 lines
Diff to previous 2.53 , to selected 2.76
Fixed bug in CIE (u',v') BSDF output
Wed Mar 25 19:18:28 2015 UTC (10 years, 7 months ago) by greg
Changes since 2.52: +39 -19 lines
Diff to previous 2.52 , to selected 2.76
Changed output of tensor tree to use CIE (u',v') coordinates
Mon Mar 16 00:40:51 2015 UTC (10 years, 7 months ago) by greg
Diff to previous 2.51 , to selected 2.76
Fixed issue with missing rcollate -oc specification
Thu Mar 12 13:24:41 2015 UTC (10 years, 7 months ago) by greg
Diff to previous 2.50 , to selected 2.76
Added missing semicolons
Wed Mar 4 17:42:54 2015 UTC (10 years, 8 months ago) by greg
Diff to previous 2.49 , to selected 2.76
Fixes for Windows
Fri Feb 20 18:26:09 2015 UTC (10 years, 8 months ago) by greg
Changes since 2.48: +274 -564 lines
Diff to previous 2.48 , to selected 2.76
Wed Jul 9 15:03:11 2014 UTC (11 years, 3 months ago) by greg
Changes since 2.47: +4 -1 lines
Diff to previous 2.47 , to selected 2.76
Added warning for -t3 w/o +forward and +backward
Thu Apr 24 23:08:08 2014 UTC (11 years, 6 months ago) by greg
Changes since 2.46: +293 -166 lines
Diff to previous 2.46 , to selected 2.76
Andy finished making genBSDF Windows-compatible
Mon Apr 7 21:33:25 2014 UTC (11 years, 6 months ago) by greg
Diff to previous 2.45 , to selected 2.76
Added protection against very small dimension(s)
Thu Oct 3 17:27:41 2013 UTC (12 years, 1 month ago) by greg
Diff to previous 2.44 , to selected 2.76
Re-allowed rttree_reduce -a option for isotropic transmission
Sat Sep 7 17:56:02 2013 UTC (12 years, 1 month ago) by greg
Diff to previous 2.43 , to selected 2.76
Bug fix for round-off error at phi=315 degrees
Mon Aug 5 22:56:50 2013 UTC (12 years, 2 months ago) by greg
Diff to previous 2.42 , to selected 2.76
Tue Apr 23 23:22:09 2013 UTC (12 years, 6 months ago) by greg
Diff to previous 2.41 , to selected 2.76
Correction to last change
Tue Apr 23 23:19:09 2013 UTC (12 years, 6 months ago) by greg
Diff to previous 2.40 , to selected 2.76
Sat Oct 13 20:15:43 2012 UTC (13 years ago) by greg
Changes since 2.39: +11 -8 lines
Diff to previous 2.39 , to selected 2.76
Mon Sep 10 18:06:08 2012 UTC (13 years, 1 month ago) by greg
Changes since 2.38: +3 -1 lines
Diff to previous 2.38 , to selected 2.76
Hopeful fixes to tensor tree reciprocity and orientation
Sun Sep 2 15:33:16 2012 UTC (13 years, 2 months ago) by greg
Changes since 2.37: +9 -7 lines
Diff to previous 2.37 , to selected 2.76
Thu Jun 14 22:42:21 2012 UTC (13 years, 4 months ago) by greg
Changes since 2.36: +5 -5 lines
Diff to previous 2.36 , to selected 2.76
Thu Jun 14 18:35:03 2012 UTC (13 years, 4 months ago) by greg
Changes since 2.35: +29 -98 lines
Diff to previous 2.35 , to selected 2.76
Simplified and called new rcontrib program
Wed May 9 17:40:17 2012 UTC (13 years, 5 months ago) by greg
Changes since 2.34: +72 -72 lines
Diff to previous 2.34 , to selected 2.76
Minor changes that should not affect results
Thu Mar 15 02:32:19 2012 UTC (13 years, 7 months ago) by greg
Changes since 2.33: +7 -1 lines
Diff to previous 2.33 , to selected 2.76
Fix for -t3 N -t -1
Tue Mar 6 04:41:31 2012 UTC (13 years, 7 months ago) by greg
Changes since 2.32: +27 -11 lines
Diff to previous 2.32 , to selected 2.76
Changed default -t to 90 and set up -t -1 to skip rttree_reduce call
Thu Feb 23 21:28:42 2012 UTC (13 years, 8 months ago) by greg
Changes since 2.31: +3 -1 lines
Diff to previous 2.31 , to selected 2.76
Fixed problem with extra newlines
Mon Feb 20 04:54:49 2012 UTC (13 years, 8 months ago) by greg
Changes since 2.30: +4 -4 lines
Diff to previous 2.30 , to selected 2.76
Took out reciprocity averaging for matrix data, which wasn't being done properly
Mon Feb 20 02:56:19 2012 UTC (13 years, 8 months ago) by greg
Diff to previous 2.29 , to selected 2.76
Minor fix for corner case
Fri Feb 17 00:14:46 2012 UTC (13 years, 8 months ago) by greg
Changes since 2.28: +7 -8 lines
Diff to previous 2.28 , to selected 2.76
Mon Nov 21 20:07:50 2011 UTC (13 years, 11 months ago) by greg
Changes since 2.27: +7 -7 lines
Diff to previous 2.27 , to selected 2.76
Added reciprocity averaging
Thu Oct 27 16:35:54 2011 UTC (14 years ago) by greg
Diff to previous 2.26 , to selected 2.76
Tue Oct 25 20:51:10 2011 UTC (14 years ago) by greg
Diff to previous 2.25 , to selected 2.76
Wed Aug 24 04:14:58 2011 UTC (14 years, 2 months ago) by greg
Diff to previous 2.24 , to selected 2.76
Tue Aug 23 14:02:41 2011 UTC (14 years, 2 months ago) by greg
Diff to previous 2.23 , to selected 2.76
Fri Jun 24 19:07:38 2011 UTC (14 years, 4 months ago) by greg
Diff to previous 2.22 , to selected 2.76
Fri Jun 24 00:41:51 2011 UTC (14 years, 4 months ago) by greg
Diff to previous 2.21 , to selected 2.76
Wed Jun 8 23:16:47 2011 UTC (14 years, 4 months ago) by greg
Diff to previous 2.20 , to selected 2.76
Sat Jun 4 00:33:53 2011 UTC (14 years, 5 months ago) by greg
Diff to previous 2.19 , to selected 2.76
Fri Jun 3 19:41:14 2011 UTC (14 years, 5 months ago) by greg
Diff to previous 2.18 , to selected 2.76
Wed Jun 1 22:50:24 2011 UTC (14 years, 5 months ago) by greg
Diff to previous 2.17 , to selected 2.76
Wed Jun 1 00:29:40 2011 UTC (14 years, 5 months ago) by greg
Diff to previous 2.16 , to selected 2.76
Tue May 31 20:50:26 2011 UTC (14 years, 5 months ago) by greg
Diff to previous 2.15 , to selected 2.76
Wed May 25 19:24:11 2011 UTC (14 years, 5 months ago) by greg
Diff to previous 2.14 , to selected 2.76
Sat Apr 16 01:13:22 2011 UTC (14 years, 6 months ago) by greg
Diff to previous 2.13 , to selected 2.76
Eliminated Unix dependencies
Sat Apr 16 00:39:07 2011 UTC (14 years, 6 months ago) by greg
Diff to previous 2.12 , to selected 2.76
Bug fix for 32-bit OS
Thu Feb 24 20:27:00 2011 UTC (14 years, 8 months ago) by greg
Diff to previous 2.11 , to selected 2.76
Fixed usage message
Thu Feb 24 20:14:26 2011 UTC (14 years, 8 months ago) by greg
Diff to previous 2.10 , to selected 2.76
Tue Feb 22 22:51:23 2011 UTC (14 years, 8 months ago) by greg
Diff to previous 2.9 , to selected 2.76
Mon Feb 21 22:48:51 2011 UTC (14 years, 8 months ago) by greg
Diff to previous 2.8 , to selected 2.76
Sat Jan 29 16:44:01 2011 UTC (14 years, 9 months ago) by greg
Diff to previous 2.7 , to selected 2.76
Thu Jan 27 22:28:12 2011 UTC (14 years, 9 months ago) by greg
Diff to previous 2.6 , to selected 2.76
Wed Dec 15 17:23:58 2010 UTC (14 years, 10 months ago) by greg
Diff to previous 2.5 , to selected 2.76
Thu Dec 9 17:00:43 2010 UTC (14 years, 10 months ago) by greg
Diff to previous 2.4 , to selected 2.76
Thu Dec 9 06:14:04 2010 UTC (14 years, 10 months ago) by greg
Diff to previous 2.3 , to selected 2.76
Thu Sep 9 06:02:16 2010 UTC (15 years, 1 month ago) by greg
Diff to previous 2.2 , to selected 2.76
Fri Sep 3 23:53:50 2010 UTC (15 years, 2 months ago) by greg
Diff to previous 2.1 , to selected 2.76
Thu Sep 2 02:29:24 2010 UTC (15 years, 2 months ago) by greg
Diff to selected 2.76
