root/radiance/ray/src/px/pmblur2.c
Thu Nov 7 23:20:29 2019 UTC (5 years, 5 months ago) by greg
Thu Aug 2 18:33:45 2018 UTC (6 years, 9 months ago) by greg
Sat Oct 13 05:18:18 2012 UTC (12 years, 6 months ago) by greg
Changes since 2.4: +3 -4 lines
Reduced sampling artifacts substantially
Fri Oct 5 18:54:40 2012 UTC (12 years, 6 months ago) by greg
Changes since 2.3: +5 -3 lines
Added check for frame start equal frame end
Fri Oct 5 15:25:12 2012 UTC (12 years, 7 months ago) by greg
Changes since 2.2: +21 -9 lines
Added check for same object -- does not seem to make much difference
Fri Oct 5 02:07:10 2012 UTC (12 years, 7 months ago) by greg
Changes since 2.1: +13 -7 lines
Diff to previous 2.1
Added optional setting of the number of time slices to pmblur2
Fri Oct 5 00:59:38 2012 UTC (12 years, 7 months ago) by greg
