root/radiance/ray/src/hd/SConscript
Mon Jan 8 13:38:37 2018 UTC (6 years, 4 months ago) by schorsch
Changes since 1.12: +3 -0 lines
Diff to previous 1.12 , to selected 1.4
Mon Mar 28 17:35:13 2016 UTC (8 years, 1 month ago) by schorsch
Diff to previous 1.11 , to selected 1.4
syntax.
Fri Mar 18 22:55:49 2016 UTC (8 years, 2 months ago) by schorsch
Changes since 1.10: +9 -10 lines
Diff to previous 1.10 , to selected 1.4
better solution for addobjnotify
Thu Mar 10 21:43:23 2016 UTC (8 years, 2 months ago) by schorsch
Changes since 1.9: +9 -14 lines
Diff to previous 1.9 , to selected 1.4
Thu Mar 10 01:49:56 2016 UTC (8 years, 2 months ago) by schorsch
Changes since 1.8: +9 -7 lines
Diff to previous 1.8 , to selected 1.4
SCons build system learns about platform architecture
Sat Mar 5 13:24:58 2016 UTC (8 years, 2 months ago) by schorsch
Changes since 1.7: +10 -7 lines
Diff to previous 1.7 , to selected 1.4
Tue Dec 23 15:04:00 2008 UTC (15 years, 4 months ago) by schorsch
Diff to previous 1.6 , to selected 1.4
Mon Apr 21 07:31:29 2008 UTC (16 years, 1 month ago) by schorsch
Changes since 1.5: +4 -4 lines
Diff to previous 1.5 , to selected 1.4
Scons update for mingw.
Mon Sep 19 12:37:46 2005 UTC (18 years, 8 months ago) by schorsch
Changes since 1.4: +4 -1 lines
Diff to previous 1.4
Added rhoptimize to SCons build.
Revision 1.4 - (view) (download) (annotate) - [selected]
Mon Nov 8 19:24:46 2004 UTC (19 years, 6 months ago) by schorsch
Changes since 1.3: +5 -22 lines
Diff to previous 1.3
Sun Jul 4 12:08:48 2004 UTC (19 years, 10 months ago) by schorsch
Diff to previous 1.2 , to selected 1.4
Mon Oct 27 10:35:42 2003 UTC (20 years, 6 months ago) by schorsch
Changes since 1.1: +29 -19 lines
Diff to previous 1.1 , to selected 1.4
Tue Oct 21 19:27:29 2003 UTC (20 years, 7 months ago) by schorsch
Diff to selected 1.4
