root/radiance/ray/src/hd/SConscript
Revision: 1.13
Committed: Mon Jan 8 13:38:37 2018 UTC (7 years, 6 months ago) by schorsch
CVS Tags: rad5R4, rad5R2, rad5R3, rad6R0, HEAD
Changes since 1.12: +3 -0 lines
# User Rev Content
1 schorsch 1.13 from __future__ import division, print_function, unicode_literals
2
3 schorsch 1.1 import os
4
5     Import('env')
6
7     # math libs
8     mlib = env['RAD_MLIB']
9
10 schorsch 1.8 # compose paths
11     def radbin(name): return os.path.join('$RAD_BUILDBIN', name)
12     def radlib(name): return os.path.join('$RAD_BUILDLIB', name)
13
14 schorsch 1.1 # common objects
15     viewbeams = env.Object(source='viewbeams.c')
16     holo = env.Object(source='holo.c')
17 schorsch 1.2 holofile = env.Object(source='holofile.c')
18 schorsch 1.5 clumpbeams = env.Object(source='clumpbeams.c')
19 schorsch 1.1
20     # standard targets
21     PROGS = (
22 schorsch 1.2 ('rholo', Split('''rholo.c rholo2.c rholo2l.c rholo3.c rholo4.c''')
23 schorsch 1.10 + [env.version, holofile, holo, viewbeams], ['rtrad'],0),
24 schorsch 1.8 ('rhpict', Split('rhpict.c rhpict2.c')+[env.version, holofile, holo, viewbeams],
25 schorsch 1.10 ['rtrad'],1),
26     ('rhcopy', Split('rhcopy.c') + [clumpbeams, holofile, holo], ['rtrad'],1),
27     ('rhinfo', Split('rhinfo.c') + [holofile, holo], ['rtrad'],1),
28     ('rhoptimize', Split('rhoptimize.c') + [clumpbeams,holofile,holo], ['rtrad'],1),
29     ('genrhgrid', Split('genrhgrid.c') + [holofile, holo], ['rtrad'],1),
30 schorsch 1.1 )
31 schorsch 1.9 if 1:
32 schorsch 1.1 for p in PROGS:
33 schorsch 1.9 if not p[3] and os.name == 'nt': continue
34 schorsch 1.8 prog = env.Program(target=radbin(p[0]),
35 schorsch 1.2 source=p[1], LIBS=p[2] + mlib)
36 schorsch 1.1 Default(prog)
37     env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
38
39     # display drivers
40     if env.has_key('X11INCLUDE'):
41 schorsch 1.7 xenv = env.Clone(CPPPATH=[env['X11INCLUDE']] + env['CPPPATH'],
42 schorsch 1.1 LIBPATH=[env['X11LIB']] + env['LIBPATH'],)
43     # common objects
44     rhdisp = xenv.Object(source='rhdisp.c')
45     rhdisp2 = xenv.Object(source='rhdisp2.c')
46     rhd_qtree = env.Object(source='rhd_qtree.c')
47     xcommon = [rhdisp, rhdisp2, holo, viewbeams]
48     # other stuff
49     devdir = os.path.join(xenv['RAD_BUILDBIN'],'dev')
50     idevdir = os.path.join(xenv['RAD_BINDIR'],'dev')
51     ocppflags = xenv.get('CPPFLAGS', [])
52 schorsch 1.11 addobj = xenv.get('ADDOBJNOTIFY')
53 schorsch 1.1
54     # XXX the .hdi extension will cause problems on Windows
55     xenv['PROGSUFFIX'] = '.hdi'
56
57     def make_hdi(p): # build them
58     obj = xenv.Object(target=p[3], source=p[4], CPPFLAGS=ocppflags + p[5])
59 schorsch 1.8 prog = xenv.Program(target=radbin(p[0]),
60 schorsch 1.1 source=[obj] + p[1] + xcommon, LIBS=p[2])
61     Default(prog)
62     inst = xenv.Install(idevdir, prog)
63     # XXX what are the alternative "<driver>h" names good for?
64 schorsch 1.8 insth = xenv.InstallAs(target=radbin(
65 schorsch 1.1 p[0] + 'h' + xenv['PROGSUFFIX']), source=prog)
66     env.Append(RAD_BININSTALL=[inst, insth])
67
68     # (name, sources, libs, obj, objsrc, objflags)
69     XHDI = (('x11', Split('rhd_ctab.c rhd_qtree2r.c') + [rhd_qtree],
70 schorsch 1.11 ['rtrad', 'X11'] + mlib,
71 schorsch 1.1 'rhd_x11', 'rhd_x11.c', []),
72     )
73     for p in XHDI:
74     make_hdi(p)
75
76     if env.has_key('OGL'):
77 schorsch 1.10 rgllibs = ['rgl','rtrad']
78 schorsch 1.1 ogl_common_s = Split('rhd_odraw.c rhd_geom.c')
79     ogl_common = map(lambda s:xenv.Object(source=s), ogl_common_s)
80     rhdobj = xenv.Object(source='rhdobj.c')
81
82     GLHDI = (
83 schorsch 1.4 # glx1h
84 schorsch 1.1 ('glx1', ['rhd_qtree2c.c', rhd_qtree],
85 schorsch 1.11 ['rtrad', 'GLU','GL','X11'] + mlib,
86 schorsch 1.1 'rhd_glx1', 'rhd_glx1.c', ['-DNOSTEREO']),
87
88 schorsch 1.4 # oglh
89 schorsch 1.11 ('ogl', ogl_common + [addobj],
90     rgllibs+['rtrad', 'GLU','GL','X11'] + mlib,
91 schorsch 1.1 'rhd_ogl0', 'rhd_ogl.c', ['-DNOSTEREO']),
92
93 schorsch 1.4 # ogloh
94 schorsch 1.11 ('oglo', [rhdobj] + ogl_common + [addobj],
95     rgllibs+['rtrad']+['rtrad', 'GLU','GL','X11'] + mlib,
96 schorsch 1.1 'rhd_oglo', 'rhd_ogl.c', ['-DDOBJ', '-DNOSTEREO']),
97     )
98     for p in GLHDI:
99     make_hdi(p)
100     if xenv['RAD_STEREO'] == '-DSTEREO':
101
102     GLSHDI = (
103 schorsch 1.4 # oglsh
104 schorsch 1.1 ('ogls', ogl_common,
105 schorsch 1.11 rgllibs+['rtrad', 'GLU','GL','X11','Xext'] + mlib,
106 schorsch 1.12 'rhd_ogls', 'rhd_ogl.c', ['-DSTEREO']),
107 schorsch 1.1
108 schorsch 1.4 # oglsoh
109 schorsch 1.1 ('oglso', [rhdobj] + ogl_common,
110 schorsch 1.11 rgllibs+['rtrad', 'GLU','GL','X11','Xext'] + mlib,
111 schorsch 1.12 'rhd_oglso', 'rhd_ogl.c', ['-DDOBJ', '-DSTEREO']),
112 schorsch 1.1 )
113     for p in GLHDI:
114     make_hdi(p)
115
116
117
118 schorsch 1.8 # vim: set syntax=python:
119 schorsch 1.13 # vi: set ts=4 sw=4 :
