root/Development/ray/src/cv/mgflib/parser.h
Revision 1.40
Tue Feb 22 15:58:42 2011 UTC (14 years, 10 months ago) by greg
Changes since 1.39: +1 -1 lines
FILE REMOVED
Finish of code reorg, moving MGF library into src/cv and src/common
Fri Jan 14 05:46:12 2011 UTC (14 years, 11 months ago) by greg
Changes since 1.38: +7 -11 lines
Diff to previous 1.38 , to selected 1.28
Eliminated unnecessary MEM_PTR
Mon Jan 3 20:30:21 2011 UTC (15 years ago) by greg
Changes since 1.37: +3 -44 lines
Diff to previous 1.37 , to selected 1.28
Separated color manipulation routines
Sat Nov 15 17:54:06 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 1.36: +4 -1 lines
Diff to previous 1.36 , to selected 1.28
Mon Jun 30 14:59:11 2003 UTC (22 years, 6 months ago) by schorsch
Changes since 1.35: +1 -5 lines
Diff to previous 1.35 , to selected 1.28
Thu Jun 26 00:58:09 2003 UTC (22 years, 6 months ago) by schorsch
Changes since 1.34: +6 -6 lines
Diff to previous 1.34 , to selected 1.28
Sat Jun 7 01:11:17 2003 UTC (22 years, 7 months ago) by schorsch
Changes since 1.33: +14 -82 lines
Diff to previous 1.33 , to selected 1.28
Removed NOPROTO sections.
Fri Feb 28 20:11:29 2003 UTC (22 years, 10 months ago) by greg
Changes since 1.32: +2 -14 lines
Diff to previous 1.32 , to selected 1.28
Updates for 3.5 release
Fri Jan 16 10:47:27 1998 UTC (27 years, 11 months ago) by gregl
Diff to previous 1.31 , to selected 1.28
changed M_PI definition to ward off long double problems
Fri Oct 10 16:45:50 1997 UTC (28 years, 2 months ago) by gregl
Changes since 1.30: +15 -10 lines
Diff to previous 1.30 , to selected 1.28
Added client data pointers to context structures (vertex, color, material).
Tue Mar 18 11:05:40 1997 UTC (28 years, 9 months ago) by greg
Changes since 1.29: +35 -5 lines
Diff to previous 1.29 , to selected 1.28
added fh entity and general cleanup
Thu Feb 8 16:29:33 1996 UTC (29 years, 11 months ago) by greg
Changes since 1.28: +2 -0 lines
Diff to previous 1.28
added check for previous definition of PI
Revision 1.28 - (view) (download) (annotate) - [selected]
Wed Nov 29 19:55:42 1995 UTC (30 years, 1 month ago) by greg
Changes since 1.27: +11 -3 lines
Diff to previous 1.27
made some of xf.c's internal (static) routines global
Wed Nov 29 16:45:13 1995 UTC (30 years, 1 month ago) by greg
Changes since 1.26: +2 -1 lines
Diff to previous 1.26 , to selected 1.28
added error for unmatched xf or o context close
Wed Nov 8 09:40:26 1995 UTC (30 years, 2 months ago) by greg
Changes since 1.25: +2 -1 lines
Diff to previous 1.25 , to selected 1.28
added check for input line exceeding MG_MAXLINE
Thu May 11 21:48:42 1995 UTC (30 years, 8 months ago) by greg
Changes since 1.24: +7 -2 lines
Diff to previous 1.24 , to selected 1.28
added version tracking
Thu May 11 20:17:36 1995 UTC (30 years, 8 months ago) by greg
Changes since 1.23: +8 -2 lines
Diff to previous 1.23 , to selected 1.28
added default handling of undefined entities
Thu May 11 09:12:12 1995 UTC (30 years, 8 months ago) by greg
Changes since 1.22: +9 -5 lines
Diff to previous 1.22 , to selected 1.28
fixed bug in order of global transform arguments
Wed May 10 17:46:05 1995 UTC (30 years, 8 months ago) by greg
Diff to previous 1.21 , to selected 1.28
added check for illegal names and identifiers
Tue May 9 11:47:27 1995 UTC (30 years, 8 months ago) by greg
Changes since 1.20: +31 -31 lines
Diff to previous 1.20 , to selected 1.28
improved comments
Thu Apr 13 12:54:23 1995 UTC (30 years, 8 months ago) by greg
Changes since 1.19: +23 -19 lines
Diff to previous 1.19 , to selected 1.28
added index of refraction to materials
Fri Mar 10 15:16:42 1995 UTC (30 years, 10 months ago) by greg
Changes since 1.18: +3 -21 lines
Diff to previous 1.18 , to selected 1.28
moved CIE definitions to context.c
Tue Mar 7 14:53:17 1995 UTC (30 years, 10 months ago) by greg
Changes since 1.17: +29 -28 lines
Diff to previous 1.17 , to selected 1.28
added cct entity
Fri Feb 24 16:50:05 1995 UTC (30 years, 10 months ago) by greg
Changes since 1.16: +7 -7 lines
Diff to previous 1.16 , to selected 1.28
fixed context handlers for spectral power distribution data
Fri Sep 2 16:04:16 1994 UTC (31 years, 4 months ago) by greg
Changes since 1.15: +11 -8 lines
Diff to previous 1.15 , to selected 1.28
corrected problems with cmix function (I think -- needs checking!)
Thu Sep 1 09:17:46 1994 UTC (31 years, 4 months ago) by greg
Changes since 1.14: +5 -5 lines
Diff to previous 1.14 , to selected 1.28
fixed unused macro and comment
Thu Jul 21 14:56:36 1994 UTC (31 years, 5 months ago) by greg
Changes since 1.13: +3 -2 lines
Diff to previous 1.13 , to selected 1.28
added rev field to XF_SPEC structure to indicate vertex reversal
Fri Jul 1 18:06:53 1994 UTC (31 years, 6 months ago) by greg
Changes since 1.12: +11 -9 lines
Diff to previous 1.12 , to selected 1.28
added "sides" entity for one- vs. two-sided surfaces
Fri Jul 1 10:18:36 1994 UTC (31 years, 6 months ago) by greg
Changes since 1.11: +9 -9 lines
Diff to previous 1.11 , to selected 1.28
changed context names from struct members to extern variables
Thu Jun 30 11:07:38 1994 UTC (31 years, 6 months ago) by greg
Diff to previous 1.10 , to selected 1.28
added c_getmaterial() call
Wed Jun 29 16:15:17 1994 UTC (31 years, 6 months ago) by greg
Changes since 1.9: +34 -10 lines
Diff to previous 1.9 , to selected 1.28
made the -a (array) option work within files as well
Sat Jun 25 16:33:17 1994 UTC (31 years, 6 months ago) by greg
Changes since 1.8: +7 -6 lines
Diff to previous 1.8 , to selected 1.28
bug fixes and enhancements
Sat Jun 25 11:55:42 1994 UTC (31 years, 6 months ago) by greg
Changes since 1.7: +9 -5 lines
Diff to previous 1.7 , to selected 1.28
added name and clock members to C_COLOR and C_VERTEX structures
Sat Jun 25 09:47:58 1994 UTC (31 years, 6 months ago) by greg
Diff to previous 1.6 , to selected 1.28
minor fixes and enhancements
Fri Jun 24 16:28:12 1994 UTC (31 years, 6 months ago) by greg
Changes since 1.5: +25 -32 lines
Diff to previous 1.5 , to selected 1.28
added cspec and cmix entities
Fri Jun 24 09:32:55 1994 UTC (31 years, 6 months ago) by greg
Changes since 1.4: +78 -24 lines
Diff to previous 1.4 , to selected 1.28
added prism entity and minor changes
Thu Jun 23 07:48:36 1994 UTC (31 years, 6 months ago) by greg
Diff to previous 1.3 , to selected 1.28
improved table lookup routines with new delete function
Wed Jun 22 17:15:46 1994 UTC (31 years, 6 months ago) by greg
Changes since 1.2: +19 -3 lines
Diff to previous 1.2 , to selected 1.28
more bug fixes
Wed Jun 22 15:33:42 1994 UTC (31 years, 6 months ago) by greg
Changes since 1.1: +32 -19 lines
Diff to previous 1.1 , to selected 1.28
various enhancements and fixes
Tue Jun 21 14:45:41 1994 UTC (31 years, 6 months ago) by greg
Diff to selected 1.28
