| 1 |
/* RCSid: $Id: parser.h,v 1.39 2011/01/14 05:46:12 greg Exp $ */
| 2 |
| 3 |
* Header file for MGF interpreter
| 4 |
| 5 |
#ifndef _MGF_PARSER_H_
| 6 |
#define _MGF_PARSER_H_
| 7 |
| 8 |
/* must include stdio.h and stdlib.h before us */
| 9 |
| 10 |
#include "ccolor.h"
| 11 |
| 12 |
#ifdef __cplusplus
| 13 |
extern "C" {
| 14 |
#endif
| 15 |
| 16 |
#define MG_VMAJOR 2 /* major version number */
| 17 |
#define MG_VMINOR 0 /* minor version number */
| 18 |
| 19 |
/* Entities (list is only appended, never modified) */
| 20 |
#define MG_E_COMMENT 0 /* # */
| 21 |
#define MG_E_COLOR 1 /* c */
| 22 |
#define MG_E_CCT 2 /* cct */
| 23 |
#define MG_E_CONE 3 /* cone */
| 24 |
#define MG_E_CMIX 4 /* cmix */
| 25 |
#define MG_E_CSPEC 5 /* cspec */
| 26 |
#define MG_E_CXY 6 /* cxy */
| 27 |
#define MG_E_CYL 7 /* cyl */
| 28 |
#define MG_E_ED 8 /* ed */
| 29 |
#define MG_E_FACE 9 /* f */
| 30 |
#define MG_E_INCLUDE 10 /* i */
| 31 |
#define MG_E_IES 11 /* ies */
| 32 |
#define MG_E_IR 12 /* ir */
| 33 |
#define MG_E_MATERIAL 13 /* m */
| 34 |
#define MG_E_NORMAL 14 /* n */
| 35 |
#define MG_E_OBJECT 15 /* o */
| 36 |
#define MG_E_POINT 16 /* p */
| 37 |
#define MG_E_PRISM 17 /* prism */
| 38 |
#define MG_E_RD 18 /* rd */
| 39 |
#define MG_E_RING 19 /* ring */
| 40 |
#define MG_E_RS 20 /* rs */
| 41 |
#define MG_E_SIDES 21 /* sides */
| 42 |
#define MG_E_SPH 22 /* sph */
| 43 |
#define MG_E_TD 23 /* td */
| 44 |
#define MG_E_TORUS 24 /* torus */
| 45 |
#define MG_E_TS 25 /* ts */
| 46 |
#define MG_E_VERTEX 26 /* v */
| 47 |
#define MG_E_XF 27 /* xf */
| 48 |
/* end of Version 1 entities */
| 49 |
#define MG_E_FACEH 28 /* fh */
| 50 |
/* end of Version 2 entities */
| 51 |
| 52 |
#define MG_NENTITIES 29 /* total # entities */
| 53 |
| 54 |
#define MG_NELIST {28,29} /* entity count for version 1 and up */
| 55 |
| 56 |
#define MG_NAMELIST {"#","c","cct","cone","cmix","cspec","cxy","cyl","ed",\
| 57 |
"f","i","ies","ir","m","n","o","p","prism","rd",\
| 58 |
"ring","rs","sides","sph","td","torus","ts","v","xf",\
| 59 |
"fh"}
| 60 |
| 61 |
#define MG_MAXELEN 6
| 62 |
| 63 |
extern char mg_ename[MG_NENTITIES][MG_MAXELEN];
| 64 |
| 65 |
/* Handler routines for each entity and unknown ones */
| 66 |
extern int (*mg_ehand[MG_NENTITIES])(int argc, char **argv);
| 67 |
extern int (*mg_uhand)(int argc, char **argv);
| 68 |
extern int mg_defuhand(int, char **);
| 69 |
| 70 |
extern unsigned mg_nunknown; /* count of unknown entities */
| 71 |
| 72 |
/* Error codes */
| 73 |
#define MG_OK 0 /* normal return value */
| 74 |
#define MG_EUNK 1 /* unknown entity */
| 75 |
#define MG_EARGC 2 /* wrong number of arguments */
| 76 |
#define MG_ETYPE 3 /* argument type error */
| 77 |
#define MG_EILL 4 /* illegal argument value */
| 78 |
#define MG_EUNDEF 5 /* undefined reference */
| 79 |
#define MG_ENOFILE 6 /* cannot open input file */
| 80 |
#define MG_EINCL 7 /* error in included file */
| 81 |
#define MG_EMEM 8 /* out of memory */
| 82 |
#define MG_ESEEK 9 /* file seek error */
| 83 |
#define MG_EBADMAT 10 /* bad material specification */
| 84 |
#define MG_ELINE 11 /* input line too long */
| 85 |
#define MG_ECNTXT 12 /* unmatched context close */
| 86 |
| 87 |
#define MG_NERRS 13
| 88 |
| 89 |
extern char *mg_err[MG_NERRS]; /* list of error messages */
| 90 |
| 91 |
| 92 |
* The general process for running the parser is to fill in the mg_ehand
| 93 |
* array with handlers for each entity you know how to handle.
| 94 |
* Then, call mg_init to fill in the rest. This function will report
| 95 |
* an error and quit if you try to support an inconsistent set of entities.
| 96 |
* For each file you want to parse, call mg_load with the file name.
| 97 |
* To read from standard input, use NULL as the file name.
| 98 |
* For additional control over error reporting and file management,
| 99 |
* use mg_open, mg_read, mg_parse and mg_close instead of mg_load.
| 100 |
* To pass an entity of your own construction to the parser, use
| 101 |
* the mg_handle function rather than the mg_ehand routines directly.
| 102 |
* (The first argument to mg_handle is the entity #, or -1.)
| 103 |
* To free any data structures and clear the parser, use mg_clear.
| 104 |
* If there is an error, mg_load, mg_open, mg_parse, mg_handle and
| 105 |
* mg_fgoto will return an error from the list above. In addition,
| 106 |
* mg_load will report the error to stderr. The mg_read routine
| 107 |
* returns 0 when the end of file has been reached.
| 108 |
| 109 |
| 110 |
#define MG_MAXLINE 4096 /* maximum input line length */
| 111 |
#define MG_MAXARGC (MG_MAXLINE/4) /* maximum argument count */
| 112 |
| 113 |
typedef struct mg_fctxt {
| 114 |
char fname[96]; /* file name */
| 115 |
FILE *fp; /* stream pointer */
| 116 |
int fid; /* unique file context id */
| 117 |
char inpline[MG_MAXLINE]; /* input line */
| 118 |
int lineno; /* line number */
| 119 |
struct mg_fctxt *prev; /* previous context */
| 120 |
} MG_FCTXT;
| 121 |
| 122 |
typedef struct {
| 123 |
int fid; /* file this position is for */
| 124 |
int lineno; /* line number in file */
| 125 |
long offset; /* offset from beginning */
| 126 |
} MG_FPOS;
| 127 |
| 128 |
extern MG_FCTXT *mg_file; /* current file context */
| 129 |
| 130 |
extern void mg_init(void); /* fill in mg_ehand array */
| 131 |
extern int mg_load(char *); /* parse a file */
| 132 |
extern int mg_open(MG_FCTXT *, char *); /* open new input file */
| 133 |
extern int mg_read(void); /* read next line */
| 134 |
extern int mg_parse(void); /* parse current line */
| 135 |
extern void mg_fgetpos(MG_FPOS *); /* get position on input file */
| 136 |
extern int mg_fgoto(MG_FPOS *); /* go to position on input file */
| 137 |
extern void mg_close(void); /* close input file */
| 138 |
extern void mg_clear(void); /* clear parser */
| 139 |
extern int mg_handle(int, int, char **); /* handle an entity */
| 140 |
| 141 |
#ifndef MG_NQCD
| 142 |
#define MG_NQCD 5 /* default number of divisions */
| 143 |
#endif
| 144 |
| 145 |
extern int mg_nqcdivs; /* divisions per quarter circle */
| 146 |
| 147 |
| 148 |
* The following library routines are included for your convenience:
| 149 |
| 150 |
| 151 |
extern int mg_entity(char *); /* get entity number from its name */
| 152 |
extern int isint(char *); /* non-zero if integer format */
| 153 |
extern int isintd(char *, char *); /* same with delimiter set */
| 154 |
extern int isflt(char *); /* non-zero if floating point format */
| 155 |
extern int isfltd(char *, char *); /* same with delimiter set */
| 156 |
extern int isname(char *); /* non-zero if legal identifier name */
| 157 |
extern int badarg(int, char **, char *);/* check argument format */
| 158 |
extern int e_include(int, char **); /* expand include entity */
| 159 |
extern int e_pipe(int, char **); /* expand piped command */
| 160 |
extern int e_sph(int, char **); /* expand sphere as other entities */
| 161 |
extern int e_torus(int, char **); /* expand torus as other entities */
| 162 |
extern int e_cyl(int, char **); /* expand cylinder as other entities */
| 163 |
extern int e_ring(int, char **); /* expand ring as other entities */
| 164 |
extern int e_cone(int, char **); /* expand cone as other entities */
| 165 |
extern int e_prism(int, char **); /* expand prism as other entities */
| 166 |
extern int e_faceh(int, char **); /* expand face w/ holes as face */
| 167 |
| 168 |
| 169 |
* Definitions for 3-d vector manipulation functions
| 170 |
| 171 |
| 172 |
#ifdef SMLFLT
| 173 |
#define RREAL float
| 174 |
#define FTINY (1e-3)
| 175 |
#else
| 176 |
#define RREAL double
| 177 |
#define FTINY (1e-6)
| 178 |
#endif
| 179 |
#define FHUGE (1e10)
| 180 |
| 181 |
typedef RREAL FVECT[3];
| 182 |
| 183 |
#define VCOPY(v1,v2) ((v1)[0]=(v2)[0],(v1)[1]=(v2)[1],(v1)[2]=(v2)[2])
| 184 |
#define DOT(v1,v2) ((v1)[0]*(v2)[0]+(v1)[1]*(v2)[1]+(v1)[2]*(v2)[2])
| 185 |
#define VSUM(vr,v1,v2,f) ((vr)[0]=(v1)[0]+(f)*(v2)[0], \
| 186 |
(vr)[1]=(v1)[1]+(f)*(v2)[1], \
| 187 |
(vr)[2]=(v1)[2]+(f)*(v2)[2])
| 188 |
| 189 |
#define is0vect(v) (DOT(v,v) <= FTINY*FTINY)
| 190 |
| 191 |
#define round0(x) if (x <= FTINY && x >= -FTINY) x = 0
| 192 |
| 193 |
extern double normalize(FVECT); /* normalize a vector */
| 194 |
extern void fcross(FVECT,FVECT,FVECT);/* cross product of two vectors */
| 195 |
| 196 |
| 197 |
* Definitions for context handling routines
| 198 |
* (materials, colors, vectors)
| 199 |
| 200 |
| 201 |
#define C_1SIDEDTHICK 0.005 /* assumed thickness of 1-sided mat. */
| 202 |
| 203 |
typedef struct {
| 204 |
int clock; /* incremented each change -- resettable */
| 205 |
void *client_data; /* pointer to private client-owned data */
| 206 |
int sided; /* 1 if surface is 1-sided, 0 for 2-sided */
| 207 |
float nr, ni; /* index of refraction, real and imaginary */
| 208 |
float rd; /* diffuse reflectance */
| 209 |
C_COLOR rd_c; /* diffuse reflectance color */
| 210 |
float td; /* diffuse transmittance */
| 211 |
C_COLOR td_c; /* diffuse transmittance color */
| 212 |
float ed; /* diffuse emittance */
| 213 |
C_COLOR ed_c; /* diffuse emittance color */
| 214 |
float rs; /* specular reflectance */
| 215 |
C_COLOR rs_c; /* specular reflectance color */
| 216 |
float rs_a; /* specular reflectance roughness */
| 217 |
float ts; /* specular transmittance */
| 218 |
C_COLOR ts_c; /* specular transmittance color */
| 219 |
float ts_a; /* specular transmittance roughness */
| 220 |
} C_MATERIAL; /* material context */
| 221 |
| 222 |
typedef struct {
| 223 |
| 224 |
| 225 |
FVECT p, n; /* point and normal */
| 226 |
} C_VERTEX; /* vertex context */
| 227 |
| 228 |
#define C_DEFMATERIAL {1,NULL,0,1.,0.,0.,C_DEFCOLOR,0.,C_DEFCOLOR,0.,\
| 229 |
C_DEFCOLOR,0.,C_DEFCOLOR,0.,0.,C_DEFCOLOR,0.}
| 230 |
#define C_DEFVERTEX {1,NULL,{0.,0.,0.},{0.,0.,0.}}
| 231 |
| 232 |
extern C_COLOR *c_ccolor; /* the current color */
| 233 |
extern char *c_ccname; /* current color name */
| 234 |
extern C_MATERIAL *c_cmaterial; /* the current material */
| 235 |
extern char *c_cmname; /* current material name */
| 236 |
extern C_VERTEX *c_cvertex; /* the current vertex */
| 237 |
extern char *c_cvname; /* current vertex name */
| 238 |
| 239 |
extern int c_hcolor(int, char **); /* handle color entity */
| 240 |
extern int c_hmaterial(int, char **); /* handle material entity */
| 241 |
extern int c_hvertex(int, char **); /* handle vertex entity */
| 242 |
extern void c_clearall(void); /* clear context tables */
| 243 |
extern C_MATERIAL *c_getmaterial(char *); /* get a named material */
| 244 |
extern C_VERTEX *c_getvert(char *); /* get a named vertex */
| 245 |
extern C_COLOR *c_getcolor(char *); /* get a named color */
| 246 |
| 247 |
| 248 |
* Definitions for hierarchical object name handler
| 249 |
| 250 |
| 251 |
extern int obj_nnames; /* depth of name hierarchy */
| 252 |
extern char **obj_name; /* names in hierarchy */
| 253 |
| 254 |
extern int obj_handler(int, char **); /* handle an object entity */
| 255 |
extern void obj_clear(void); /* clear object stack */
| 256 |
| 257 |
| 258 |
* Definitions for hierarchical transformation handler
| 259 |
| 260 |
| 261 |
typedef RREAL MAT4[4][4];
| 262 |
| 263 |
#define copymat4(m4a,m4b) (void)memcpy((char *)m4a,(char *)m4b,sizeof(MAT4))
| 264 |
| 265 |
#define MAT4IDENT { {1.,0.,0.,0.}, {0.,1.,0.,0.}, \
| 266 |
{0.,0.,1.,0.}, {0.,0.,0.,1.} }
| 267 |
| 268 |
extern MAT4 m4ident;
| 269 |
| 270 |
#define setident4(m4) copymat4(m4, m4ident)
| 271 |
| 272 |
/* regular transformation */
| 273 |
typedef struct {
| 274 |
MAT4 xfm; /* transform matrix */
| 275 |
RREAL sca; /* scalefactor */
| 276 |
} XF;
| 277 |
| 278 |
#define identxf(xp) (void)(setident4((xp)->xfm),(xp)->sca=1.0)
| 279 |
| 280 |
#define XF_MAXDIM 8 /* maximum array dimensions */
| 281 |
| 282 |
struct xf_array {
| 283 |
MG_FPOS spos; /* starting position on input */
| 284 |
int ndim; /* number of array dimensions */
| 285 |
struct {
| 286 |
short i, n; /* current count and maximum */
| 287 |
char arg[8]; /* string argument value */
| 288 |
} aarg[XF_MAXDIM];
| 289 |
| 290 |
| 291 |
typedef struct xf_spec {
| 292 |
long xid; /* unique transform id */
| 293 |
short xac; /* context argument count */
| 294 |
short rev; /* boolean true if vertices reversed */
| 295 |
XF xf; /* cumulative transformation */
| 296 |
struct xf_array *xarr; /* transformation array pointer */
| 297 |
struct xf_spec *prev; /* previous transformation context */
| 298 |
} XF_SPEC; /* followed by argument buffer */
| 299 |
| 300 |
extern XF_SPEC *xf_context; /* current transform context */
| 301 |
extern char **xf_argend; /* last transform argument */
| 302 |
| 303 |
#define xf_ac(xf) ((xf)==NULL ? 0 : (xf)->xac)
| 304 |
#define xf_av(xf) (xf_argend - (xf)->xac)
| 305 |
| 306 |
#define xf_argc xf_ac(xf_context)
| 307 |
#define xf_argv xf_av(xf_context)
| 308 |
| 309 |
| 310 |
* The transformation handler should do most of the work that needs
| 311 |
* doing. Just pass it any xf entities, then use the associated
| 312 |
* functions to transform and translate points, transform vectors
| 313 |
* (without translation), rotate vectors (without scaling) and scale
| 314 |
* values appropriately.
| 315 |
| 316 |
* The routines xf_xfmpoint, xf_xfmvect and xf_rotvect take two
| 317 |
* 3-D vectors (which may be identical), transforms the second and
| 318 |
* puts the result into the first.
| 319 |
| 320 |
| 321 |
| 322 |
extern int xf_handler(int, char **); /* handle xf entity */
| 323 |
extern void xf_xfmpoint(FVECT, FVECT); /* transform point */
| 324 |
extern void xf_xfmvect(FVECT, FVECT); /* transform vector */
| 325 |
extern void xf_rotvect(FVECT, FVECT); /* rotate vector */
| 326 |
extern double xf_scale(double); /* scale a value */
| 327 |
extern void xf_clear(void); /* clear xf stack */
| 328 |
| 329 |
/* The following are support routines you probably won't call directly */
| 330 |
| 331 |
XF_SPEC *new_xf(int, char **); /* allocate new transform */
| 332 |
void free_xf(XF_SPEC *); /* free a transform */
| 333 |
int xf_aname(struct xf_array *); /* name this instance */
| 334 |
long comp_xfid(MAT4); /* compute unique ID */
| 335 |
extern void multmat4(MAT4, MAT4, MAT4); /* m4a = m4b X m4c */
| 336 |
extern void multv3(FVECT, FVECT, MAT4); /* v3a = v3b X m4 (vectors) */
| 337 |
extern void multp3(FVECT, FVECT, MAT4); /* p3a = p3b X m4 (points) */
| 338 |
extern int xf(XF *, int, char **); /* interpret transform spec. */
| 339 |
| 340 |
/* cvrgb.c */
| 341 |
extern void mgf2rgb(C_COLOR *cin, double intensity, float cout[3]);
| 342 |
| 343 |
| 344 |
* Miscellaneous definitions
| 345 |
| 346 |
| 347 |
#ifndef PI
| 348 |
#ifdef M_PI
| 349 |
#define PI ((double)M_PI)
| 350 |
#else
| 351 |
#define PI 3.14159265358979323846
| 352 |
#endif
| 353 |
#endif
| 354 |
| 355 |
#ifdef __cplusplus
| 356 |
| 357 |
#endif
| 358 |
#endif /* _MGF_PARSER_H_ */
| 359 |
