root/radiance/ray/src/common/image.c
Sat Jul 16 00:26:34 2022 UTC (22 months, 3 weeks ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 2.54: +5 -5 lines
Diff to previous 2.54 , to selected 2.38
perf: very minor optimization in viewloc()
Thu Jan 13 00:26:09 2022 UTC (2 years, 4 months ago) by greg
Changes since 2.53: +10 -11 lines
Diff to previous 2.53 , to selected 2.38
perf: minor improvement to cropview()
Wed Jan 12 21:07:39 2022 UTC (2 years, 4 months ago) by greg
Changes since 2.52: +84 -10 lines
Diff to previous 2.52 , to selected 2.38
refactor: created cropview() function to manage view sections
Fri Feb 12 00:47:08 2021 UTC (3 years, 3 months ago) by greg
Changes since 2.51: +10 -15 lines
Diff to previous 2.51 , to selected 2.38
refactor: added macros for RREAL comparisons
Thu May 14 20:49:57 2020 UTC (4 years ago) by greg
Changes since 2.50: +5 -5 lines
Diff to previous 2.50 , to selected 2.38
Minor aesthetic fixes
Sat May 4 00:36:58 2019 UTC (5 years, 1 month ago) by greg
Changes since 2.49: +3 -2 lines
Diff to previous 2.49 , to selected 2.38
Eliminated cases where stdin was being closed
Tue Aug 7 23:17:06 2018 UTC (5 years, 10 months ago) by greg
Changes since 2.48: +4 -4 lines
Diff to previous 2.48 , to selected 2.38
Fixed inconsistent treatment of white space in view argument parsing
Fri Apr 27 18:09:26 2018 UTC (6 years, 1 month ago) by greg
Changes since 2.47: +6 -5 lines
Diff to previous 2.47 , to selected 2.38
Fixed logical errors in last two changes
Fri Apr 27 17:36:01 2018 UTC (6 years, 1 month ago) by greg
Changes since 2.46: +7 -6 lines
Diff to previous 2.46 , to selected 2.38
Slight tweak on last change, should not affect outcome
Fri Apr 27 05:00:29 2018 UTC (6 years, 1 month ago) by greg
Changes since 2.45: +18 -9 lines
Diff to previous 2.45 , to selected 2.38
Improved viewloc() return values to include aft clipping test
Tue Feb 6 02:08:12 2018 UTC (6 years, 4 months ago) by greg
Changes since 2.44: +3 -1 lines
Diff to previous 2.44 , to selected 2.38
Added missing error check to viewloc()
Wed Jan 24 17:22:24 2018 UTC (6 years, 4 months ago) by greg
Changes since 2.43: +5 -8 lines
Diff to previous 2.43 , to selected 2.38
Final tweak returns out-of-frame if on frame edge
Wed Jan 24 04:39:52 2018 UTC (6 years, 4 months ago) by greg
Changes since 2.42: +7 -3 lines
Diff to previous 2.42 , to selected 2.38
Wed Jan 24 04:23:06 2018 UTC (6 years, 4 months ago) by greg
Changes since 2.41: +12 -11 lines
Diff to previous 2.41 , to selected 2.38
Tweaked viewloc() return value so 1 is in front, -1 is behind and 0 is error
Wed Jan 24 03:34:15 2018 UTC (6 years, 4 months ago) by greg
Changes since 2.40: +20 -16 lines
Diff to previous 2.40 , to selected 2.38
Added off-view checking to viewloc()
Wed Apr 3 00:35:09 2013 UTC (11 years, 2 months ago) by greg
Changes since 2.39: +6 -16 lines
Diff to previous 2.39 , to selected 2.38
Added VSUM() macro calls
Sun Mar 24 19:40:26 2013 UTC (11 years, 2 months ago) by greg
Changes since 2.38: +3 -2 lines
Diff to previous 2.38
Added check for negative fore clipping plane
Revision 2.38 - (view) (download) (annotate) - [selected]
Fri Nov 16 00:14:19 2012 UTC (11 years, 6 months ago) by greg
Changes since 2.37: +5 -7 lines
Diff to previous 2.37
Bug fix in viewloc() for stereographic view type
Sat Oct 27 03:01:21 2012 UTC (11 years, 7 months ago) by greg
Changes since 2.36: +4 -3 lines
Diff to previous 2.36 , to selected 2.38
Minor efficiency improvement in loc2pix()
Wed Mar 2 17:24:55 2011 UTC (13 years, 3 months ago) by greg
Changes since 2.35: +8 -8 lines
Diff to previous 2.35 , to selected 2.38
Minor fix in conversion of negative image locations
Fri Dec 12 22:05:38 2008 UTC (15 years, 5 months ago) by greg
Changes since 2.34: +58 -41 lines
Diff to previous 2.34 , to selected 2.38
ANSI C definition updates
Tue Mar 11 02:21:46 2008 UTC (16 years, 3 months ago) by greg
Changes since 2.33: +47 -11 lines
Diff to previous 2.33 , to selected 2.38
Sun Nov 19 01:14:31 2006 UTC (17 years, 6 months ago) by greg
Diff to previous 2.32 , to selected 2.38
Minor bug fix
Wed Jul 12 01:37:40 2006 UTC (17 years, 11 months ago) by greg
Changes since 2.31: +7 -7 lines
Diff to previous 2.31 , to selected 2.38
Fixed bug where tabs in view files were not being interpreted as spaces
Fri Feb 18 17:42:14 2005 UTC (19 years, 3 months ago) by greg
Diff to previous 2.30 , to selected 2.38
Added check for illegal view distance
Mon Feb 7 20:13:55 2005 UTC (19 years, 4 months ago) by greg
Changes since 2.29: +2 -1 lines
Diff to previous 2.29 , to selected 2.38
Robustness improvements in depth-of-field blurring
Tue Jan 18 00:33:16 2005 UTC (19 years, 4 months ago) by greg
Changes since 2.28: +10 -5 lines
Diff to previous 2.28 , to selected 2.38
Tue Jun 8 19:48:29 2004 UTC (20 years ago) by greg
Changes since 2.27: +2 -1 lines
Diff to previous 2.27 , to selected 2.38
Thu Feb 12 18:55:50 2004 UTC (20 years, 4 months ago) by greg
Changes since 2.26: +2 -1 lines
Diff to previous 2.26 , to selected 2.38
Fri Jan 2 11:36:26 2004 UTC (20 years, 5 months ago) by schorsch
Changes since 2.25: +10 -7 lines
Diff to previous 2.25 , to selected 2.38
Thu Jan 1 19:47:05 2004 UTC (20 years, 5 months ago) by greg
Diff to previous 2.24 , to selected 2.38
Other updates affected by command renaming
Thu Jan 1 19:31:45 2004 UTC (20 years, 5 months ago) by greg
Diff to previous 2.23 , to selected 2.38
Wed Nov 26 19:16:23 2003 UTC (20 years, 6 months ago) by greg
Diff to previous 2.22 , to selected 2.38
Minor code improvements
Changes since 2.21: +2 -4 lines
Diff to previous 2.21 , to selected 2.38
Sun Sep 7 05:32:02 2003 UTC (20 years, 9 months ago) by greg
Diff to previous 2.20 , to selected 2.38
Prototype fix
Fri Aug 29 23:03:13 2003 UTC (20 years, 9 months ago) by greg
Changes since 2.19: +4 -2 lines
Diff to previous 2.19 , to selected 2.38
Fixed bug in last "improvement"
Tue Aug 26 04:24:26 2003 UTC (20 years, 9 months ago) by greg
Diff to previous 2.18 , to selected 2.38
Minor improvements
Diff to previous 2.17 , to selected 2.38
Changes since 2.16: +1 -56 lines
Diff to previous 2.16 , to selected 2.38
Changes since 2.15: +75 -14 lines
Diff to previous 2.15 , to selected 2.38
Fri Feb 26 12:24:07 1999 UTC (25 years, 3 months ago) by gwlarson
Diff to previous 2.14 , to selected 2.38
allowed negative fore clipping plane for holographic rendering
Tue Oct 27 08:44:29 1998 UTC (25 years, 7 months ago) by gwlarson
Diff to previous 2.13 , to selected 2.38
Tue Dec 9 16:41:03 1997 UTC (26 years, 6 months ago) by gregl
Changes since 2.12: +8 -9 lines
Diff to previous 2.12 , to selected 2.38
fixed computation for VT_CYL in viewloc() -- at last!
Wed Jan 17 10:55:40 1996 UTC (28 years, 4 months ago) by greg
Diff to previous 2.11 , to selected 2.38
replaced sskip() behavior and added new sskip2() function
Wed Jan 10 19:25:57 1996 UTC (28 years, 5 months ago) by greg
Changes since 2.10: +59 -3 lines
Diff to previous 2.10 , to selected 2.38
added viewopt() routine to get minimal view specification
Thu Aug 24 11:55:03 1995 UTC (28 years, 9 months ago) by greg
Diff to previous 2.9 , to selected 2.38
fixed bug in viewloc() for cylindrical sources
Fri Aug 18 10:20:10 1995 UTC (28 years, 9 months ago) by greg
Changes since 2.8: +38 -6 lines
Diff to previous 2.8 , to selected 2.38
added cylindrical view type
Wed Dec 21 09:07:19 1994 UTC (29 years, 5 months ago) by greg
Diff to previous 2.7 , to selected 2.38
bug fix from last change
Tue Dec 20 20:15:04 1994 UTC (29 years, 5 months ago) by greg
Changes since 2.6: +46 -20 lines
Diff to previous 2.6 , to selected 2.38
added -vo and -va (fore and aft clipping plane) parameters
Sat Dec 5 16:23:37 1992 UTC (31 years, 6 months ago) by greg
Changes since 2.5: +1 -5 lines
Diff to previous 2.5 , to selected 2.38
fixed bug in -vta type with -DSMLFLT option in viewray()
Tue Sep 8 10:04:30 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.4: +10 -8 lines
Diff to previous 2.4 , to selected 2.38
Tue Sep 8 09:09:20 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.3: +5 -3 lines
Diff to previous 2.3 , to selected 2.38
Tue Apr 28 09:36:42 1992 UTC (32 years, 1 month ago) by greg
Changes since 2.2: +30 -13 lines
Diff to previous 2.2 , to selected 2.38
added isview() call
Thu Dec 19 14:45:50 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 2.1 , to selected 2.38
Tue Nov 12 16:55:38 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.17 , to selected 2.38
Mon Nov 11 14:00:14 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.16: +72 -33 lines
Diff to previous 1.16 , to selected 2.38
Thu Nov 7 11:04:00 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.15: +10 -9 lines
Diff to previous 1.15 , to selected 2.38
added badarg() routine for argument checking
Thu Apr 18 14:52:55 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.14: +15 -10 lines
Diff to previous 1.14 , to selected 2.38
changed interface to header routines
Mon Mar 18 13:48:05 1991 UTC (33 years, 3 months ago) by greg
Changes since 1.13: +4 -1 lines
Diff to previous 1.13 , to selected 2.38
normalize view up vector (bug in routines expecting nomralized)
Mon Oct 15 14:17:05 1990 UTC (33 years, 8 months ago) by greg
Changes since 1.12: +7 -13 lines
Diff to previous 1.12 , to selected 2.38
fixed bug in hemispherical view calculation
Sat Oct 13 20:56:01 1990 UTC (33 years, 8 months ago) by greg
Changes since 1.11: +123 -31 lines
Diff to previous 1.11 , to selected 2.38
added fisheye view types
Fri Sep 21 17:06:31 1990 UTC (33 years, 8 months ago) by greg
Changes since 1.10: +9 -4 lines
Diff to previous 1.10 , to selected 2.38
added folding of pyramid to viewpixel()
Thu Sep 13 08:34:15 1990 UTC (33 years, 9 months ago) by greg
Diff to previous 1.9 , to selected 2.38
added roundoff to computation of resolutions in normaspect()
Tue Jan 16 16:21:07 1990 UTC (34 years, 5 months ago) by greg
Changes since 1.8: +6 -5 lines
Diff to previous 1.8 , to selected 2.38
fixed bugs in sscanview() and fprintview()
Tue Jan 16 11:29:43 1990 UTC (34 years, 5 months ago) by greg
Diff to previous 1.7 , to selected 2.38
added ability to recover dimensions from picture files
Tue Jan 9 11:37:50 1990 UTC (34 years, 5 months ago) by greg
Changes since 1.6: +5 -7 lines
Diff to previous 1.6 , to selected 2.38
fixed routine for computing pixel ratio
Tue Jan 9 09:08:09 1990 UTC (34 years, 5 months ago) by greg
Changes since 1.5: +16 -0 lines
Diff to previous 1.5 , to selected 2.38
added routine for computing image size and pixel aspect ratios
Mon Jan 8 14:45:52 1990 UTC (34 years, 5 months ago) by greg
Changes since 1.4: +122 -127 lines
Diff to previous 1.4 , to selected 2.38
got rid of resolution and added shift and lift options
Fri Dec 22 08:21:53 1989 UTC (34 years, 5 months ago) by greg
Diff to previous 1.3 , to selected 2.38
changed vhs2 and vvs2 to vhn2 and vvn2
Sun Dec 10 16:19:54 1989 UTC (34 years, 6 months ago) by greg
Changes since 1.2: +54 -7 lines
Diff to previous 1.2 , to selected 2.38
added routines pixelview() and sskip()
Fri Oct 20 16:53:03 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.1: +0 -16 lines
Diff to previous 1.1 , to selected 2.38
moved bigdiff() from image.c to color.c (more logical)
Thu Feb 2 10:34:34 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 2.38
