root/radiance/ray/src/cal/total.c
Revision: 1.2
Committed: Sun Jun 8 12:03:09 2003 UTC (20 years, 5 months ago) by schorsch
Changes since 1.1: +11 -6 lines
2 static const char RCSid[] = "$Id: total.c,v 1.1 2003/02/22 02:07:20 greg Exp $";
5 * total.c - program to reduce columns of data.
6 *
7 * 5/18/88
8 */
9
10 #include <stdio.h>
11 #include <stdlib.h>
12 #include <ctype.h>
13 #include <math.h>
14
15 #define MAXCOL 256 /* maximum number of columns */
16
17 #define ADD 0 /* add numbers */
18 #define MULT 1 /* multiply numbers */
19 #define MAX 2 /* maximum */
20 #define MIN 3 /* minimum */
21
22 double init_val[] = {0., 1., -1e12, 1e12}; /* initial values */
23
24 int func = ADD; /* default function */
25 double power = 0.0; /* power for sum */
26 int mean = 0; /* compute mean */
27 int count = 0; /* number to sum */
28 int tabc = '\t'; /* default separator */
29 int subtotal = 0; /* produce subtotals? */
30
31 static int execute(char *fname);
32
33 int
34 main(
35 int argc,
36 char *argv[]
37 )
38 {
39 int status;
40 int a;
41
42 for (a = 1; a < argc; a++)
43 if (argv[a][0] == '-')
44 if (argv[a][1] >= '0' && argv[a][1] <= '9')
45 count = atoi(argv[a]+1);
46 else
47 switch (argv[a][1]) {
48 case 'm':
49 mean = !mean;
50 break;
51 case 'p':
52 func = MULT;
53 break;
54 case 's':
55 func = ADD;
56 power = atof(argv[a]+2);
57 break;
58 case 'u':
59 func = MAX;
60 break;
61 case 'l':
62 func = MIN;
63 break;
64 case 't':
65 tabc = argv[a][2];
66 break;
67 case 'r':
68 subtotal = !subtotal;
69 break;
70 default:
71 fprintf(stderr,
72 "Usage: %s [-m][-sE|p|u|l][-tC][-count [-r]] [file..]\n",
73 argv[0]);
74 exit(1);
75 }
76 else
77 break;
78 if (mean) {
79 if (func == MAX) {
80 fprintf(stderr, "%s: average maximum?!\n", argv[0]);
81 exit(1);
82 }
83 if (func == MIN) {
84 fprintf(stderr, "%s: average minimum?!\n", argv[0]);
85 exit(1);
86 }
87 }
88 status = 0;
89 if (a >= argc)
90 status = execute(NULL) == -1 ? 1 : status;
91 else
92 for ( ; a < argc; a++)
93 status = execute(argv[a]) == -1 ? 2 : status;
94 exit(status);
95 }
96
97
98 static int
99 execute( /* compute result */
100 char *fname
101 )
102 {
103 double result[MAXCOL];
104 char buf[16*MAXCOL];
105 register char *cp, *num;
106 register int n;
107 double d;
108 int ncol;
109 long nlin, ltotal;
110 FILE *fp;
111 /* open file */
112 if (fname == NULL)
113 fp = stdin;
114 else if ((fp = fopen(fname, "r")) == NULL) {
115 fprintf(stderr, "%s: cannot open\n", fname);
116 return(-1);
117 }
118 ltotal = 0;
119 while (!feof(fp)) {
120 if (ltotal == 0) /* initialize */
121 if (func == MULT) /* special case */
122 for (n = 0; n < MAXCOL; n++)
123 result[n] = 0.0;
124 else
125 for (n = 0; n < MAXCOL; n++)
126 result[n] = init_val[func];
127 ncol = 0;
128 for (nlin = 0; (count <= 0 || nlin < count) &&
129 (cp = fgets(buf, sizeof(buf), fp)) != NULL;
130 nlin++) {
131 /* compute */
132 for (n = 0; n < MAXCOL; n++) {
133 while (isspace(*cp))
134 cp++;
135 if (!*cp)
136 break;
137 num = cp;
138 while (*cp && !(isspace(tabc)?isspace(*cp):*cp==tabc))
139 cp++;
140 if (*cp)
141 *cp++ = '\0';
142 if (!*num || isspace(*num))
143 d = init_val[func];
144 else
145 d = atof(num);
146 switch (func) {
147 case ADD:
148 if (d == 0.0)
149 break;
150 if (power != 0.0)
151 result[n] += pow(fabs(d),power);
152 else
153 result[n] += d;
154 break;
155 case MULT:
156 if (d == 0.0)
157 break;
158 result[n] += log(fabs(d));
159 break;
160 case MAX:
161 if (d > result[n])
162 result[n] = d;
163 break;
164 case MIN:
165 if (d < result[n])
166 result[n] = d;
167 break;
168 }
169 }
170 if (n > ncol)
171 ncol = n;
172 }
173 if (nlin == 0)
174 break;
175 /* compute and print */
176 ltotal += nlin;
177 for (n = 0; n < ncol; n++) {
178 d = result[n];
179 if (mean) {
180 d /= (double)ltotal;
181 if (func == ADD && power != 0.0 && d != 0.0)
182 d = pow(d, 1.0/power);
183 }
184 if (func == MULT)
185 d = exp(d);
186 printf("%.9g%c", d, tabc);
187 }
188 putchar('\n');
189 if (!subtotal)
190 ltotal = 0;
191 }
192 /* close file */
193 return(fclose(fp));
194 }
