root/radiance/ray/src/cal/cal/vwparab.cal
Revision: 1.1
Committed: Sat Feb 22 02:07:21 2003 UTC (21 years, 4 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1, rad3R5, rad3R6, rad3R6P1, rad3R8
1 {
2 Generate rays for a parabolic view projection --
3 i.e., a round image that when projected downwards
4 in parallel onto a parabolic reflector results in
5 a panoramic view from the paraboloid's focal point.
6
7 The forward view direction corresponding to the top
8 of the image is always +Y, and the up direction is
9 always +Z.
10
11 9/8/98 Greg Ward Larson
12
13 Inputs:
14 maxalt : Maximum altitude (in degrees)
15 x, y = Image position, (0,0)->(1,0) is LL->LR
16
17 Outputs:
18 dx, dy, dz = Direction vector for image point (x,y)
19
20 Typical command line:
21 cnt 1024 1024 | rcalc -e maxalt:25 \
22 -e 'x=($2+.5)/1024;y=1-($1+.5)/1024' -f vwparab.cal \
23 -e '$1=25.5;$2=12;$3=5;$4=dx;$5=dy;$6=dz' \
24 | rtrace @electric.opt -fac -x 1024 -y 1024 \
25 electric.oct > pan.pic
26 }
27 amax : PI/180*maxalt;
28 F0 : .5/cos(amax) - .5*tan(amax); { dist. btwn. parabola and directrix }
29 xr = 2*x - 1;
30 yr = 2*y - 1;
31 r2 = xr*xr + yr*yr;
32 r = sqrt(r2); { never actually needed }
33 z = r2/(4*F0) + F0;
34 zo = r2/(4*F0) - F0;
35 sin_alt = zo/z;
36 cos_alt = r/z;
37 dx = xr/z; { same as xr/r*cos_alt }
38 dy = yr/z; { same as yr/r*cos_alt }
39 dz = zo/z; { same as sin_alt }
