root/radiance/ray/doc/man/man1/pcomb.1
Thu Mar 27 01:26:55 2025 UTC (2 months, 3 weeks ago) by greg
Diff to previous 1.19 , to selected 1.13
feat(pvsum): Added new pvsum tool for spectral data, similar to dctimestep
Tue Dec 12 16:31:45 2023 UTC (18 months ago) by greg
Diff to previous 1.18 , to selected 1.13
Mon Dec 11 01:08:43 2023 UTC (18 months ago) by greg
Changes since 1.17: +9 -8 lines
Diff to previous 1.17 , to selected 1.13
docs(pcomb): Changed single- to double-quotes and other example tweaks
Mon Dec 11 01:02:18 2023 UTC (18 months ago) by greg
Changes since 1.16: +3 -3 lines
Diff to previous 1.16 , to selected 1.13
docs(pcomb): Added missing command references
Mon Dec 11 01:00:27 2023 UTC (18 months ago) by greg
Changes since 1.15: +10 -1 lines
Diff to previous 1.15 , to selected 1.13
docs(pcomb): Added example using depth-buffer as input
Sat Dec 9 23:46:50 2023 UTC (18 months, 1 week ago) by greg
Changes since 1.14: +25 -19 lines
Diff to previous 1.14 , to selected 1.13
feat(pcomb): Added support for 1- and 3-component float matrix i/o
Wed Dec 6 17:56:57 2023 UTC (18 months, 1 week ago) by greg
Changes since 1.13: +5 -3 lines
Diff to previous 1.13
docs(rmtxcomb): Added example and described -h option
Revision 1.13 - (view) (download) (annotate) - [selected]
Wed Dec 6 01:27:00 2023 UTC (18 months, 1 week ago) by greg
Changes since 1.12: +5 -4 lines
Diff to previous 1.12
docs(rmtxcomb): Added man page for new rmtxcomb tool
Fri Mar 18 21:09:16 2022 UTC (3 years, 3 months ago) by greg
Diff to previous 1.11 , to selected 1.13
docs(pcomb, pcompos): Added remarks about EXPOSURE settings
Fri May 4 23:56:49 2018 UTC (7 years, 1 month ago) by greg
CVS Tags: rad5R2, rad5R3
Changes since 1.10: +6 -1 lines
Diff to previous 1.10 , to selected 1.13
Mon Feb 5 20:07:17 2018 UTC (7 years, 4 months ago) by greg
Changes since 1.9: +3 -1 lines
Diff to previous 1.9 , to selected 1.13
Decided to share first input view in the output of pcomb
Mon Nov 10 19:08:17 2008 UTC (16 years, 7 months ago) by greg
CVS Tags: rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1
Diff to previous 1.8 , to selected 1.13
Tue Sep 4 17:36:40 2007 UTC (17 years, 9 months ago) by greg
Changes since 1.7: +6 -6 lines
Diff to previous 1.7 , to selected 1.13
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
Fri Sep 8 21:38:25 2006 UTC (18 years, 9 months ago) by greg
Changes since 1.6: +10 -1 lines
Diff to previous 1.6 , to selected 1.13
Tue Mar 1 22:55:21 2005 UTC (20 years, 3 months ago) by greg
Diff to previous 1.5 , to selected 1.13
Updated pixel window size to match with code
Thu Jan 1 19:31:45 2004 UTC (21 years, 5 months ago) by greg
Diff to previous 1.4 , to selected 1.13
Tue Dec 9 15:59:06 2003 UTC (21 years, 6 months ago) by greg
Diff to previous 1.3 , to selected 1.13
Fixed RCSid specification
Tue Oct 21 15:08:19 2003 UTC (21 years, 8 months ago) by greg
Changes since 1.2: +5 -1 lines
Diff to previous 1.2 , to selected 1.13
Added comment about use of WE constant
Mon Apr 7 15:43:08 2003 UTC (22 years, 2 months ago) by greg
Diff to previous 1.1 , to selected 1.13
Updated man pages and fixed ages old bug in conversion of negative colors
Tue Mar 11 19:20:21 2003 UTC (22 years, 3 months ago) by greg
Diff to selected 1.13
Added documentation to repository
