root/Development/ray/doc/man/man1/pcomb.1
Revision: 1.20
Committed: Thu Mar 27 01:26:55 2025 UTC (9 months, 1 week ago) by greg
CVS Tags: rad6R0, HEAD
feat(pvsum): Added new pvsum tool for spectral data, similar to dctimestep
# User Rev Content
1 greg 1.20 .\" RCSid "$Id: pcomb.1,v 1.19 2023/12/12 16:31:45 greg Exp $"
2 greg 1.1 .TH PCOMB 1 8/31/96 RADIANCE
3     .SH NAME
4 greg 1.15 pcomb - combine RADIANCE pictures and/or float matrices
5 greg 1.1 .SH SYNOPSIS
6     .B pcomb
7     [
8 greg 1.7 .B -h
9     ][
10 greg 1.1 .B -w
11     ][
12 greg 1.15 .B -ff
13     ][
14 greg 1.1 .B "\-x xres"
15     ][
16     .B "\-y yres"
17     ][
18     .B "\-f file"
19     ][
20     .B "\-e expr"
21     ]
22     [
23     [
24     .B -o
25     ][
26     .B "\-s factor"
27     ][
28     .B "\-c r g b"
29     ]
30     .B "input .."
31     ]
32     .SH DESCRIPTION
33     .I Pcomb
34 greg 1.15 combines equal-sized RADIANCE pictures or raw float matrices
35     and sends the result to the standard output.
36 greg 1.1 By default, the result is just a linear combination of
37 greg 1.15 the input pixels multiplied by
38 greg 1.1 .I \-s
39     and
40     .I \-c
41     coefficients,
42     but an arbitrary mapping can be assigned with the
43     .I \-e
44     and
45     .I \-f
46 greg 1.14 options, similar to
47     .I rcalc(1).
48 greg 1.13 (The variable and function definitions in each
49 greg 1.11 .I \-f source
50 greg 1.13 file are read and compiled from the RADIANCE library
51     where it is found.)\0
52 greg 1.1 Negative coefficients and functions are allowed, and
53     .I pcomb
54 greg 1.15 will produce color values of zero where they would be negative
55     unless the
56     .I \-ff
57     option is used to specify floating-point matrix output.
58 greg 1.1 .PP
59     The variables
60     .I ro,
61     .I go
62     and
63     .I bo
64     specify the red, green and blue output values, respectively.
65     Alternatively, the single variable
66     .I lo
67     can be used to specify a brightness value for black and white output.
68     The predefined functions
69     .I ri(n),
70     .I gi(n)
71     and
72     .I bi(n)
73 greg 1.15 give the red, green and blue values for
74     input
75 greg 1.1 .I n.
76     To access a pixel that is nearby the current one, these functions
77     also accept optional x and y offsets.
78     For example,
79     .I ri(3,-2,1)
80 greg 1.15 would return the red component of the pixel from input 3
81 greg 1.1 that is left 2 and up 1 from the current position.
82 greg 1.15 Although x offsets may be as large as width of the input,
83 greg 1.6 y offsets are limited to a small window (+/- 32 pixels) due to efficiency
84 greg 1.1 considerations.
85     However, it is not usually necessary to worry about this problem --
86     if the requested offset is not available, the next best pixel is
87     returned instead.
88     .PP
89     For additional convenience, the function
90     .I li(n)
91 greg 1.15 is defined as the input brightness for input
92 greg 1.1 .I n.
93     This function also accepts x and y offsets.
94     .PP
95     The constant
96     .I nfiles
97     gives the number of input files present,
98     and
99     .I WE
100 greg 1.3 gives the white efficacy (lumens/brightness) for pixel values,
101     which may be used with the
102     .I \-o
103     option or the le(n) values to convert to absolute
104     photometric units (see below).
105 greg 1.1 The variables
106     .I x
107     and
108     .I y
109     give the current output pixel location for use in
110     spatially dependent functions, the constants
111     .I xmax
112     and
113     .I ymax
114     give the input resolution, and the constants
115     .I xres
116     and
117     .I yres
118     give the output resolution (usually the same, but see below).
119     The constant functions
120     .I "re(n), ge(n), be(n),"
121     and
122     .I le(n)
123 greg 1.15 give the exposure values for input
124 greg 1.1 .I n,
125     and
126     .I pa(n)
127     gives the corresponding pixel aspect ratio.
128 greg 1.12 Exposure values will be set to 1.0 for inputs with the
129     .I \-o
130     option set.
131 greg 1.15 Finally, for inputs with stored view parameters,
132 greg 1.1 the functions
133     .I "Ox(n), Oy(n)"
134     and
135     .I Oz(n)
136     return the ray origin in world coordinates for the current pixel
137 greg 1.15 in input
138 greg 1.1 .I n,
139     and
140     .I "Dx(n), Dy(n)"
141     and
142     .I Dz(n)
143     return the normalized ray direction.
144     In addition, the function
145     .I T(n)
146     returns the distance from the origin to the aft clipping plane
147     (or zero if there is no aft plane), and the function
148     .I S(n)
149     returns the solid angle of the current pixel in steradians
150     (always zero for parallel views).
151     If the current pixel is outside the view region,
152     .I T(n)
153     will return a negative value, and
154     .I S(n)
155     will return zero.
156 greg 1.15 The first input input with a view is assumed to correspond to the
157     view of the output, which is written into the header.
158 greg 1.1 .PP
159     The
160 greg 1.7 .I \-h
161     option may be used to reduce the information header size, which
162     can grow disproportionately after multiple runs of
163     .I pcomb
164     and/or
165     .I pcompos(1).
166     The
167 greg 1.1 .I \-w
168     option can be used to suppress warning messages about invalid
169     calculations.
170     The
171     .I \-o
172     option indicates that original pixel values are to be used for the next
173 greg 1.15 input, undoing any previous exposure changes or color correction.
174 greg 1.1 .PP
175     The
176     .I \-x
177     and
178     .I \-y
179     options can be used to specify the desired output resolution,
180     .I xres
181     and
182     .I yres,
183     and can be expressions involving other constants such as
184     .I xmax
185     and
186     .I ymax.
187     The constants
188     .I xres
189     and
190     .I yres
191     may also be specified in a file or expression.
192     The default output resolution is the same as the input resolution.
193     .PP
194     The
195     .I \-x
196     and
197     .I \-y
198     options must be present if there are no input files, when
199     the definitions of
200     .I ro,
201     .I go
202     and
203     .I bo
204     will be used to compute each output pixel.
205 greg 1.15 This is useful for producing simple test inputs for various
206 greg 1.1 purposes.
207     (Theoretically, one could write a complete renderer using just the
208     functional language...)
209     .PP
210     The standard input can be specified with a hyphen ('-').
211 greg 1.15 A command that produces a RADIANCE picture or float matrix
212     can be given in place of a file
213 greg 1.1 by preceeding it with an exclamation point ('!').
214     .SH EXAMPLES
215     To produce a picture showing the difference between pic1 and pic2:
216     .IP "" .2i
217 greg 1.18 pcomb \-e "ro=ri(1)\-ri(2);go=gi(1)\-gi(2);bo=bi(1)\-bi(2)" pic1 pic2 > diff
218 greg 1.1 .PP
219     Or, more efficiently:
220     .IP "" .2i
221 greg 1.8 pcomb pic1 \-s \-1 pic2 > diff
222 greg 1.1 .PP
223     To precompute the gamma correction for a picture:
224     .IP "" .2i
225 greg 1.18 pcomb \-e "ro=ri(1)^.4;go=gi(1)^.4;bo=bi(1)^.4" inp.hdr > gam.hdr
226 greg 1.1 .PP
227     To perform some special filtering:
228     .IP "" .2i
229 greg 1.9 pcomb \-f myfilt.cal \-x xmax/2 \-y ymax/2 input.hdr > filtered.hdr
230 greg 1.1 .PP
231     To make a picture of a dot:
232     .IP "" .2i
233 greg 1.18 pcomb \-x 100 \-y 100 \-e "ro=b;go=b;bo=b;b=if((x-50)^2+(y-50)^2\-25^2,0,1)" > dot
234 greg 1.16 .PP
235     Use a depth buffer to superimpose 3-D gridlines on rendered image:
236     .IP "" .2i
237     rcollate -hi -ff -o 3000x3000 raw_orig.zbf
238 greg 1.18 | pcomb -e "frac(x):x-floor(x);EPS:.0001"
239     -e "t=gi(2);Px=Ox(1)+t*Dx(1)-EPS;Py=Oy(1)+t*Dy(1)-EPS;Pz=Oz(1)+t*Dz(1)-EPS"
240     -e "Rg:0;Gg:0;Bg:1;gsiz:0.03"
241     -e "ingr=gsiz-min(frac(Px),frac(Py),frac(Pz))"
242     -e "ro=if(ingr,Rg,ri(1));go=if(ingr,Gg,gi(1));bo=if(ingr,Bg,bi(1))"
243 greg 1.16 raw_orig.hdr - > trans_def_grid.hdr
244 greg 1.11 .SH ENVIRONMENT
245     RAYPATH the directories to check for auxiliary files.
246 greg 1.1 .SH AUTHOR
247     Greg Ward
248     .SH "SEE ALSO"
249 greg 1.20 getinfo(1), icalc(1), pcompos(1), pfilt(1), pvalue(1), pvsum(1), rcalc(1),
250 greg 1.19 rcollate(1), rcomb(1), rmtxop(1), rpict(1)
