root/radiance/ray/doc/man/man1/mkillum.1
Sun Aug 11 02:57:49 2013 UTC (11 years, 9 months ago) by greg
Changes since 1.11: +1 -15 lines
Diff to previous 1.11
Removed deprecated thickness setting used for BSDF input
Sat Oct 13 20:15:43 2012 UTC (12 years, 7 months ago) by greg
Changes since 1.10: +1 -29 lines
Diff to previous 1.10
Fri Sep 3 23:53:49 2010 UTC (14 years, 9 months ago) by greg
Changes since 1.9: +13 -9 lines
Diff to previous 1.9
Mon Nov 10 19:08:17 2008 UTC (16 years, 7 months ago) by greg
Changes since 1.8: +5 -7 lines
Diff to previous 1.8
Fri Apr 18 00:39:24 2008 UTC (17 years, 1 month ago) by greg
Diff to previous 1.7
Added clarification of "up" orientation for BSDFs
Thu Dec 13 07:03:36 2007 UTC (17 years, 5 months ago) by greg
Changes since 1.6: +43 -2 lines
Diff to previous 1.6
Tue Sep 4 17:36:40 2007 UTC (17 years, 9 months ago) by greg
Diff to previous 1.5
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
Tue Feb 22 16:10:43 2005 UTC (20 years, 3 months ago) by greg
Changes since 1.4: +9 -1 lines
Diff to previous 1.4
Added example with multiple input files
Fri Sep 17 21:43:49 2004 UTC (20 years, 8 months ago) by greg
Changes since 1.3: +13 -2 lines
Diff to previous 1.3
Thu Jan 1 19:31:45 2004 UTC (21 years, 5 months ago) by greg
Diff to previous 1.2
Tue Dec 9 15:59:06 2003 UTC (21 years, 6 months ago) by greg
Fixed RCSid specification
Tue Mar 11 19:20:21 2003 UTC (22 years, 3 months ago) by greg
Added documentation to repository
