root/radiance/ray/doc/man/man1/mkillum.1
Revision: 1.7
Committed: Thu Dec 13 07:03:36 2007 UTC (17 years, 6 months ago) by greg
Changes since 1.6: +43 -2 lines
1 .\" RCSid "$Id: mkillum.1,v 1.6 2007/09/04 17:36:40 greg Exp $"
2 .TH MKILLUM 1 10/6/95 RADIANCE
3 .SH NAME
4 mkillum - compute illum sources for a RADIANCE scene
5 .SH SYNOPSIS
6 .B mkillum
7 [
8 .B "\-n nprocs"
9 ][
10 .B "rtrace options"
11 ]
12 .B octree
13 .B "[ \< file .. ]"
14 .br
15 .B "mkillum [ rtrace options ] \-defaults"
16 .SH DESCRIPTION
17 .I Mkillum
18 takes a prepared RADIANCE scene description and an octree and computes
19 light source distributions for each surface, replacing them with
20 secondary sources whose contributions can be computed more efficiently by
21 .I rpict(1)
22 and
23 .I rvu(1).
24 This type of optimization is most useful for windows and skylights which
25 represent concentrated sources of indirect illumination.
26 .I Mkillum
27 is not appropriate for very large sources or sources with highly
28 directional distributions.
29 These are best handled respectively by the ambient calculation
30 and the secondary source types in RADIANCE.
31 .PP
32 If the
33 .I \-n
34 option is specified with a value greater than 1, multiple
35 .I rtrace(1)
36 processes will be used to accelerate computation on a shared
37 memory machine.
38 Note that there is no benefit to using more processes
39 than there are local CPUs available to do the work.
40 .PP
41 Remaining arguments to
42 .I mkillum
43 are passed directly to
44 .I rtrace(1),
45 which is used to compute the light distributions for the input surfaces.
46 These surfaces can be any combination of polygons, spheres and rings.
47 Other surfaces may be included, but
48 .I mkillum
49 cannot compute their distributions.
50 .PP
51 By default,
52 .I mkillum
53 reads from its standard input and writes to its standard output.
54 It is possible to specify multiple input files in a somewhat
55 unconventional fashion by placing a lesser-than symbol ('<') before
56 the file names.
57 (Note that this character must be escaped from most shells.)
58 This is necessary so
59 .I mkillum
60 can tell where the arguments to
61 .I rtrace(1)
62 end and its own input files begin.
63 .SH VARIABLES
64 .I Mkillum
65 has a number of parameters that can be changed by
66 comments in the input file of the form:
67 .nf
68
69 #@mkillum variable=value option switch{+|-} ..
70
71 .fi
72 String or integer variables are separated from their values by the
73 equals sign ('=').
74 Options appear by themselves.
75 Switches are followed either by a
76 plus sign to turn them on or a minus sign to turn them off.
77 .PP
78 Parameters are usually changed many times within the
79 same input file to tailor the calculation, specify different
80 labels and so on.
81 The parameters and their meanings are described below.
82 .TP 10n
83 .BI o =string
84 Set the output file to
85 .I string.
86 All subsequent scene data will be sent to this file.
87 If this appears in the first comment in the input, nothing will be
88 sent to the standard output.
89 Note that this is not recommended when running
90 .I mkillum
91 from
92 .I rad(1),
93 which expects the output to be on the standard output.
94 .TP
95 .BI m =string
96 Set the material identifier to
97 .I string.
98 This name will be used not only as the new surface modifier, but it
99 will also be used to name the distribution pattern and the data files.
100 The distribution name will be
101 .I string
102 plus the suffix ".dist".
103 The data file will be named
104 .I string
105 plus possibly an integer plus a ".dat" suffix.
106 The integer is used to avoid accidently writing over an existing
107 file.
108 If overwriting the file is desired, use the
109 .I f
110 variable below.
111 .TP
112 .BI f =string
113 Set the data file name to
114 .I string.
115 The next data file will be given this name plus a ".dat" suffix.
116 Subsequent files will be named
117 .I string
118 plus an integer plus the ".dat" suffix.
119 An existing file with the same name will be clobbered.
120 This variable may be unset by leaving off the value.
121 (See also the
122 .I m
123 variable above.)
124 .TP
125 .BR a
126 Produce secondary sources for all of the surfaces in the input.
127 This is the default.
128 .TP
129 .BI e =string
130 Produce secondary sources for all surfaces except those modified by
131 .I string.
132 Surfaces modified by
133 .I string
134 will be passed to the output unchanged.
135 .TP
136 .BI i =string
137 Only produce secondary sources for surfaces modified by
138 .I string.
139 .TP
140 .BR n
141 Do not produce any secondary sources.
142 All input will be passed to the output unaffected, except any
143 void surfaces will be removed.
144 .TP
145 .BI b =real
146 Do not produce a secondary source for a surface if its average
147 brightness (radiance) is less than the value
148 .I real.
149 .TP
150 .BI c ={d|a|n}
151 Use color information according to the given character.
152 If the character is
153 .I d,
154 then color information will be used in three separate data files and
155 the distribution will be fully characterized in terms of color.
156 If the character is
157 .I a,
158 then only the average color is computed and the distribution will
159 not contain color information.
160 If the character is
161 .I n,
162 even the average distribution color will be thrown away,
163 producing secondary sources that are completely uncolored.
164 This may be desirable from a color-balancing point of view.
165 .TP
166 .BI d =integer
167 Set the number of direction samples per projected steradian to
168 .I integer.
169 The number of directions stored in the associated data file will be
170 approximately this number multiplied by pi for polygons and rings, and
171 by 4pi for spheres.
172 If
173 .I integer
174 is zero, then a diffuse source is assumed and no distribution is
175 created.
176 .TP
177 .BI d =string
178 Set the surface Bidirectional Scattering Distribution Function (BSDF)
179 to the given file.
180 The RADIANCE library path will be searched if the file does not begin
181 with a '.' or '~' character.
182 This file must contain an LBNL Window 6 XML specification of a valid
183 BSDF for the given surface, and all rays will be interpreted through
184 this function.
185 The orientation of the BSDF may be controlled with the
186 .I u
187 setting, described below.
188 The thickness of the surface may be controlled with the
189 .I t
190 setting.
191 If this variable has no setting or an integer is specified,
192 .I mkillum
193 returns to the default behavior of computing the output distribution
194 directly.
195 .TP
196 .BI s =integer
197 Set the number of ray samples per direction to
198 .I integer.
199 This variable affects the accuracy of the distribution value for
200 each direction as well as the computation time for
201 .I mkillum.
202 .TP
203 .BR l{+|-}
204 Switch between light sources and illum sources.
205 If this switch is enabled
206 .I (l+),
207 .I mkillum
208 will use the material type "light" to represent surfaces.
209 If disabled
210 .I (l-),
211 .I mkillum
212 will use the material type "illum" with the input surface modifier
213 as its alternate material.
214 The default is
215 .I l-.
216 .TP
217 .BI u =[+|-]{X|Y|Z}
218 The given axis will be considered "up" for the purposes of interpreting
219 BSDF data specified with the
220 .I d
221 variable.
222 The BSDF will be reoriented relative to the surface as necessary to keep
223 the up vector in the vertical plane that contains this axis and the
224 surface normal.
225 The default value is +Z.
226 .TP
227 .BI t =real
228 Set the surface thickness to
229 .I real
230 in world coordinates.
231 This value is used for determining where to start rays that need to begin
232 on the opposite side of the surface, specifically to compute the incoming
233 distribution for a BSDF computation.
234 The default value is 0.
235 .SH EXAMPLES
236 The following command generates illum's corresponding to geometry
237 in the files "it1.rad" and "it2.rad":
238 .IP "" .3i
239 mkillum \-ab 2 \-ad 1024 \-av .1 .1 .1 basic.oct "<" it1.rad it2.rad > illums.rad
240 .PP
241 The output file "illums.rad" would then be combined with the original
242 scene geometry to create a more easily rendered composite.
243 .SH ENVIRONMENT
244 RAYPATH the directories to check for auxiliary files.
245 .SH AUTHOR
246 Greg Ward
247 .SH ACKNOWLEDGEMENT
248 Work on this program was initiated and sponsored by the LESO
249 group at EPFL in Switzerland.
250 .SH "SEE ALSO"
251 oconv(1), rad(1), rpict(1), rtrace(1), rvu(1)
