root/radiance/ray/doc/man/man1/mkillum.1
Revision: 1.11
Committed: Sat Oct 13 20:15:43 2012 UTC (12 years, 8 months ago) by greg
Changes since 1.10: +1 -29 lines
1 .\" RCSid "$Id: mkillum.1,v 1.10 2010/09/03 23:53:49 greg Exp $"
2 .TH MKILLUM 1 10/6/95 RADIANCE
3 .SH NAME
4 mkillum - compute illum sources for a RADIANCE scene
5 .SH SYNOPSIS
6 .B mkillum
7 [
8 .B "\-n nprocs"
9 ][
10 .B "rtrace options"
11 ]
12 .B octree
13 .B "[ \< file .. ]"
14 .br
15 .B "mkillum [ rtrace options ] \-defaults"
16 .SH DESCRIPTION
17 .I Mkillum
18 takes a prepared RADIANCE scene description and an octree and computes
19 light source distributions for each surface, replacing them with
20 secondary sources whose contributions can be computed more efficiently by
21 .I rpict(1)
22 and
23 .I rvu(1).
24 This type of optimization is most useful for windows and skylights which
25 represent concentrated sources of indirect illumination.
26 .I Mkillum
27 is not appropriate for very large sources or sources with highly
28 directional distributions.
29 These are best handled respectively by the ambient calculation
30 and the secondary source types in RADIANCE.
31 .PP
32 If the
33 .I \-n
34 option is specified with a value greater than 1, multiple
35 ray tracing processes will be used to accelerate computation on a shared
36 memory machine.
37 Note that there is no benefit to using more processes
38 than there are local CPUs available to do the work.
39 .PP
40 Remaining arguments to
41 .I mkillum
42 are interpreted as rendering options for
43 .I rtrace(1),
44 to compute the light distributions for the input surfaces.
45 These surfaces can be any combination of polygons, spheres and rings.
46 Other surfaces may be included, but
47 .I mkillum
48 cannot compute their distributions.
49 .PP
50 By default,
51 .I mkillum
52 reads from its standard input and writes to its standard output.
53 It is possible to specify multiple input files in a somewhat
54 unconventional fashion by placing a lesser-than symbol ('<') before
55 the file names.
56 (Note that this character must be escaped from most shells.)
57 This is necessary so
58 .I mkillum
59 can tell where the rendering arguments
60 end and its own input files begin.
61 .SH VARIABLES
62 .I Mkillum
63 has a number of parameters that can be changed by
64 comments in the input file of the form:
65 .nf
66
67 #@mkillum variable=value option switch{+|-} ..
68
69 .fi
70 String or integer variables are separated from their values by the
71 equals sign ('=').
72 Options appear by themselves.
73 Switches are followed either by a
74 plus sign to turn them on or a minus sign to turn them off.
75 .PP
76 Parameters are usually changed many times within the
77 same input file to tailor the calculation, specify different
78 labels and so on.
79 The parameters and their meanings are described below.
80 .TP 10n
81 .BI o =string
82 Set the output file to
83 .I string.
84 All subsequent scene data will be sent to this file.
85 If this appears in the first comment in the input, nothing will be
86 sent to the standard output.
87 Note that this is not recommended when running
88 .I mkillum
89 from
90 .I rad(1),
91 which expects the output to be on the standard output.
92 .TP
93 .BI m =string
94 Set the material identifier to
95 .I string.
96 This name will be used not only as the new surface modifier, but it
97 will also be used to name the distribution pattern and the data files.
98 The distribution name will be
99 .I string
100 plus the suffix ".dist".
101 The data file will be named
102 .I string
103 plus possibly an integer plus a ".dat" suffix.
104 The integer is used to avoid accidently writing over an existing
105 file.
106 If overwriting the file is desired, use the
107 .I f
108 variable below.
109 .TP
110 .BI f =string
111 Set the data file name to
112 .I string.
113 The next data file will be given this name plus a ".dat" suffix.
114 Subsequent files will be named
115 .I string
116 plus an integer plus the ".dat" suffix.
117 An existing file with the same name will be clobbered.
118 This variable may be unset by leaving off the value.
119 (See also the
120 .I m
121 variable above.)
122 .TP
123 .BR a
124 Produce secondary sources for all of the surfaces in the input.
125 This is the default.
126 .TP
127 .BI e =string
128 Produce secondary sources for all surfaces except those modified by
129 .I string.
130 Surfaces modified by
131 .I string
132 will be passed to the output unchanged.
133 .TP
134 .BI i =string
135 Only produce secondary sources for surfaces modified by
136 .I string.
137 .TP
138 .BR n
139 Do not produce any secondary sources.
140 All input will be passed to the output unaffected, except any
141 void surfaces will be removed.
142 .TP
143 .BI b =real
144 Do not produce a secondary source for a surface if its average
145 brightness (radiance) is less than the value
146 .I real.
147 .TP
148 .BI c ={d|a|n}
149 Use color information according to the given character.
150 If the character is
151 .I d,
152 then color information will be used in three separate data files and
153 the distribution will be fully characterized in terms of color.
154 If the character is
155 .I a,
156 then only the average color is computed and the distribution will
157 not contain color information.
158 If the character is
159 .I n,
160 even the average distribution color will be thrown away,
161 producing secondary sources that are completely uncolored.
162 This may be desirable from a color-balancing point of view.
163 .TP
164 .BI d =integer
165 Set the number of direction samples per projected steradian to
166 .I integer.
167 The number of directions stored in the associated data file will be
168 approximately this number multiplied by pi for polygons and rings, and
169 by 4pi for spheres.
170 If
171 .I integer
172 is zero, then a diffuse source is assumed and no distribution is
173 created.
174 .TP
175 .BI s =integer
176 Set the number of ray samples per direction to
177 .I integer.
178 This variable affects the accuracy of the distribution value for
179 each direction as well as the computation time for
180 .I mkillum.
181 .TP
182 .BR l{+|-}
183 Switch between light sources and illum sources.
184 If this switch is enabled
185 .I (l+),
186 .I mkillum
187 will use the material type "light" to represent surfaces.
188 If disabled
189 .I (l-),
190 .I mkillum
191 will use the material type "illum" with the input surface modifier
192 as its alternate material.
193 The default is
194 .I l-.
195 .TP
196 .BI t =real
197 Set the surface thickness to
198 .I real
199 in world coordinates.
200 This value is used for determining where to start rays that need to begin
201 on the opposite side of a fenestration system, specifically
202 to compute the incoming distribution for a BSDF computation.
203 If the thickness is set to 0 and a BSDF contains detailed geometry,
204 it will be translated and output as part of the new description, provided the
205 .I l-
206 option is also in effect.
207 (This currently works only for rectangular polygons.)\0
208 The default thickness is 0.
209 .SH EXAMPLES
210 The following command generates illum's corresponding to geometry
211 in the files "it1.rad" and "it2.rad":
212 .IP "" .3i
213 mkillum \-ab 2 \-ad 1024 \-av .1 .1 .1 basic.oct "<" it1.rad it2.rad > illums.rad
214 .PP
215 The output file "illums.rad" would then be combined with the original
216 scene geometry to create a more easily rendered composite.
217 .SH ENVIRONMENT
218 RAYPATH the directories to check for auxiliary files.
219 .SH AUTHOR
220 Greg Ward
221 .SH ACKNOWLEDGEMENT
222 Work on this program was initiated and sponsored by the LESO
223 group at EPFL in Switzerland.
224 .SH "SEE ALSO"
225 genBSDF(1), oconv(1), rad(1), rpict(1), rtrace(1), rvu(1)
