| 1 |
RCSid "$Id: README.txt,v 1.9 2023/11/15 18:02:52 greg Exp $" |
| 2 |
| 3 |
Hello and welcome to the Radiance synthetic imaging system. This is |
| 4 |
the twenty-seventh release, Version 6.1, and it includes all source files |
| 5 |
for local compilation with a standard C compiler. To find out what's |
| 6 |
new in this release, check the text file "doc/notes/ReleaseNotes". |
| 7 |
| 8 |
Radiance is open source software copyrighted and distributed by |
| 9 |
Lawrence Berkeley National Laboratory in California. By downloading |
| 10 |
and installing this software, you are implicitly agreeing to the |
| 11 |
copyright appended to this README file, and the license agreement (License.txt) |
| 12 |
in the same directory. Please read both carefully before proceeding. |
| 13 |
| 14 |
Please read this entire file before sending e-mail asking |
| 15 |
how to install this software or what to do with it. Some |
| 16 |
frequently asked questions are answered here and also on our |
| 17 |
website at: |
| 18 |
| 19 |
https://www.radiance-online.org/ |
| 20 |
| 21 |
The CVS source tree is available, including post-release bug-fixes and |
| 22 |
mailing lists access at: |
| 23 |
| 24 |
https://www.radiance-online.org/download-install/CVS%20source%20code |
| 25 |
| 26 |
The website below has some precompiled Radiance binaries |
| 27 |
and add-ons for common Unix platforms: |
| 28 |
| 29 |
https://www.radiance-online.org/download-install/installation-information |
| 30 |
| 31 |
We have attempted to make it easy for you (and for us) to install |
| 32 |
the software on differently configured systems using a global make |
| 33 |
script. To install the software, just type: |
| 34 |
| 35 |
./makeall install |
| 36 |
| 37 |
You can clean up the .o files and so forth with: |
| 38 |
| 39 |
./makeall clean |
| 40 |
| 41 |
Or, if you are confident you can do both at the same time with: |
| 42 |
| 43 |
./makeall install clean |
| 44 |
| 45 |
You can give other make options at the end of the command as well. For |
| 46 |
example, the -n option will tell you what makeall is going to do without |
| 47 |
actually doing it. |
| 48 |
| 49 |
If you downloaded the binaries, so compilation is not necessary, |
| 50 |
run the following command to install the library files only: |
| 51 |
| 52 |
./makeall library |
| 53 |
| 54 |
The makeall script may ask you questions about your system and where you |
| 55 |
want to install the executables and library files. The pathnames you |
| 56 |
give should be relative to root for the programs to work properly. You |
| 57 |
may also use the tilde ('~') character to give paths starting with |
| 58 |
someone's home directory. |
| 59 |
| 60 |
If you do NOT have X11 support, please read the note "noX11.help" in |
| 61 |
this directory. It explains what to change to make things work. |
| 62 |
| 63 |
Although it is set automatically by makeall, individuals may want to |
| 64 |
set the RAYPATH environment variable manually. This variable tells |
| 65 |
Radiance where to look for auxiliary files, and usually includes the |
| 66 |
current directory as well as the system library (ray/lib in this |
| 67 |
distribution). As you develop auxiliary files yourself, it is often |
| 68 |
useful to add in your own library directory before the system directory. |
| 69 |
An example setting such as this would go in a user's .login file: |
| 70 |
| 71 |
setenv RAYPATH .:${HOME}/mylib:/usr/local/lib/ray |
| 72 |
| 73 |
After installing the software, you may want to start by scanning the |
| 74 |
troff input documentation contained in "doc/ray.1", which is also formatted |
| 75 |
for web browsers in "doc/ray.html". |
| 76 |
A PDF version of this manual may be found in |
| 77 |
"doc/pdf/ray.pdf", along with an older tutorial by Cindy Larson, |
| 78 |
"doc/pdf/raduser1_6.pdf". |
| 79 |
| 80 |
To check that everything is peforming correctly, you can run: |
| 81 |
| 82 |
./makeall test |
| 83 |
| 84 |
For complete documentation on the system as of release 3.1, refer to |
| 85 |
"Rendering with Radiance" by Larson and Shakespeare, which used to be |
| 86 |
available from Morgan Kauffman Publishing. Recently, the authors have |
| 87 |
taken over printing of the book, which is now available from booksurge.com. |
| 88 |
You may find it linked to the Radiance website page: |
| 89 |
| 90 |
http://radsite.lbl.gov/radiance/book/ |
| 91 |
| 92 |
The first chapter of this book, which includes a basic tutorial and |
| 93 |
serves as a good introduction for new users, may be found in |
| 94 |
"doc/pdf/RwR01.pdf". |
| 95 |
| 96 |
Important additions since version 3.1 include the holodeck programs (rholo, |
| 97 |
etc., built in src/hd), glrad, ranimove, the new "mesh" primitive, |
| 98 |
and rtcontrib. Again, check doc/notes/ReleaseNotes for details. |
| 99 |
| 100 |
Individual manual pages may be found in the subdirectory "doc/man". |
| 101 |
You may want to copy these to the system manual directory, or add this |
| 102 |
directory to your MANPATH environment variable in your shell |
| 103 |
initialization file. A good starting place is to print the text file |
| 104 |
ray/doc/man/whatis, which gives a one line description of each program in |
| 105 |
the Radiance package. To print out the manual pages, use the "-man" |
| 106 |
macro package. |
| 107 |
| 108 |
The most important program to learn about if you are a new user of Radiance |
| 109 |
(or have not used this program before) is "rad". It controls Radiance |
| 110 |
lighting parameters, and automates much of the rendering process. |
| 111 |
To get started, change directory to obj/misc and try running: |
| 112 |
| 113 |
% rad -o x11 daf.rif |
| 114 |
| 115 |
This works if you are running X11. If you are not, you can still generate |
| 116 |
an image with: |
| 117 |
| 118 |
% rad daf.rif & |
| 119 |
| 120 |
When the picture is done, you can convert it to another format for display |
| 121 |
with any of the ra_* programs listed in the doc/whatis database. |
| 122 |
| 123 |
There is a user interface built on top of this using Tcl/Tk, called trad. |
| 124 |
If you do not have Tcl/Tk installed on your system, you must do so prior |
| 125 |
to building this distribution if you want trad to install. (Try a google |
| 126 |
search on "Tcl/Tk" or go to "http://www.scriptics.com/software/tcltk/".) |
| 127 |
| 128 |
+++++++++++++++++ COPYRIGHT NOTICE +++++++++++++++++ |
| 129 |
| 130 |
Radiance v5.4 Copyright (c) 1990 to 2022, The Regents of the University of |
| 131 |
California, through Lawrence Berkeley National Laboratory (subject to receipt |
| 132 |
of any required approvals from the U.S. Dept. of Energy). All rights reserved. |
| 133 |
| 134 |
If you have questions about your rights to use or distribute this software, |
| 135 |
please contact Berkeley Lab's Intellectual Property Office at |
| 136 |
[email protected]. |
| 137 |
| 138 |
NOTICE. This Software was developed under funding from the U.S. Department |
| 139 |
of Energy and the U.S. Government consequently retains certain rights. As |
| 140 |
such, the U.S. Government has been granted for itself and others acting on |
| 141 |
its behalf a paid-up, nonexclusive, irrevocable, worldwide license in the |
| 142 |
Software to reproduce, distribute copies to the public, prepare derivative |
| 143 |
works, and perform publicly and display publicly, and to permit others to do so. |
| 144 |
