| 1 |
RCSid "$Id: README.txt,v 1.9 2023/11/15 18:02:52 greg Exp $"
| 2 |
| 3 |
Hello and welcome to the Radiance synthetic imaging system. This is
| 4 |
the twenty-seventh release, Version 6.1, and it includes all source files
| 5 |
for local compilation with a standard C compiler. To find out what's
| 6 |
new in this release, check the text file "doc/notes/ReleaseNotes".
| 7 |
| 8 |
Radiance is open source software copyrighted and distributed by
| 9 |
Lawrence Berkeley National Laboratory in California. By downloading
| 10 |
and installing this software, you are implicitly agreeing to the
| 11 |
copyright appended to this README file, and the license agreement (License.txt)
| 12 |
in the same directory. Please read both carefully before proceeding.
| 13 |
| 14 |
Please read this entire file before sending e-mail asking
| 15 |
how to install this software or what to do with it. Some
| 16 |
frequently asked questions are answered here and also on our
| 17 |
website at:
| 18 |
| 19 |
https://www.radiance-online.org/
| 20 |
| 21 |
The CVS source tree is available, including post-release bug-fixes and
| 22 |
mailing lists access at:
| 23 |
| 24 |
https://www.radiance-online.org/download-install/CVS%20source%20code
| 25 |
| 26 |
The website below has some precompiled Radiance binaries
| 27 |
and add-ons for common Unix platforms:
| 28 |
| 29 |
https://www.radiance-online.org/download-install/installation-information
| 30 |
| 31 |
We have attempted to make it easy for you (and for us) to install
| 32 |
the software on differently configured systems using a global make
| 33 |
script. To install the software, just type:
| 34 |
| 35 |
./makeall install
| 36 |
| 37 |
You can clean up the .o files and so forth with:
| 38 |
| 39 |
./makeall clean
| 40 |
| 41 |
Or, if you are confident you can do both at the same time with:
| 42 |
| 43 |
./makeall install clean
| 44 |
| 45 |
You can give other make options at the end of the command as well. For
| 46 |
example, the -n option will tell you what makeall is going to do without
| 47 |
actually doing it.
| 48 |
| 49 |
If you downloaded the binaries, so compilation is not necessary,
| 50 |
run the following command to install the library files only:
| 51 |
| 52 |
./makeall library
| 53 |
| 54 |
The makeall script may ask you questions about your system and where you
| 55 |
want to install the executables and library files. The pathnames you
| 56 |
give should be relative to root for the programs to work properly. You
| 57 |
may also use the tilde ('~') character to give paths starting with
| 58 |
someone's home directory.
| 59 |
| 60 |
If you do NOT have X11 support, please read the note "noX11.help" in
| 61 |
this directory. It explains what to change to make things work.
| 62 |
| 63 |
Although it is set automatically by makeall, individuals may want to
| 64 |
set the RAYPATH environment variable manually. This variable tells
| 65 |
Radiance where to look for auxiliary files, and usually includes the
| 66 |
current directory as well as the system library (ray/lib in this
| 67 |
distribution). As you develop auxiliary files yourself, it is often
| 68 |
useful to add in your own library directory before the system directory.
| 69 |
An example setting such as this would go in a user's .login file:
| 70 |
| 71 |
setenv RAYPATH .:${HOME}/mylib:/usr/local/lib/ray
| 72 |
| 73 |
After installing the software, you may want to start by scanning the
| 74 |
troff input documentation contained in "doc/ray.1", which is also formatted
| 75 |
for web browsers in "doc/ray.html".
| 76 |
A PDF version of this manual may be found in
| 77 |
"doc/pdf/ray.pdf", along with an older tutorial by Cindy Larson,
| 78 |
"doc/pdf/raduser1_6.pdf".
| 79 |
| 80 |
To check that everything is peforming correctly, you can run:
| 81 |
| 82 |
./makeall test
| 83 |
| 84 |
For complete documentation on the system as of release 3.1, refer to
| 85 |
"Rendering with Radiance" by Larson and Shakespeare, which used to be
| 86 |
available from Morgan Kauffman Publishing. Recently, the authors have
| 87 |
taken over printing of the book, which is now available from booksurge.com.
| 88 |
You may find it linked to the Radiance website page:
| 89 |
| 90 |
http://radsite.lbl.gov/radiance/book/
| 91 |
| 92 |
The first chapter of this book, which includes a basic tutorial and
| 93 |
serves as a good introduction for new users, may be found in
| 94 |
"doc/pdf/RwR01.pdf".
| 95 |
| 96 |
Important additions since version 3.1 include the holodeck programs (rholo,
| 97 |
etc., built in src/hd), glrad, ranimove, the new "mesh" primitive,
| 98 |
and rtcontrib. Again, check doc/notes/ReleaseNotes for details.
| 99 |
| 100 |
Individual manual pages may be found in the subdirectory "doc/man".
| 101 |
You may want to copy these to the system manual directory, or add this
| 102 |
directory to your MANPATH environment variable in your shell
| 103 |
initialization file. A good starting place is to print the text file
| 104 |
ray/doc/man/whatis, which gives a one line description of each program in
| 105 |
the Radiance package. To print out the manual pages, use the "-man"
| 106 |
macro package.
| 107 |
| 108 |
The most important program to learn about if you are a new user of Radiance
| 109 |
(or have not used this program before) is "rad". It controls Radiance
| 110 |
lighting parameters, and automates much of the rendering process.
| 111 |
To get started, change directory to obj/misc and try running:
| 112 |
| 113 |
% rad -o x11 daf.rif
| 114 |
| 115 |
This works if you are running X11. If you are not, you can still generate
| 116 |
an image with:
| 117 |
| 118 |
% rad daf.rif &
| 119 |
| 120 |
When the picture is done, you can convert it to another format for display
| 121 |
with any of the ra_* programs listed in the doc/whatis database.
| 122 |
| 123 |
There is a user interface built on top of this using Tcl/Tk, called trad.
| 124 |
If you do not have Tcl/Tk installed on your system, you must do so prior
| 125 |
to building this distribution if you want trad to install. (Try a google
| 126 |
search on "Tcl/Tk" or go to "http://www.scriptics.com/software/tcltk/".)
| 127 |
| 128 |
+++++++++++++++++ COPYRIGHT NOTICE +++++++++++++++++
| 129 |
| 130 |
Radiance v5.4 Copyright (c) 1990 to 2022, The Regents of the University of
| 131 |
California, through Lawrence Berkeley National Laboratory (subject to receipt
| 132 |
of any required approvals from the U.S. Dept. of Energy). All rights reserved.
| 133 |
| 134 |
If you have questions about your rights to use or distribute this software,
| 135 |
please contact Berkeley Lab's Intellectual Property Office at
| 136 |
[email protected].
| 137 |
| 138 |
NOTICE. This Software was developed under funding from the U.S. Department
| 139 |
of Energy and the U.S. Government consequently retains certain rights. As
| 140 |
such, the U.S. Government has been granted for itself and others acting on
| 141 |
its behalf a paid-up, nonexclusive, irrevocable, worldwide license in the
| 142 |
Software to reproduce, distribute copies to the public, prepare derivative
| 143 |
works, and perform publicly and display publicly, and to permit others to do so.
| 144 |
