root/radiance/test/renders/ref/mixtex_fish.hdr
Tue Apr 26 20:06:43 2022 UTC (3 years, 5 months ago) by greg
Changes since 1.6: +14 -8 lines
Diff to previous 1.6
test: Updated reference images after ambient super-sampling bug fix
Fri Feb 19 06:01:47 2021 UTC (4 years, 7 months ago) by greg
Changes since 1.5: +10 -15 lines
Diff to previous 1.5
test: fixes and improvements with addition of batches for splitting job
Fri Jan 22 00:01:38 2021 UTC (4 years, 8 months ago) by greg
Changes since 1.4: +13 -14 lines
Diff to previous 1.4
test: updated default -av setting in rad, which affected tests
Fri Jan 1 20:15:35 2021 UTC (4 years, 9 months ago) by greg
Changes since 1.3: +14 -8 lines
Diff to previous 1.3
Added bias compensation to photon-mapping tests
Tue Aug 11 16:33:34 2020 UTC (5 years, 2 months ago) by greg
Changes since 1.2: +9 -17 lines
Diff to previous 1.2
test: updated references for other mixtex views after portal change
Fri Dec 7 17:44:58 2018 UTC (6 years, 10 months ago) by greg
Changes since 1.1: +16 -14 lines
Diff to previous 1.1
Switched to photon-mapping in mixtex scene to reduce artifacts
Sat Dec 1 02:06:09 2018 UTC (6 years, 10 months ago) by greg
Finished additions for BSDF's, etc. to complete primitive testing
