root/radiance/test/py_tests/test_xform.py
Revision: 1.1
Committed: Sun Dec 7 20:40:51 2003 UTC (21 years, 10 months ago) by schorsch
Content type: text/x-python
CVS Tags: rad3R7P2, rad4R2P2, rad4R2P1, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad5R0
First attempt at testing framework.
1
2 import os
3 import math
4 import string
5 import unittest
6
7 from unit_tools import support
8 from unit_tools import lcompare
9
10 class XformTestCase(unittest.TestCase):
11 def setUp(self):
12 self.oldpath = os.environ['PATH']
13 os.environ['PATH'] = os.path.abspath(support.BINDIR)
14
15 def tearDown(self):
16 os.environ['PATH'] = self.oldpath
17
18 def test_xform(self):
19 cmd = 'xform -e -s 3.14159 "%s"' % support.datafile('xform_1.dat')
20 result = lcompare.split_rad(os.popen(cmd).read())
21 expect = lcompare.split_radfile(support.datafile('xform_res1.dat'))
22 try: lcompare.llcompare(result, expect, ignore_empty=1)
23 except lcompare.error, e:
24 self.fail('%s [%s]' % (str(e),cmd))
25
26
27 def test_xform(self):
28 cmd = 'xform -e -mx "%s"' % support.datafile('xform_2.dat')
29 result = lcompare.split_rad(os.popen(cmd).read())
30 expect = lcompare.split_radfile(support.datafile('xform_res2.dat'))
31 try: lcompare.llcompare(result, expect, ignore_empty=1)
32 except lcompare.error, e:
33 self.fail('%s [%s]' % (str(e),cmd))
34
35 def main():
36 support.run_case(XformTestCase)
37
38 if __name__ == '__main__':
39 main()
40
41 # vi: set ts=4 sw=4 :
