| 1 |
schorsch |
1.1 |
| 2 |
import os |
| 3 |
import string |
| 4 |
import unittest |
| 5 |
| 6 |
from unit_tools import support |
| 7 |
from unit_tools import lcompare |
| 8 |
| 9 |
class HistoTestCase(unittest.TestCase): |
| 10 |
def setUp(self): |
| 11 |
self.oldpath = os.environ['PATH'] |
| 12 |
os.environ['PATH'] = os.path.abspath(support.BINDIR) |
| 13 |
| 14 |
def tearDown(self): |
| 15 |
os.environ['PATH'] = self.oldpath |
| 16 |
| 17 |
def test_histo(self): |
| 18 |
schorsch |
1.2 |
cmd = 'histo -0.5 8.5 9 < "%s"' % support.datafile('histo.dat') |
| 19 |
schorsch |
1.1 |
raw = os.popen(cmd).read() |
| 20 |
result = map(string.split,string.split(raw,'\n')) |
| 21 |
expect = [ |
| 22 |
schorsch |
1.2 |
[0, 720, 240, 432, 1080, 270], |
| 23 |
[1, 720, 240, 432, 1080, 270], |
| 24 |
[2, 720, 240, 432, 0, 270], |
| 25 |
[3, 0, 240, 432, 0, 270], |
| 26 |
[4, 0, 240, 432, 0, 270], |
| 27 |
[5, 0, 240, 0, 0, 270], |
| 28 |
[6, 0, 240, 0, 0, 270], |
| 29 |
[7, 0, 240, 0, 0, 270], |
| 30 |
[8, 0, 240, 0, 0, 0], |
| 31 |
| 32 |
try: lcompare.llcompare(result, expect, ignore_empty=1) |
| 33 |
except lcompare.error, e: |
| 34 |
self.fail('%s [%s]' % (str(e),cmd)) |
| 35 |
| 36 |
def test_histo_c(self): |
| 37 |
cmd = 'histo -c -0.5 8.5 9 < "%s"' % support.datafile('histo.dat') |
| 38 |
| 39 |
| 40 |
expect = [ |
| 41 |
[-0.5, 0, 0, 0, 0, 0], |
| 42 |
[0.5, 720, 240, 432, 1080, 270], |
| 43 |
[1.5, 1440, 480, 864, 2160, 540], |
| 44 |
[2.5, 2160, 720, 1296, 2160, 810], |
| 45 |
[3.5, 2160, 960, 1728, 2160, 1080], |
| 46 |
[4.5, 2160, 1200, 2160, 2160, 1350], |
| 47 |
[5.5, 2160, 1440, 2160, 2160, 1620], |
| 48 |
[6.5, 2160, 1680, 2160, 2160, 1890], |
| 49 |
[7.5, 2160, 1920, 2160, 2160, 2160], |
| 50 |
[8.5, 2160, 2160, 2160, 2160, 2160], |
| 51 |
| 52 |
| 53 |
| 54 |
| 55 |
| 56 |
def test_histo_p(self): |
| 57 |
cmd = 'histo -p -0.5 8.5 9 < "%s"' % support.datafile('histo.dat') |
| 58 |
| 59 |
| 60 |
expect = [ |
| 61 |
[0, 33.333333, 11.111111, 20.0, 50.0, 12.5], |
| 62 |
[1, 33.333333, 11.111111, 20.0, 50.0, 12.5], |
| 63 |
[2, 33.333333, 11.111111, 20.0, 0.0, 12.5], |
| 64 |
[3, 0.0, 11.111111, 20.0, 0.0, 12.5], |
| 65 |
[4, 0.0, 11.111111, 20.0, 0.0, 12.5], |
| 66 |
[5, 0.0, 11.111111, 0.0, 0.0, 12.5], |
| 67 |
[6, 0.0, 11.111111, 0.0, 0.0, 12.5], |
| 68 |
[7, 0.0, 11.111111, 0.0, 0.0, 12.5], |
| 69 |
[8, 0.0, 11.111111, 0.0, 0.0, 0.0], |
| 70 |
| 71 |
| 72 |
| 73 |
| 74 |
| 75 |
def test_histo_pc(self): |
| 76 |
cmd = 'histo -p -c -0.5 8.5 9 < "%s"' % support.datafile('histo.dat') |
| 77 |
| 78 |
| 79 |
expect = [ |
| 80 |
[-0.5, 0.0, 0.0, 0.0, 0.0, 0.0], |
| 81 |
[0.5, 33.333333, 11.111111, 20.0, 50.0, 12.5], |
| 82 |
[1.5, 66.666667, 22.222222, 40.0, 100.0, 25.0], |
| 83 |
[2.5, 100.0, 33.333333, 60.0, 100.0, 37.5], |
| 84 |
[3.5, 100.0, 44.444444, 80.0, 100.0, 50.0], |
| 85 |
[4.5, 100.0, 55.555556, 100.0, 100.0, 62.5], |
| 86 |
[5.5, 100.0, 66.666667, 100.0, 100.0, 75.0], |
| 87 |
[6.5, 100.0, 77.777778, 100.0, 100.0, 87.5], |
| 88 |
[7.5, 100.0, 88.888889, 100.0, 100.0, 100.0], |
| 89 |
[8.5, 100.0, 100.0, 100.0, 100.0, 100.0], |
| 90 |
schorsch |
1.1 |
| 91 |
| 92 |
| 93 |
| 94 |
| 95 |
def main(): |
| 96 |
support.run_case(HistoTestCase) |
| 97 |
| 98 |
if __name__ == '__main__': |
| 99 |
main() |
| 100 |
| 101 |
# vi: set ts=4 sw=4 : |
