root/radiance/test/py_tests/test_histo.py
Revision: 1.2
Committed: Sun Dec 14 21:04:07 2003 UTC (21 years, 10 months ago) by schorsch
Content type: text/x-python
CVS Tags: rad3R7P2, rad4R2P2, rad4R2P1, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad5R0
Changes since 1.1: +69 -7 lines
Added tests for -c and -p options. Changed intervals to avoid rounding instabilities.
1
2 import os
3 import string
4 import unittest
5
6 from unit_tools import support
7 from unit_tools import lcompare
8
9 class HistoTestCase(unittest.TestCase):
10 def setUp(self):
11 self.oldpath = os.environ['PATH']
12 os.environ['PATH'] = os.path.abspath(support.BINDIR)
13
14 def tearDown(self):
15 os.environ['PATH'] = self.oldpath
16
17 def test_histo(self):
18 cmd = 'histo -0.5 8.5 9 < "%s"' % support.datafile('histo.dat')
19 raw = os.popen(cmd).read()
20 result = map(string.split,string.split(raw,'\n'))
21 expect = [
22 [0, 720, 240, 432, 1080, 270],
23 [1, 720, 240, 432, 1080, 270],
24 [2, 720, 240, 432, 0, 270],
25 [3, 0, 240, 432, 0, 270],
26 [4, 0, 240, 432, 0, 270],
27 [5, 0, 240, 0, 0, 270],
28 [6, 0, 240, 0, 0, 270],
29 [7, 0, 240, 0, 0, 270],
30 [8, 0, 240, 0, 0, 0],
31 ]
32 try: lcompare.llcompare(result, expect, ignore_empty=1)
33 except lcompare.error, e:
34 self.fail('%s [%s]' % (str(e),cmd))
35
36 def test_histo_c(self):
37 cmd = 'histo -c -0.5 8.5 9 < "%s"' % support.datafile('histo.dat')
38 raw = os.popen(cmd).read()
39 result = map(string.split,string.split(raw,'\n'))
40 expect = [
41 [-0.5, 0, 0, 0, 0, 0],
42 [0.5, 720, 240, 432, 1080, 270],
43 [1.5, 1440, 480, 864, 2160, 540],
44 [2.5, 2160, 720, 1296, 2160, 810],
45 [3.5, 2160, 960, 1728, 2160, 1080],
46 [4.5, 2160, 1200, 2160, 2160, 1350],
47 [5.5, 2160, 1440, 2160, 2160, 1620],
48 [6.5, 2160, 1680, 2160, 2160, 1890],
49 [7.5, 2160, 1920, 2160, 2160, 2160],
50 [8.5, 2160, 2160, 2160, 2160, 2160],
51 ]
52 try: lcompare.llcompare(result, expect, ignore_empty=1)
53 except lcompare.error, e:
54 self.fail('%s [%s]' % (str(e),cmd))
55
56 def test_histo_p(self):
57 cmd = 'histo -p -0.5 8.5 9 < "%s"' % support.datafile('histo.dat')
58 raw = os.popen(cmd).read()
59 result = map(string.split,string.split(raw,'\n'))
60 expect = [
61 [0, 33.333333, 11.111111, 20.0, 50.0, 12.5],
62 [1, 33.333333, 11.111111, 20.0, 50.0, 12.5],
63 [2, 33.333333, 11.111111, 20.0, 0.0, 12.5],
64 [3, 0.0, 11.111111, 20.0, 0.0, 12.5],
65 [4, 0.0, 11.111111, 20.0, 0.0, 12.5],
66 [5, 0.0, 11.111111, 0.0, 0.0, 12.5],
67 [6, 0.0, 11.111111, 0.0, 0.0, 12.5],
68 [7, 0.0, 11.111111, 0.0, 0.0, 12.5],
69 [8, 0.0, 11.111111, 0.0, 0.0, 0.0],
70 ]
71 try: lcompare.llcompare(result, expect, ignore_empty=1)
72 except lcompare.error, e:
73 self.fail('%s [%s]' % (str(e),cmd))
74
75 def test_histo_pc(self):
76 cmd = 'histo -p -c -0.5 8.5 9 < "%s"' % support.datafile('histo.dat')
77 raw = os.popen(cmd).read()
78 result = map(string.split,string.split(raw,'\n'))
79 expect = [
80 [-0.5, 0.0, 0.0, 0.0, 0.0, 0.0],
81 [0.5, 33.333333, 11.111111, 20.0, 50.0, 12.5],
82 [1.5, 66.666667, 22.222222, 40.0, 100.0, 25.0],
83 [2.5, 100.0, 33.333333, 60.0, 100.0, 37.5],
84 [3.5, 100.0, 44.444444, 80.0, 100.0, 50.0],
85 [4.5, 100.0, 55.555556, 100.0, 100.0, 62.5],
86 [5.5, 100.0, 66.666667, 100.0, 100.0, 75.0],
87 [6.5, 100.0, 77.777778, 100.0, 100.0, 87.5],
88 [7.5, 100.0, 88.888889, 100.0, 100.0, 100.0],
89 [8.5, 100.0, 100.0, 100.0, 100.0, 100.0],
90 ]
91 try: lcompare.llcompare(result, expect, ignore_empty=1)
92 except lcompare.error, e:
93 self.fail('%s [%s]' % (str(e),cmd))
94
95 def main():
96 support.run_case(HistoTestCase)
97
98 if __name__ == '__main__':
99 main()
100
101 # vi: set ts=4 sw=4 :
