root/radiance/test/cv/ref/checkBSDFout.txt
Revision: 1.2
Committed: Fri May 23 20:21:14 2025 UTC (4 months, 1 week ago) by greg
CVS Tags: rad6R0, HEAD
test(checkBSDF): Updated headline to match current code
1 =====================================================
2 File: '../renders/blinds20c.xml'
3 Manufacturer: 'Greg Ward'
4 BSDF Name: 'Green specular venetian blinds at 20 degree angle'
5 Dimensions (W x H x Thickness): 300 x 97.369 x 3.75911 cm
6 Type: Anisotropic_Tensor_Tree
7 Color: 1
8 Has Geometry: 1
9 Component Lambertian XYZ (%) Max. Tot. Dir Min. Angle
10 Interior Refl 0.0 0.0 0.0 46.4% 3.58 deg
11 Exterior Refl 0.0 0.0 0.0 66.5% 3.58 deg
12 Int->Ext Trans 0.0 0.0 0.0 100.4% 3.58 deg
13 Ext->Int Trans 0.0 0.0 0.0 0.0% 180 deg
14 Component Reciprocity Error (min avg max %)
15 Interior Refl 0.0 0.0 0.0
16 Exterior Refl 0.0 0.0 0.0
17 Transmission 0 0 0
18 =====================================================
19 File: '../renders/sawtooth.xml'
20 Manufacturer: 'Manufacturer'
21 BSDF Name: 'Name'
22 Dimensions (W x H x Thickness): 24 x 24 x 0.2 cm
23 Type: Klems_Full
24 Color: 0
25 Has Geometry: 0
26 Component Lambertian XYZ (%) Max. Tot. Dir Min. Angle
27 Interior Refl 0.0 0.0 0.0 69.9% 8.56 deg
28 Exterior Refl 0.0 0.0 0.0 0.0% 180 deg
29 Int->Ext Trans 0.0 0.0 0.0 0.0% 180 deg
30 Ext->Int Trans 0 0 0 0.0% 180 deg
31 Component Reciprocity Error (min avg max %)
32 Interior Refl 0.0 5.6 99.4
33 Exterior Refl 0 0 0
34 Transmission 0 0 0
