| 1 |
| 2 |
Radiance Testing Framework |
| 3 |
| 4 |
| 5 |
A toolkit to test all (eventually) components of the Radiance |
| 6 |
synthetic image generation system for conformance to their |
| 7 |
specification. |
| 8 |
| 9 |
| 10 |
Limitations |
| 11 |
| 12 |
For the moment, we use PyUnit to run our tests. This means that |
| 13 |
we're restricted to test only complete programs, and not actual |
| 14 |
units (since PyUnit was designed to test Python units, not C). |
| 15 |
A C-level testing framework may be added later. |
| 16 |
| 17 |
There's no good way to automatically test GUI programs like |
| 18 |
rview. We have to rely on good human testers to check whether |
| 19 |
those work correctly or not. |
| 20 |
| 21 |
| 22 |
Requirements |
| 23 |
| 24 |
You need a working installation of Python 2.1 (or newer) on your |
| 25 |
system. The reason for this is that the PyUnit framework isn't |
| 26 |
included with earlier versions. If you prefer to use an older |
| 27 |
Python (back to 1.5.2), you can get PyUnit here, and install it |
| 28 |
somewhere on your PYTHONPATH: |
| 29 |
http://pyunit.sourceforge.net/ |
| 30 |
| 31 |
Our testing framework currently assumes that the Radiance files |
| 32 |
reside in the following local file tree (seen from the "test/" |
| 33 |
subdirectory where this file resides): |
| 34 |
| 35 |
executables: ../bin/*[.exe] |
| 36 |
support files: ../lib/* |
| 37 |
data files: ./test data/* |
| 38 |
| 39 |
This is the location where the SCons build system places |
| 40 |
everything, which means we're testing the software after building |
| 41 |
but before installing. |
| 42 |
The space character in the name of the test data directory is |
| 43 |
deliberate, because it is a design requirement that all our |
| 44 |
executables can handle path names with spaces. |
| 45 |
| 46 |
| 47 |
How to run tests |
| 48 |
| 49 |
The simplest way to run tests is to use the SCons build system. |
| 50 |
The file ray/INSTALL.scons explains the requirements and details. |
| 51 |
Once you have SCons working, go to the ray directory and type |
| 52 |
| 53 |
$> scons test |
| 54 |
| 55 |
which will automatically execute all available tests in the |
| 56 |
correct environment. |
| 57 |
| 58 |
You can also run the tests manually: |
| 59 |
| 60 |
On unix systems, just type "run_all.py" in this directory to |
| 61 |
test everything. If that file doesn't have execute rights, you |
| 62 |
can supply it to the python interpreter as its single argument: |
| 63 |
"python run_all.py". You can also run individual test suites from |
| 64 |
the "py_tests" directory directly: "python test_getinfo.py". |
| 65 |
| 66 |
On Windows, this should usually work as well. As an alternative, |
| 67 |
use the "winrun.bat" script. WARNING: You need to change the |
| 68 |
paths in this script to match your Python installation first. |
| 69 |
| 70 |
| 71 |
What gets tested |
| 72 |
| 73 |
There are several test groups, each containing a number of test |
| 74 |
suites, each containing one or more tests. When running tests, |
| 75 |
the name of the test groups and test suites will get printed to |
| 76 |
the console, the latter with an "ok" if they succeeded. |
| 77 |
| 78 |
If any test fails, there will be diagnostic output about the |
| 79 |
nature of the failure, but the remaining tests will continue to |
| 80 |
be executed. Note that several utility programs may be used to |
| 81 |
access the results of other calculations, so if eg. getinfo is |
| 82 |
broken, that may cause a number of seemingly unrelated tests to |
| 83 |
fail as well. |
| 84 |
| 85 |
| 86 |
How to report failures |
| 87 |
| 88 |
If any of the tests fail on your platform, please report your |
| 89 |
results (and as much ancilliary information about your system and |
| 90 |
Radiance version as possible) to the radiance code development |
| 91 |
mailing list on http://www.radiance-online.org/ |
| 92 |
The developers will then either try to fix the bug, or instruct |
| 93 |
you on how to refine your testing to get more information about |
| 94 |
what went wrong. |
| 95 |
| 96 |
| 97 |
How to contribute test cases |
| 98 |
| 99 |
The list of tests run is still very much incomplete, but will |
| 100 |
hopefully grow quickly. You can contribute by creating tests too! |
| 101 |
Please ask on the code development mailing list first, so that we |
| 102 |
can avoid overlaps between the work of different contributors. |
| 103 |
| 104 |
There are two classes of tests to be considered: |
| 105 |
| 106 |
- Testing individual executables |
| 107 |
This means that an individual program like ev, xfom, or getinfo |
| 108 |
is tested with typical input data, and the output is compared |
| 109 |
against the expected result. |
| 110 |
| 111 |
- Testing specific calculations |
| 112 |
This will mainly affect the actual simulation programs rpict |
| 113 |
and rtrace. For example, there should be a test suite for every |
| 114 |
material (and modifier) type, which uses rtrace to shoot a |
| 115 |
series of rays against a surface under varying angles, in order |
| 116 |
to verify material behaviour under different parameters. Tests |
| 117 |
of this kind may require a custom script. |
| 118 |
| 119 |
Contributed tests can be of two kinds. In the simplest case, you |
| 120 |
can contribute a small(!) set of test data, the command line(s) |
| 121 |
used to run your tests on them, and a list of expected results. |
| 122 |
Result comparisons are typically done in text form (by line). |
| 123 |
If the result is a picture, we'll use ttyimage to pick out a few |
| 124 |
scan lines for comparison (the image dimensions must be less than |
| 125 |
128 pixels). Other binary data needs to be converted into a |
| 126 |
suitable text representation as well. If you're not sure what to |
| 127 |
use, the developers can help you about that point. They will then |
| 128 |
also wrap your test case into a Python module for integration |
| 129 |
with the framework. |
| 130 |
| 131 |
Contributors sufficiently familiar with the Python programming |
| 132 |
language and the PyUnit test framework can also submit complete |
| 133 |
test suites in Python. Please use the existing tests in the |
| 134 |
"py_tests" directory as a template, and check out the helper |
| 135 |
modules in "py_tests/unit_tools". |
| 136 |
| 137 |
In any case, please note that we can't use any shell scripts or |
| 138 |
similar tools in our tests. All tests should be able to run on |
| 139 |
all supported platforms, where your favourite shell may not be |
| 140 |
available. The Python programming language is available for |
| 141 |
pretty much any platform, so we decided to use only that. |
| 142 |
| 143 |
| 144 |
