root/radiance/src/util/xglaresrc.c
Revision: 2.6
Committed: Sat Feb 22 02:07:30 2003 UTC (22 years, 8 months ago) by greg
5 * Circle sources in a displayed image.
6 *
7 * 18 Mar 1991 Greg Ward
8 */
9
10 #include "standard.h"
11 #include "view.h"
12 #include "vfork.h"
13 #include <signal.h>
14 #include <X11/Xlib.h>
15 #include <X11/Xutil.h>
16
17 #define XIM "ximage"
18
19 #define NSEG 30 /* number of segments per circle */
20
21 #define FONTNAME "8x13" /* text font we'll use */
22
23 float col[3] = {1.,0.,0.}; /* color */
24
25 VIEW ourview = STDVIEW; /* view for picture */
26 RESOLU pres; /* picture resolution */
27
28 char *progname; /* program name */
29
30 Display *theDisplay = NULL; /* connection to server */
31
32 #define rwind RootWindow(theDisplay,ourScreen)
33 #define ourScreen DefaultScreen(theDisplay)
34
35 GC vecGC, strGC;
36 Window gwind;
37
38
39 main(argc, argv)
40 int argc;
41 char *argv[];
42 {
43 char *windowname = NULL;
44 FILE *fp;
45
46 progname = *argv++; argc--;
47 while (argc > 0 && argv[0][0] == '-') {
48 switch (argv[0][1]) {
49 case 'n':
50 windowname = *++argv;
51 argc--;
52 break;
53 case 'c':
54 col[0] = atof(*++argv);
55 col[1] = atof(*++argv);
56 col[2] = atof(*++argv);
57 argc -= 3;
58 break;
59 }
60 argv++; argc--;
61 }
62 if (argc < 1 || argc > 2) {
63 fprintf(stderr,
64 "Usage: %s [-n windowname][-c color] picture [glaresrc]\n",
65 progname);
66 exit(1);
67 }
68 init(argv[0], windowname);
69 if (argc < 2)
70 fp = stdin;
71 else if ((fp = fopen(argv[1], "r")) == NULL) {
72 fprintf(stderr, "%s: cannot open \"%s\"\n", progname, argv[1]);
73 exit(1);
74 }
75 circle_sources(fp);
76 exit(0);
77 }
78
79
80 init(pname, wname) /* get view and find window */
81 char *pname, *wname;
82 {
83 extern Window xfindwind();
84 XWindowAttributes wa;
85 XColor xc;
86 XGCValues gcv;
87 register int i;
88 /* get the viewing parameters */
89 if (viewfile(pname, &ourview, &pres) <= 0 ||
90 setview(&ourview) != NULL) {
91 fprintf(stderr, "%s: cannot get view from \"%s\"\n",
92 progname, pname);
93 exit(1);
94 }
95 /* open the display */
96 if ((theDisplay = XOpenDisplay(NULL)) == NULL) {
97 fprintf(stderr,
98 "%s: cannot open display; DISPLAY variable set?\n",
99 progname);
100 exit(1);
101 }
102 /* find our window */
103 if (wname == NULL) {
104 /* remove directory prefix from name */
105 for (i = strlen(pname); i-- > 0; )
106 if (pname[i] == '/')
107 break;
108 wname = pname+i+1;
109 i = 0;
110 } else
111 i = 1;
112 gwind = xfindwind(theDisplay, rwind, wname, 4);
113 if (gwind == None) {
114 if (i) {
115 fprintf(stderr, "%s: cannot find \"%s\" window\n",
116 progname, wname);
117 exit(2);
118 }
119 /* start ximage */
120 if (vfork() == 0) {
121 execlp(XIM, XIM, "-c", "256", pname, 0);
122 perror(XIM);
123 fprintf(stderr, "%s: cannot start %s\n",
124 progname, XIM);
125 kill(getppid(), SIGPIPE);
126 _exit(1);
127 }
128 do
129 sleep(8);
130 while ((gwind=xfindwind(theDisplay,rwind,wname,4)) == None);
131 } else
132 XMapRaised(theDisplay, gwind);
133 do {
134 XGetWindowAttributes(theDisplay, gwind, &wa);
135 sleep(6);
136 } while (wa.map_state != IsViewable);
137 if (wa.width != scanlen(&pres) || wa.height != numscans(&pres)) {
138 fprintf(stderr,
139 "%s: warning -- window seems to be the wrong size!\n",
140 progname);
141 if (pres.rt & YMAJOR) {
142 pres.xr = wa.width;
143 pres.yr = wa.height;
144 } else {
145 pres.xr = wa.height;
146 pres.yr = wa.width;
147 }
148 }
149 /* set graphics context */
150 gcv.font = XLoadFont(theDisplay, FONTNAME);
151 if (gcv.font == 0) {
152 fprintf(stderr, "%s: cannot load font \"%s\"\n",
153 progname, FONTNAME);
154 exit(1);
155 }
156 xc.red = col[0] >= 1.0 ? 65535 : (unsigned)(65536*col[0]);
157 xc.green = col[1] >= 1.0 ? 65535 : (unsigned)(65536*col[1]);
158 xc.blue = col[2] >= 1.0 ? 65535 : (unsigned)(65536*col[2]);
159 xc.flags = DoRed|DoGreen|DoBlue;
160 gcv.background = xc.green >= 32768 ?
161 BlackPixel(theDisplay,DefaultScreen(theDisplay)) :
162 WhitePixel(theDisplay,DefaultScreen(theDisplay)) ;
163 if (XAllocColor(theDisplay, wa.colormap, &xc)) {
164 gcv.foreground = xc.pixel;
165 vecGC = XCreateGC(theDisplay,gwind,
166 GCForeground|GCBackground|GCFont,&gcv);
167 strGC = vecGC;
168 } else {
169 gcv.function = GXinvert;
170 vecGC = XCreateGC(theDisplay,gwind,GCFunction,&gcv);
171 gcv.foreground = xc.green < 32768 ?
172 BlackPixel(theDisplay,DefaultScreen(theDisplay)) :
173 WhitePixel(theDisplay,DefaultScreen(theDisplay)) ;
174 strGC = XCreateGC(theDisplay,gwind,
175 GCForeground|GCBackground|GCFont,&gcv);
176 }
177 }
178
179
180 circle_sources(fp) /* circle sources listed in fp */
181 FILE *fp;
182 {
183 char linbuf[256];
184 int reading = 0;
185 FVECT dir;
186 double dom, lum;
187
188 while (fgets(linbuf, sizeof(linbuf), fp) != NULL)
189 if (reading) {
190 if (!strncmp(linbuf, "END", 3)) {
191 XFlush(theDisplay);
192 return;
193 }
194 if (sscanf(linbuf, "%lf %lf %lf %lf %lf",
195 &dir[0], &dir[1], &dir[2],
196 &dom, &lum) != 5)
197 break;
198 circle(dir, dom);
199 value(dir, lum);
200 } else if (!strcmp(linbuf, "BEGIN glare source\n"))
201 reading++;
202
203 fprintf(stderr, "%s: error reading glare sources\n", progname);
204 exit(1);
205 }
206
207
208 circle(dir, dom) /* indicate a solid angle on image */
209 FVECT dir;
210 double dom;
211 {
212 FVECT start, cur;
213 XPoint pt[NSEG+1];
214 FVECT pp;
215 int ip[2];
216 register int i;
217
218 fcross(cur, dir, ourview.vup);
219 if (normalize(cur) == 0.0)
220 goto fail;
221 spinvector(start, dir, cur, acos(1.-dom/(2.*PI)));
222 for (i = 0; i <= NSEG; i++) {
223 spinvector(cur, start, dir, 2.*PI*i/NSEG);
224 cur[0] += ourview.vp[0];
225 cur[1] += ourview.vp[1];
226 cur[2] += ourview.vp[2];
227 viewloc(pp, &ourview, cur);
228 if (pp[2] <= 0.0)
229 goto fail;
230 loc2pix(ip, &pres, pp[0], pp[1]);
231 pt[i].x = ip[0];
232 pt[i].y = ip[1];
233 }
234 XDrawLines(theDisplay, gwind, vecGC, pt, NSEG+1, CoordModeOrigin);
235 return;
236 fail:
237 fprintf(stderr, "%s: cannot draw source at (%f,%f,%f)\n",
238 progname, dir[0], dir[1], dir[2]);
239 }
240
241
242 value(dir, v) /* print value on image */
243 FVECT dir;
244 double v;
245 {
246 FVECT pos;
247 FVECT pp;
248 int ip[2];
249 char buf[32];
250
251 pos[0] = ourview.vp[0] + dir[0];
252 pos[1] = ourview.vp[1] + dir[1];
253 pos[2] = ourview.vp[2] + dir[2];
254 viewloc(pp, &ourview, pos);
255 if (pp[2] <= 0.0)
256 return;
257 loc2pix(ip, &pres, pp[0], pp[1]);
258 sprintf(buf, "%.0f", v);
259 XDrawImageString(theDisplay, gwind, strGC,
260 ip[0], ip[1], buf, strlen(buf));
261 }
