root/radiance/src/util/xglaresrc.c
Revision: 2.11
Committed: Mon Apr 2 16:45:41 2018 UTC (7 years, 6 months ago) by greg
Changes since 2.10: +5 -4 lines
Fixed issue with reading data in glarendx
2 static const char RCSid[] = "$Id: xglaresrc.c,v 2.10 2018/01/24 04:39:52 greg Exp $";
5 * Circle sources in a displayed image.
6 *
7 * 18 Mar 1991 Greg Ward
8 */
9
10 #include "standard.h"
11
12 #include <unistd.h>
13 #include <signal.h>
14 #include <X11/Xlib.h>
15 #include <X11/Xutil.h>
16
17 #include "view.h"
18
19 #define XIM "ximage"
20
21 #define NSEG 30 /* number of segments per circle */
22
23 #define FONTNAME "8x13" /* text font we'll use */
24
25 float col[3] = {1.,0.,0.}; /* color */
26
27 VIEW ourview = STDVIEW; /* view for picture */
28 RESOLU pres; /* picture resolution */
29
30 char *progname; /* program name */
31
32 Display *theDisplay = NULL; /* connection to server */
33
34 #define rwind RootWindow(theDisplay,ourScreen)
35 #define ourScreen DefaultScreen(theDisplay)
36
37 GC vecGC, strGC;
38 Window gwind;
39
40 static void init(char *pname, char *wname);
41 static void circle_sources(FILE *fp);
42 static void circle(FVECT dir, double dom);
43 static void value(FVECT dir, double v);
44
45
46 int
47 main(
48 int argc,
49 char *argv[]
50 )
51 {
52 char *windowname = NULL;
53 FILE *fp;
54
55 progname = *argv++; argc--;
56 while (argc > 0 && argv[0][0] == '-') {
57 switch (argv[0][1]) {
58 case 'n':
59 windowname = *++argv;
60 argc--;
61 break;
62 case 'c':
63 col[0] = atof(*++argv);
64 col[1] = atof(*++argv);
65 col[2] = atof(*++argv);
66 argc -= 3;
67 break;
68 }
69 argv++; argc--;
70 }
71 if (argc < 1 || argc > 2) {
72 fprintf(stderr,
73 "Usage: %s [-n windowname][-c color] picture [glaresrc]\n",
74 progname);
75 exit(1);
76 }
77 init(argv[0], windowname);
78 if (argc < 2)
79 fp = stdin;
80 else if ((fp = fopen(argv[1], "r")) == NULL) {
81 fprintf(stderr, "%s: cannot open \"%s\"\n", progname, argv[1]);
82 exit(1);
83 }
84 circle_sources(fp);
85 exit(0);
86 }
87
88
89 static void
90 init( /* get view and find window */
91 char *pname,
92 char *wname
93 )
94 {
95 extern Window xfindwind();
96 XWindowAttributes wa;
97 XColor xc;
98 XGCValues gcv;
99 register int i;
100 /* get the viewing parameters */
101 if (viewfile(pname, &ourview, &pres) <= 0 ||
102 setview(&ourview) != NULL) {
103 fprintf(stderr, "%s: cannot get view from \"%s\"\n",
104 progname, pname);
105 exit(1);
106 }
107 /* open the display */
108 if ((theDisplay = XOpenDisplay(NULL)) == NULL) {
109 fprintf(stderr,
110 "%s: cannot open display; DISPLAY variable set?\n",
111 progname);
112 exit(1);
113 }
114 /* find our window */
115 if (wname == NULL) {
116 /* remove directory prefix from name */
117 for (i = strlen(pname); i-- > 0; )
118 if (pname[i] == '/')
119 break;
120 wname = pname+i+1;
121 i = 0;
122 } else
123 i = 1;
124 gwind = xfindwind(theDisplay, rwind, wname, 4);
125 if (gwind == None) {
126 if (i) {
127 fprintf(stderr, "%s: cannot find \"%s\" window\n",
128 progname, wname);
129 exit(2);
130 }
131 /* start ximage */
132 if (fork() == 0) {
133 execlp(XIM, XIM, "-c", "256", pname, 0);
134 perror(XIM);
135 fprintf(stderr, "%s: cannot start %s\n",
136 progname, XIM);
137 kill(getppid(), SIGPIPE);
138 _exit(1);
139 }
140 do
141 sleep(8);
142 while ((gwind=xfindwind(theDisplay,rwind,wname,4)) == None);
143 } else
144 XMapRaised(theDisplay, gwind);
145 do {
146 XGetWindowAttributes(theDisplay, gwind, &wa);
147 sleep(6);
148 } while (wa.map_state != IsViewable);
149 if (wa.width != scanlen(&pres) || wa.height != numscans(&pres)) {
150 fprintf(stderr,
151 "%s: warning -- window seems to be the wrong size!\n",
152 progname);
153 if (pres.rt & YMAJOR) {
154 pres.xr = wa.width;
155 pres.yr = wa.height;
156 } else {
157 pres.xr = wa.height;
158 pres.yr = wa.width;
159 }
160 }
161 /* set graphics context */
162 gcv.font = XLoadFont(theDisplay, FONTNAME);
163 if (gcv.font == 0) {
164 fprintf(stderr, "%s: cannot load font \"%s\"\n",
165 progname, FONTNAME);
166 exit(1);
167 }
168 xc.red = col[0] >= 1.0 ? 65535 : (unsigned)(65536*col[0]);
169 xc.green = col[1] >= 1.0 ? 65535 : (unsigned)(65536*col[1]);
170 xc.blue = col[2] >= 1.0 ? 65535 : (unsigned)(65536*col[2]);
171 xc.flags = DoRed|DoGreen|DoBlue;
172 gcv.background = xc.green >= 32768 ?
173 BlackPixel(theDisplay,DefaultScreen(theDisplay)) :
174 WhitePixel(theDisplay,DefaultScreen(theDisplay)) ;
175 if (XAllocColor(theDisplay, wa.colormap, &xc)) {
176 gcv.foreground = xc.pixel;
177 vecGC = XCreateGC(theDisplay,gwind,
178 GCForeground|GCBackground|GCFont,&gcv);
179 strGC = vecGC;
180 } else {
181 gcv.function = GXinvert;
182 vecGC = XCreateGC(theDisplay,gwind,GCFunction,&gcv);
183 gcv.foreground = xc.green < 32768 ?
184 BlackPixel(theDisplay,DefaultScreen(theDisplay)) :
185 WhitePixel(theDisplay,DefaultScreen(theDisplay)) ;
186 strGC = XCreateGC(theDisplay,gwind,
187 GCForeground|GCBackground|GCFont,&gcv);
188 }
189 }
190
191
192 static void
193 circle_sources( /* circle sources listed in fp */
194 FILE *fp
195 )
196 {
197 char linbuf[256];
198 int reading = 0;
199 FVECT dir;
200 double dom, lum;
201
202 while (fgets(linbuf, sizeof(linbuf), fp) != NULL)
203 if (reading) {
204 if (!strncmp(linbuf, "END", 3)) {
205 XFlush(theDisplay);
206 return;
207 }
208 if (sscanf(linbuf, FVFORMAT,
209 &dir[0], &dir[1], &dir[2]) != 3 ||
210 sscanf(sskip2(linbuf, 3), "%lf %lf",
211 &dom, &lum) != 2)
212 break;
213 circle(dir, dom);
214 value(dir, lum);
215 } else if (!strcmp(linbuf, "BEGIN glare source\n"))
216 reading++;
217
218 fprintf(stderr, "%s: error reading glare sources\n", progname);
219 exit(1);
220 }
221
222
223 static void
224 circle( /* indicate a solid angle on image */
225 FVECT dir,
226 double dom
227 )
228 {
229 FVECT start, cur;
230 XPoint pt[NSEG+1];
231 FVECT pp;
232 int ip[2];
233 register int i;
234
235 fcross(cur, dir, ourview.vup);
236 if (normalize(cur) == 0.0)
237 goto fail;
238 spinvector(start, dir, cur, acos(1.-dom/(2.*PI)));
239 for (i = 0; i <= NSEG; i++) {
240 spinvector(cur, start, dir, 2.*PI*i/NSEG);
241 cur[0] += ourview.vp[0];
242 cur[1] += ourview.vp[1];
243 cur[2] += ourview.vp[2];
244 if (viewloc(pp, &ourview, cur) <= 0)
245 goto fail;
246 loc2pix(ip, &pres, pp[0], pp[1]);
247 pt[i].x = ip[0];
248 pt[i].y = ip[1];
249 }
250 XDrawLines(theDisplay, gwind, vecGC, pt, NSEG+1, CoordModeOrigin);
251 return;
252 fail:
253 fprintf(stderr, "%s: cannot draw source at (%f,%f,%f)\n",
254 progname, dir[0], dir[1], dir[2]);
255 }
256
257
258 static void
259 value( /* print value on image */
260 FVECT dir,
261 double v
262 )
263 {
264 FVECT pos;
265 FVECT pp;
266 int ip[2];
267 char buf[32];
268
269 pos[0] = ourview.vp[0] + dir[0];
270 pos[1] = ourview.vp[1] + dir[1];
271 pos[2] = ourview.vp[2] + dir[2];
272 if (viewloc(pp, &ourview, pos) <= 0)
273 return;
274 loc2pix(ip, &pres, pp[0], pp[1]);
275 sprintf(buf, "%.0f", v);
276 XDrawImageString(theDisplay, gwind, strGC,
277 ip[0], ip[1], buf, strlen(buf));
278 }
