root/radiance/src/util/xglaresrc.c
Revision: 2.14
Committed: Sat Jun 7 05:09:46 2025 UTC (4 months, 1 week ago) by greg
CVS Tags: rad6R0, HEAD
Error occurred while calculating annotation data.
2 static const char RCSid[] = "$Id: xglaresrc.c,v 2.13 2025/06/03 21:31:51 greg Exp $";
5 * Circle sources in a displayed image.
6 *
7 * 18 Mar 1991 Greg Ward
8 */
9
10 #include "standard.h"
11 #include "paths.h"
12
13 #include <signal.h>
14 #include <X11/Xlib.h>
15 #include <X11/Xutil.h>
16
17 #include "view.h"
18
19 #define XIM "ximage"
20
21 #define NSEG 30 /* number of segments per circle */
22
23 #define FONTNAME "8x13" /* text font we'll use */
24
25 float col[3] = {1.,0.,0.}; /* color */
26
27 VIEW ourview = STDVIEW; /* view for picture */
28 RESOLU pres; /* picture resolution */
29
30 Display *theDisplay = NULL; /* connection to server */
31
32 #define rwind RootWindow(theDisplay,ourScreen)
33 #define ourScreen DefaultScreen(theDisplay)
34
35 GC vecGC, strGC;
36 Window gwind;
37
38 static void init(char *pname, char *wname);
39 static void circle_sources(FILE *fp);
40 static void circle(FVECT dir, double dom);
41 static void value(FVECT dir, double v);
42
43
44 int
45 main(
46 int argc,
47 char *argv[]
48 )
49 {
50 char *windowname = NULL;
51 FILE *fp;
52
53 fixargv0(*argv++); argc--;
54 while (argc > 0 && argv[0][0] == '-') {
55 switch (argv[0][1]) {
56 case 'n':
57 windowname = *++argv;
58 argc--;
59 break;
60 case 'c':
61 col[0] = atof(*++argv);
62 col[1] = atof(*++argv);
63 col[2] = atof(*++argv);
64 argc -= 3;
65 break;
66 }
67 argv++; argc--;
68 }
69 if (argc < 1 || argc > 2) {
70 fprintf(stderr,
71 "Usage: %s [-n windowname][-c color] picture [glaresrc]\n",
72 progname);
73 exit(1);
74 }
75 init(argv[0], windowname);
76 if (argc < 2)
77 fp = stdin;
78 else if ((fp = fopen(argv[1], "r")) == NULL) {
79 fprintf(stderr, "%s: cannot open \"%s\"\n", progname, argv[1]);
80 exit(1);
81 }
82 circle_sources(fp);
83 exit(0);
84 }
85
86
87 static void
88 init( /* get view and find window */
89 char *pname,
90 char *wname
91 )
92 {
93 extern Window xfindwind();
94 XWindowAttributes wa;
95 XColor xc;
96 XGCValues gcv;
97 register int i;
98 /* get the viewing parameters */
99 if (viewfile(pname, &ourview, &pres) <= 0 ||
100 setview(&ourview) != NULL) {
101 fprintf(stderr, "%s: cannot get view from \"%s\"\n",
102 progname, pname);
103 exit(1);
104 }
105 /* open the display */
106 if ((theDisplay = XOpenDisplay(NULL)) == NULL) {
107 fprintf(stderr,
108 "%s: cannot open display; DISPLAY variable set?\n",
109 progname);
110 exit(1);
111 }
112 /* find our window */
113 if (wname == NULL) {
114 /* remove directory prefix from name */
115 for (i = strlen(pname); i-- > 0; )
116 if (pname[i] == '/')
117 break;
118 wname = pname+i+1;
119 i = 0;
120 } else
121 i = 1;
122 gwind = xfindwind(theDisplay, rwind, wname, 4);
123 if (gwind == None) {
124 if (i) {
125 fprintf(stderr, "%s: cannot find \"%s\" window\n",
126 progname, wname);
127 exit(2);
128 }
129 /* start ximage */
130 if (fork() == 0) {
131 execlp(XIM, XIM, "-c", "256", pname, 0);
132 perror(XIM);
133 fprintf(stderr, "%s: cannot start %s\n",
134 progname, XIM);
135 kill(getppid(), SIGPIPE);
136 _exit(1);
137 }
138 do
139 sleep(8);
140 while ((gwind=xfindwind(theDisplay,rwind,wname,4)) == None);
141 } else
142 XMapRaised(theDisplay, gwind);
143 do {
144 XGetWindowAttributes(theDisplay, gwind, &wa);
145 sleep(6);
146 } while (wa.map_state != IsViewable);
147 if (wa.width != scanlen(&pres) || wa.height != numscans(&pres)) {
148 fprintf(stderr,
149 "%s: warning -- window seems to be the wrong size!\n",
150 progname);
151 if (pres.rt & YMAJOR) {
152 pres.xr = wa.width;
153 pres.yr = wa.height;
154 } else {
155 pres.xr = wa.height;
156 pres.yr = wa.width;
157 }
158 }
159 /* set graphics context */
160 gcv.font = XLoadFont(theDisplay, FONTNAME);
161 if (gcv.font == 0) {
162 fprintf(stderr, "%s: cannot load font \"%s\"\n",
163 progname, FONTNAME);
164 exit(1);
165 }
166 xc.red = col[0] >= 1.0 ? 65535 : (unsigned)(65536*col[0]);
167 xc.green = col[1] >= 1.0 ? 65535 : (unsigned)(65536*col[1]);
168 xc.blue = col[2] >= 1.0 ? 65535 : (unsigned)(65536*col[2]);
169 xc.flags = DoRed|DoGreen|DoBlue;
170 gcv.background = xc.green >= 32768 ?
171 BlackPixel(theDisplay,DefaultScreen(theDisplay)) :
172 WhitePixel(theDisplay,DefaultScreen(theDisplay)) ;
173 if (XAllocColor(theDisplay, wa.colormap, &xc)) {
174 gcv.foreground = xc.pixel;
175 vecGC = XCreateGC(theDisplay,gwind,
176 GCForeground|GCBackground|GCFont,&gcv);
177 strGC = vecGC;
178 } else {
179 gcv.function = GXinvert;
180 vecGC = XCreateGC(theDisplay,gwind,GCFunction,&gcv);
181 gcv.foreground = xc.green < 32768 ?
182 BlackPixel(theDisplay,DefaultScreen(theDisplay)) :
183 WhitePixel(theDisplay,DefaultScreen(theDisplay)) ;
184 strGC = XCreateGC(theDisplay,gwind,
185 GCForeground|GCBackground|GCFont,&gcv);
186 }
187 }
188
189
190 static void
191 circle_sources( /* circle sources listed in fp */
192 FILE *fp
193 )
194 {
195 char linbuf[256];
196 int reading = 0;
197 FVECT dir;
198 double dom, lum;
199
200 while (fgets(linbuf, sizeof(linbuf), fp) != NULL)
201 if (reading) {
202 if (!strncmp(linbuf, "END", 3)) {
203 XFlush(theDisplay);
204 return;
205 }
206 if (sscanf(linbuf, FVFORMAT,
207 &dir[0], &dir[1], &dir[2]) != 3 ||
208 sscanf(sskip2(linbuf, 3), "%lf %lf",
209 &dom, &lum) != 2)
210 break;
211 circle(dir, dom);
212 value(dir, lum);
213 } else if (!strcmp(linbuf, "BEGIN glare source\n"))
214 reading++;
215
216 fprintf(stderr, "%s: error reading glare sources\n", progname);
217 exit(1);
218 }
219
220
221 static void
222 circle( /* indicate a solid angle on image */
223 FVECT dir,
224 double dom
225 )
226 {
227 FVECT start, cur;
228 XPoint pt[NSEG+1];
229 FVECT pp;
230 int ip[2];
231 register int i;
232
233 fcross(cur, dir, ourview.vup);
234 if (normalize(cur) == 0.0)
235 goto fail;
236 spinvector(start, dir, cur, acos(1.-dom/(2.*PI)));
237 for (i = 0; i <= NSEG; i++) {
238 spinvector(cur, start, dir, 2.*PI*i/NSEG);
239 cur[0] += ourview.vp[0];
240 cur[1] += ourview.vp[1];
241 cur[2] += ourview.vp[2];
242 if (viewloc(pp, &ourview, cur) != VL_GOOD)
243 goto fail;
244 loc2pix(ip, &pres, pp[0], pp[1]);
245 pt[i].x = ip[0];
246 pt[i].y = ip[1];
247 }
248 XDrawLines(theDisplay, gwind, vecGC, pt, NSEG+1, CoordModeOrigin);
249 return;
250 fail:
251 fprintf(stderr, "%s: cannot draw source at (%f,%f,%f)\n",
252 progname, dir[0], dir[1], dir[2]);
253 }
254
255
256 static void
257 value( /* print value on image */
258 FVECT dir,
259 double v
260 )
261 {
262 FVECT pos;
263 FVECT pp;
264 int ip[2];
265 char buf[32];
266
267 pos[0] = ourview.vp[0] + dir[0];
268 pos[1] = ourview.vp[1] + dir[1];
269 pos[2] = ourview.vp[2] + dir[2];
270 if (viewloc(pp, &ourview, pos) != VL_GOOD)
271 return;
272 loc2pix(ip, &pres, pp[0], pp[1]);
273 sprintf(buf, "%.0f", v);
274 XDrawImageString(theDisplay, gwind, strGC,
275 ip[0], ip[1], buf, strlen(buf));
276 }
