Revision: | 3.2 |
Committed: | Fri Nov 19 23:00:49 2004 UTC (20 years, 10 months ago) by greg |
Content type: | application/x-csh |
Branch: | MAIN |
CVS Tags: | rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad3R7P2, rad3R7P1, rad6R0, rad4R1, rad4R0, rad3R8, rad3R9, rad4R2P1, rad4R2P2, HEAD |
Changes since 3.1: | +4 -1 lines |
Log Message: | Added check to vinfo to insure that header ends with empty line |
# | Content |
1 | #!/bin/csh -f |
2 | # RCSid: $Id: vinfo.csh,v 3.1 2003/02/22 02:07:30 greg Exp $ |
3 | # |
4 | # Edit information header in Radiance file |
5 | # |
6 | set plist=() |
7 | set ilist=() |
8 | foreach f ($*) |
9 | if (! -f $f:q) then |
10 | echo "${f}: no such file or directory" |
11 | continue |
12 | endif |
13 | if (! -w $f:q) then |
14 | echo "$f is read-only" |
15 | sleep 1 |
16 | continue |
17 | endif |
18 | set info="$f.info" |
19 | getinfo < $f:q > $info:q |
20 | set plist=($plist:q $f:q) |
21 | set ilist=($ilist:q $info:q) |
22 | end |
23 | vi $ilist:q |
24 | set i=1 |
25 | while ( $i <= $#plist ) |
26 | set f=$plist[$i]:q |
27 | set info=$ilist[$i]:q |
28 | if ("`tail -1 $info:q`" != "") then |
29 | echo "" >> $info:q |
30 | endif |
31 | getinfo < $f:q | cmp -s - $info:q |
32 | if ($status != 0) then |
33 | getinfo - < $f:q >> $info:q |
34 | mv $info:q $f:q |
35 | else |
36 | rm $info:q |
37 | endif |
38 | @ i++ |
39 | end |
