| 1 |
#!/usr/bin/wish |
| 2 |
# RCSid: $Id: trad.wsh,v 2.16 2011/10/26 20:06:17 greg Exp $ |
| 3 |
# the next line restarts using wish in case of shell execution \ |
| 4 |
exec wish "$0" "$@" |
| 5 |
| 6 |
# TCL/TK-based Rad Input File Editor |
| 7 |
| 8 |
| 9 |
# Insert our autoload directory (may require local system modification) |
| 10 |
| 11 |
set radlib /usr/local/lib/ray/tcl |
| 12 |
set helplib $radlib |
| 13 |
| 14 |
set auto_path [linsert $auto_path 0 $radlib] |
| 15 |
| 16 |
# Assign global globbing variables |
| 17 |
| 18 |
set myglob(rif) *.rif |
| 19 |
set myglob(materials) *.mat |
| 20 |
set myglob(illum) *.rad |
| 21 |
set myglob(scene) *.rad |
| 22 |
set myglob(objects) * |
| 23 |
| 24 |
# Create required procedures |
| 25 |
| 26 |
proc modified {} { # check for radvar modification |
| 27 |
global radvar oldradvar |
| 28 |
if {! [info exists oldradvar]} {return 0} |
| 29 |
foreach n [array names oldradvar] { |
| 30 |
if {! [info exists radvar($n)] || |
| 31 |
"$radvar($n)" != "$oldradvar($n)"} { |
| 32 |
return 1 |
| 33 |
| 34 |
| 35 |
return 0 |
| 36 |
| 37 |
| 38 |
proc chksave {} { # check if RIF is saved and accost user if not |
| 39 |
global readonly rifname oldradvar curmess |
| 40 |
if [modified] { |
| 41 |
if $readonly { |
| 42 |
set warnmess "You have modified variables, but the\ |
| 43 |
file \"[file tail $rifname]\" was opened read-only. |
| 44 |
Do you wish to save this information somehow?" |
| 45 |
set yesmess {Go to File Screen} |
| 46 |
} else { |
| 47 |
set warnmess "The file \"[file tail $rifname]\" has\ |
| 48 |
been modified since it was last saved. |
| 49 |
Do you wish to save it now?" |
| 50 |
set yesmess {Save File} |
| 51 |
| 52 |
switch [tk_dialog .dlg {File Modified} $warnmess \ |
| 53 |
warning 0 $yesmess {Discard Changes} \ |
| 54 |
{Cancel Operation}] { |
| 55 |
1 { return 1 } |
| 56 |
2 { return 0 } |
| 57 |
| 58 |
if $readonly { |
| 59 |
set curmess {Rename file or uncheck read-only to save.} |
| 60 |
.file invoke |
| 61 |
return 0 |
| 62 |
} elseif {[save_vars $rifname]} { |
| 63 |
gotfile 1 |
| 64 |
return 1 |
| 65 |
| 66 |
return 0 |
| 67 |
| 68 |
return 1 |
| 69 |
| 70 |
| 71 |
# Set global variable default values |
| 72 |
| 73 |
set readonly 0 |
| 74 |
set alldone 0 |
| 75 |
set rifname [pwd]/ |
| 76 |
| 77 |
# Propogate essential variables |
| 78 |
| 79 |
proc setrname {name elem op} { |
| 80 |
global rifname |
| 81 |
wm title . $rifname |
| 82 |
wm iconname . [file tail $rifname] |
| 83 |
| 84 |
trace variable rifname w setrname |
| 85 |
| 86 |
# Make main window frames |
| 87 |
| 88 |
set smallscrn [expr [winfo screenwidth .] < 830] |
| 89 |
| 90 |
message .mess -relief ridge -font fixed -textvariable curmess -anchor nw |
| 91 |
if $smallscrn { |
| 92 |
frame .upper -width 640 -height 410 |
| 93 |
frame .upper.right -width 120 -height 410 |
| 94 |
.mess configure -width 640 |
| 95 |
} else { |
| 96 |
frame .upper -width 830 -height 410 |
| 97 |
frame .upper.right -width 130 -height 410 |
| 98 |
.mess configure -width 830 |
| 99 |
| 100 |
pack .upper -side top |
| 101 |
place .upper.right -relx .98 -rely 0 -anchor ne |
| 102 |
pack .mess -side top -expand yes -fill both |
| 103 |
helplink .mess trad trad messages |
| 104 |
. configure -cursor top_left_arrow |
| 105 |
| 106 |
# Make mode buttons |
| 107 |
| 108 |
proc changescreen {} { # switch screen according to curmode |
| 109 |
global curscreen curmode curmess smallscrn |
| 110 |
if [info exists curscreen] { |
| 111 |
if {"$curmode" == "$curscreen"} {return} |
| 112 |
destroy .upper.left |
| 113 |
do_$curscreen done |
| 114 |
set curmess {} |
| 115 |
| 116 |
set curscreen $curmode |
| 117 |
do_$curscreen .upper.left |
| 118 |
if $smallscrn { |
| 119 |
.upper.left configure -width 520 -height 410 |
| 120 |
} else { |
| 121 |
.upper.left configure -width 700 -height 410 |
| 122 |
| 123 |
place .upper.left -x 0 -y 0 |
| 124 |
| 125 |
| 126 |
label .upper.right.title -text "- TRAD -" |
| 127 |
pack .upper.right.title -side top -pady 10 |
| 128 |
| 129 |
proc setbutt v { |
| 130 |
radiobutton .$v -text [string toupper $v] \ |
| 131 |
-variable curmode -value $v \ |
| 132 |
-width 10 -relief groove -anchor w \ |
| 133 |
-command changescreen |
| 134 |
pack .$v -in .upper.right -side top -pady 5 |
| 135 |
helplink .$v trad $v intro |
| 136 |
| 137 |
| 138 |
setbutt file |
| 139 |
setbutt scene |
| 140 |
setbutt zone |
| 141 |
setbutt views |
| 142 |
setbutt options |
| 143 |
setbutt action |
| 144 |
setbutt results |
| 145 |
rename setbutt {} |
| 146 |
button .upper.right.help -text HELP -width 9 \ |
| 147 |
-command "gethelp trad trad intro" |
| 148 |
pack .upper.right.help -side top -pady 5 -anchor se |
| 149 |
helplink .upper.right.help trad trad help |
| 150 |
button .upper.right.quit -text QUIT \ |
| 151 |
-command {if [chksave] {destroy .}} -width 9 |
| 152 |
pack .upper.right.quit -side top -pady 5 -anchor se |
| 153 |
helplink .upper.right.quit trad trad quit |
| 154 |
| 155 |
if $smallscrn { |
| 156 |
wm minsize . 640 460 |
| 157 |
wm maxsize . 640 512 |
| 158 |
} else { |
| 159 |
wm minsize . 830 460 |
| 160 |
wm maxsize . 830 512 |
| 161 |
| 162 |
wm iconbitmap . @$radlib/trad.icon |
| 163 |
| 164 |
proc gotfile o { # set file possession state |
| 165 |
global oldradvar radvar |
| 166 |
catch {unset oldradvar} |
| 167 |
if $o { |
| 168 |
set mode normal |
| 169 |
foreach n [array names radvar] { |
| 170 |
set oldradvar($n) $radvar($n) |
| 171 |
| 172 |
} else { |
| 173 |
set mode disabled |
| 174 |
| 175 |
foreach b {scene zone views options action results} { |
| 176 |
.$b configure -state $mode |
| 177 |
| 178 |
| 179 |
| 180 |
# Decide where to go and start |
| 181 |
| 182 |
gotfile 0 |
| 183 |
if {[llength $argv] == 0} { |
| 184 |
set curmess "Choose a Radiance project file." |
| 185 |
.file invoke |
| 186 |
} elseif {[llength $argv] == 1} { |
| 187 |
cd [file dirname $argv] |
| 188 |
set curfile [file tail $argv] |
| 189 |
if {! [file isfile $curfile]} { |
| 190 |
if [newnew $curfile] { |
| 191 |
.scene invoke |
| 192 |
} else { |
| 193 |
.file invoke |
| 194 |
| 195 |
} elseif {[newload $curfile]} { |
| 196 |
if $alldone { |
| 197 |
set curmess "All renderings are finished." |
| 198 |
.results invoke |
| 199 |
} else { |
| 200 |
.action invoke |
| 201 |
| 202 |
} else { |
| 203 |
.file invoke |
| 204 |
| 205 |
} else { |
| 206 |
puts stderr {Usage: trad [rifname]} |
| 207 |
exit 1 |
| 208 |
