root/radiance/src/util/trad.hlp
Revision: 2.2
Committed: Fri Oct 28 11:09:52 1994 UTC (31 years ago) by greg
Changes since 2.1: +1 -3 lines
correction about loading bad RIF
1 $Id$
2
3 This help file is associated with the trad interface to the Radiance
4 rad(1) program. Trad consists of trad.wsh and one do_*.tcl file for
5 each screen. There are currently seven such screens: Action, File,
6 Options, Results, Scene, Views and Zone.
7
8 .Trad.Intro
9
10 Trad is a graphical user interface (GUI) to the
11 rad(1) program, which controls the operation of the basic
12 Radiance scene compiling, rendering and picture filtering programs.
13 Trad also includes links to a few utilities for displaying and
14 converting results, but most of what it does can be done by editing a
15 small text file, called the "rad input file".
16 Scene creation still requires the use of a text or graphical editor,
17 or translation from some external CAD format.
18
19 Trad interaction is broken into seven screens.
20 Each screen is accessed by pressing its associated radio
21 button along the right-hand side of the main window.
22 If trad is started with no file name, the File screen is displayed,
23 and you must pick a valid rad input file before any other screen may
24 be accessed.
25 If a name is given for a file that doesn't exist, trad goes to the
26 Scene screen and prompts you to enter the names of one or more
27 Radiance scene description files.
28 If a rad input file exists already, trad determines if there are
29 renderings still to be done or if everything is finished.
30 If there is still work to be done, trad opens first with the Action
31 screen.
32 If all renderings are complete and up-to-date, trad opens right to
33 Results screen.
34
35 For additional guidance on Radiance in general, consult the Radiance
36 Tutorial, Reference Manual, and man pages.
37 In particular, it is a good idea to read through the rad(1) man page
38 before using this interface.
39
40 To find out how to get more help, press the "Next" button to the
41 right.
42
43 .Trad.Help
44
45 If you have specific questions about trad, search through the
46 category and topic menus on this help window, or press and release
47 the left mouse button while holding the control key over the object of
48 curiosity in the main trad window.
49 (In general, only active windows are given help file links -- click
50 on these rather than the text labels.)
51
52 For help on the help facility itself, Control-click on the problem
53 help widget or on the window title in the upper right corner for
54 more general information.
55 (To get back to trad-specific help, press the "HELP" button in the
56 main trad window or Control-click on a trad widget.)
57
58 Once the help window has been displayed, it is usually best to
59 lower or iconify it rather than dismissing it if further help is
60 needed.
61 This way, you will not have to wait for the help file to be read in
62 all over again every time you have a question.
63
64 .Trad.Messages
65
66 Informative messages, commands executed by rad, and errors
67 appear in the message window at the bottom of the trad frame.
68 Growing the trad window means growing this message window, and
69 not much else.
70 This is not really necessary, since the window will be grown
71 automatically if the message requires it.
72
73 Serious errors will be accompanied by the sounding of the bell.
74
75 .Trad.Quit
76
77 To quit the trad application, press the "Quit" button at any time.
78 If you have made changes to the rad input variables, you will be
79 asked prior to program exit if you want to save your changes first.
80
81 Any batch process running in the background will continue to run,
82 and the associated error messages will be viewable by
83 trad later when you open the same rad input file.
84
85 .File.Intro
86
87 This button selects the trad File screen, which allows rad input
88 files to be loaded and saved, and new files to be created.
89
90 .File.Load
91
92 This button loads the selected file into trad.
93 If the current file has been changed and these changes have not been
94 saved, you will be given first the opportunity to save your changes.
95
96 The actual load operation may take several seconds or even minutes,
97 depending on the status of the rendering process.
98 This is because the rad program itself is used to interpret the
99 input file, and if there is no up-to-date octree associated with the
100 file, it is necessary to run getbbox on the entire scene
101 before the variable values can be set.
102 It is possible to eliminate this delay in future loads by going to
103 the Action screen and running oconv.
104
105 If the opened file has read-only mode set (see chmod(1)), then the
106 "Read Only" check box will be lit.
107 Unchecking this box means that it will be possible to save the file
108 later, though the actual mode on the file will not be changed until
109 it is saved.
110 Loading a writable file always clears the "Read Only" check box.
111
112 If an error is encountered while trying to load the file, a message
113 will be printed in the box at the bottom.
114
115 .File.Save
116
117 The "Save" button in the File screen saves any changes to the
118 current file.
119 This information is saved in the original file by default, but may
120 be saved in another file by entering a new name in the "File" field.
121 If this new file already exists, a dialogue box will ask if you really
122 want to overwrite it.
123 If the file name is different than the original
124 one loaded, the "Read Only" check box will be ignored.
125
126 .File.New
127
128 The "New" button clears all rad variables in preparation for
129 writing a new rad input file.
130 If the file selected already exists, a warning box will ask if you
131 really want to ignore the previous file contents.
132 If you agree, then no warning will be given when the file is later
133 overwritten.
134
135 .File.ReadOnly
136
137 The "Read Only" check box permits you to indicate that the opened
138 file should not be overwritten.
139 This box will be checked automatically if the permissions on the
140 edited file do not allow writing by the user.
141 If the box is subsequently unchecked, trad will attempt to change
142 permissions and write to the file when a save is requested.
143 If this fails, an error message will indicate the problem.
144
145 .Scene.Intro
146
147 This button selects the trad Scene screen.
148 On this screen, you may enter the octree file and the scene files
149 that go into it, as well as any mkillum or other files on which the
150 scene depends.
151 These files are generally produced by hand in a text editor or by
152 conversion from an external CAD format, such as DXF.
153 (See the Radiance Reference Manual and Radiance Tutorial for details on the
154 information contained in these files.)
155
156 To enter a file of a particular type, press the corresponding button
157 to get a dialogue box that allows you to pick existing files from any
158 directory.
159
160 Use the "Discard" button to remove one or more files from a specific
161 list.
162 The actual file is untouched.
163
164 .Scene.Octree
165
166 The "Octree" entry in the Scene screen names the octree file to be
167 compiled by oconv from the materials and scene files.
168 (See the oconv(1) man page for more details.)
169
170 If make(1) is being used to build the octree, you should leave all
171 other windows on this screen empty.
172 The octree can still be rebuilt from trad by pressing the "oconv"
173 or "Force" buttons on the Action screen, but normally it is
174 expected to be current.
175 In particular, an unsupported octree must exist before loading
176 a rad input file on which it depends.
177
178 The default octree name is the root name from the render input file
179 plus ".oct".
180 If mkillum is being used (i.e. one or more illum files is given),
181 then two additional octrees will be created, named the same except
182 for an additional "0" or "1" immediately before the file suffix
183 (normally ".oct").
184
185 To delete the named octree, and therefore force the scene to be
186 recompiled and all the pictures to be rerendered, use the "Delete"
187 button next to the octree window.
188
189 .Scene.OctDelete
190
191 The "Delete" button next to the octree window removes the named
192 octree from the filesystem, forcing the scene to be later recompiled
193 and all the pictures to be rerendered (if desired).
194 This is appropriate if you add or remove materials, scene or illum
195 files from one or more lists, or make some change to a materials file
196 that requires the octree to be rebuilt (such as adding or removing
197 individual materials).
198
199 Verification is required before the octree will be deleted.
200
201 You can achieve the same effect as manually removing the octree by
202 pressing the "Force" button on the scene compilation section
203 of the Action screen.
204 (See the "Force" topic under the "Action" help category for more
205 information.)
206
207 .Scene.Materials
208
209 Materials files generally contain Radiance material descriptions
210 only, not geometry.
211 The purpose of listing them separately is so that minor changes to
212 material parameters will not force the octree to be rebuilt,
213 incurring an additional delay that is unnecessary.
214
215 The "Materials" button is used to add materials files to the list.
216 A dialogue box appears when you press this button and allows you to
217 select files to be included.
218 Each new selection is added to the end of the materials list.
219 The default matching pattern for material files is "*.mat".
220 This may of course be reassigned within the file selection window.
221
222 The list box showing the current materials may be edited in three
223 ways besides the dialogue for adding files.
224 First, entries may be removed from the list
225 using the "Discard" button.
226 Second, entries may be moved within the box by selecting them with
227 the left mouse button and clicking the middle mouse button over the
228 entry you wish to place the selected items above.
229 If you wish to put the selected items at the very end of the list,
230 click the middle mouse button below the last entry.
231 Third, entries may be moved from other windows by
232 selecting them and pressing the middle button.
233 This works for the list boxes on this screen as well as selections
234 in other windows on the display.
235
236 The order of materials files is usually unimportant, but sometimes
237 there are definitions in later files that depend on prerequisites in
238 earlier files.
239 An example of this is a window illum source that depends on a sky
240 description file, which must appear before it.
241 The order of files shown in the list is the order they will be given
242 to oconv and therefore to the rendering programs.
243
244 .Scene.Illum
245
246 Illum files are Radiance scene descriptions that contain surfaces
247 to be converted into illum sources by mkillum(1).
248 Please consult the manual page for mkillum and understand the
249 Radiance Tutorial before using this box, since these files differ slightly
250 from standard Radiance scene descriptions.
251
252 The "Illum" button is used to add illum files to the list.
253 A dialogue box appears when you press this button and allows you to
254 select files to be included.
255 Each new selection is added to the end of the illum list.
256 The default matching pattern for material files is "*.rad".
257 This may of course be reassigned within the file selection window.
258
259 The list box showing the current illum files may be edited in three
260 ways besides the dialogue for adding files.
261 First, entries may be removed from the list
262 using the "Discard" button.
263 Second, entries may be moved within the box by selecting them with
264 the left mouse button and clicking the middle mouse button over the
265 entry you wish to place the selected items above.
266 If you wish to put the selected items at the very end of the list,
267 click the middle mouse button below the last entry.
268 Third, entries may be moved from other windows by
269 selecting them and pressing the middle button.
270 This works for the list boxes on this screen as well as selections
271 in other windows on the display.
272
273 .Scene.Scene
274
275 Scene files give the geometry and (perhaps) some of the materials
276 used in a particular Radiance model.
277 These files are given to oconv(1) in the order specified.
278 The ordering of files is usually not important, unless some later
279 files use materials or other modifiers defined in earlier files.
280
281 The "Scene" button is used to add scene files to the list.
282 A dialogue box appears when you press this button and allows you to
283 select files to be included.
284 Each new selection is added to the end of the scene list.
285 The default matching pattern for material files is "*.rad".
286 This may of course be reassigned within the file selection window.
287
288 The list box showing the current scene files may be edited in three
289 ways besides the dialogue for adding files.
290 First, entries may be removed from the list
291 using the "Discard" button.
292 Second, entries may be moved within the box by selecting them with
293 the left mouse button and clicking the middle mouse button over the
294 entry you wish to place the selected items above.
295 If you wish to put the selected items at the very end of the list,
296 click the middle mouse button below the last entry.
297 Third, entries may be moved from other windows by
298 selecting them and pressing the middle button.
299 This works for the list boxes on this screen as well as selections
300 in other windows on the display.
301
302 .Scene.Objects
303
304 Object files are files on which the given octree depends, but which
305 are not included directly on the oconv command line.
306 If any of these files is modified, then it is assumed that the
307 octree must be rebuilt.
308
309 To automatically determine which files in the working directory
310 affect the octree, press the "Auto" button just below the "Objects"
311 button.
312 Note that this will only add files to the object list.
313 If you wish to completely replace what is already there, you must
314 therefore select all the files and use the "Discard" button before
315 pressing "Auto".
316
317 .Scene.Discard
318
319 The "Discard" button removes the selected file names from a list.
320 The actual files are untouched, of course.
321 (Some care should be taken here, since there is no undo
322 function associated with this window other than reloading the
323 original information with the "Revert" button.)
324
325 .Scene.Edit
326
327 Use the "Edit" button to open a text editor on the selected file(s).
328 This is a convenient way to look at and change the contents of the
329 Radiance input files.
330
331 .Scene.Copy
332
333 The "Copy" button may be used to selectively copy the scene file
334 information from another rad input file.
335 Specifically, the variables "OCTREE, materials, illum, scene and
336 objects" will be read in to replace the current values.
337
338 All other variables will be unaffected.
339
340 .Scene.Revert
341
342 The "Revert" button is a convenient way to revert to the original
343 values in the rad input file.
344 Only the variables on the Scene screen will be affected, but any changes
345 to these variables since the last save will be lost.
346
347 .Zone.Intro
348
349 This button selects the trad Zone screen.
350 On this screen, the user should enter the maximum and minimum
351 coordinates of the zone of interest for this set of renderings.
352 This zone need not correspond exactly to any interior or exterior
353 walls, as it is used primarily to set rendering parameters and
354 standard viewpoints.
355
356 An interior zone means that standard viewpoints will be selected
357 from the inside of this box.
358 An exterior zone means that standard viewpoints will be selected
359 from the outside of this box.
360 The default zone is an exterior one computed from the bounding box
361 of the entire scene.
362 (Note that this is not usually desirable.)
363
364 In addition to the ZONE variable, this screen offers the ability
365 to set four other rad variables that are generally associated with a
366 particular scene and a particular zone.
367 These are the rad DETAIL, INDIRECT, VARIABILITY and EXPOSURE
368 variables.
369 For more information on these topics, use the Topic menu or consult
370 the rad manual page.
371
372 .Zone.Type
373
374 There are two types of zones understood by rad, "Interior" and
375 "Exterior".
376 An interior zone is indicated when renderings generally take place
377 inside a specified 3-d box.
378 A typical example might be a single room or auditorium.
379 An exterior zone is indicated when renderings generally take place
380 outside a specified 3-d box, which is the focus of attention.
381 A typical example might be a building exterior or a single object,
382 such as a chair.
383
384 .Zone.Zone
385
386 A zone is specified by six real numbers, corresponding to the world
387 coordinates of the box's corners.
388 Zone boxes are always axis-aligned, therefore one need only specify
389 the minimum and maximum X, Y, and Z coordinates.
390
391 The exact values of these coordinates is not terribly important, as
392 they are only used to guide the setting of certain rendering
393 parameters and standard view positions.
394 It does not matter for instance whether the values lie on the inside
395 or the outside of walls, or if there are non-rectilinear geometries
396 defining the space perimeter.
397 In fact, the whole space may not even be aligned with the X, Y, and Z
398 axes, and a very approximate box may be given.
399 In this case, the standard views may not be very intelligent or
400 useful, but the rendering parameters will still be satisfactory so
401 long as the overall size of the given box is close to the overall
402 size of the space.
403
404 The Zone entry windows may be manipulated in the following ways.
405 Control-U clears the current window.
406 Control-V pastes the contents of the current selection at the
407 insertion point.
408 Return moves the focus to the next window in the chain.
409
410 .Zone.Detail
411
412 The "Detail" setting indicates the relative level
413 of geometric detail in this zone.
414 If the zone is empty except for a few large pieces of furniture, a
415 "Low" setting is indicated.
416 (For an exterior zone, low detail would mean that the object is
417 relatively simple.)
418 If the zone contains a usual amount of furniture and clutter, a
419 "Medium" setting is appropriate.
420 If the zone contains a great many small objects or protrusions, a
421 setting of "High" is indicated.
422
423 This variable is used by rad to set rendering parameters that are
424 affected by the sizes of objects relative to the overall size of the
425 space.
426
427 .Zone.Indirect
428
429 The "Indirect" setting indicates how important indirect illumination
430 is in this space.
431 A setting of "0" means that most light falls directly on visible
432 surfaces, and this setting can be used in most cases.
433 A setting of "1" means that most objects are not directly
434 illuminated by light sources, but receive light only after it has
435 bounced once off some other surface, such as the ceiling.
436 Likewise, a setting of "2" means that light must reflect twice off
437 other surfaces before reaching most objects of interest.
438
439 Keep in mind that the rendering calculation increases substantially
440 with each increment to this variable, so it is a good idea to use
441 the smallest reasonable value.
442
443 .Zone.Variability
444
445 The "Variability" setting gives a qualitative indication of how
446 light varies in magnitude over surfaces in this zone.
447 In a typical direct or indirect lighting situation, this variable
448 would be set to "Low", indicating that light is fairly uniform
449 throughout the space.
450 If there are some areas that are much better lit than others, such
451 as desks with powerful tasks lights in a room with dimmer ambient
452 lighting, a "Medium" setting is appropriate.
453 If there is direct sunlight entering the room, casting bright
454 patches on some surfaces and not others, then a setting of "High" is
455 indicated.
456
457 Note that this variable speaks to the magnitude of light variations
458 more than the patterns of light.
459 It may well be that the light is casting interesting patterns such
460 as scallops on the walls or something, but as long as the variations
461 in brightness are less than an order of magnitude or so, it is a low
462 variability situation.
463 The high variability
464 example given above of direct sun entering a space corresponds to a
465 a variation in brightness of about three orders of magnitude, or
466 1,000 to 1!
467
468 .Zone.Exposure
469
470 The "Exposure" setting gives the multiplier between the initial
471 radiance values at each pixel (in watts/steradian/meter^2) to the
472 display pixel values (in the range of 0-1, where 0 is black and 1 is
473 the maximum monitor output).
474 This setting also determines the average "ambient level," which is
475 an important parameter for rendering accuracy.
476
477 There are two basic ways to compute the exposure value.
478 The first is by trial and error, where the value is adjusted up and
479 down within rview using the "e = value" command.
480 Though it sounds flaky, this is the most reliable way to set the
481 exposure (and ambient level) in general lighting situations.
482
483 The second method is using a zonal cavity approximation.
484 For this, you must estimate the total light flux entering the zone
485 from light sources and windows, and the total illuminated area.
486 (This applies to interior zones, only. For exterior zones, use the
487 value suggested by gensky in its output.)
488 In addition, you must approximate the area-weighted average
489 reflectance of the illuminated surfaces.
490 The formula then for the exposure multiplier using this information
491 is: pi*tot_area*(1-avg_refl)/(2*tot_flux*avg_refl)
492 where pi is 3.1416, tot_area is given in square meters and
493 tot_flux is given in watts.
494 (Divide total lumens by 179 lumens/watt to get watts.)
495
496 The exposure value may either be given as a positive real value, or
497 as a real value preceeded by a '+' or '-' indicating a positive or
498 negative number of f-stops (powers of two) from the original value.
499
500 If no exposure is given, pfilt will automatically compute the
501 average for each image, and a default ambient level of 10 will be
502 used for exterior zones and 0.01 for interior zones.
503
504 .Zone.Copy
505
506 The "Copy" button on the Zone screen takes all values for this
507 screen from another rad input file, replacing the current values.
508 Specifically, the rad variables "ZONE, DETAIL, INDIRECT,
509 VARIABILITY and EXPOSURE" will be copied from the named file.
510
511 All other variables will be left untouched.
512
513 .Zone.Revert
514
515 The "Revert" button is a convenient way to revert to the original
516 values in the rad input file.
517 Only the variables on the Zone screen will be affected, but any changes
518 to these variables since the last save will be lost.
519
520 .Views.Intro
521
522 This button selects the trad Views screen.
523 This screen provides a means of setting the multi-valued
524 "view" variable.
525 Each view setting is listed by name, or by number if no name has
526 been assigned.
527 To add a new view, enter a unique name and specify the view
528 options,
529 then press the "Add" or "Set Default" button.
530 If a view with the same name already exists, it is unconditionally
531 overwritten.
532 To modify a particular view, simply select it, change its name
533 and/or parameters, and press the "Change" button.
534 To remove an unwanted view, select it and press the "Delete" button.
535 To undo this action, simply press the "Add" button again.
536
537 The first view in the list is the default given to rview during
538 interactive rendering, and is the first view rendered in a batch run.
539 To change the default view, select the newly desired view and press
540 the "Set Default" button.
541 This button also acts like the "Add" button inasmuch as a new view
542 may be entered and this button will add it and make it the default
543 at the same time.
544
545 The Views screen also allows the standard view up vector to be
546 changed, as well as the root picture name and the output resolution.
547
548 .Views.List
549
550 The list box on the far left of the Views screen shows the
551 currently defined view names.
552 Clicking on any of these with the left mouse button shows the view
553 parameters and allows the view to be edited.
554
555 To change the name or options, edit the "Name" or "Options"
556 entry and click on the "Change" button.
557
558 Use the "Add" button to add a new view, which may be modified from
559 an old one by changing the name and options.
560
561 Use the "Delete" button to delete the selected view from the list.
562
563 Views are listed in the order in which they appear in
564 the rad input file.
565
566 The standard view is "X" is used if no views are specified.
567
568 .Views.Name
569
570 Each view has a unique name, which may be chosen at the user's
571 discretion or taken from a list of standard views, described below.
572 An invented name should be kept as short as possible, since it is
573 added to the picture file name along with the standard ".pic" suffix.
574
575 The standard views are specified by strings of the form
576 "[Xx]?[Yy]?[Zz]?[vlah]?".
577 (That is, an optional upper or lower case X followed by an optional
578 upper or lower case Y followed by an optional upper or lower case Z
579 followed by an optional lower case V, L, A or H.)
580 The letters indicate the desired view position, where upper case "X"
581 means maximum X, lower case "y" means minimum Y and so on.
582 The final letter is the view type, where 'v' is perspective (the
583 default), 'l' is parallel, 'a' is angular fisheye, and 'h' is
584 hemispherical fisheye.
585 A perspective view from maximum X, minimum Y would be "Xy" or
586 "Xyv".
587 A parallel view from maximum Z would be "Zl".
588 If "ZONE" is an interior zone, the standard views will
589 be inside the perimeter.
590 If it is an exterior zone, the standard views will be outside.
591 Note that the standard views are best used as starting points,
592 and additional arguments may be given after the
593 identifier to modify a standard view to suit a particular model.
594
595 .Views.Options
596
597 The "Options" entry window is where the Radiance view
598 corresponding to the selected name is given.
599 If the view is one of the standard names (described in the "Views
600 Name" section), then the options are truly optional, and will
601 modify the standard view.
602 Otherwise, it is usually necessary to specify a set of options to
603 define a view.
604
605 The simplest view specification is of the form "-vf viewfile", where
606 "viewfile" is a file created with the rview "view" command, or a
607 Radiance picture.
608 This method of naming views, although convenient, is not the best
609 since it is difficult to know exactly where such a view is by
610 seeing only its file name.
611 Also, the file may change or be moved or removed, and then the view
612 may be different than expected or gone altogether.
613
614 To add view options selected from another X11 window, select the
615 text from another window in the normal fashion, use the left mouse
616 button to click on the insertion point in the options string, then
617 use Control-V to insert the text at that point.
618 For convenience, the middle mouse button has been made
619 equivalent to Control-V in this window, but it is not the normal
620 interaction mode for trad.
621
622 Consult the rpict(1) manual page for a full description of the various
623 view options, all of which begin with "-v".
624 Just briefly, the "-vt?" option sets the view type, where "?" is
625 replaced by one of the letters "v, l, a or h", corresponding to
626 perspective, parallel, angular and hemispherical fisheye, respectively.
627 The "-vp x y z" option sets the view position (eyepoint), where "x y z"
628 is replaced by the position in 3-space.
629 The "-vd xd yd zd" option sets the view direction, where "xd yd zd"
630 is a vector pointing in the desired direction.
631 (To compute this direction from a "look-at" point, simply subtract
632 the eyepoint from the look-at point. Vector normalization is
633 unnecessary.)
634 The "-vh horiz" and "-vv vert" options set the horizontal and
635 vertical view sizes, respectively.
636 For perspective views, these correspond to full camera angles in
637 degrees.
638 For parallel views (using the "-vtl" option), they correspond to
639 image plane size in world coordinates.
640 The lesser used "-vu xd yd zd", "-vs vs" and "-vl vl" options
641 will not be discussed here.
642
643 The order of the view options is irrelevant, unless the same option
644 is given twice, in which case the last one is used.
645 Trad does not check the syntax of the view options strings, so be
646 careful!
647 In particular, make sure that each option and each argument has a
648 space between it and whatever follows.
649
650 Hitting return in the "Options" window is equivalent to pressing the
651 "Add" button.
652
653 .Views.Add
654
655 The view "Add" button takes the currently defined view given by the
656 "Name" and "Options" windows and appends it to the list of views.
657 If another view by the same name exists, it is removed first.
658
659 Since the view is added to the end of the "Views" list, the "Add"
660 button is a convenient way to move views to a lower-priority
661 position.
662 Simply select the view you wish to be last and press "Add".
663
664 To add a view as the first (i.e. the default) view instead of the
665 last, use the "Set Default" button.
666
667 .Views.Change
668
669 The view "Change" button deletes the currently selected view and
670 adds the currently defined view in its place, changing the name
671 and/or view options in the process.
672
673 .Views.Delete
674
675 The view "Delete" button removes the currently selected view from
676 the view list.
677
678 To undo this action, simply press the "Add" button immediately
679 afterwards, while the deleted view is still present in the edit
680 window.
681
682 .Views.Clear
683
684 The "Clear" button simply clears the "Name" and "Options" windows
685 for the convenience of entering a new view.
686 It has no effect on the rad input variables.
687
688 Note that Control-U will always clear an entry box whose cursor is
689 active.
690
691 .Views.Default
692
693 The "Set Default" button may be used to make the selected view the
694 default view for rendering.
695 This simply moves the view to the top of the list in the rad input file.
696 The default view will be the one normally rendered by rview when rad
697 is started interactively, and is the first view rendered in a batch
698 process.
699
700 A new view may be added as the default view by pressing the "Set
701 Default" button rather than the "Add" button.
702 It is never necessary to press both.
703
704 If the selected view is already the default, this button will be
705 disabled and will read "Is Default" instead of "Set Default".
706
707 .Views.Up
708
709 The standard view up vector may be set to the positive X axis (+X),
710 the positive Y axis (+Y), the positive Z axis (+Z), the negative
711 X axis (-X), the negative Y axis (-Y), or the negative Z axis (-Z).
712
713 This setting may always be overriden by the "-vu xd yd zd" option,
714 and will be altered for a particular view if it happens to be
715 parallel to the view direction.
716
717 .Views.Picture
718
719 The root picture file name is given in the "Picture" entry window.
720 To this will be added an underscore, followed by the name of
721 the particular view being rendered, followed by the ".pic" suffix.
722
723 To render pictures into a different directory than the one
724 containing the rad input file, simply precede the file name by a
725 relative or absolute directory.
726 (Do not use the tilde shorthand for home directories,
727 as it is not guaranteed to work on all systems.)
728
729 The default picture name is the root name of the rad input file.
730
731 .Views.Resolution
732
733 The final picture resolution is set in the "Resolution" entry
734 window.
735 The first entry is the X resolution (in pixels), and the second
736 (optional) entry is the Y resolution.
737 If there is only one entry, the maximum X and Y resolution will be
738 equal.
739 If a third entry is given, it is taken as the aspect ratio of the
740 destination pixels.
741 A number greater than one means that the pixels on the destination
742 device are taller than they are wide (and therefore there are more
743 of them horizontally than vertically spanning a like distance), and
744 a number less than one means the opposite.
745 An aspect ratio of zero means that the exact given X and Y
746 dimensions are to be honored, whatever the resulting pixel ratio.
747 Normally, either the X or the Y resolution is reduced as necessary
748 to maintain a specific pixel aspect ratio (1 by default).
749
750 The default value for this variable is "512".
751
752 .Views.Copy
753
754 The "Copy" button in the Views screen permits those variables
755 represented on this screen to be copied from another rad input file.
756 Specifically, the affected variables are "view, UP, PICTURE, and
757 RESOLUTION".
758
759 The original values will be lost, and all other variables will be
760 untouched.
761
762 .Views.Revert
763
764 The "Revert" button is a convenient way to revert to the original
765 values in the rad input file.
766 Only the variables on the Views screen will be affected, but any changes
767 to these variables since the last save will be lost.
768
769 .Options.Intro
770
771 This button selects the trad Options screen.
772 This screen allows the setting of various options for
773 controlling the rendering process.
774 The most general option is rendering "Quality", which determines the
775 overall accuracy and beauty of the pictures produced.
776 A separate "Penumbras" option indicates the importance of soft
777 shadows in this scene.
778 The "Ambfile" variable allows you to specify a file for sharing
779 ambient files between runs, and it is recommended that you set
780 this variable for high quality renderings.
781 The "Optfile" variable allows you to specify a separate file for
782 storing rendering options, which reduces the size of the command
783 line and makes it easier to run programs such as rtrace(1).
784 The "Report" variable may be used to specify a time interval (in
785 minutes) between progress reports.
786
787 Other windows allow the user to customize the options to oconv(1),
788 mkillum(1), rview(1) and rpict(1), and pfilt(1).
789
790 .Options.Quality
791
792 The "Quality" setting affects the overall accuracy and beauty of the
793 renderings produced.
794
795 A "Low" setting is appropriate for quick checks of scene geometry and
796 crude lighting studies.
797 No interreflection calculation will take place, regardless of the
798 setting of the "INDIRECT" variable, and other options are tuned for
799 speed over accuracy.
800 The computed picture size will exactly equal the final picture
801 size, thus some aliasing may be apparent.
802
803 A "Medium" quality setting is most often used for draft renderings, as
804 it provides a good balance between rendering time and accuracy.
805 The number of interreflections calculated will be equal to the
806 setting of the "INDIRECT" variable.
807 The computed picture size will be twice the final size, for a modest
808 degree of anti-aliasing.
809
810 A "High" quality setting is usually reserved for final renderings.
811 The number of interreflections computed will equal the value of the
812 "INDIRECT" variable plus one, to guarantee accuracy.
813 The computed picture size will be three times the final size, so
814 aliasing artifacts should be negligible.
815
816 When increasing the value of the "Quality" setting, it is usually a
817 good idea to delete the old "Ambfile", if there is one.
818 (See the "AmbDelete" topic under the current help category for
819 details.)
820
821 .Options.Penumbras
822
823 The "Penumbras" setting determines whether or not Radiance will
824 make a special effort to generate soft shadows from area light sources.
825 Since this is a potentially expensive calculation, penumbras should
826 only be switched "On" when they are really needed.
827
828 Leaving this setting "Off" does not mean that area light sources
829 will be treated as points.
830 It only means that some accuracy and possibly some smoothness
831 will be traded for speed in the shadow calculations.
832
833 .Options.Ambfile
834
835 The "Ambfile" is the file used to store Radiance ambient values for
836 later reuse in other renderings.
837 This can greatly reduce the time required to generate multiple
838 views, as well as improve the quality of a single view whenever
839 interreflections are computed.
840
841 It is strongly recommended that the user set this variable, especially
842 when the "QUALITY" variable is set to "High".
843 The usual convention is to use the root name of the rad input file,
844 followed with the ".amb" suffix.
845 It is generally not a good idea to share ambient files between
846 different zones, as the placement and accuracy of these values will
847 vary according to the location and characteristics of each zone.
848
849 .Options.AmbDelete
850
851 The "Delete" button next to the "Ambfile" window on the Options
852 screens allows you to remove the named ambient file.
853 This is usually done when a change to one or more rad variables
854 casts doubt on the accuracy of the values stored in this file.
855 In particular, increases in the variables, "DETAIL, INDIRECT,
856 VARIABILITY, EXPOSURE or QUALITY" generally invalidate this file.
857
858 If the ambient file is not empty, you will be asked to verify this
859 operation since the values may represent a significant computational
860 effort.
861
862 .Options.Optfile
863
864 The "Optfile" setting assigns a file to hold rendering options,
865 which may be a convenience when these options are reused for
866 rtrace(1) or rpiece(1), or manual invocations of rview or rpict.
867 Using an options file also reduces the size of the command line,
868 making it a little easier on the eye.
869
870 To assure that the "Optfile" contents are up-to-date, you should press
871 the "oconv" or "Script" button on the Action screen.
872
873 .Options.Report
874
875 The "Report" setting indicates the time interval (in minutes)
876 between rpict progress reports.
877 Normally, rpict runs silently, but it is often nice to know how far
878 a given rendering has progressed.
879 Normally, progress reports and errors during batch renderings
880 are sent to the error file given by the root of the rad input
881 file name followed by the ".err" suffix.
882 (See the "Errors" topic under the "Action" screen category.)
883 If you wish these reports and errors to be directed to a different
884 file, follow the time interval by a space and a file name.
885
886 No setting on this variable means do not report rendering progress.
887 A zero setting means the same thing, and may be used when a
888 separate error file is desired but progress reports are not.
889
890 .Options.Oconv
891
892 The "oconv opts" window may be used to specify any additional
893 options to the oconv(1) command used to compile the scene
894 description.
895
896 In particular, the "-f" option for creating a "frozen" octree may
897 speed rendering start-up substantially, although it makes it
898 impossible to change even material properties without
899 recompiling the scene again.
900 (The "-f" option is technically incompatible with naming
901 "materials" files on the Scene screen.)
902
903 If oconv generates a "set overflow" error, it may mean that the "-r
904 res" option is needed to increase the octree resolution.
905 See the oconv(1) man page for details.
906
907 The "-i octree" option should be used with extreme caution, as incremental
908 building of octrees is not very well supported by rad.
909 You may do it this way if you specify the input octree as one of the
910 "Objects" files on the Scene screen, but it is preferable to use the
911 UNIX make(1) utility to incrementally build the octree instead, and
912 indicate this by not specifying any illum or scene files.
913
914 .Options.Mkillum
915
916 The "mkillum opts" window may be used to specify options to the
917 mkillum(1) command, whose options are actually passed to rtrace(1).
918 These options apply only if there are one or more "Illum" files
919 named on the Scene screen.
920
921 It is very important to set mkillum options sensibly,
922 since rad does not have the intelligence to do it for you.
923
924 .Options.Render
925
926 The "render opts" window is used to specify additional options to
927 the rview(1) and rpict(1) rendering programs.
928 Most of the important parameters are computed by rad, so this
929 window is usually used to override specific parameters or to give
930 additional information, such as which materials to exclude from the
931 interreflection calculation.
932
933 .Options.Pfilt
934
935 The "pfilt opts" window is used to specify additional options to
936 the pfilt(1) picture filtering program.
937
938 Note that the "-e expval", "-x xres" and "-y yres" options are
939 already dictated by the settings of the "EXPOSURE" and "RESOLUTION"
940 variables, and should therefore be used with caution.
941
942 Also note that the setting of some pfilt options require a
943 two-pass filtering process, rather than the default single pass.
944 If no "EXPOSURE" setting is given, this is not a problem, but if a
945 value for the "EXPOSURE" variable is set as recommended, then it is
946 necessary to manually specify the "-2" option to pfilt, followed by
947 an exposure that undoes the "EXPOSURE" setting.
948 An equivalent workaround is to unset the EXPOSURE variable and
949 manually set the render option "-av V V V", where "V" is equal to
950 0.5/old_EXPOSURE.
951
952 .Options.Copy
953
954 The "Copy" button in the Options screen permits those variables
955 represented on this screen to be copied from another rad input file.
956 Specifically, the affected variables are "QUALITY, PENUMBRAS,
957 AMBFILE, OPTFILE, REPORT, oconv, mkillum, render and pfilt".
958
959 The original values will be lost, and all other variables will be
960 untouched.
961
962 .Options.Revert
963
964 The "Revert" button is a convenient way to revert to the original values
965 in the rad input file.
966 Only the variables on the Options screen will be affected, but any changes
967 to these variables since the last save will be lost.
968
969 .Action.Intro
970
971 This button selects the trad Action screen.
972 This screen is where the actual Radiance programs are
973 run, usually via rad(1).
974 The top row of buttons is used to update the octree following a
975 change to one or more input files.
976 The "rview" button starts an interactive rendering in the
977 foreground.
978 The next set of buttons provides for the control of a batch
979 rendering process, taking place in the background.
980 Finally, the bottom set of buttons allows you to preview what would
981 happen during a batch rendering, or (equivalently) make a script of
982 UNIX commands for later execution.
983
984 When the Action screen is first brought up, the message window
985 displays the current status of any batch rendering process.
986 The status must either be "No batch rendering in progress," which
987 means that as far as trad can tell a batch rendering was never
988 started, "Batch rendering stopped," meaning that there is no current
989 process but at least some views have not been rendered or are
990 out-of-date, or "Batch rendering finished," meaning that everything
991 is done.
992
993 .Action.Oconv
994
995 The "oconv" button on the Action screen may be used to manually
996 compile the scene description and bring the octree up to date.
997 It is normally not necessary to use this button, since the octree
998 will be rebuilt if appropriate prior to rendering.
999 However, if the octree is maintained by make(1) rather than rad, or
1000 the octree was never created and you want trad to start a little
1001 faster next time, or you just need the octree for some reason other
1002 than rendering, this is the button for you.
1003
1004 If you have made changes to the rad variables or the Radiance
1005 material files that invalidate the current octree or renderings but
1006 would not automatically rebuild the octree because the scene files
1007 themselves were not changed, it may be wise to use the "Force"
1008 button.
1009 In contrast, if you have made some insignificant changes to the
1010 scene files that should not make any difference to the octree or the
1011 renderings, you may want to use the "Touch" button.
1012
1013 Pressing the "oconv" button also updates the contents of the
1014 "Optfile" if one is given on the Options screen.
1015 This may be useful for computing rendering parameters for rtrace(1)
1016 or rpiece(1).
1017
1018 .Action.Force
1019
1020 The "Force" button on the Action screen
1021 causes the octree to be unconditionally rebuilt,
1022 by removing it first.
1023 This will also require all pictures to be rerendered, so only use
1024 this button if it is really necessary, i.e. if you have made
1025 some important changes to the rad
1026 variables on the Scene, Zone or Options screens, but have not
1027 changed any scene file on which the octree depends.
1028
1029 If the octree itself should not be affected by these changes, only
1030 the renderings, you may delete the faulty picture files instead from
1031 the Results screen and the ambient file (if it exists) from the
1032 Options screen.
1033
1034 .Action.Touch
1035
1036 The "Touch" button on the Action screen
1037 should be used when some insignificant change has
1038 been made to the Radiance input files, which might otherwise cause
1039 the octree to be rebuilt and the picture files to be rerendered.
1040
1041 Care should be exercised in using this button since you may have
1042 made a change that really does affect the octree in an important
1043 way.
1044 Even something as seemingly trivial as deleting an unused material
1045 will cause an unfrozen octree to become invalid and unusable.
1046
1047 Therefore, if you know the octree should be rebuilt, but you do not
1048 want to cause any of the currently rendered pictures to be redone,
1049 press the "oconv" button to bring the octree up to date, followed
1050 by the "Touch" button.
1051 (This will still cause the ambient file to be removed,
1052 unfortunately.)
1053
1054 .Action.Rview
1055
1056 The "rview" button on the Action screen starts an interactive
1057 rendering for the selected view, indicated by the menu button
1058 just to the right.
1059 Other views may be accessed within rview using the "L name"
1060 command, and new views can be added with the "V name"
1061 command.
1062 (See the rview(1) man page and the "View" topic in the current
1063 help category for more information.)
1064
1065 If the octree is out-of-date, it will be rebuilt before rendering
1066 begins.
1067
1068 .Action.View
1069
1070 The Action screen contains two menus for selecting views.
1071 The top menu, next to the "rview" button, sets the view to start
1072 with in rview, and is selected from the current view list.
1073 The second view menu, next to the "Start" button for batch
1074 rendering, selects the view or views to render in batch mode.
1075 If the special entry "ALL" is selected, then every view in the
1076 current list will be rendered if it hasn't been already.
1077
1078 The batch rendering view menu also selects the view or views
1079 to use in producing a script during a dry run.
1080
1081 .Action.Start
1082
1083 The "Start" button for batch rendering on the Action screen
1084 initiates a rad rendering process in the background using the
1085 selected view or views shown on the menu button to the right.
1086
1087 If any of the rad variables have been changed since the
1088 file was last saved, you will first be asked if you wish to save
1089 your changes before starting a background process.
1090 If you discard these changes, then the batch rendering will be
1091 conducted using the previously saved values.
1092
1093 Once a background process is going, the "Start" button is
1094 disabled, and rendering progress can be monitored by checking
1095 the error file periodically.
1096 (This file is named by the root of the rad input file followed by
1097 ".err".)
1098 When a batch process is started or already running, this button
1099 will be disabled.
1100
1101 The background process can be killed during this or later
1102 invocations of trad using the "Kill" button.
1103
1104 .Action.Kill
1105
1106 The batch rendering "Kill" button kills the
1107 background process started earlier with the "Start" button.
1108 The rad process id is taken from the first line of the error file,
1109 and this process and all its children are killed when the
1110 button is pressed.
1111
1112 So long as there is an ambient file specified in the Options
1113 screen, no data is lost by killing and restarting a batch
1114 rendering, though some new startup costs will be incurred.
1115
1116 The "Kill" button is disabled if no running batch process is
1117 detected.
1118
1119 .Action.CheckErr
1120
1121 Pressing the "Check errors" button
1122 displays the contents of the batch rendering error file, named
1123 by the root of the current rad input file followed by the ".err"
1124 suffix.
1125 This file will contain the command lines executed by rad so far,
1126 and may or may not contain additional progress reports from
1127 rpict, depending on the initial setting of the "REPORT" variable.
1128
1129 If no error file exists, this button will be disabled.
1130
1131 .Action.Script
1132
1133 The dry run "Script" button runs rad with the
1134 "-n" option so that you may see the commands that would be
1135 executed during a batch run without actually executing them.
1136 If a file is named in the window next to this button, the output
1137 will simply be written to that file.
1138 If no file is named, a temporary file is created and an editor
1139 window is opened on it.
1140
1141 Producing a dry run also writes the "Optfile" if one is specified
1142 on the Options screen.
1143 This may be useful for computing rendering parameters for rtrace(1)
1144 or rpiece(1).
1145
1146 The view or views are selected by the same menu used for
1147 batch rendering.
1148 (See the "View" topic under the current help category for more
1149 information.)
1150
1151 .Action.Edit
1152
1153 The dry run "Edit" button is used to edit the named script file
1154 created by pressing the "Script" button.
1155 If no file is named, this button is ineffective.
1156
1157 .Action.Delete
1158
1159 The "Delete" button removes the named script file, created by the
1160 "Script" button.
1161 If no file is named, or the named file does not exist, this button has
1162 no effect.
1163
1164 .Results.Intro
1165
1166 This button selects the trad Results screen.
1167 This screen permits rendered pictures to be displayed,
1168 converted to other image formats, and printed.
1169 Only finished pictures may be converted or printed, but
1170 incomplete pictures (i.e. aborted renderings or renderings in
1171 progress) may be displayed interactively.
1172
1173 The left-hand window shows a list of completed views, and the
1174 right-hand window shows views that have been started but not
1175 finished.
1176 Note that other views may not even be started, thus may not
1177 appear in either list.
1178 Also, just because a view appears on the Results screen, it does
1179 not mean that view is up-to-date with respect to the Radiance
1180 input files.
1181 (The best way currently to tell which pictures are out-of-date
1182 is to press the "Script" button on the Action screen and examine
1183 the output.)
1184
1185 .Results.Finished
1186
1187 The "Finished views" list box on the Results screen shows those
1188 renderings which have completed, whether or not they are up-to-date
1189 with respect to the Radiance input files.
1190 Select pictures in this box for display, conversion to other image
1191 formats, and/or printing.
1192 Selected pictures may also be deleted with the "Delete" button.
1193
1194 To select one or more pictures from this box, click the left mouse
1195 button on a view name, and drag it up or down to select multiple
1196 views.
1197 Shift-click also allows views to be added to the selection.
1198
1199 .Results.Unfinished
1200
1201 The "Unfinished views" list box on the Results screen shows those
1202 renderings which have not yet completed.
1203 These partial pictures may or may not be out-of-date
1204 with respect to the Radiance input files.
1205 Select pictures in this box for display or deletion.
1206 It is not possible to convert or print an unfinished picture.
1207
1208 To select one or more pictures from this box, click the left mouse
1209 button on a view name, and drag it up or down to select multiple
1210 views.
1211 Shift-click also allows views to be added to the selection.
1212
1213 .Results.Rescan
1214
1215 The "Rescan" button on the Results screen is used to update the
1216 finished and unfinished view lists, in case one or more pictures
1217 has completed since the Results screen was brought up.
1218
1219 .Results.Delete
1220
1221 The "Delete" button on the Results screen is used to remove the
1222 selected picture files from the filesystem.
1223 Verification is required before any action is taken.
1224
1225 .Results.Display
1226
1227 The "Display" button on the Results screen may be used to display
1228 the selected images using ximage(1) or any other Radiance picture
1229 display program.
1230
1231 The current display command is shown in the adjacent command window,
1232 and may be customized if necessary.
1233 (See the "DispCommand" topic in the current help category for
1234 details.)
1235
1236 .Results.DispCommand
1237
1238 The current display command in the Results screen determines how
1239 finished and unfinished Radiance pictures will be displayed.
1240 This command contains two variable fields.
1241 The first field is a signed integer, indicated by the "%+d" format.
1242 The second field is a string, indicated by the "%s" format.
1243 Both fields must appear in any display command used, and must be in
1244 this order on the command line.
1245 The first field is used to adjust the exposure of an unfinished
1246 picture, and the second field is the file name.
1247 The rest of the command is arbitrary, so long as it is understood by
1248 the system.
1249
1250 The default command is "ximage -e %+d %s >& /dev/null &", which
1251 executes ximage in the background and sends any output (including
1252 error messages) to the null device.
1253 If you don't wish ximage to run in the background, you may remove
1254 the last part of the command (" >& /dev/null &").
1255
1256 .Results.Convert
1257
1258 The "Convert" button on the Results screen converts the selected
1259 pictures to the format indicated on the menu button to the right.
1260 (See the "ConvType" topic under the current help category for
1261 details.)
1262
1263 Each finished picture is converted to the selected format and given
1264 the name indicated by the adjacent window labeled "File".
1265 (See the "ConvFile" topic under the current help category for
1266 details.)
1267
1268 .Results.ConvType
1269
1270 The image type button on the Results screen determines the
1271 destination format for converted Radiance pictures.
1272 You may choose from the list that pops up when you press this
1273 button.
1274 Often, a given format may have more than one subtype.
1275 In general, 8-bit means 8-bit color with a lookup table,
1276 B&W means 8-bit greyscale with no lookup, and 24-bit means 24-bit
1277 true color.
1278
1279 The file suffix is determined by the basic conversion type, but may
1280 be changed along with the rest of the name by editing the file name
1281 window.
1282 (See the "ConvFile" topic under the current help category for
1283 details.)
1284
1285 .Results.ConvFile
1286
1287 The image conversion file name window on the Results screen should contain
1288 a single "%s" format field, which will be replaced by the view name
1289 being converted.
1290
1291 The default name is the same as the value of the rad "PICTURE"
1292 variable, followed by a suffix appropriate to the selected file type.
1293
1294 .Results.Print
1295
1296 The "Print" button on the Results screen executes the given
1297 system command to print one copy each of the selected picture(s).
1298 This button does not work on unfinished pictures.
1299
1300 The actual command used for printing may be edited in the adjacent
1301 window.
1302 (See the "PrintCommand" topic under the current help category for
1303 details.)
1304
1305 .Results.PrintCommand
1306
1307 The print command window on the Results screen contains the system
1308 command to use in printing out finished Radiance pictures.
1309 The "%s" format field, which must appear somewhere in the command,
1310 is replaced by the selected Radiance picture file name(s).
1311
1312 The default command is "ra_ps %s | lpr", which converts the Radiance
1313 picture to a black and white PostScript file and sends it to the lpr
1314 print spooler.
1315 If your printer does not understand PostScript, or your system does
1316 not support lpr, this command must obviously be changed.
