root/radiance/src/util/tclIndex
Revision: 3.1
Committed: Sat Feb 22 02:07:30 2003 UTC (22 years, 7 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad3R7P2, rad3R7P1, rad6R0, rad4R1, rad4R0, rad3R5, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad4R2P2, HEAD
# User Rev Content
1 greg 3.1 # Tcl autoload index file, version 2.0
2     # This file is generated by the "auto_mkindex" command
3     # and sourced to set up indexing information for one or
4     # more commands. Typically each line is a command that
5     # sets an element in the auto_index array, where the
6     # element name is the name of a command and the value is
7     # a script that loads the command.
8
9     set auto_index(make_script) "source $dir/do_action.tcl"
10     set auto_index(make_oct) "source $dir/do_action.tcl"
11     set auto_index(run_rad) "source $dir/do_action.tcl"
12     set auto_index(run_batch) "source $dir/do_action.tcl"
13     set auto_index(kill_batch) "source $dir/do_action.tcl"
14     set auto_index(make_vmenus) "source $dir/do_action.tcl"
15     set auto_index(do_action) "source $dir/do_action.tcl"
16     set auto_index(amb_delete) "source $dir/do_options.tcl"
17     set auto_index(copyopts) "source $dir/do_options.tcl"
18     set auto_index(do_options) "source $dir/do_options.tcl"
19     set auto_index(newfent) "source $dir/do_scene.tcl"
20     set auto_index(lbgetf) "source $dir/do_scene.tcl"
21     set auto_index(oct_delete) "source $dir/do_scene.tcl"
22     set auto_index(getdepend) "source $dir/do_scene.tcl"
23     set auto_index(vwselfil) "source $dir/do_scene.tcl"
24     set auto_index(movselfil) "source $dir/do_scene.tcl"
25     set auto_index(delselfil) "source $dir/do_scene.tcl"
26     set auto_index(copyscene) "source $dir/do_scene.tcl"
27     set auto_index(do_scene) "source $dir/do_scene.tcl"
28     set auto_index(zonechange) "source $dir/do_zone.tcl"
29     set auto_index(indscale) "source $dir/do_zone.tcl"
30     set auto_index(copyzone) "source $dir/do_zone.tcl"
31     set auto_index(do_zone) "source $dir/do_zone.tcl"
32     set auto_index(preen) "source $dir/do_file.tcl"
33     set auto_index(setradvar) "source $dir/do_file.tcl"
34     set auto_index(putradvar) "source $dir/do_file.tcl"
35     set auto_index(load_vars) "source $dir/do_file.tcl"
36     set auto_index(save_vars) "source $dir/do_file.tcl"
37     set auto_index(newload) "source $dir/do_file.tcl"
38     set auto_index(newsave) "source $dir/do_file.tcl"
39     set auto_index(newnew) "source $dir/do_file.tcl"
40     set auto_index(do_file) "source $dir/do_file.tcl"
41     set auto_index(testappend) "source $dir/do_results.tcl"
42     set auto_index(list_views) "source $dir/do_results.tcl"
43     set auto_index(delpic) "source $dir/do_results.tcl"
44     set auto_index(get_selpics) "source $dir/do_results.tcl"
45     set auto_index(dsppic) "source $dir/do_results.tcl"
46     set auto_index(cnvpic) "source $dir/do_results.tcl"
47     set auto_index(prtpic) "source $dir/do_results.tcl"
48     set auto_index(do_results) "source $dir/do_results.tcl"
49     set auto_index(viewchange) "source $dir/do_views.tcl"
50     set auto_index(vnchange) "source $dir/do_views.tcl"
51     set auto_index(selview) "source $dir/do_views.tcl"
52     set auto_index(addview) "source $dir/do_views.tcl"
53     set auto_index(delview) "source $dir/do_views.tcl"
54     set auto_index(copyviews) "source $dir/do_views.tcl"
55     set auto_index(do_views) "source $dir/do_views.tcl"
56     set auto_index(getfile) "source $dir/getfile.tcl"
57     set auto_index(update_dir) "source $dir/getfile.tcl"
58     set auto_index(set_curfile) "source $dir/getfile.tcl"
59     set auto_index(chk_select) "source $dir/getfile.tcl"
60     set auto_index(beep) "source $dir/util.tcl"
61     set auto_index(view_txt) "source $dir/util.tcl"
62     set auto_index(cardval) "source $dir/util.tcl"
63     set auto_index(writevars) "source $dir/util.tcl"
64     set auto_index(helplink) "source $dir/gethelp.tcl"
65     set auto_index(gethelp) "source $dir/gethelp.tcl"
66     set auto_index(helpopen) "source $dir/gethelp.tcl"
67     set auto_index(helpgoto) "source $dir/gethelp.tcl"
68     set auto_index(helpupdate) "source $dir/gethelp.tcl"
69     set auto_index(helphist) "source $dir/gethelp.tcl"
70     set auto_index(helpsearch) "source $dir/gethelp.tcl"
