root/radiance/src/util/t16anim.c
Revision: 1.2
Committed: Sat Feb 22 02:07:30 2003 UTC (22 years, 8 months ago) by greg
Changes since 1.1: +1 -4 lines
5 * Send Targa 16-bit files to PC animation system.
6 *
7 * 6/20/88
8 */
9
10 #include <stdio.h>
11
12 #include "client/clnt.h"
13
14 #include "targa.h"
15
16 #define goodpic(h) (((h)->dataType==IM_RGB || (h)->dataType==IM_CRGB) \
17 && (h)->dataBits==16)
18
19 FILE *popen();
20
21 char *pcom = NULL; /* uncompress command */
22
23
24 main(argc, argv)
25 int argc;
26 char **argv;
27 {
28 int startrec = 0;
29 char *progname;
30 int prognum = PCPROGRAM;
31 /* initialize */
32 for (progname = *argv++; --argc; argv++)
33 if (!strcmp(*argv, "-p") && argv[1]) {
34 prognum = atoi(*++argv); argc--;
35 } else if (!strcmp(*argv, "-u") && argv[1]) {
36 pcom = *++argv; argc--;
37 } else if (!strcmp(*argv, "-r") && argv[1]) {
38 startrec = atoi(*++argv); argc--;
39 } else
40 break;
41 if (!argc) {
42 fputs("Usage: ", stderr);
43 fputs(progname, stderr);
44 fputs(" [-p prognum] [-u uncompress] [-r record] hostname [frame..]\n",
45 stderr);
46 exit(1);
47 }
48 scry_open(*argv++, prognum); argc--;
49 scry_get_info(2) ;
50 scry_set_compress(NONE);
51 if (startrec > 0)
52 scry_init_record(startrec, argc>0?argc:1);
53 else
54 scry_init_record(PREVIEW,0);
55 /* send frames */
56 if (argc <= 0)
57 sendframe(NULL);
58 else
59 for ( ; argc > 0; argc--, argv++)
60 sendframe(*argv);
61 /* clean up */
62 scry_close();
63 exit(0);
64 }
65
66
67 sendframe(file) /* convert and send a frame */
68 char *file;
69 {
70 static struct hdStruct head;
71 char command[128];
72 register FILE *fp;
73 register int i, j;
74 register int c;
75 /* DAVIDR */
76 unsigned char *image_read,*newimage,*compdata ;
77 int new_ht, new_wd, new_depth ;
78 /* end DAVIDR */
79 /* open file */
80 if (file == NULL) {
81 if (pcom != NULL)
82 fp = popen(pcom, "r");
83 else
84 fp = stdin;
85 file = "<stdin>";
86 } else {
87 if (pcom != NULL) {
88 sprintf(command, "( %s ) < %s", pcom, file);
89 fp = popen(command, "r");
90 } else
91 fp = fopen(file, "r");
92 }
93 if (fp == NULL) {
94 perror(file);
95 exit(1);
96 }
97 /* check format */
98 if (getthead(&head, NULL, fp) == -1 || !goodpic(&head))
99 goto badfmt;
100 /* DAVIDR */
101 image_read = (unsigned char *) malloc((head.dataBits)/8 * head.x * head.y) ;
102 /* get frame */
103 for (i = 0 ; i < head.y ; i++)
104 fread(&(image_read[(head.y-i-1)*head.x*(head.dataBits/8)]),(head.dataBits)/8,head.x,fp) ;
105 newimage = NULL ;
106 /* convert to server size and visual */
107 scry_conv_vis (image_read,&newimage,head.y,head.x,&new_ht,&new_wd,(head.dataBits)/8,&new_depth) ;
108 free (image_read) ;
109 compdata = NULL ;
110 /* compress if necessary */
111 scry_compress(newimage,&compdata,new_ht,new_wd,new_depth) ;
112 /* send frame */
113 scry_send_frame(compdata);
114 free(newimage) ;
115 free(compdata) ;
116 /* end DAVIDR */
117 /* close file */
118 if (pcom != NULL)
119 pclose(fp);
120 else
121 fclose(fp);
122 return;
123 badfmt:
124 fputs(file, stderr);
125 fputs(": wrong targa format\n", stderr);
126 exit(1);
127 readerr:
128 fputs(file, stderr);
129 fputs(": read error\n", stderr);
130 exit(1);
131 }
132
133
134 getthead(hp, ip, fp) /* read header from input */
135 struct hdStruct *hp;
136 char *ip;
137 register FILE *fp;
138 {
139 int nidbytes;
140
141 if ((nidbytes = getc(fp)) == EOF)
142 return(-1);
143 hp->mapType = getc(fp);
144 hp->dataType = getc(fp);
145 hp->mapOrig = getint2(fp);
146 hp->mapLength = getint2(fp);
147 hp->CMapBits = getc(fp);
148 hp->XOffset = getint2(fp);
149 hp->YOffset = getint2(fp);
150 hp->x = getint2(fp);
151 hp->y = getint2(fp);
152 hp->dataBits = getc(fp);
153 hp->imType = getc(fp);
154
155 if (ip != NULL)
156 if (nidbytes)
157 fread(ip, nidbytes, 1, fp);
158 else
159 *ip = '\0';
160 else if (nidbytes)
161 fseek(fp, (long)nidbytes, 1);
162
163 return(feof(fp) || ferror(fp) ? -1 : 0);
164 }
165
166
167
168
169 int
170 getint2(fp) /* get a 2-byte positive integer */
171 register FILE *fp;
172 {
173 register int b1, b2;
174
175 if ((b1 = getc(fp)) == EOF || (b2 = getc(fp)) == EOF) {
176 fputs("Unexpected EOF\n", stderr);
177 exit(1);
178 }
179 return(b1 | b2<<8);
180 }
181
182
