root/radiance/src/util/rttree_reduce.c
Tue Mar 18 01:33:07 2014 UTC (11 years, 7 months ago) by greg
Changes since 2.9: +27 -4 lines
Added protection against negative and NaN values on input
Mon Mar 17 01:59:48 2014 UTC (11 years, 7 months ago) by greg
Changes since 2.8: +5 -2 lines
Added call to flockfile() to reduce i/o overhead
Thu Oct 3 03:36:11 2013 UTC (12 years ago) by greg
Changes since 2.7: +11 -10 lines
Fixed reciprocity averaging error discovered by Zack Rogers
Sun Mar 25 15:23:55 2012 UTC (13 years, 6 months ago) by greg
Added missing option from usage line
Mon Nov 21 20:07:50 2011 UTC (13 years, 10 months ago) by greg
Changes since 2.5: +35 -1 lines
Added reciprocity averaging
Sat Aug 20 02:46:13 2011 UTC (14 years, 2 months ago) by greg
Changes since 2.4: +4 -4 lines
Fixed bug in data ordering
Fri Jun 3 18:12:58 2011 UTC (14 years, 4 months ago) by greg
Changes since 2.3: +4 -4 lines
Fixed bugs in variable-resolution isotropic BSDFs
Wed Jun 1 16:51:03 2011 UTC (14 years, 4 months ago) by greg
Changes since 2.2: +14 -11 lines
Improved percentile thresholding measure
Tue May 31 20:50:26 2011 UTC (14 years, 4 months ago) by greg
Changes since 2.1: +50 -9 lines
Diff to previous 2.1
Thu May 26 15:32:02 2011 UTC (14 years, 4 months ago) by greg
Initial rttree_reduce implementation
