root/radiance/src/util/rtpict.pl
Revision: 2.33
Committed: Sat Sep 13 17:54:39 2025 UTC (8 weeks ago) by greg
Changes since 2.32: +8 -3 lines
fix(rtpict): Further fixes for running under Windows with -o* option
1 #!/usr/bin/perl -w
2 # RCSid $Id: rtpict.pl,v 2.32 2025/09/13 16:52:28 greg Exp $
3 #
4 # Run rtrace in parallel mode to simulate rpict -n option
5 # May also be used to render layered images with -o* option
6 #
7 # G. Ward
8 #
9 use strict;
10 my $windoz = ($^O eq "MSWin32" or $^O eq "MSWin64");
11 # we'll run rpict if no -n or -o* option
12 my $nprocs = 1;
13 # rtrace options and the associated number of arguments
14 my %rtraceC = ('-dt',1, '-dc',1, '-dj',1, '-ds',1, '-dr',1, '-dp',1,
15 '-ss',1, '-st',1, '-e',1, '-am',1, '-P',1, '-PP',1,
16 '-ab',1, '-af',1, '-ai',1, '-aI',1, '-ae',1, '-aE',1,
17 '-av',3, '-aw',1, '-aa',1, '-ar',1, '-ad',1, '-as',1,
18 '-me',3, '-ma',3, '-mg',1, '-ms',1, '-lr',1, '-lw',1,
19 '-ap',2, '-am',1, '-ac',1, '-aC',1,
20 '-cs',1, '-cw',2, '-pc',8, '-pXYZ',0);
21 # boolean rtrace options
22 my @boolO = ('-w', '-bv', '-dv', '-i', '-u', '-co');
23 # view options and the associated number of arguments
24 my %vwraysC = ('-vf',1, '-vtv',0, '-vtl',0, '-vth',0, '-vta',0, '-vts',0, '-vtc',0,
25 '-x',1, '-y',1, '-vp',3, '-vd',3, '-vu',3, '-vh',1, '-vv',1,
26 '-vo',1, '-va',1, '-vs',1, '-vl',1, '-pa',1, '-pj',1, '-pd',1);
27 # options we need to silently ignore
28 my %ignoreC = ('-t',1, '-ps',1, '-pt',1, '-pm',1,);
29 # Starting options for rtrace (rpict values)
30 my @rtraceA = split(' ', 'rtrace -u- -dt .05 -dc .5 -ds .25 -dr 1 ' .
31 '-aa .2 -ar 64 -ad 512 -as 128 -lr 7 -lw 1e-04');
32 my @vwraysA = ('vwrays', '-pj', '.67');
33 my @vwrightA = ('vwright', '-vtv');
34 my @rpictA = ('rpict', '-ps', '1');
35 my @pvalueA = ('pvalue', '-r');
36 my $outpatt = '^-o[vrxlLRXnNsmM]+';
37 my $refDepth = "";
38 my $irrad = 0;
39 my $specout = 0;
40 my $ncsamp = 3;
41 my $persist = 0;
42 my $ambounce = 0;
43 my $ambcache = 1;
44 my $ambfile;
45 my $outlyr;
46 my $outdir;
47 my $outpic;
48 my $outzbf;
49 OPTION: # sort through options
50 while ($#ARGV >= 0 && "$ARGV[0]" =~ /^[-\@]/) {
51 # Check for file inclusion
52 if ("$ARGV[0]" =~ /^\@/) {
53 open my $handle, '<', substr($ARGV[0], 1) or die "No file for $ARGV[0]\n";
54 shift @ARGV;
55 chomp(my @args = <$handle>);
56 close $handle;
57 unshift @ARGV, split(/\s+/, "@args");
58 next OPTION;
59 }
60 # Check booleans
61 for my $boopt (@boolO) {
62 if ("$ARGV[0]" =~ ('^' . $boopt . '[-+01tfynTFYN]?$')) {
63 if ("$ARGV[0]" eq '-i') {
64 $irrad = ! $irrad;
65 } elsif ("$ARGV[0]" =~ /^-i[-+01tfynTFYN]/) {
66 $irrad = ("$ARGV[0]" =~ /^-i[+1tyTY]/);
67 } elsif ("$ARGV[0]" eq '-co') {
68 $specout = ! $specout;
69 } elsif ("$ARGV[0]" =~ /^-co[-+01tfynTFYN]/) {
70 $specout = ("$ARGV[0]" =~ /^-co[+1tyTY]/);
71 }
72 push(@rpictA, $ARGV[0]) if ("$ARGV[0]" !~ /^-co/);
73 push @rtraceA, shift(@ARGV);
74 next OPTION;
75 }
76 }
77 # Check view options
78 if (defined $vwraysC{$ARGV[0]}) {
79 push @vwraysA, $ARGV[0];
80 my $isvopt = ("$ARGV[0]" =~ /^-v/);
81 push(@vwrightA, $ARGV[0]) if ($isvopt);
82 push @rpictA, shift(@ARGV);
83 for (my $i = $vwraysC{$rpictA[-1]}; $i-- > 0; ) {
84 push @vwraysA, $ARGV[0];
85 push(@vwrightA, $ARGV[0]) if ($isvopt);
86 push @rpictA, shift(@ARGV);
87 }
88 next OPTION;
89 }
90 # Check rtrace options
91 if (defined $rtraceC{$ARGV[0]}) {
92 if ("$ARGV[0]" =~ /^-PP?$/) {
93 $persist = 1;
94 } elsif ("$ARGV[0]" eq '-ab') {
95 $ambounce = $ARGV[1];
96 } elsif ("$ARGV[0]" eq '-aa') {
97 $ambcache = ($ARGV[1] > 0.0);
98 } elsif ("$ARGV[0]" eq '-af') {
99 $ambfile = "$ARGV[1]";
100 } elsif ("$ARGV[0]" eq '-pXYZ') {
101 push @pvalueA, $ARGV[0];
102 $specout = 0;
103 } elsif ("$ARGV[0]" eq '-pc') {
104 push @pvalueA, '-p';
105 push @pvalueA, @ARGV[1..8];
106 $specout = 0;
107 } elsif ("$ARGV[0]" eq '-cs') {
108 $ncsamp = $ARGV[1];
109 }
110 push @rtraceA, $ARGV[0];
111 push @rpictA, shift(@ARGV);
112 for (my $i = $rtraceC{$rpictA[-1]}; $i-- > 0; ) {
113 push @rtraceA, $ARGV[0];
114 push @rpictA, shift(@ARGV);
115 }
116 next OPTION;
117 }
118 # Check options to ignore
119 if (defined $ignoreC{$ARGV[0]}) {
120 push @rpictA, shift(@ARGV);
121 for (my $i = $ignoreC{$rpictA[-1]}; $i-- > 0; ) {
122 push @rpictA, shift(@ARGV);
123 }
124 next OPTION;
125 }
126 # Check for output file or number of processes
127 if ("$ARGV[0]" eq '-o') {
128 shift @ARGV;
129 $outpic = shift(@ARGV);
130 } elsif ("$ARGV[0]" eq '-z') {
131 push @rpictA, shift(@ARGV);
132 $outzbf = $ARGV[0];
133 push @rpictA, shift(@ARGV);
134 } elsif ("$ARGV[0]" eq '-n') {
135 shift @ARGV;
136 $nprocs = shift(@ARGV);
137 } elsif ("$ARGV[0]" eq '-d') {
138 shift @ARGV;
139 $refDepth = ' -d ' . shift(@ARGV);
140 } elsif ("$ARGV[0]" =~ "$outpatt") {
141 push @rtraceA, $ARGV[0];
142 $outlyr = substr(shift(@ARGV), 2);
143 $outdir = shift(@ARGV);
144 } else {
145 die "Unsupported option: " . $ARGV[0] . "\n";
146 }
147 }
148 die "-o* option cannot contain spaces\n" if ($windoz && $outdir =~ /[ ]/);
149 die "Number of processes must be positive\n" if ($nprocs <= 0);
150 if ($windoz && $nprocs > 1) {
151 print STDERR "Only one process supported under Windows\n";
152 $nprocs = 1;
153 }
154 if ($specout) {
155 $specout = ($ncsamp > 3);
156 }
157 if (defined $outdir) { # check conflicting options
158 die "Options -o and -o* are mutually exclusive\n" if (defined $outpic);
159 die "Options -z and -o* are mutually exclusive\n" if (defined $outzbf);
160 }
161 if (defined $outpic) { # redirect output?
162 die "File '$outpic' already exists\n" if (-e $outpic);
163 open STDOUT, '>', "$outpic";
164 }
165 #####################################################################
166 ##### May as well run rpict?
167 if ($specout == 0 && $nprocs == 1 && $persist == 0 && !defined($outdir)) {
168 push(@rpictA, $ARGV[0]) if ($#ARGV == 0);
169 exec @rpictA ;
170 }
171 # OK, we're running rtrace in some capacity...
172 push @rtraceA, ('-n', "$nprocs");
173 die "Need single octree argument\n" if ($#ARGV != 0);
174 my $oct = $ARGV[0];
175 my $view = `@vwrightA 0`;
176 chomp $view;
177 my @res = split(/\s/, `@vwraysA -d`);
178 #####################################################################
179 ##### Resort pixels to reduce ambient cache collisions?
180 if ($nprocs > 1 && $ambounce > 0 && $ambcache && defined($ambfile)) {
181 if ($specout == 0 && !defined($outzbf) && !defined($outdir)) {
182 # Straight picture output, so just shuffle sample order
183 system "cnt -s $res[1] $res[3] > /tmp/ord$$.txt";
184 die "cnt error\n" if ( $? );
185 system "@vwraysA -ff -i < /tmp/ord$$.txt " .
186 "| @rtraceA -ffa -ov '$oct' > /tmp/pix$$.txt";
187 die "Error running rtrace\n" if ( $? );
188 system "( getinfo < /tmp/pix$$.txt | getinfo -r NCOMP " .
189 "| getinfo -a 'VIEW=$view'; " .
190 "getinfo - < /tmp/pix$$.txt | rlam /tmp/ord$$.txt - " .
191 "| sort -k2rn -k1n ) | @pvalueA -Y $res[3] +X $res[1]";
192 die "rlam error\n" if ( $? );
193 unlink ("/tmp/ord$$.txt", "/tmp/pix$$.txt");
194 exit 0;
195 }
196 # Else randomize overture calculation to prime ambient cache
197 my @ores = (int($res[1]/6), int($res[3]/6));
198 print STDERR "Running $ores[0] by $ores[1] overture calculation " .
199 "to populate '$ambfile'...\n";
200 system "cnt -s @ores | @vwraysA -i -ff -x $ores[0] -y $ores[1] -pj 0 " .
201 "| @rtraceA -ff -ov -pY '$oct' > /dev/null";
202 die "Failure running overture\n" if ( $? );
203 print STDERR "Finished overture.\n";
204 }
205 #####################################################################
206 ##### Generating picture with depth buffer?
207 if (defined $outzbf) {
208 my $picvt = $specout ? 'rcomb -fc -' : "@pvalueA -df";
209 exec qq{@vwraysA -ff | @rtraceA -fff -olv @res "$oct" | } .
210 qq{rsplit -ih -iH -f -of "$outzbf" -oh -oH -of$ncsamp - | } .
211 $picvt . qq{ | getinfo -a "VIEW=$view"};
212 }
213 #####################################################################
214 ##### Base case with output picture only?
215 if (! defined $outdir) {
216 exec qq{@vwraysA -ff | @rtraceA -ffc @res "$oct" | getinfo -a "VIEW=$view"};
217 }
218 #####################################################################
219 ##### Layered image output case
220 my @rsplitA = ("rsplit", "'-t '", "-ih", "-iH", "-oh", "-oH");
221 # Supported rtrace -o* options and output file name.typ
222 my %rtoutC = (
223 v => 'radiance.hdr',
224 r => 'r_refl.hdr',
225 x => 'r_unrefl.hdr',
226 l => 'd_effective.dpt',
227 L => 'd_firstsurf.dpt',
228 R => 'd_refl.dpt',
229 X => 'd_unrefl.dpt',
230 n => 'perturbed.nrm',
231 N => 'unperturbed.nrm',
232 s => 'surface.idx',
233 m => 'modifier.idx',
234 M => 'material.idx'
235 );
236 # Arguments for rsplit based on output file type
237 my %rcodeC = (
238 '.hdr', ['-of3', "!@pvalueA -df -u"],
239 '.hsr', ["-of$ncsamp", '!rcomb -fc -'],
240 '.dpt', ['-of', "!rcode_depth$refDepth -ff"],
241 '.nrm', ['-of3', '!rcode_norm -ff'],
242 '.idx', ['-oa', '!rcode_ident "-t "']
243 );
244 if ($specout) { # adjust actions for -co+ option
245 $rtoutC{'v'} = 'radiance.hsr';
246 $rtoutC{'r'} = 'r_refl.hsr';
247 $rtoutC{'x'} = 'r_unrefl.hsr';
248 }
249 if ($irrad) { # adjust actions for -i+ option
250 $rtoutC{'v'} = $specout ? 'irradiance.hsr' : 'irradiance.hdr';
251 delete $rtoutC{'r'};
252 delete $rtoutC{'x'};
253 delete $rtoutC{'R'};
254 delete $rtoutC{'X'};
255 }
256 if (! -d $outdir) {
257 mkdir $outdir or die("Cannot create output directory '$outdir'\n");
258 }
259 # construct rsplit command
260 foreach my $oval (split //, $outlyr) {
261 die "Duplicate or unsupported type '$oval' in -o$outlyr\n"
262 if (!defined $rtoutC{$oval});
263 my $outfile = "$outdir/$rtoutC{$oval}";
264 die "File '$outfile' already exists\n" if (-e $outfile);
265 my ($otyp) = ($rtoutC{$oval} =~ /(\.[^.]+)$/);
266 push @rsplitA, $rcodeC{$otyp}[0];
267 if ($windoz) {
268 push @rsplitA, qq{"$rcodeC{$otyp}[1] > $outfile"};
269 } else {
270 push @rsplitA, qq{'$rcodeC{$otyp}[1] > "$outfile"'};
271 }
272 delete $rtoutC{$oval};
273 }
274 # call rtrace + rsplit
275 exec qq{@vwraysA -ff | @rtraceA -fff @res "$oct" | getinfo -a "VIEW=$view" | @rsplitA};
