root/radiance/src/util/rsensor.c
Revision: 2.25
Committed: Tue Jun 3 21:31:51 2025 UTC (4 months, 1 week ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.24: +3 -4 lines
2 static const char RCSid[] = "$Id: rsensor.c,v 2.24 2025/04/23 02:35:27 greg Exp $";
4
5 /*
6 * Compute sensor signal based on spatial sensitivity.
7 *
8 * Created Feb 2008 for Architectural Energy Corp.
9 */
10
11 #include "ray.h"
12 #include "platform.h"
13 #include "source.h"
14 #include "func.h"
15 #include "view.h"
16 #include "random.h"
17
18 #define DEGREE (PI/180.)
19
20 #define MAXNT 181 /* maximum number of theta divisions */
21 #define MAXNP 360 /* maximum number of phi divisions */
22
23 extern int nowarn; /* don't report warnings? */
24
25 /* current sensor's perspective */
26 VIEW ourview = {VT_ANG,{0.,0.,0.},{0.,0.,1.},{1.,0.,0.},
27 1.,180.,180.,0.,0.,0.,0.,
28 {0.,0.,0.},{0.,0.,0.},0.,0.};
29
30 long nsamps = 10000; /* desired number of initial samples */
31 int ndsamps = 32; /* number of direct samples */
32 int nprocs = 1; /* number of rendering processes */
33
34 float *sensor = NULL; /* current sensor data */
35 int sntp[2]; /* number of sensor theta and phi angles */
36 float maxtheta; /* maximum theta value for this sensor */
37 float tvals[MAXNT+1]; /* theta prob. values (1-D table of 1-cos(t)) */
38 float *pvals = NULL; /* phi prob. values (2-D table in radians) */
39 int ntheta = 0; /* polar angle divisions */
40 int nphi = 0; /* azimuthal angle divisions */
41 double gscale = 1.; /* global scaling value */
42
43 #define s_theta(t) sensor[(t+1)*(sntp[1]+1)]
44 #define s_phi(p) sensor[(p)+1]
45 #define s_val(t,p) sensor[(p)+1+(t+1)*(sntp[1]+1)]
46
47 static void comp_sensor(char *sfile);
48
49 static void
50 over_options() /* overriding options */
51 {
52 directvis = (ndsamps <= 0);
53 do_irrad = 0;
54 }
55
56 static void
57 print_defaults() /* print out default parameters */
58 {
59 over_options();
60 printf("-n %-9d\t\t\t# number of processes\n", nprocs);
61 printf("-rd %-9ld\t\t\t# ray directions\n", nsamps);
62 printf("-dn %-9d\t\t\t# direct number of samples\n", ndsamps);
63 printf("-vp %f %f %f\t# view point\n",
64 ourview.vp[0], ourview.vp[1], ourview.vp[2]);
65 printf("-vd %f %f %f\t# view direction\n",
66 ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
67 printf("-vu %f %f %f\t# view up\n",
68 ourview.vup[0], ourview.vup[1], ourview.vup[2]);
69 printf("-vo %f\t\t\t# view fore clipping distance\n", ourview.vfore);
70 print_rdefaults();
71 }
72
73
74 void
75 quit(ec) /* make sure exit is called */
76 int ec;
77 {
78 if (ray_pnprocs > 0) /* close children if any */
79 ray_pclose(0);
80 else if (ray_pnprocs < 0)
81 _exit(ec); /* avoid flush in child */
82 exit(ec);
83 }
84
85
86 int
87 main(
88 int argc,
89 char *argv[]
90 )
91 {
92 int doheader = 1;
93 int optwarn = 0;
94 int i, rval;
95 /* set global progname */
96 fixargv0(argv[0]);
97 /* set up rendering defaults */
98 rand_samp = 1;
99 dstrsrc = 0.65;
100 srcsizerat = 0.1;
101 directrelay = 3;
102 ambounce = 1;
103 maxdepth = -10;
104 /* initialize calcomp routines */
105 initfunc();
106 /* get options from command line */
107 for (i = 1; i < argc; i++) {
108 while ((rval = expandarg(&argc, &argv, i)) > 0)
109 ;
110 if (rval < 0) {
111 sprintf(errmsg, "cannot expand '%s'", argv[i]);
112 error(SYSTEM, errmsg);
113 }
114 if (argv[i][0] != '-') {
115 if (i >= argc-1)
116 break; /* final octree argument */
117 if (!ray_pnprocs) {
118 over_options();
119 if (doheader) { /* print header */
120 newheader("RADIANCE", stdout);
121 printargs(argc, argv, stdout);
122 fputformat("ascii", stdout);
123 putchar('\n');
124 }
125 /* start process(es) */
126 if (strcmp(argv[argc-1], "."))
127 ray_pinit(argv[argc-1], nprocs);
128 }
129 comp_sensor(argv[i]); /* process a sensor file */
130 continue;
131 }
132 if (argv[i][1] == 'r') { /* sampling options */
133 if (argv[i][2] == 'd')
134 nsamps = atol(argv[++i]);
135 else {
136 sprintf(errmsg, "bad option at '%s'", argv[i]);
137 error(USER, errmsg);
138 }
139 continue;
140 }
141 /* direct component samples */
142 if (argv[i][1] == 'd' && argv[i][2] == 'n') {
143 ndsamps = atoi(argv[++i]);
144 continue;
145 }
146 if (argv[i][1] == 'v') { /* next sensor view */
147 if (argv[i][2] == 'f') {
148 rval = viewfile(argv[++i], &ourview, NULL);
149 if (rval < 0) {
150 sprintf(errmsg,
151 "cannot open view file \"%s\"",
152 argv[i]);
153 error(SYSTEM, errmsg);
154 } else if (rval == 0) {
155 sprintf(errmsg,
156 "bad view file \"%s\"",
157 argv[i]);
158 error(USER, errmsg);
159 }
160 continue;
161 }
162 rval = getviewopt(&ourview, argc-i, argv+i);
163 if (rval >= 0) {
164 i += rval;
165 continue;
166 }
167 sprintf(errmsg, "bad view option at '%s'", argv[i]);
168 error(USER, errmsg);
169 }
170 if (!strcmp(argv[i], "-w")) { /* toggle warnings */
171 nowarn = !nowarn;
172 continue;
173 }
174 if (ray_pnprocs) {
175 if (!optwarn++)
176 error(WARNING,
177 "rendering options should appear before first sensor");
178 } else if (!strcmp(argv[i], "-defaults")) {
179 print_defaults();
180 return(0);
181 }
182 if (argv[i][1] == 'h') { /* header toggle */
183 doheader = !doheader;
184 continue;
185 }
186 if (!strcmp(argv[i], "-n")) { /* number of processes */
187 nprocs = atoi(argv[++i]);
188 if (nprocs <= 0)
189 error(USER, "illegal number of processes");
190 continue;
191 }
192 rval = getrenderopt(argc-i, argv+i);
193 if (rval < 0) {
194 sprintf(errmsg, "bad render option at '%s'", argv[i]);
195 error(USER, errmsg);
196 }
197 i += rval;
198 }
199 if (sensor == NULL)
200 error(USER, i<argc ? "missing sensor file" : "missing octree");
201 quit(0);
202 }
203
204 /* Load sensor sensitivities (first row and column are angles) */
205 static float *
206 load_sensor(
207 int ntp[2],
208 char *sfile
209 )
210 {
211 int warnedneg;
212 char linebuf[8192];
213 int last_pos_val = 0;
214 int nelem = 1000;
215 float *sarr = (float *)malloc(sizeof(float)*nelem);
216 FILE *fp;
217 char *cp;
218 int i;
219
220 fp = frlibopen(sfile);
221 if (fp == NULL) {
222 sprintf(errmsg, "cannot open sensor file '%s'", sfile);
223 error(SYSTEM, errmsg);
224 }
225 fgets(linebuf, sizeof(linebuf), fp);
226 if (!strncmp(linebuf, "Elevation ", 10))
227 fgets(linebuf, sizeof(linebuf), fp);
228 /* get phi values */
229 sarr[0] = .0f;
230 if (strncmp(linebuf, "degrees", 7)) {
231 sprintf(errmsg, "Missing 'degrees' in sensor file '%s'", sfile);
232 error(USER, errmsg);
233 }
234 cp = sskip(linebuf);
235 ntp[1] = 0;
236 for ( ; ; ) {
237 sarr[ntp[1]+1] = atof(cp);
238 cp = fskip(cp);
239 if (cp == NULL)
240 break;
241 if (ntp[1] > 1 && sarr[ntp[1]+1] <= sarr[ntp[1]]+FTINY) {
242 sprintf(errmsg,
243 "Phi values not monotinically increasing in sensor file '%s'",
244 sfile);
245 error(USER, errmsg);
246 }
247 ++ntp[1];
248 }
249 warnedneg = 0;
250 ntp[0] = 0; /* get thetas + data */
251 while (fgets(linebuf, sizeof(linebuf), fp) != NULL) {
252 ++ntp[0];
253 if ((ntp[0]+1)*(ntp[1]+1) > nelem) {
254 nelem += (nelem>>2) + ntp[1];
255 sarr = (float *)realloc((void *)sarr,
256 sizeof(float)*nelem);
257 if (sarr == NULL)
258 error(SYSTEM, "out of memory in load_sensor()");
259 }
260 cp = linebuf;
261 i = ntp[0]*(ntp[1]+1);
262 for ( ; ; ) {
263 sarr[i] = atof(cp);
264 cp = fskip(cp);
265 if (cp == NULL)
266 break;
267 if (sarr[i] < .0) {
268 if (!warnedneg++) {
269 sprintf(errmsg,
270 "Negative value(s) in sensor file '%s' (ignored)\n", sfile);
271 error(WARNING, errmsg);
272 }
273 sarr[i] = .0;
274 } else if (sarr[i] > FTINY && i > ntp[0]*(ntp[1]+1))
275 last_pos_val = i;
276 ++i;
277 }
278 if (i == ntp[0]*(ntp[1]+1)) /* empty line? */
279 break;
280 if (ntp[0] > 1 && sarr[ntp[0]*(ntp[1]+1)] <=
281 sarr[(ntp[0]-1)*(ntp[1]+1)]) {
282 sprintf(errmsg,
283 "Theta values not monotinically increasing in sensor file '%s'",
284 sfile);
285 error(USER, errmsg);
286 }
287 if (i != (ntp[0]+1)*(ntp[1]+1)) {
288 sprintf(errmsg,
289 "bad column count near line %d in sensor file '%s'",
290 ntp[0]+1, sfile);
291 error(USER, errmsg);
292 }
293 }
294 /* truncate zero region */
295 ntp[0] = (last_pos_val + ntp[1])/(ntp[1]+1) - 1;
296 nelem = (ntp[0]+1)*(ntp[1]+1);
297 fclose(fp);
298 errmsg[0] = '\0'; /* sanity checks */
299 if (!last_pos_val)
300 sprintf(errmsg, "no positive sensor values in file '%s'", sfile);
301 else if (fabs(sarr[ntp[1]+1]) > FTINY)
302 sprintf(errmsg, "minimum theta must be 0 in sensor file '%s'",
303 sfile);
304 else if (fabs(sarr[1]) > FTINY)
305 sprintf(errmsg, "minimum phi must be 0 in sensor file '%s'",
306 sfile);
307 else if (sarr[ntp[1]] < 270.-FTINY)
308 sprintf(errmsg,
309 "maximum phi must be 270 or greater in sensor file '%s'",
310 sfile);
311 else if (sarr[ntp[1]] >= 360.-FTINY)
312 sprintf(errmsg,
313 "maximum phi must be less than 360 in sensor file '%s'",
314 sfile);
315 if (errmsg[0])
316 error(USER, errmsg);
317 return((float *)realloc((void *)sarr, sizeof(float)*nelem));
318 }
319
320 /* Initialize probability table */
321 static void
322 init_ptable(
323 char *sfile
324 )
325 {
326 long samptot = nsamps;
327 float *rowp, *rowp1;
328 double rowsum[MAXNT], rowomega[MAXNT];
329 double thdiv[MAXNT+1], phdiv[MAXNP+1];
330 double tsize, psize;
331 double prob, frac, frac1;
332 int i, j, t, p;
333 /* free old table */
334 if (sensor != NULL)
335 free((void *)sensor);
336 if (pvals != NULL)
337 free((void *)pvals);
338 if (sfile == NULL || !*sfile) {
339 sensor = NULL;
340 sntp[0] = sntp[1] = 0;
341 pvals = NULL;
342 ntheta = nphi = 0;
343 return;
344 }
345 /* load sensor table */
346 sensor = load_sensor(sntp, sfile);
347 if (sntp[0] > MAXNT) {
348 sprintf(errmsg, "Too many theta rows in sensor file '%s'",
349 sfile);
350 error(INTERNAL, errmsg);
351 }
352 if (sntp[1] > MAXNP) {
353 sprintf(errmsg, "Too many phi columns in sensor file '%s'",
354 sfile);
355 error(INTERNAL, errmsg);
356 }
357 /* compute boundary angles */
358 maxtheta = DEGREE*(1.5f*s_theta(sntp[0]-1) - 0.5f*s_theta(sntp[0]-2));
359 if (maxtheta > PI)
360 maxtheta = PI;
361 thdiv[0] = .0;
362 for (t = 1; t < sntp[0]; t++)
363 thdiv[t] = DEGREE/2.*(s_theta(t-1) + s_theta(t));
364 thdiv[sntp[0]] = maxtheta;
365 phdiv[0] = DEGREE*(1.5f*s_phi(0) - 0.5f*s_phi(1));
366 for (p = 1; p < sntp[1]; p++)
367 phdiv[p] = DEGREE/2.*(s_phi(p-1) + s_phi(p));
368 phdiv[sntp[1]] = DEGREE*(1.5f*s_phi(sntp[1]-1) - 0.5f*s_phi(sntp[1]-2));
369 /* size our table */
370 tsize = 1. - cos(maxtheta);
371 psize = PI*tsize/maxtheta;
372 if (sntp[0]*sntp[1] < samptot) /* don't overdo resolution */
373 samptot = sntp[0]*sntp[1];
374 ntheta = (int)(sqrt((double)samptot*tsize/psize)*sntp[0]/sntp[1]) + 1;
375 if (ntheta > MAXNT)
376 ntheta = MAXNT;
377 nphi = samptot/ntheta;
378 pvals = (float *)malloc(sizeof(float)*(ntheta+1)*(nphi+1));
379 if (pvals == NULL)
380 error(SYSTEM, "out of memory in init_ptable()");
381 gscale = .0; /* compute our inverse table */
382 for (i = 0; i < sntp[0]; i++) {
383 rowp = &s_val(i,0);
384 rowsum[i] = 1e-20;
385 for (j = 0; j < sntp[1]; j++)
386 rowsum[i] += *rowp++;
387 rowomega[i] = cos(thdiv[i]) - cos(thdiv[i+1]);
388 rowomega[i] *= 2.*PI / (double)sntp[1];
389 gscale += rowsum[i] * rowomega[i];
390 }
391 if (gscale <= FTINY) {
392 sprintf(errmsg, "Sensor values sum to zero in file '%s'", sfile);
393 error(USER, errmsg);
394 }
395 for (i = 0; i < ntheta; i++) {
396 prob = (double)i / (double)ntheta;
397 for (t = 0; t < sntp[0]; t++)
398 if ((prob -= rowsum[t]*rowomega[t]/gscale) <= .0)
399 break;
400 if (t >= sntp[0])
401 error(INTERNAL, "code error 1 in init_ptable()");
402 frac = 1. + prob/(rowsum[t]*rowomega[t]/gscale);
403 tvals[i] = 1. - ( (1.-frac)*cos(thdiv[t]) +
404 frac*cos(thdiv[t+1]) );
405 /* offset b/c sensor values are centered */
406 if ((t < sntp[0]-1) & (!t | (frac >= 0.5))) {
407 frac -= 0.5;
408 } else {
409 frac += 0.5;
410 --t;
411 }
412 pvals[i*(nphi+1)] = phdiv[0];
413 for (j = 1; j < nphi; j++) {
414 prob = (double)j / (double)nphi;
415 rowp = &s_val(t,0);
416 rowp1 = &s_val(t+1,0);
417 for (p = 0; p < sntp[1]; p++)
418 if ((prob -= (1.-frac)*rowp[p]/rowsum[t] +
419 frac*rowp1[p]/rowsum[t+1]) <= .0)
420 break;
421 if (p >= sntp[1]) { /* should never happen? */
422 p = sntp[1] - 1;
423 prob = .5;
424 }
425 frac1 = 1. + prob/((1.-frac)*rowp[p]/rowsum[t]
426 + frac*rowp1[p]/rowsum[t+1]);
427 pvals[i*(nphi+1) + j] = (1.-frac1)*phdiv[p] +
428 frac1*phdiv[p+1];
429 }
430 pvals[i*(nphi+1) + nphi] = phdiv[sntp[1]];
431 }
432 /* duplicate final row */
433 memcpy(pvals+ntheta*(nphi+1), pvals+(ntheta-1)*(nphi+1),
434 sizeof(*pvals)*(nphi+1));
435 tvals[0] = .0f;
436 tvals[ntheta] = (float)tsize;
437 }
438
439 /* Get normalized direction from random variables in [0,1) range */
440 static void
441 get_direc(
442 FVECT dvec,
443 double x,
444 double y
445 )
446 {
447 double xfrac = x*ntheta;
448 int tndx = (int)xfrac;
449 double yfrac = y*nphi;
450 int pndx = (int)yfrac;
451 double rad, phi;
452 FVECT dv;
453 int i;
454
455 xfrac -= (double)tndx;
456 yfrac -= (double)pndx;
457 pndx += tndx*(nphi+1);
458
459 dv[2] = 1. - ((1.-xfrac)*tvals[tndx] + xfrac*tvals[tndx+1]);
460 rad = sqrt(1. - dv[2]*dv[2]);
461 phi = (1.-yfrac)*pvals[pndx] + yfrac*pvals[pndx+1];
462 dv[0] = -rad*sin(phi);
463 dv[1] = rad*cos(phi);
464 for (i = 3; i--; )
465 dvec[i] = dv[0]*ourview.hvec[i] +
466 dv[1]*ourview.vvec[i] +
467 dv[2]*ourview.vdir[i] ;
468 }
469
470 /* Get sensor value in the specified direction (normalized) */
471 static float
472 sens_val(
473 FVECT dvec
474 )
475 {
476 FVECT dv;
477 float theta, phi;
478 int t, p;
479
480 dv[2] = DOT(dvec, ourview.vdir);
481 theta = acos(dv[2]);
482 if (theta >= maxtheta)
483 return(.0f);
484 dv[0] = DOT(dvec, ourview.hvec);
485 dv[1] = DOT(dvec, ourview.vvec);
486 phi = atan2(-dv[0], dv[1]);
487 while (phi < .0f) phi += (float)(2.*PI);
488 t = (int)(theta/maxtheta * sntp[0]);
489 p = (int)(phi*(1./(2.*PI)) * sntp[1]);
490 /* hack for non-uniform sensor grid */
491 theta *= (float)(1./DEGREE);
492 phi *= (float)(1./DEGREE);
493 while (t+1 < sntp[0] && theta >= s_theta(t+1))
494 ++t;
495 while (t-1 >= 0 && theta <= s_theta(t-1))
496 --t;
497 while (p+1 < sntp[1] && phi >= s_phi(p+1))
498 ++p;
499 while (p-1 >= 0 && phi <= s_phi(p-1))
500 --p;
501 return(s_val(t,p));
502 }
503
504 /* Print origin and direction */
505 static void
506 print_ray(
507 FVECT rorg,
508 FVECT rdir
509 )
510 {
511 printf("%.6g %.6g %.6g %.8f %.8f %.8f\n",
512 rorg[0], rorg[1], rorg[2],
513 rdir[0], rdir[1], rdir[2]);
514 }
515
516 /* Compute sensor output */
517 static void
518 comp_sensor(
519 char *sfile
520 )
521 {
522 int ndirs = dstrsrc > FTINY ? ndsamps :
523 ndsamps > 0 ? 1 : 0;
524 char *err;
525 int nt, np;
526 SCOLOR vsum;
527 RAY rr;
528 double sf;
529 int i, j;
530 /* set view */
531 ourview.type = VT_ANG;
532 ourview.horiz = ourview.vert = 180.;
533 ourview.hoff = ourview.voff = .0;
534 err = setview(&ourview);
535 if (err != NULL)
536 error(USER, err);
537 /* assign probability table */
538 init_ptable(sfile);
539 /* stratified MC sampling */
540 scolorblack(vsum);
541 nt = (int)(sqrt((double)nsamps*ntheta/nphi) + .5);
542 np = nsamps/nt;
543 sf = gscale/nsamps;
544 for (i = 0; i < nt; i++)
545 for (j = 0; j < np; j++) {
546 VCOPY(rr.rorg, ourview.vp);
547 get_direc(rr.rdir, (i+frandom())/nt, (j+frandom())/np);
548 if (ourview.vfore > FTINY)
549 VSUM(rr.rorg, rr.rorg, rr.rdir, ourview.vfore);
550 if (!ray_pnprocs) {
551 print_ray(rr.rorg, rr.rdir);
552 continue;
553 }
554 rr.rmax = .0;
555 rayorigin(&rr, PRIMARY|SPECULAR, NULL, NULL);
556 scalescolor(rr.rcoef, sf);
557 if (ray_pqueue(&rr) == 1)
558 saddscolor(vsum, rr.rcol);
559 }
560 /* remaining rays pure MC */
561 for (i = nsamps - nt*np; i-- > 0; ) {
562 VCOPY(rr.rorg, ourview.vp);
563 get_direc(rr.rdir, frandom(), frandom());
564 if (ourview.vfore > FTINY)
565 VSUM(rr.rorg, rr.rorg, rr.rdir, ourview.vfore);
566 if (!ray_pnprocs) {
567 print_ray(rr.rorg, rr.rdir);
568 continue;
569 }
570 rr.rmax = .0;
571 rayorigin(&rr, PRIMARY|SPECULAR, NULL, NULL);
572 scalescolor(rr.rcoef, sf);
573 if (ray_pqueue(&rr) == 1)
574 saddscolor(vsum, rr.rcol);
575 }
576 if (!ray_pnprocs) /* just printing rays */
577 return;
578 /* scale partial result */
579 scalescolor(vsum, sf);
580 /* add direct component */
581 for (i = ndirs; i-- > 0; ) {
582 SRCINDEX si;
583 initsrcindex(&si);
584 while (srcray(&rr, NULL, &si)) {
585 sf = sens_val(rr.rdir);
586 if (sf <= FTINY)
587 continue;
588 sf *= si.dom/ndirs;
589 scalescolor(rr.rcoef, sf);
590 if (ray_pqueue(&rr) == 1) {
591 smultscolor(rr.rcol, rr.rcoef);
592 saddscolor(vsum, rr.rcol);
593 }
594 }
595 }
596 while (ray_presult(&rr, 0) > 0) { /* finish our calculation */
597 smultscolor(rr.rcol, rr.rcoef);
598 saddscolor(vsum, rr.rcol);
599 }
600 for (i = 0; i < NCSAMP; i++) /* print our result */
601 printf(" %.4e", vsum[i]);
602 fputc('\n', stdout);
603 }
