root/radiance/src/util/rsensor.c
Tue Jun 3 21:31:51 2025 UTC (4 months, 2 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.24: +3 -4 lines
Diff to previous 2.24 , to selected 2.17
Wed Apr 23 02:35:27 2025 UTC (5 months, 3 weeks ago) by greg
Changes since 2.23: +4 -1 lines
Diff to previous 2.23 , to selected 2.17
fix: Added missing calls to initfunc()
Sat Dec 16 03:30:35 2023 UTC (22 months ago) by greg
Changes since 2.22: +5 -8 lines
Diff to previous 2.22 , to selected 2.17
feat(rsensor): Supports n-channel color output for multispectral calcs
Fri Nov 17 20:02:08 2023 UTC (23 months ago) by greg
Changes since 2.21: +17 -15 lines
Diff to previous 2.21 , to selected 2.17
Tue Mar 15 18:05:03 2022 UTC (3 years, 7 months ago) by greg
Changes since 2.20: +3 -7 lines
Diff to previous 2.20 , to selected 2.17
fix(rsensor): Minor corrections wrt. integer types
Fri Jul 24 17:09:33 2020 UTC (5 years, 2 months ago) by greg
Changes since 2.19: +2 -1 lines
Diff to previous 2.19 , to selected 2.17
fix(rsensor): added missing declaration for _exit()
Mon Jul 20 15:54:29 2020 UTC (5 years, 2 months ago) by greg
Changes since 2.18: +4 -2 lines
Diff to previous 2.18 , to selected 2.17
fix(mkillum, rcontrib, rtrace, ranimove, rsensor): stall under macOS 10.15
due to broken flockfile() implementation -- workaround is better, anyway
Tue Jun 9 21:34:15 2015 UTC (10 years, 4 months ago) by greg
Changes since 2.17: +8 -4 lines
Diff to previous 2.17
Added checks for extra and missing angles and documented behavior
Revision 2.17 - (view) (download) (annotate) - [selected]
Fri Apr 24 19:17:12 2015 UTC (10 years, 5 months ago) by greg
Changes since 2.16: +5 -11 lines
Diff to previous 2.16
Fix for anisotropic sensitivity array
Thu Apr 23 23:54:08 2015 UTC (10 years, 5 months ago) by greg
Changes since 2.15: +11 -5 lines
Diff to previous 2.15 , to selected 2.17
Avoid generating rays behind sensor
Thu Apr 23 23:34:18 2015 UTC (10 years, 5 months ago) by greg
Diff to previous 2.14 , to selected 2.17
Minor fixes shouldn't affect behavior
Tue Sep 30 23:14:34 2014 UTC (11 years ago) by greg
CVS Tags: rad4R2P2
Changes since 2.13: +3 -4 lines
Diff to previous 2.13 , to selected 2.17
Fixed bug related to many rows (altitude) and few columns (azimuth) for sensor
Wed Oct 16 04:35:50 2013 UTC (12 years ago) by greg
CVS Tags: rad4R2, rad4R2P1
Changes since 2.12: +5 -4 lines
Diff to previous 2.12 , to selected 2.17
Fixed bug for distributions with zero sensitivity at zenith
Mon Sep 26 15:33:29 2011 UTC (14 years ago) by greg
Diff to previous 2.11 , to selected 2.17
Added SPECULAR flag to ray samples to work better with BSDF materials
Mon Jun 20 23:08:43 2011 UTC (14 years, 4 months ago) by greg
Changes since 2.10: +7 -5 lines
Diff to previous 2.10 , to selected 2.17
Fixed serious bug in rsensor that caused it to fail for source sampling
Thu May 19 16:09:38 2011 UTC (14 years, 5 months ago) by greg
Changes since 2.9: +14 -4 lines
Diff to previous 2.9 , to selected 2.17
Bug fix related to zero rows and added check for negative sensitivities
Tue May 17 19:34:36 2011 UTC (14 years, 5 months ago) by greg
Changes since 2.8: +40 -21 lines
Diff to previous 2.8 , to selected 2.17
Fixes pointed out by David G-M
Sun Sep 26 15:41:46 2010 UTC (15 years ago) by greg
Changes since 2.7: +26 -3 lines
Diff to previous 2.7 , to selected 2.17
Added ability to output sample rays rather than compute results
Sat Dec 12 19:01:00 2009 UTC (15 years, 10 months ago) by greg
Changes since 2.6: +12 -1 lines
Diff to previous 2.6 , to selected 2.17
Sat Dec 13 00:44:05 2008 UTC (16 years, 10 months ago) by greg
Changes since 2.5: +27 -13 lines
Diff to previous 2.5 , to selected 2.17
Improved sampling method very slightly
Fri Apr 11 22:06:04 2008 UTC (17 years, 6 months ago) by greg
Changes since 2.4: +8 -4 lines
Diff to previous 2.4 , to selected 2.17
Changed default view and added handling of fore clipping distance
Fri Feb 22 21:52:10 2008 UTC (17 years, 7 months ago) by greg
Changes since 2.3: +1 -7 lines
Diff to previous 2.3 , to selected 2.17
Fixed minor inaccuracy in phi lookup
Fri Feb 22 18:04:02 2008 UTC (17 years, 7 months ago) by greg
Changes since 2.2: +23 -19 lines
Diff to previous 2.2 , to selected 2.17
Fixed options processing
Thu Feb 21 20:18:25 2008 UTC (17 years, 8 months ago) by greg
Changes since 2.1: +46 -27 lines
Diff to previous 2.1 , to selected 2.17
First tested version
Thu Feb 21 01:22:06 2008 UTC (17 years, 8 months ago) by greg
Diff to selected 2.17
