root/radiance/src/util/rpiece.c
Revision: 2.9
Committed: Sun Aug 9 13:31:30 1992 UTC (33 years, 2 months ago) by greg
Changes since 2.8: +50 -19 lines
added process forking
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Generate sections of a picture.
9 */
10
11 #include "standard.h"
12 #include <fcntl.h>
13 #include <signal.h>
14 #include "color.h"
15 #include "view.h"
16 #include "resolu.h"
17
18 /* set the following to 0 to forgo forking */
19 #ifndef MAXFORK
20 #define MAXFORK 2 /* max. unreaped child processes */
21 #endif
22
23 /* rpict command */
24 char *rpargv[128] = {"rpict", "-S", "1", "-x", "512", "-y", "512", "-pa", "1"};
25 int rpargc = 9;
26 int rpd[3];
27 FILE *torp, *fromrp;
28 COLR *pbuf;
29 /* our view parameters */
30 VIEW ourview = STDVIEW;
31 double pixaspect = 1.0;
32 int hres = 512, vres = 512, hmult = 2, vmult = 2;
33 /* output file */
34 char *outfile = NULL;
35 int outfd;
36 long scanorig;
37 int syncfd = -1; /* lock file descriptor */
38 int nforked = 0;
39
40 char *progname;
41 int verbose = 0;
42
43 extern long lseek(), ftell();
44
45 int gotalrm = 0;
46 int onalrm() { gotalrm++; }
47
48
49 main(argc, argv)
50 int argc;
51 char *argv[];
52 {
53 register int i, rval;
54
55 progname = argv[0];
56 for (i = 1; i < argc; i++) {
57 if (argv[i][0] == '-')
58 switch (argv[i][1]) {
59 case 'v':
60 switch (argv[i][2]) {
61 case '\0': /* verbose option */
62 verbose = !verbose;
63 continue;
64 case 'f': /* view file */
65 if (viewfile(argv[++i], &ourview, NULL) <= 0) {
66 fprintf(stderr,
67 "%s: not a view file\n", argv[i]);
68 exit(1);
69 }
70 continue;
71 default: /* view option? */
72 rval = getviewopt(&ourview, argc-i, argv+i);
73 if (rval >= 0) {
74 i += rval;
75 continue;
76 }
77 break;
78 }
79 break;
80 case 'p': /* pixel aspect ratio? */
81 if (argv[i][2] == 'a' && !argv[i][3])
82 pixaspect = atof(argv[i+1]);
83 break;
84 case 'x': /* piece x resolution */
85 if (!argv[i][2])
86 hres = atoi(argv[i+1]);
87 break;
88 case 'y': /* piece y resolution */
89 if (!argv[i][2])
90 vres = atoi(argv[i+1]);
91 break;
92 case 'X': /* horizontal multiplier */
93 if (argv[i][2])
94 break;
95 hmult = atoi(argv[++i]);
96 continue;
97 case 'Y': /* vertical multiplier */
98 if (argv[i][2])
99 break;
100 vmult = atoi(argv[++i]);
101 continue;
102 case 'F': /* syncronization file */
103 if (argv[i][2])
104 break;
105 if ((syncfd = open(argv[++i], O_RDWR)) < 0) {
106 fprintf(stderr, "%s: cannot open\n",
107 argv[i]);
108 exit(1);
109 }
110 continue;
111 case 'o': /* output file */
112 if (argv[i][2])
113 break;
114 outfile = argv[++i];
115 continue;
116 }
117 rpargv[rpargc++] = argv[i];
118 }
119 rpargv[rpargc] = NULL;
120 if (outfile == NULL) {
121 fprintf(stderr, "%s: missing output file\n", argv[0]);
122 exit(1);
123 }
124 init(argc, argv);
125 rpiece();
126 rval = cleanup();
127 exit(rval);
128 }
129
130
131 init(ac, av) /* set up output file and start rpict */
132 int ac;
133 char **av;
134 {
135 extern char VersionID[];
136 char *err;
137 FILE *fp;
138 int hr, vr;
139 /* set up view */
140 if ((err = setview(&ourview)) != NULL) {
141 fprintf(stderr, "%s: %s\n", progname, err);
142 exit(1);
143 }
144 if (syncfd != -1) {
145 char buf[32];
146 buf[read(syncfd, buf, sizeof(buf)-1)] = '\0';
147 sscanf(buf, "%d %d", &hmult, &vmult);
148 }
149 normaspect(viewaspect(&ourview)*hmult/vmult, &pixaspect, &hres, &vres);
150 /* open output file */
151 if ((outfd = open(outfile, O_WRONLY|O_CREAT|O_EXCL, 0666)) >= 0) {
152 if ((fp = fdopen(dup(outfd), "w")) == NULL)
153 goto filerr;
154 printargs(ac, av, fp); /* write header */
155 fprintf(fp, "SOFTWARE= %s\n", VersionID);
156 fputs(VIEWSTR, fp);
157 fprintview(&ourview, fp);
158 putc('\n', fp);
159 if (pixaspect < .99 || pixaspect > 1.01)
160 fputaspect(pixaspect, fp);
161 fputformat(COLRFMT, fp);
162 putc('\n', fp);
163 fprtresolu(hres*hmult, vres*vmult, fp);
164 } else if ((outfd = open(outfile, O_RDWR)) >= 0) {
165 if ((fp = fdopen(dup(outfd), "r+")) == NULL)
166 goto filerr;
167 getheader(fp, NULL); /* skip header */
168 if (fscnresolu(&hr, &vr, fp) < 0 || /* check resolution */
169 hr != hres*hmult || vr != vres*vmult) {
170 fprintf(stderr, "%s: resolution mismatch on file \"%s\"\n",
171 progname, outfile);
172 exit(1);
173 }
174 } else {
175 fprintf(stderr, "%s: cannot open file \"%s\"\n",
176 progname, outfile);
177 exit(1);
178 }
179 scanorig = ftell(fp); /* record position of first scanline */
180 if (fclose(fp) == -1) /* done with stream i/o */
181 goto filerr;
182 sync(); /* flush NFS buffers */
183 /* start rpict process */
184 if (open_process(rpd, rpargv) <= 0) {
185 fprintf(stderr, "%s: cannot start %s\n", progname, rpargv[0]);
186 exit(1);
187 }
188 if ((fromrp = fdopen(rpd[0], "r")) == NULL ||
189 (torp = fdopen(rpd[1], "w")) == NULL) {
190 fprintf(stderr, "%s: cannot open stream to %s\n",
191 progname, rpargv[0]);
192 exit(1);
193 }
194 if ((pbuf = (COLR *)malloc(hres*vres*sizeof(COLR))) == NULL) {
195 fprintf(stderr, "%s: out of memory\n", progname);
196 exit(1);
197 }
198 signal(SIGALRM, onalrm);
199 return;
200 filerr:
201 fprintf(stderr, "%s: i/o error on file \"%s\"\n", progname, outfile);
202 exit(1);
203 }
204
205
206 int
207 nextpiece(xp, yp) /* get next piece assignment */
208 int *xp, *yp;
209 {
210 extern char *fgets();
211 struct flock fls;
212 char buf[64];
213
214 if (gotalrm) /* someone wants us to quit */
215 return(0);
216 if (syncfd != -1) { /* use sync file */
217 fls.l_type = F_WRLCK; /* gain exclusive access */
218 fls.l_whence = 0;
219 fls.l_start = 0L;
220 fls.l_len = 0L;
221 fcntl(syncfd, F_SETLKW, &fls);
222 lseek(syncfd, 0L, 0);
223 buf[read(syncfd, buf, sizeof(buf)-1)] = '\0';
224 if (sscanf(buf, "%*d %*d %d %d", xp, yp) < 2) {
225 *xp = hmult-1;
226 *yp = vmult;
227 }
228 if (--(*yp) < 0) { /* decrement position */
229 *yp = vmult-1;
230 if (--(*xp) < 0) { /* all done! */
231 close(syncfd);
232 return(0);
233 }
234 }
235 sprintf(buf, "%d %d\n%d %d\n", hmult, vmult, *xp, *yp);
236 lseek(syncfd, 0L, 0); /* write new position */
237 write(syncfd, buf, strlen(buf));
238 fls.l_type = F_UNLCK; /* release sync file */
239 fcntl(syncfd, F_SETLKW, &fls);
240 return(1);
241 }
242 if (fgets(buf, sizeof(buf), stdin) == NULL) /* use stdin */
243 return(0);
244 if (sscanf(buf, "%d %d", xp, yp) == 2)
245 return(1);
246 fprintf(stderr, "%s: input format error\n", progname);
247 exit(1);
248 }
249
250
251 int
252 cleanup() /* close rpict process and clean up */
253 {
254 register int pid;
255 int status, rstat = 0;
256
257 free((char *)pbuf);
258 fclose(torp);
259 fclose(fromrp);
260 while ((pid = wait(&status)) != -1)
261 if (rstat == 0)
262 rstat = status>>8 & 0xff;
263 return(rstat);
264 }
265
266
267 rpiece() /* render picture piece by piece */
268 {
269 VIEW pview;
270 int xorg, yorg;
271
272 while (nextpiece(&xorg, &yorg)) {
273 copystruct(&pview, &ourview); /* compute view for piece */
274 switch (ourview.type) {
275 case VT_PER:
276 pview.horiz = 2.*180./PI*atan(
277 tan(PI/180./2.*ourview.horiz)/hmult );
278 pview.vert = 2.*180./PI*atan(
279 tan(PI/180./2.*ourview.vert)/vmult );
280 break;
281 case VT_PAR:
282 case VT_ANG:
283 pview.horiz = ourview.horiz / hmult;
284 pview.vert = ourview.vert / vmult;
285 break;
286 case VT_HEM:
287 pview.horiz = 2.*180./PI*asin(
288 sin(PI/180./2.*ourview.horiz)/hmult );
289 pview.vert = 2.*180./PI*asin(
290 sin(PI/180./2.*ourview.vert)/vmult );
291 break;
292 default:
293 fprintf(stderr, "%s: unknown view type '-vt%c'\n",
294 progname, ourview.type);
295 exit(1);
296 }
297 pview.hoff += xorg - 0.5*(hmult-1);
298 pview.voff += yorg - 0.5*(vmult-1);
299 fputs(VIEWSTR, torp);
300 fprintview(&pview, torp);
301 putc('\n', torp);
302 fflush(torp); /* assign piece to rpict */
303 putpiece(xorg, yorg); /* place piece in output */
304 if (verbose) { /* notify caller */
305 printf("%d %d done\n", xorg, yorg);
306 fflush(stdout);
307 }
308 }
309 }
310
311
312 int
313 putpiece(xpos, ypos) /* get next piece from rpict */
314 int xpos, ypos;
315 {
316 struct flock fls;
317 int pid, status;
318 int hr, vr;
319 register int y;
320 /* check bounds */
321 if (xpos < 0 | ypos < 0 | xpos >= hmult | ypos >= vmult) {
322 fprintf(stderr, "%s: requested piece (%d,%d) out of range\n",
323 progname, xpos, ypos);
324 exit(1);
325 }
326 /* check header from rpict */
327 getheader(fromrp, NULL);
328 if (fscnresolu(&hr, &vr, fromrp) < 0 || hr != hres || vr != vres) {
329 fprintf(stderr, "%s: resolution mismatch from %s\n",
330 progname, rpargv[0]);
331 exit(1);
332 }
333 /* load new piece into buffer */
334 for (y = 0; y < vr; y++)
335 if (freadcolrs(pbuf+y*hr, hr, fromrp) < 0) {
336 fprintf(stderr, "%s: read error from %s\n",
337 progname, rpargv[0]);
338 exit(1);
339 }
340 #if MAXFORK
341 /* fork so we don't slow rpict down */
342 if ((pid = fork()) > 0) {
343 if (++nforked > MAXFORK) {
344 wait(&status); /* reap a child */
345 if (status)
346 exit(status>>8 & 0xff);
347 nforked--;
348 }
349 return(pid);
350 }
351 #else
352 pid = -1; /* no forking */
353 #endif
354 /* lock file section so NFS doesn't mess up */
355 fls.l_whence = 0;
356 fls.l_len = (long)vres*hmult*hres*sizeof(COLR);
357 fls.l_start = scanorig + (vmult-1-ypos)*fls.l_len;
358 fls.l_type = F_WRLCK;
359 fcntl(outfd, F_SETLKW, &fls);
360 /* write new piece to file */
361 if (lseek(outfd, fls.l_start+(long)xpos*hres*sizeof(COLR), 0) == -1)
362 goto seekerr;
363 if (hmult == 1) {
364 if (writebuf(outfd, (char *)pbuf,
365 vr*hr*sizeof(COLR)) != vr*hr*sizeof(COLR))
366 goto writerr;
367 } else
368 for (y = 0; y < vr; y++) {
369 if (writebuf(outfd, (char *)(pbuf+y*hr),
370 hr*sizeof(COLR)) != hr*sizeof(COLR))
371 goto writerr;
372 if (y < vr-1 && lseek(outfd,
373 (long)(hmult-1)*hr*sizeof(COLR),
374 1) == -1)
375 goto seekerr;
376 }
377 if (pid == -1) { /* fork failed */
378 fls.l_type = F_UNLCK; /* release lock */
379 fcntl(outfd, F_SETLKW, &fls);
380 return(0);
381 }
382 _exit(0); /* else exit child process (releasing lock) */
383 seekerr:
384 fprintf(stderr, "%s: seek error on file \"%s\"\n", progname, outfile);
385 _exit(1);
386 writerr:
387 fprintf(stderr, "%s: write error on file \"%s\"\n", progname, outfile);
388 _exit(1);
389 }
