root/radiance/src/util/rmtxop.c
Revision: 2.27
Committed: Sat Dec 2 00:42:21 2023 UTC (22 months, 1 week ago) by greg
Changes since 2.26: +89 -20 lines
feat(rmtxop): Added -c _file_ and -C options for specifying color spaces
2 static const char RCSid[] = "$Id: rmtxop.c,v 2.26 2023/12/01 02:05:00 greg Exp $";
5 * General component matrix operations.
6 */
7
8 #include <errno.h>
9 #include "rtio.h"
10 #include "resolu.h"
11 #include "rmatrix.h"
12 #include "platform.h"
13
14 #define MAXCOMP MAXCSAMP /* #components we support */
15
16 /* Unary matrix operation(s) */
17 typedef struct {
18 double cmat[MAXCOMP*MAXCOMP]; /* component transformation */
19 double sca[MAXCOMP]; /* scalar coefficients */
20 const char *csym; /* symbolic coefs or file */
21 short clen; /* number of coefficients */
22 short nsf; /* number of scalars */
23 short transpose; /* do transpose? */
24 } RUNARYOP;
25
26 /* Matrix input source and requested operation(s) */
27 typedef struct {
28 const char *inspec; /* input specification */
29 RMPref rmp; /* matrix preference */
30 RUNARYOP preop; /* unary operation(s) */
31 RMATRIX *mtx; /* original matrix if loaded */
32 int binop; /* binary op with next (or 0) */
33 } ROPMAT;
34
35 int verbose = 0; /* verbose reporting? */
36
37 /* Load matrix */
38 static int
39 loadmatrix(ROPMAT *rop)
40 {
41 if (rop->mtx != NULL) /* already loaded? */
42 return(0);
43
44 rop->mtx = rmx_load(rop->inspec, rop->rmp);
45
46 return(!rop->mtx ? -1 : 1);
47 }
48
49 static int checksymbolic(ROPMAT *rop);
50
51 /* Check/set transform based on a reference input file */
52 static int
53 checkreffile(ROPMAT *rop)
54 {
55 static const char *curRF = NULL;
56 static RMATRIX refm;
57 const int nc = rop->mtx->ncomp;
58 int i;
59
60 if (!curRF || strcmp(rop->preop.csym, curRF)) {
61 FILE *fp = fopen(rop->preop.csym, "rb");
62 if (!rmx_load_header(&refm, fp)) {
63 fprintf(stderr, "%s: cannot read info header\n",
64 rop->preop.csym);
65 curRF = NULL;
66 if (fp) fclose(fp);
67 return(-1);
68 }
69 fclose(fp);
70 curRF = rop->preop.csym;
71 }
72 if ((refm.ncomp == 3) & (refm.dtype != DTspec)) {
73 rop->preop.csym = (refm.dtype == DTxyze) ? "XYZ" : "RGB";
74 return(checksymbolic(rop));
75 }
76 if (refm.ncomp == 2) {
77 fprintf(stderr, "%s: cannot convert to 2 components\n",
78 curRF);
79 return(-1);
80 }
81 if (refm.ncomp == 1) {
82 rop->preop.csym = "Y"; /* XXX big assumption */
83 return(checksymbolic(rop));
84 }
85 if (refm.ncomp == nc &&
86 !memcmp(refm.wlpart, rop->mtx->wlpart, sizeof(refm.wlpart)))
87 return(0); /* nothing to do */
88
89 if ((nc <= 3) | (nc > MAXCSAMP) | (refm.ncomp > MAXCSAMP)) {
90 fprintf(stderr, "%s: cannot resample from %d to %d components\n",
91 curRF, nc, refm.ncomp);
92 return(-1);
93 }
94 rop->preop.clen = refm.ncomp * nc; /* compute spec to ref */
95
96 for (i = 0; i < nc; i++) {
97 SCOLOR scstim, scresp;
98 int j;
99 memset(scstim, 0, sizeof(COLORV)*nc);
100 scstim[i] = 1.f;
101 convertscolor(scresp, refm.ncomp, refm.wlpart[0], refm.wlpart[3],
102 scstim, nc, rop->mtx->wlpart[0], rop->mtx->wlpart[3]);
103 for (j = refm.ncomp; j-- > 0; )
104 rop->preop.cmat[j*nc + i] = scresp[j];
105 }
106 return(0);
107 }
108
109 /* Compute conversion row from spectrum to one channel of RGB */
110 static void
111 rgbrow(ROPMAT *rop, int r, int p)
112 {
113 const int nc = rop->mtx->ncomp;
114 const float * wlp = rop->mtx->wlpart;
115 int i;
116
117 for (i = nc; i--; ) {
118 int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc;
119 int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc;
120 COLOR crgb;
121 spec_rgb(crgb, nmStart, nmEnd);
122 rop->preop.cmat[r*nc+i] = crgb[p];
123 }
124 }
125
126 /* Compute conversion row from spectrum to one channel of XYZ */
127 static void
128 xyzrow(ROPMAT *rop, int r, int p)
129 {
130 const int nc = rop->mtx->ncomp;
131 const float * wlp = rop->mtx->wlpart;
132 int i;
133
134 for (i = nc; i--; ) {
135 int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc;
136 int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc;
137 COLOR cxyz;
138 spec_cie(cxyz, nmStart, nmEnd);
139 rop->preop.cmat[r*nc+i] = cxyz[p];
140 }
141 }
142
143 /* Use the spectral sensitivity function to compute matrix coefficients */
144 static void
145 sensrow(ROPMAT *rop, int r, double (*sf)(SCOLOR sc, int ncs, const float wlpt[4]))
146 {
147 const int nc = rop->mtx->ncomp;
148 int i;
149
150 for (i = nc; i--; ) {
151 SCOLOR sclr;
152 memset(sclr, 0, sizeof(COLORV)*nc);
153 sclr[i] = 1.f;
154 rop->preop.cmat[r*nc+i] = (*sf)(sclr, nc, rop->mtx->wlpart);
155 }
156 }
157
158 /* Check/set symbolic transform */
159 static int
160 checksymbolic(ROPMAT *rop)
161 {
162 const int nc = rop->mtx->ncomp;
163 const int dt = rop->mtx->dtype;
164 int i, j;
165 /* check suffix => reference file */
166 if (strchr(rop->preop.csym, '.') > rop->preop.csym)
167 return(checkreffile(rop));
168
169 if (nc < 3) {
170 fprintf(stderr, "%s: -c '%s' requires at least 3 components\n",
171 rop->inspec, rop->preop.csym);
172 return(-1);
173 }
174 rop->preop.clen = strlen(rop->preop.csym) * nc;
175 if (rop->preop.clen > MAXCOMP*MAXCOMP) {
176 fprintf(stderr, "%s: -c '%s' results in too many components\n",
177 rop->inspec, rop->preop.csym);
178 return(-1);
179 }
180 for (j = 0; rop->preop.csym[j]; j++) {
181 int comp = 0;
182 switch (rop->preop.csym[j]) {
183 case 'B':
184 ++comp;
185 /* fall through */
186 case 'G':
187 ++comp;
188 /* fall through */
189 case 'R':
190 if (dt == DTxyze) {
191 for (i = 3; i--; )
192 rop->preop.cmat[j*nc+i] = 1./WHTEFFICACY *
193 xyz2rgbmat[comp][i];
194 } else if (nc == 3)
195 rop->preop.cmat[j*nc+comp] = 1.;
196 else
197 rgbrow(rop, j, comp);
198 break;
199 case 'Z':
200 ++comp;
201 /* fall through */
202 case 'Y':
203 ++comp;
204 /* fall through */
205 case 'X':
206 if (dt == DTxyze) {
207 rop->preop.cmat[j*nc+comp] = 1.;
208 } else if (nc == 3) {
209 for (i = 3; i--; )
210 rop->preop.cmat[j*nc+i] =
211 rgb2xyzmat[comp][i];
212 } else if (comp == CIEY)
213 sensrow(rop, j, scolor2photopic);
214 else
215 xyzrow(rop, j, comp);
216
217 for (i = nc*(dt != DTxyze); i--; )
218 rop->preop.cmat[j*nc+i] *= WHTEFFICACY;
219 break;
220 case 'S': /* scotopic (il)luminance */
221 sensrow(rop, j, scolor2scotopic);
222 for (i = nc; i--; )
223 rop->preop.cmat[j*nc+i] *= WHTSCOTOPIC;
224 break;
225 case 'M': /* melanopic (il)luminance */
226 sensrow(rop, j, scolor2melanopic);
227 for (i = nc; i--; )
228 rop->preop.cmat[j*nc+i] *= WHTMELANOPIC;
229 break;
230 case 'A': /* average component */
231 for (i = nc; i--; )
232 rop->preop.cmat[j*nc+i] = 1./(double)nc;
233 break;
234 default:
235 fprintf(stderr, "%s: -c '%c' unsupported\n",
236 rop->inspec, rop->preop.csym[j]);
237 return(-1);
238 }
239 }
240 /* return recommended output type */
241 if (!strcmp(rop->preop.csym, "XYZ")) {
242 if (dt <= DTspec)
243 return(DTxyze);
244 } else if (!strcmp(rop->preop.csym, "RGB")) {
245 if (dt <= DTspec)
246 return(DTrgbe);
247 }
248 if ((nc > 3) & (dt <= DTspec))
249 return(DTfloat); /* probably not actual spectrum */
250 return(0);
251 }
252
253 /* Get matrix and perform unary operations */
254 static RMATRIX *
255 loadop(ROPMAT *rop)
256 {
257 int outtype = 0;
258 RMATRIX *mres;
259 int i, j;
260
261 if (loadmatrix(rop) < 0) /* make sure we're loaded */
262 return(NULL);
263
264 if (rop->preop.csym && /* symbolic transform? */
265 (outtype = checksymbolic(rop)) < 0)
266 goto failure;
267 if (rop->preop.clen > 0) { /* apply component transform? */
268 if (rop->preop.clen % rop->mtx->ncomp) {
269 fprintf(stderr, "%s: -c must have N x %d coefficients\n",
270 rop->inspec, rop->mtx->ncomp);
271 goto failure;
272 }
273 if (rop->preop.nsf > 0) { /* scale transform, first */
274 if (rop->preop.nsf == 1) {
275 for (i = rop->preop.clen; i--; )
276 rop->preop.cmat[i] *= rop->preop.sca[0];
277 } else if (rop->preop.nsf != rop->mtx->ncomp) {
278 fprintf(stderr, "%s: -s must have one or %d factors\n",
279 rop->inspec, rop->mtx->ncomp);
280 goto failure;
281 } else {
282 for (j = rop->preop.clen/rop->preop.nsf; j--; )
283 for (i = rop->preop.nsf; i--; )
284 rop->preop.cmat[j*rop->preop.nsf+i] *=
285 rop->preop.sca[i];
286 }
287 }
288 mres = rmx_transform(rop->mtx, rop->preop.clen/rop->mtx->ncomp,
289 rop->preop.cmat);
290 if (mres == NULL) {
291 fprintf(stderr, "%s: matrix transform failed\n",
292 rop->inspec);
293 goto failure;
294 }
295 if (verbose)
296 fprintf(stderr, "%s: applied %d x %d transform%s\n",
297 rop->inspec, mres->ncomp,
298 rop->mtx->ncomp,
299 rop->preop.nsf ? " (* scalar)" : "");
300 rop->preop.nsf = 0; /* now folded in */
301 if ((mres->ncomp > 3) & (mres->dtype <= DTspec))
302 outtype = DTfloat; /* probably not actual spectrum */
303 rmx_free(rop->mtx);
304 rop->mtx = mres;
305 }
306 if (rop->preop.nsf > 0) { /* apply scalar(s)? */
307 if (rop->preop.nsf == 1) {
308 for (i = rop->mtx->ncomp; --i; )
309 rop->preop.sca[i] = rop->preop.sca[0];
310 } else if (rop->preop.nsf != rop->mtx->ncomp) {
311 fprintf(stderr, "%s: -s must have one or %d factors\n",
312 rop->inspec, rop->mtx->ncomp);
313 goto failure;
314 }
315 if (!rmx_scale(rop->mtx, rop->preop.sca)) {
316 fputs(rop->inspec, stderr);
317 fputs(": scalar operation failed\n", stderr);
318 goto failure;
319 }
320 if (verbose) {
321 fputs(rop->inspec, stderr);
322 fputs(": applied scalar (", stderr);
323 for (i = 0; i < rop->preop.nsf; i++)
324 fprintf(stderr, " %f", rop->preop.sca[i]);
325 fputs(" )\n", stderr);
326 }
327 }
328 if (rop->preop.transpose) { /* transpose matrix? */
329 mres = rmx_transpose(rop->mtx);
330 if (mres == NULL) {
331 fputs(rop->inspec, stderr);
332 fputs(": transpose failed\n", stderr);
333 goto failure;
334 }
335 if (verbose) {
336 fputs(rop->inspec, stderr);
337 fputs(": transposed rows and columns\n", stderr);
338 }
339 rmx_free(rop->mtx);
340 rop->mtx = mres;
341 }
342 mres = rop->mtx;
343 rop->mtx = NULL;
344 if (outtype)
345 mres->dtype = outtype;
346 return(mres);
347 failure:
348 rmx_free(rop->mtx);
349 return(rop->mtx = NULL);
350 }
351
352 /* Execute binary operation, free matrix arguments and return new result */
353 static RMATRIX *
354 binaryop(const char *inspec, RMATRIX *mleft, int op, RMATRIX *mright)
355 {
356 RMATRIX *mres = NULL;
357 int i;
358
359 if ((mleft == NULL) | (mright == NULL))
360 return(NULL);
361 switch (op) {
362 case '.': /* concatenate */
363 if (mleft->ncomp != mright->ncomp) {
364 fputs(inspec, stderr);
365 fputs(": # components do not match\n", stderr);
366 } else if (mleft->ncols != mright->nrows) {
367 fputs(inspec, stderr);
368 fputs(": mismatched dimensions\n",
369 stderr);
370 } else
371 mres = rmx_multiply(mleft, mright);
372 rmx_free(mleft);
373 rmx_free(mright);
374 if (mres == NULL) {
375 fputs(inspec, stderr);
376 fputs(": concatenation failed\n", stderr);
377 return(NULL);
378 }
379 if (verbose) {
380 fputs(inspec, stderr);
381 fputs(": concatenated matrix\n", stderr);
382 }
383 break;
384 case '+':
385 if (!rmx_sum(mleft, mright, NULL)) {
386 fputs(inspec, stderr);
387 fputs(": matrix sum failed\n", stderr);
388 rmx_free(mleft);
389 rmx_free(mright);
390 return(NULL);
391 }
392 if (verbose) {
393 fputs(inspec, stderr);
394 fputs(": added in matrix\n", stderr);
395 }
396 rmx_free(mright);
397 mres = mleft;
398 break;
399 case '*':
400 case '/': {
401 const char * tnam = (op == '/') ?
402 "division" : "multiplication";
403 errno = 0;
404 if (!rmx_elemult(mleft, mright, (op == '/'))) {
405 fprintf(stderr, "%s: element-wise %s failed\n",
406 inspec, tnam);
407 rmx_free(mleft);
408 rmx_free(mright);
409 return(NULL);
410 }
411 if (errno)
412 fprintf(stderr,
413 "%s: warning - error during element-wise %s\n",
414 inspec, tnam);
415 else if (verbose)
416 fprintf(stderr, "%s: element-wise %s\n", inspec, tnam);
417 rmx_free(mright);
418 mres = mleft;
419 } break;
420 default:
421 fprintf(stderr, "%s: unknown operation '%c'\n", inspec, op);
422 rmx_free(mleft);
423 rmx_free(mright);
424 return(NULL);
425 }
426 return(mres);
427 }
428
429 /* Perform matrix operations from left to right */
430 static RMATRIX *
431 op_left2right(ROPMAT *mop)
432 {
433 RMATRIX *mleft = loadop(mop);
434
435 while (mop->binop) {
436 if (mleft == NULL)
437 break;
438 mleft = binaryop(mop[1].inspec,
439 mleft, mop->binop, loadop(mop+1));
440 mop++;
441 }
442 return(mleft);
443 }
444
445 /* Perform matrix operations from right to left */
446 static RMATRIX *
447 op_right2left(ROPMAT *mop)
448 {
449 RMATRIX *mright;
450 int rpos = 0;
451 /* find end of list */
452 while (mop[rpos].binop)
453 if (mop[rpos++].binop != '.') {
454 fputs(
455 "Right-to-left evaluation only for matrix multiplication!\n",
456 stderr);
457 return(NULL);
458 }
459 mright = loadop(mop+rpos);
460 while (rpos-- > 0) {
461 if (mright == NULL)
462 break;
463 mright = binaryop(mop[rpos+1].inspec,
464 loadop(mop+rpos), mop[rpos].binop, mright);
465 }
466 return(mright);
467 }
468
469 #define t_nrows(mop) ((mop)->preop.transpose ? (mop)->mtx->ncols \
470 : (mop)->mtx->nrows)
471 #define t_ncols(mop) ((mop)->preop.transpose ? (mop)->mtx->nrows \
472 : (mop)->mtx->ncols)
473
474 /* Should we prefer concatenating from rightmost matrix towards left? */
475 static int
476 prefer_right2left(ROPMAT *mop)
477 {
478 int mri = 0;
479
480 while (mop[mri].binop) /* find rightmost matrix */
481 if (mop[mri++].binop != '.')
482 return(0); /* pre-empt reversal for other ops */
483
484 if (mri <= 1)
485 return(0); /* won't matter */
486
487 if (loadmatrix(mop+mri) < 0) /* load rightmost cat */
488 return(1); /* fail will bail in a moment */
489
490 if (t_ncols(mop+mri) == 1)
491 return(1); /* definitely better R->L */
492
493 if (t_ncols(mop+mri) >= t_nrows(mop+mri))
494 return(0); /* ...probably worse */
495
496 if (loadmatrix(mop) < 0) /* load leftmost */
497 return(0); /* fail will bail in a moment */
498
499 return(t_ncols(mop+mri) < t_nrows(mop));
500 }
501
502 static int
503 get_factors(double da[], int n, char *av[])
504 {
505 int ac;
506
507 for (ac = 0; ac < n && isflt(av[ac]); ac++)
508 da[ac] = atof(av[ac]);
509 return(ac);
510 }
511
512 static ROPMAT *
513 resize_moparr(ROPMAT *mop, int n2alloc)
514 {
515 int nmats = 0;
516 int i;
517
518 while (mop[nmats++].binop)
519 ;
520 for (i = nmats; i > n2alloc; i--)
521 rmx_free(mop[i].mtx);
522 mop = (ROPMAT *)realloc(mop, n2alloc*sizeof(ROPMAT));
523 if (mop == NULL) {
524 fputs("Out of memory in resize_moparr()\n", stderr);
525 exit(1);
526 }
527 if (n2alloc > nmats)
528 memset(mop+nmats, 0, (n2alloc-nmats)*sizeof(ROPMAT));
529 return(mop);
530 }
531
532 /* Load one or more matrices and operate on them, sending results to stdout */
533 int
534 main(int argc, char *argv[])
535 {
536 int outfmt = DTfromHeader;
537 const char *defCsym = NULL;
538 int nall = 2;
539 ROPMAT *mop = (ROPMAT *)calloc(nall, sizeof(ROPMAT));
540 int nmats = 0;
541 RMATRIX *mres = NULL;
542 int stdin_used = 0;
543 int i;
544 /* get options and arguments */
545 for (i = 1; i < argc; i++) {
546 if (argv[i][0] && !argv[i][1] &&
547 strchr(".+*/", argv[i][0]) != NULL) {
548 if (!nmats || mop[nmats-1].binop) {
549 fprintf(stderr,
550 "%s: missing matrix argument before '%c' operation\n",
551 argv[0], argv[i][0]);
552 return(1);
553 }
554 mop[nmats-1].binop = argv[i][0];
555 } else if (argv[i][0] != '-' || !argv[i][1]) {
556 if (argv[i][0] == '-') {
557 if (stdin_used++) {
558 fprintf(stderr,
559 "%s: standard input used for more than one matrix\n",
560 argv[0]);
561 return(1);
562 }
563 mop[nmats].inspec = stdin_name;
564 } else
565 mop[nmats].inspec = argv[i];
566 if (!mop[nmats].preop.csym)
567 mop[nmats].preop.csym = defCsym;
568 if (nmats > 0 && !mop[nmats-1].binop)
569 mop[nmats-1].binop = '.';
570 nmats++;
571 } else {
572 int n = argc-1 - i;
573 switch (argv[i][1]) { /* get option */
574 case 'v':
575 verbose++;
576 break;
577 case 'f':
578 switch (argv[i][2]) {
579 case 'd':
580 outfmt = DTdouble;
581 break;
582 case 'f':
583 outfmt = DTfloat;
584 break;
585 case 'a':
586 outfmt = DTascii;
587 break;
588 case 'c':
589 outfmt = DTrgbe;
590 break;
591 default:
592 goto userr;
593 }
594 break;
595 case 't':
596 mop[nmats].preop.transpose = 1;
597 break;
598 case 's':
599 if (n > MAXCOMP) n = MAXCOMP;
600 i += mop[nmats].preop.nsf =
601 get_factors(mop[nmats].preop.sca,
602 n, argv+i+1);
603 if (mop[nmats].preop.nsf <= 0) {
604 fprintf(stderr, "%s: -s missing arguments\n",
605 argv[0]);
606 goto userr;
607 }
608 break;
609 case 'C':
610 if (!n || isflt(argv[i+1]))
611 goto userr;
612 defCsym = mop[nmats].preop.csym = argv[++i];
613 mop[nmats].preop.clen = 0;
614 break;
615 case 'c':
616 if (n && !isflt(argv[i+1])) {
617 mop[nmats].preop.csym = argv[++i];
618 mop[nmats].preop.clen = 0;
619 break;
620 }
621 if (n > MAXCOMP*MAXCOMP) n = MAXCOMP*MAXCOMP;
622 i += mop[nmats].preop.clen =
623 get_factors(mop[nmats].preop.cmat,
624 n, argv+i+1);
625 if (mop[nmats].preop.clen <= 0) {
626 fprintf(stderr, "%s: -c missing arguments\n",
627 argv[0]);
628 goto userr;
629 }
630 mop[nmats].preop.csym = NULL;
631 break;
632 case 'r':
633 if (argv[i][2] == 'f')
634 mop[nmats].rmp = RMPreflF;
635 else if (argv[i][2] == 'b')
636 mop[nmats].rmp = RMPreflB;
637 else
638 goto userr;
639 break;
640 default:
641 fprintf(stderr, "%s: unknown operation '%s'\n",
642 argv[0], argv[i]);
643 goto userr;
644 }
645 }
646 if (nmats >= nall)
647 mop = resize_moparr(mop, nall += 2);
648 }
649 if (mop[0].inspec == NULL) /* nothing to do? */
650 goto userr;
651 if (mop[nmats-1].binop) {
652 fprintf(stderr,
653 "%s: missing matrix argument after '%c' operation\n",
654 argv[0], mop[nmats-1].binop);
655 return(1);
656 }
657 /* favor quicker concatenation */
658 mop[nmats].mtx = prefer_right2left(mop) ? op_right2left(mop)
659 : op_left2right(mop);
660 if (mop[nmats].mtx == NULL)
661 return(1);
662 /* apply trailing unary operations */
663 mop[nmats].inspec = "trailing_ops";
664 mres = loadop(mop+nmats);
665 if (mres == NULL)
666 return(1);
667 if (outfmt == DTfromHeader) /* check data type */
668 outfmt = mres->dtype;
669 if (outfmt == DTrgbe) {
670 if (mres->ncomp > 3)
671 outfmt = DTspec;
672 else if (mres->dtype == DTxyze)
673 outfmt = DTxyze;
674 }
675 newheader("RADIANCE", stdout); /* write result to stdout */
676 printargs(argc, argv, stdout);
677 return(rmx_write(mres, outfmt, stdout) ? 0 : 1);
678 userr:
679 fprintf(stderr,
680 "Usage: %s [-v][-f{adfc}][-t][-s sf .. | -c ce ..][-rf|-rb] m1 [.+*/] .. > mres\n",
681 argv[0]);
682 return(1);
683 }
