root/radiance/src/util/rmatrix.c
Mon Aug 11 22:31:33 2025 UTC (2 months, 1 week ago) by greg
Changes since 2.100: +26 -26 lines
Diff to previous 2.100 , to selected 2.87
refactor: Got rid of confusing use of 'nc' for number of components
Thu Jun 19 22:03:37 2025 UTC (3 months, 4 weeks ago) by greg
CVS Tags: rad6R0
Changes since 2.99: +5 -6 lines
Diff to previous 2.99 , to selected 2.87
fix(rmtxop): In-core transpose wasn't working for square matrices(!)
Tue Apr 22 04:45:25 2025 UTC (5 months, 3 weeks ago) by greg
Changes since 2.98: +2 -2 lines
Diff to previous 2.98 , to selected 2.87
fix: Added check to return value of pclose() in several tools
Sat Apr 19 17:12:59 2025 UTC (5 months, 4 weeks ago) by greg
Changes since 2.97: +1 -74 lines
Diff to previous 2.97 , to selected 2.87
refactor: Isolated RMATRIX<->CMATRIX conversion routines
Fri Apr 18 23:59:03 2025 UTC (6 months ago) by greg
Changes since 2.96: +3 -16 lines
Diff to previous 2.96 , to selected 2.87
Thu Apr 17 23:30:16 2025 UTC (6 months ago) by greg
Changes since 2.95: +7 -8 lines
Diff to previous 2.95 , to selected 2.87
perf(rmtxop): Truly trivial optimization
Thu Apr 17 15:54:36 2025 UTC (6 months ago) by greg
Changes since 2.94: +9 -8 lines
Diff to previous 2.94 , to selected 2.87
perf(rmtxop): Another minor optimization in general transpose operation
Wed Apr 16 22:56:12 2025 UTC (6 months ago) by greg
Changes since 2.93: +13 -13 lines
Diff to previous 2.93 , to selected 2.87
fix(rmtxop): Forgot cast that may be needed for very large matrices
Wed Apr 16 22:47:16 2025 UTC (6 months ago) by greg
Changes since 2.92: +8 -5 lines
Diff to previous 2.92 , to selected 2.87
perf(rmtxop): Minor optimization in last change
Wed Apr 16 21:54:15 2025 UTC (6 months ago) by greg
Changes since 2.91: +52 -26 lines
Diff to previous 2.91 , to selected 2.87
perf(rmtxop): Made transpose work in situ for all matrices
Wed Apr 16 20:20:14 2025 UTC (6 months ago) by greg
Changes since 2.90: +11 -7 lines
Diff to previous 2.90 , to selected 2.87
perf: Minor optimizations should not affect results
Fri Apr 4 22:47:56 2025 UTC (6 months, 2 weeks ago) by greg
Changes since 2.89: +7 -3 lines
Diff to previous 2.89 , to selected 2.87
fix(rmtxop,rcomb): Minor fixes to auto-typing, preferring native output
Fri Apr 4 18:06:48 2025 UTC (6 months, 2 weeks ago) by greg
Changes since 2.88: +110 -57 lines
Diff to previous 2.88 , to selected 2.87
Fri Apr 4 02:53:03 2025 UTC (6 months, 2 weeks ago) by greg
Changes since 2.87: +10 -9 lines
Diff to previous 2.87
perf(rmtxop): Simplified logic and allow rmx_transfer_data() to work more cases
Revision 2.87 - (view) (download) (annotate) - [selected]
Fri Apr 4 01:48:25 2025 UTC (6 months, 2 weeks ago) by greg
Changes since 2.86: +42 -27 lines
Diff to previous 2.86
perf(rmtxop): Changed rmx_transpose() call to do in-situ operation on square matrices
Fri Mar 28 00:06:36 2025 UTC (6 months, 3 weeks ago) by greg
Changes since 2.85: +19 -15 lines
Diff to previous 2.85 , to selected 2.87
refactor: Made MAXCOMP redefinable and common between rmatrix tools
Mon Mar 24 18:55:57 2025 UTC (6 months, 3 weeks ago) by greg
Changes since 2.84: +3 -3 lines
Diff to previous 2.84 , to selected 2.87
fix: Added checks for too many spectral samples
Sat Mar 22 01:27:22 2025 UTC (6 months, 4 weeks ago) by greg
Changes since 2.83: +4 -8 lines
Diff to previous 2.83 , to selected 2.87
perf: Minor performance tweaks
Tue Oct 8 00:43:57 2024 UTC (12 months, 1 week ago) by greg
Changes since 2.82: +20 -23 lines
Diff to previous 2.82 , to selected 2.87
refactor: Minor optimizations, simplifications, and error-checking
Thu Jun 6 17:01:05 2024 UTC (16 months, 1 week ago) by greg
Changes since 2.81: +28 -30 lines
Diff to previous 2.81 , to selected 2.87
refactor: Switched out "double" for "rmx_dtype" most places
Thu Jun 6 16:46:31 2024 UTC (16 months, 1 week ago) by greg
Changes since 2.80: +26 -26 lines
Diff to previous 2.80 , to selected 2.87
fix: Minor improvement to logic surrounding memory allocation
Tue Jun 4 21:23:11 2024 UTC (16 months, 2 weeks ago) by greg
Changes since 2.79: +7 -5 lines
Diff to previous 2.79 , to selected 2.87
fix(rcomb): Added child process to sequence output; seems to finally work
Sun May 19 15:32:24 2024 UTC (17 months ago) by greg
Changes since 2.78: +32 -22 lines
Diff to previous 2.78 , to selected 2.87
feat: Added facility for app-managed matrix memory
Thu Feb 29 03:11:13 2024 UTC (19 months, 2 weeks ago) by greg
Diff to previous 2.77 , to selected 2.87
fix(rcomb): Spectral scanlines were being output in reverse order
Thu Dec 21 23:58:05 2023 UTC (21 months, 4 weeks ago) by greg
Changes since 2.76: +4 -2 lines
Diff to previous 2.76 , to selected 2.87
fix(rmtxop,rcomb): Added missing error message when input is unavailable
Tue Dec 12 18:45:53 2023 UTC (22 months ago) by greg
Changes since 2.75: +9 -5 lines
Diff to previous 2.75 , to selected 2.87
fix: made rmx_transfer_data() work when destination is memory-mapped
Mon Dec 11 19:00:22 2023 UTC (22 months, 1 week ago) by greg
Changes since 2.74: +4 -2 lines
Diff to previous 2.74 , to selected 2.87
fix(rmtxop,rmtxcomb): Fixed -fc option for spectral output
Fri Dec 8 00:12:31 2023 UTC (22 months, 1 week ago) by greg
Changes since 2.73: +4 -4 lines
Diff to previous 2.73 , to selected 2.87
fix(rmtxop,rmtxcomb): Eliminated the option of spectral output with 3 components
Wed Dec 6 17:57:34 2023 UTC (22 months, 1 week ago) by greg
Changes since 2.72: +25 -1 lines
Diff to previous 2.72 , to selected 2.87
refactor(rmtxcomb): Added library function to transfer matrix data
Tue Dec 5 21:45:39 2023 UTC (22 months, 1 week ago) by greg
Diff to previous 2.71 , to selected 2.87
fix(rmtxop,rmtxcomb): Fixed bug in ASCII matrix output
Tue Dec 5 21:13:38 2023 UTC (22 months, 1 week ago) by greg
Changes since 2.70: +4 -3 lines
Diff to previous 2.70 , to selected 2.87
fix(rmtxcomb): Additional bug fixes
Tue Dec 5 01:06:10 2023 UTC (22 months, 2 weeks ago) by greg
Diff to previous 2.69 , to selected 2.87
feat(rmtxcomb): Initial check-in of new matrix combining tool
Mon Dec 4 22:02:40 2023 UTC (22 months, 2 weeks ago) by greg
Changes since 2.68: +21 -13 lines
Diff to previous 2.68 , to selected 2.87
feat: Allow copy to be made of unallocated matrix in rmx_copy()
Sat Dec 2 16:28:35 2023 UTC (22 months, 2 weeks ago) by greg
Changes since 2.67: +19 -18 lines
Diff to previous 2.67 , to selected 2.87
feat: Made rmatrix i/o routines a little more forgiving of unknown # rows
Fri Dec 1 02:05:00 2023 UTC (22 months, 2 weeks ago) by greg
Changes since 2.66: +120 -127 lines
Diff to previous 2.66 , to selected 2.87
refactor(rmtxop): Changed rmatrix library interface for by row matrix output
Tue Nov 28 21:28:11 2023 UTC (22 months, 2 weeks ago) by greg
Changes since 2.65: +3 -8 lines
Diff to previous 2.65 , to selected 2.87
perf(rmtxop): Eliminated unnecessary loop for writing double matrix data
Tue Nov 28 21:07:20 2023 UTC (22 months, 2 weeks ago) by greg
Changes since 2.64: +80 -93 lines
Diff to previous 2.64 , to selected 2.87
refactor: Added ability to read matrix data a row at a time
Tue Nov 28 16:19:31 2023 UTC (22 months, 3 weeks ago) by greg
Changes since 2.63: +9 -10 lines
Diff to previous 2.63 , to selected 2.87
fix(rmtxop): fine-tuned header output for spectral data
Tue Nov 28 00:46:23 2023 UTC (22 months, 3 weeks ago) by greg
Changes since 2.62: +8 -7 lines
Diff to previous 2.62 , to selected 2.87
refactor: Changed return value for rmx_load_header() to true/false
Tue Nov 28 00:39:56 2023 UTC (22 months, 3 weeks ago) by greg
Changes since 2.61: +112 -83 lines
Diff to previous 2.61 , to selected 2.87
refactor: Separated header and data loading from matrices (except XMLs)
Mon Nov 27 22:04:45 2023 UTC (22 months, 3 weeks ago) by greg
Changes since 2.60: +4 -7 lines
Diff to previous 2.60 , to selected 2.87
feat(rmtxop): Added symbolic transforms to -c option and made -s apply after any such transform, so both may be used simultaneously
Tue Nov 21 01:30:20 2023 UTC (22 months, 4 weeks ago) by greg
Changes since 2.59: +134 -26 lines
Diff to previous 2.59 , to selected 2.87
Sat Jul 1 15:25:26 2023 UTC (2 years, 3 months ago) by greg
Diff to previous 2.58 , to selected 2.87
fix(rmtxop): potential overrun of #? header ID
Thu May 18 23:55:10 2023 UTC (2 years, 5 months ago) by greg
Changes since 2.57: +19 -12 lines
Diff to previous 2.57 , to selected 2.87
perf: made EXPOSURE and COLORCORR handling more consistent across types
Mon Mar 14 23:28:14 2022 UTC (3 years, 7 months ago) by greg
Diff to previous 2.56 , to selected 2.87
fix(rmtxop): Fixed recently introduced bug in RGBE/XYZE load function
Fri Mar 11 01:11:13 2022 UTC (3 years, 7 months ago) by greg
Changes since 2.55: +5 -5 lines
Diff to previous 2.55 , to selected 2.87
perf(rmtxop): Minor tweak for transpose to improve mmap efficiency
Sun Mar 6 17:21:49 2022 UTC (3 years, 7 months ago) by greg
Changes since 2.54: +3 -3 lines
Diff to previous 2.54 , to selected 2.87
fix(rmtxop): Fixed bug introduced in previous change for transpose operation
Sat Mar 5 15:33:09 2022 UTC (3 years, 7 months ago) by greg
Changes since 2.53: +7 -14 lines
Diff to previous 2.53 , to selected 2.87
perf(rmtxop): realized simpler solution to output of RGBE or XYZE from 1 chan
Sat Mar 5 01:45:21 2022 UTC (3 years, 7 months ago) by greg
Changes since 2.52: +65 -52 lines
Diff to previous 2.52 , to selected 2.87
refactor(rmtxop): Changed matrix array access macros
Fri Mar 4 17:17:28 2022 UTC (3 years, 7 months ago) by greg
Changes since 2.51: +24 -22 lines
Diff to previous 2.51 , to selected 2.87
perf(rmtxop): Reduced memory use when writing HDR output from single channel
Fri Mar 4 02:07:34 2022 UTC (3 years, 7 months ago) by greg
Changes since 2.50: +3 -2 lines
Diff to previous 2.50 , to selected 2.87
perf(rmtxop): Turned off memory-mapped input for files < 1 MByte
Fri Mar 4 01:27:12 2022 UTC (3 years, 7 months ago) by greg
Changes since 2.49: +95 -53 lines
Diff to previous 2.49 , to selected 2.87
perf(rmtxop): Added memory-mapping for double matrices
Thu Mar 3 03:55:13 2022 UTC (3 years, 7 months ago) by greg
Changes since 2.48: +2 -2 lines
Diff to previous 2.48 , to selected 2.87
feat: Added float and double alignment to i/o routines for future mmap() use
Thu Mar 18 00:34:31 2021 UTC (4 years, 7 months ago) by greg
Changes since 2.47: +20 -2 lines
Diff to previous 2.47 , to selected 2.87
fix: added check for primaries to write XYZE file
Fri Jan 22 16:19:15 2021 UTC (4 years, 8 months ago) by greg
Changes since 2.46: +4 -2 lines
Diff to previous 2.46 , to selected 2.87
fix: reinstated interpretation of NULL file name as stdin, so dctimestep works
Tue Jan 19 23:32:00 2021 UTC (4 years, 8 months ago) by greg
Changes since 2.45: +11 -9 lines
Diff to previous 2.45 , to selected 2.87
Fri Jan 15 02:46:28 2021 UTC (4 years, 9 months ago) by greg
Diff to previous 2.44 , to selected 2.87
fix: fixed malloc() call overflow for large matrices
Thu May 7 18:45:16 2020 UTC (5 years, 5 months ago) by greg
Diff to previous 2.43 , to selected 2.87
Fixed silly/fatal error in previous modifications
Thu Mar 26 18:05:44 2020 UTC (5 years, 6 months ago) by greg
Changes since 2.42: +3 -2 lines
Diff to previous 2.42 , to selected 2.87
Better fix to bug in last change
Thu Mar 26 18:04:24 2020 UTC (5 years, 6 months ago) by greg
Changes since 2.41: +2 -3 lines
Diff to previous 2.41 , to selected 2.87
Fixed bug in last change
Thu Mar 26 18:01:26 2020 UTC (5 years, 6 months ago) by greg
Changes since 2.40: +13 -8 lines
Diff to previous 2.40 , to selected 2.87
Minor efficiency improvements
Wed Mar 25 01:51:09 2020 UTC (5 years, 6 months ago) by greg
Changes since 2.39: +21 -2 lines
Diff to previous 2.39 , to selected 2.87
Sat Dec 28 18:05:14 2019 UTC (5 years, 9 months ago) by greg
Changes since 2.38: +1 -4 lines
Diff to previous 2.38 , to selected 2.87
Tue Sep 10 17:22:55 2019 UTC (6 years, 1 month ago) by greg
Diff to previous 2.37 , to selected 2.87
Info clarification
Wed Sep 4 00:03:05 2019 UTC (6 years, 1 month ago) by greg
Changes since 2.36: +3 -3 lines
Diff to previous 2.36 , to selected 2.87
Fixed binary mode setting
Tue Sep 3 23:43:07 2019 UTC (6 years, 1 month ago) by greg
Changes since 2.35: +2 -1 lines
Diff to previous 2.35 , to selected 2.87
Minor changes should not affect behavior
Wed Aug 14 18:20:02 2019 UTC (6 years, 2 months ago) by greg
Changes since 2.34: +16 -2 lines
Diff to previous 2.34 , to selected 2.87
Mon Aug 12 20:38:19 2019 UTC (6 years, 2 months ago) by greg
Changes since 2.33: +2 -2 lines
Diff to previous 2.33 , to selected 2.87
Added warning about divide-by-zero to matrix information header
Mon Aug 12 18:15:44 2019 UTC (6 years, 2 months ago) by greg
Changes since 2.32: +35 -36 lines
Diff to previous 2.32 , to selected 2.87
Made checks more compact and consistent
Mon Aug 12 04:46:34 2019 UTC (6 years, 2 months ago) by greg
Changes since 2.31: +3 -1 lines
Diff to previous 2.31 , to selected 2.87
Forgot to check for no memory
Mon Aug 12 04:12:57 2019 UTC (6 years, 2 months ago) by greg
Changes since 2.30: +7 -1 lines
Diff to previous 2.30 , to selected 2.87
Special case for vector transpose
Fri Oct 19 00:21:31 2018 UTC (7 years ago) by greg
Changes since 2.29: +5 -2 lines
Diff to previous 2.29 , to selected 2.87
Made ASCII output sensitive to matrix precision
Thu Aug 2 18:33:50 2018 UTC (7 years, 2 months ago) by greg
Diff to previous 2.28 , to selected 2.87
Wed Jun 13 18:36:38 2018 UTC (7 years, 4 months ago) by greg
Changes since 2.27: +10 -1 lines
Diff to previous 2.27 , to selected 2.87
Improved commenting on matrix operations for rmtxop
Mon Apr 9 21:36:45 2018 UTC (7 years, 6 months ago) by greg
Changes since 2.26: +4 -4 lines
Diff to previous 2.26 , to selected 2.87
Saved a little time and memory when writing out RGBE data
Mon Apr 9 21:30:07 2018 UTC (7 years, 6 months ago) by greg
Changes since 2.25: +7 -23 lines
Diff to previous 2.25 , to selected 2.87
Made double i/o more efficient by avoiding unnecessary element copies
Mon Aug 28 15:59:46 2017 UTC (8 years, 1 month ago) by greg
Changes since 2.24: +59 -1 lines
Diff to previous 2.24 , to selected 2.87
Tue Aug 30 15:11:22 2016 UTC (9 years, 1 month ago) by greg
Changes since 2.23: +2 -3 lines
Diff to previous 2.23 , to selected 2.87
Re-removed long double promotion, which I'd already done and undone previously!
Tue Aug 30 14:54:08 2016 UTC (9 years, 1 month ago) by greg
Changes since 2.22: +3 -2 lines
Diff to previous 2.22 , to selected 2.87
Force promotion to long double
Thu Aug 18 17:57:57 2016 UTC (9 years, 2 months ago) by greg
Changes since 2.21: +4 -10 lines
Diff to previous 2.21 , to selected 2.87
Thu Aug 18 00:52:48 2016 UTC (9 years, 2 months ago) by greg
Changes since 2.20: +6 -5 lines
Diff to previous 2.20 , to selected 2.87
Sun Mar 6 01:13:18 2016 UTC (9 years, 7 months ago) by schorsch
Changes since 2.19: +5 -4 lines
Diff to previous 2.19 , to selected 2.87
Tue Feb 2 18:02:32 2016 UTC (9 years, 8 months ago) by greg
Diff to previous 2.18 , to selected 2.87
Thu Aug 27 04:07:05 2015 UTC (10 years, 1 month ago) by greg
Diff to previous 2.17 , to selected 2.87
Make sure result from loading XML file is ASCII
Wed Jul 22 04:47:51 2015 UTC (10 years, 3 months ago) by greg
Changes since 2.16: +12 -7 lines
Diff to previous 2.16 , to selected 2.87
Moved some file settings around to improve logic
Wed Jul 22 04:29:56 2015 UTC (10 years, 3 months ago) by greg
Changes since 2.15: +2 -3 lines
Diff to previous 2.15 , to selected 2.87
Reduced precision of multiplies in favor of time when little differ found
Fri May 8 18:25:03 2015 UTC (10 years, 5 months ago) by greg
Diff to previous 2.14 , to selected 2.87
Added rtprocess.h needed for popen() under Windows
Mon May 4 23:27:04 2015 UTC (10 years, 5 months ago) by greg
Diff to previous 2.13 , to selected 2.87
Minor type-checking fix
Mon May 4 20:53:21 2015 UTC (10 years, 5 months ago) by greg
Changes since 2.12: +28 -11 lines
Diff to previous 2.12 , to selected 2.87
Fri Jan 23 01:14:20 2015 UTC (10 years, 8 months ago) by greg
Changes since 2.11: +5 -7 lines
Diff to previous 2.11 , to selected 2.87
Fixed rmx_identity(), which was incorrect as first written but never used
Tue Dec 16 20:21:46 2014 UTC (10 years, 10 months ago) by greg
Diff to previous 2.10 , to selected 2.87
Fixed output format for ASCII from ASCII inputs
Thu Sep 18 23:20:12 2014 UTC (11 years, 1 month ago) by greg
CVS Tags: rad4R2P2
Changes since 2.9: +3 -3 lines
Diff to previous 2.9 , to selected 2.87
Took out unreliable call to ftell()
Thu Aug 28 05:59:42 2014 UTC (11 years, 1 month ago) by greg
CVS Tags: rad4R2P1
Diff to previous 2.8 , to selected 2.87
Bug fix pointed out by Andy McNeil
Wed Aug 27 13:33:47 2014 UTC (11 years, 1 month ago) by greg
Changes since 2.7: +6 -5 lines
Diff to previous 2.7 , to selected 2.87
Bug fixes in matrix concatenation
Tue Aug 5 21:45:05 2014 UTC (11 years, 2 months ago) by greg
Changes since 2.6: +4 -1 lines
Diff to previous 2.6 , to selected 2.87
Added missing _O_BINARY setting for Windows
Sat Aug 2 17:10:43 2014 UTC (11 years, 2 months ago) by greg
Changes since 2.5: +56 -27 lines
Diff to previous 2.5 , to selected 2.87
Fri Aug 1 23:37:24 2014 UTC (11 years, 2 months ago) by greg
Changes since 2.4: +47 -3 lines
Diff to previous 2.4 , to selected 2.87
Maintain header information in matrix structure
Thu Jul 24 16:28:17 2014 UTC (11 years, 2 months ago) by greg
CVS Tags: rad4R2
Changes since 2.3: +9 -3 lines
Diff to previous 2.3 , to selected 2.87
Made NROWS/NCOLS more consistent with resolution string
Tue Jul 8 16:39:41 2014 UTC (11 years, 3 months ago) by greg
Diff to previous 2.2 , to selected 2.87
Removed unnecessary address operators from function ids.
Sat May 31 19:21:21 2014 UTC (11 years, 4 months ago) by greg
Changes since 2.1: +13 -19 lines
Diff to previous 2.1 , to selected 2.87
Bug fixes
Sat May 31 05:02:37 2014 UTC (11 years, 4 months ago) by greg
Diff to selected 2.87
