root/radiance/src/util/rcomb.c
Revision: 2.34
Committed: Tue Aug 5 16:40:10 2025 UTC (8 weeks, 3 days ago) by greg
Changes since 2.33: +13 -1 lines
docs(rcomb): Added better commenting to functions
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.34 static const char RCSid[] = "$Id: rcomb.c,v 2.33 2025/08/02 20:37:52 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * General component matrix combiner, operating on a row at a time.
6 greg 2.18 *
7     * Multi-processing mode under Unix creates children that each work
8 greg 2.19 * on one input row at a time, fed by the original process. Final conversion
9 greg 2.20 * and output to stdout is sorted by last child while its siblings send it
10 greg 2.19 * their record calculations.
11 greg 2.1 */
12
13     #include <math.h>
14     #include "platform.h"
15 greg 2.10 #include "rtprocess.h"
16 greg 2.1 #include "rtio.h"
17     #include "rmatrix.h"
18     #include "calcomp.h"
19
20     #ifndef M_PI
21     #define M_PI 3.14159265358979323846
22     #endif
23
24     /* Unary matrix operation(s) */
25     typedef struct {
26     double cmat[MAXCOMP*MAXCOMP]; /* component transformation */
27     double sca[MAXCOMP]; /* scalar coefficients */
28     const char *csym; /* symbolic coefficients */
29     short clen; /* number of coefficients */
30     short nsf; /* number of scalars */
31     } RUNARYOP;
32
33     /* Input matrix */
34     typedef struct {
35     const char *inspec; /* input specification */
36     RUNARYOP preop; /* transform operation */
37     RMATRIX imx; /* input matrix header info */
38     RMATRIX *rmp; /* active single-row matrix */
39     FILE *infp; /* open input stream */
40     } ROPMAT;
41
42     ROPMAT *mop = NULL; /* allocated input array */
43     int nall = 0; /* number allocated */
44     int nmats = 0; /* number of actual inputs */
45
46     RMATRIX *mcat = NULL; /* final concatenation */
47     int mcat_last = 0; /* goes after trailing ops? */
48
49 greg 2.2 int in_nrows; /* number of input rows (or 0) */
50     #define in_ncols (mop[0].rmp->ncols) /* number of input columns */
51 greg 2.1 #define in_ncomp (mop[0].rmp->ncomp) /* input #components */
52
53     extern int nowarn; /* turn off warnings? */
54
55     int cur_row; /* current input/output row */
56     int cur_col; /* current input/output column */
57     int cur_chan; /* if we're looping channels */
58
59 greg 2.10 SUBPROC *cproc = NULL; /* child process array */
60     int nchildren = 0; /* # of child processes */
61     int inchild = -1; /* our child ID (-1: parent) */
62
63 greg 2.22 extern int checksymbolic(ROPMAT *rop);
64 greg 2.1
65 greg 2.34 /* Split input matrices to allow for certain operations */
66 greg 2.22 int
67 greg 2.1 split_input(ROPMAT *rop)
68     {
69     if (rop->rmp == &rop->imx && !(rop->rmp = rmx_copy(&rop->imx))) {
70     fputs("Out of memory in split_input()\n", stderr);
71     return(0);
72     }
73     rmx_reset(rop->rmp);
74     return(1);
75     }
76
77     /* Check/set transform based on a reference input file */
78 greg 2.22 int
79 greg 2.1 checkreffile(ROPMAT *rop)
80     {
81     static const char *curRF = NULL;
82     static RMATRIX refm;
83     const int nc = rop->imx.ncomp;
84     int i;
85
86     if (!curRF || strcmp(rop->preop.csym, curRF)) {
87     FILE *fp = fopen(rop->preop.csym, "rb");
88     if (!rmx_load_header(&refm, fp)) {
89     fprintf(stderr, "%s: cannot read info header\n",
90     rop->preop.csym);
91     curRF = NULL;
92     if (fp) fclose(fp);
93     return(0);
94     }
95     fclose(fp);
96     curRF = rop->preop.csym;
97     }
98     if (refm.ncomp == 3) {
99     rop->preop.csym = (refm.dtype == DTxyze) ? "XYZ" : "RGB";
100     return(checksymbolic(rop));
101     }
102     if (refm.ncomp == 2) {
103     fprintf(stderr, "%s: cannot convert to 2 components\n",
104     curRF);
105     return(0);
106     }
107     if (refm.ncomp == 1) {
108     rop->preop.csym = "Y"; /* XXX big assumption */
109     return(checksymbolic(rop));
110     }
111     if (refm.ncomp == nc &&
112     !memcmp(refm.wlpart, rop->imx.wlpart, sizeof(refm.wlpart)))
113     return(1); /* nothing to do */
114
115     if ((nc <= 3) | (nc > MAXCSAMP) | (refm.ncomp > MAXCSAMP)) {
116     fprintf(stderr, "%s: cannot resample from %d to %d components\n",
117     curRF, nc, refm.ncomp);
118     return(0);
119     }
120     if (!split_input(rop)) /* get our own struct */
121     return(0);
122     rop->preop.clen = refm.ncomp * nc; /* compute spec to ref */
123
124     for (i = 0; i < nc; i++) {
125     SCOLOR scstim, scresp;
126     int j;
127     memset(scstim, 0, sizeof(COLORV)*nc);
128     scstim[i] = 1.f;
129     convertscolor(scresp, refm.ncomp, refm.wlpart[0], refm.wlpart[3],
130     scstim, nc, rop->imx.wlpart[0], rop->imx.wlpart[3]);
131     for (j = refm.ncomp; j-- > 0; )
132     rop->preop.cmat[j*nc + i] = scresp[j];
133     }
134     /* remember new spectral params */
135     memcpy(rop->rmp->wlpart, refm.wlpart, sizeof(rop->rmp->wlpart));
136     rop->rmp->ncomp = refm.ncomp;
137     return(1);
138     }
139
140     /* Compute conversion row from spectrum to one channel of RGB */
141 greg 2.22 void
142 greg 2.1 rgbrow(ROPMAT *rop, int r, int p)
143     {
144     const int nc = rop->imx.ncomp;
145     const float * wlp = rop->imx.wlpart;
146     int i;
147
148     for (i = nc; i--; ) {
149     int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc;
150     int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc;
151     COLOR crgb;
152     spec_rgb(crgb, nmStart, nmEnd);
153     rop->preop.cmat[r*nc+i] = crgb[p];
154     }
155     }
156
157     /* Compute conversion row from spectrum to one channel of XYZ */
158 greg 2.22 void
159 greg 2.1 xyzrow(ROPMAT *rop, int r, int p)
160     {
161     const int nc = rop->imx.ncomp;
162     const float * wlp = rop->imx.wlpart;
163     int i;
164
165     for (i = nc; i--; ) {
166     int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc;
167     int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc;
168     COLOR cxyz;
169     spec_cie(cxyz, nmStart, nmEnd);
170     rop->preop.cmat[r*nc+i] = cxyz[p];
171     }
172     }
173
174     /* Use the spectral sensitivity function to compute matrix coefficients */
175 greg 2.22 void
176 greg 2.25 sensrow(ROPMAT *rop, int r, double (*sf)(const SCOLOR sc, int ncs, const float wlpt[4]))
177 greg 2.1 {
178     const int nc = rop->imx.ncomp;
179     int i;
180
181     for (i = nc; i--; ) {
182     SCOLOR sclr;
183     memset(sclr, 0, sizeof(COLORV)*nc);
184     sclr[i] = 1.f;
185     rop->preop.cmat[r*nc+i] = (*sf)(sclr, nc, rop->imx.wlpart);
186     }
187     }
188
189     /* Check/set symbolic transform */
190 greg 2.22 int
191 greg 2.1 checksymbolic(ROPMAT *rop)
192     {
193     const int nc = rop->imx.ncomp;
194     const int dt = rop->imx.dtype;
195 greg 2.3 double cf = 1;
196 greg 2.1 int i, j;
197     /* check suffix => reference file */
198 greg 2.33 if (strchr(rop->preop.csym, '.') != NULL)
199 greg 2.1 return(checkreffile(rop));
200
201     if (nc < 3) {
202     fprintf(stderr, "%s: -c '%s' requires at least 3 components\n",
203     rop->inspec, rop->preop.csym);
204     return(0);
205     }
206     rop->preop.clen = strlen(rop->preop.csym) * nc;
207     if (rop->preop.clen > MAXCOMP*MAXCOMP) {
208     fprintf(stderr, "%s: -c '%s' results in too many components\n",
209     rop->inspec, rop->preop.csym);
210     return(0);
211     }
212     for (j = 0; rop->preop.csym[j]; j++) {
213     int comp = 0;
214     switch (rop->preop.csym[j]) {
215     case 'B':
216 greg 2.3 case 'b':
217 greg 2.1 ++comp;
218     /* fall through */
219     case 'G':
220 greg 2.3 case 'g':
221 greg 2.1 ++comp;
222     /* fall through */
223     case 'R':
224 greg 2.3 case 'r':
225     if (rop->preop.csym[j] <= 'Z')
226     cf = 1./WHTEFFICACY;
227 greg 2.1 if (dt == DTxyze) {
228     for (i = 3; i--; )
229 greg 2.3 rop->preop.cmat[j*nc+i] = cf*xyz2rgbmat[comp][i];
230 greg 2.1 } else if (nc == 3)
231     rop->preop.cmat[j*nc+comp] = 1.;
232     else
233     rgbrow(rop, j, comp);
234     break;
235     case 'Z':
236 greg 2.3 case 'z':
237 greg 2.1 ++comp;
238     /* fall through */
239     case 'Y':
240 greg 2.3 case 'y':
241 greg 2.1 ++comp;
242     /* fall through */
243     case 'X':
244 greg 2.3 case 'x':
245     if ((rop->preop.csym[j] <= 'Z') & (dt != DTxyze))
246     cf = WHTEFFICACY;
247 greg 2.1 if (dt == DTxyze) {
248     rop->preop.cmat[j*nc+comp] = 1.;
249     } else if (nc == 3) {
250     for (i = 3; i--; )
251     rop->preop.cmat[j*nc+i] =
252     rgb2xyzmat[comp][i];
253     } else if (comp == CIEY)
254     sensrow(rop, j, scolor2photopic);
255     else
256     xyzrow(rop, j, comp);
257
258 greg 2.3 for (i = nc*(cf != 1); i--; )
259     rop->preop.cmat[j*nc+i] *= cf;
260 greg 2.1 break;
261     case 'S': /* scotopic (il)luminance */
262 greg 2.3 cf = WHTSCOTOPIC;
263     /* fall through */
264     case 's':
265 greg 2.1 sensrow(rop, j, scolor2scotopic);
266 greg 2.3 for (i = nc*(cf != 1); i--; )
267     rop->preop.cmat[j*nc+i] *= cf;
268 greg 2.1 break;
269     case 'M': /* melanopic (il)luminance */
270 greg 2.3 cf = WHTMELANOPIC;
271     /* fall through */
272     case 'm':
273 greg 2.1 sensrow(rop, j, scolor2melanopic);
274 greg 2.3 for (i = nc*(cf != 1); i--; )
275     rop->preop.cmat[j*nc+i] *= cf;
276 greg 2.1 break;
277     case 'A': /* average component */
278 greg 2.3 case 'a':
279 greg 2.1 for (i = nc; i--; )
280     rop->preop.cmat[j*nc+i] = 1./(double)nc;
281     break;
282     default:
283     fprintf(stderr, "%s: -c '%c' unsupported\n",
284     rop->inspec, rop->preop.csym[j]);
285     return(0);
286     }
287     }
288     if (!split_input(rop)) /* get our own struct */
289     return(0);
290     memcpy(rop->rmp->wlpart, WLPART, sizeof(rop->rmp->wlpart));
291     rop->rmp->ncomp = rop->preop.clen / nc;
292     /* decide on output type */
293 greg 2.4 if (!strcasecmp(rop->preop.csym, "XYZ")) {
294 greg 2.1 if (dt <= DTspec)
295     rop->rmp->dtype = DTxyze;
296 greg 2.4 } else if (!strcasecmp(rop->preop.csym, "RGB")) {
297 greg 2.1 if (dt <= DTspec)
298     rop->rmp->dtype = DTrgbe;
299     } else if (rop->rmp->dtype == DTspec)
300     rop->rmp->dtype = DTfloat;
301     return(1);
302     }
303
304 greg 2.34 /* Set up color transform for matrix */
305 greg 2.22 int
306 greg 2.1 get_component_xfm(ROPMAT *rop)
307     {
308     int i, j;
309
310     if (rop->rmp != &rop->imx) { /* reset destination matrix */
311     rmx_free(rop->rmp);
312     rop->rmp = &rop->imx;
313     }
314     if (rop->preop.csym && /* symbolic transform? */
315     !checksymbolic(rop))
316     return(0);
317     /* undo exposure? */
318     if (fabs(1. - bright(rop->rmp->cexp)) > .025) {
319     if (rop->rmp->ncomp == 1)
320     rop->rmp->cexp[RED] = rop->rmp->cexp[GRN] =
321     rop->rmp->cexp[BLU] = bright(rop->rmp->cexp);
322     if (rop->preop.nsf <= 0) {
323     rop->preop.nsf = i = rop->rmp->ncomp;
324     while (i--)
325     rop->preop.sca[i] = 1.;
326     }
327     if (rop->preop.nsf == 1) {
328     if (rop->rmp->ncomp == 3) {
329     rop->preop.sca[2] = rop->preop.sca[1] =
330     rop->preop.sca[0];
331     rop->preop.nsf = 3;
332     } else
333     rop->preop.sca[0] /= bright(rop->rmp->cexp);
334     }
335     if (rop->preop.nsf == 3) {
336     opcolor(rop->preop.sca, /=, rop->rmp->cexp);
337     } else if (rop->preop.nsf > 3) { /* punt */
338     double mult = 1./bright(rop->rmp->cexp);
339     for (i = rop->preop.nsf; i--; )
340     rop->preop.sca[i] *= mult;
341     }
342     setcolor(rop->rmp->cexp, 1., 1., 1.);
343     }
344     if (rop->preop.clen > 0) { /* use component transform? */
345     if (rop->preop.clen % rop->imx.ncomp) {
346     fprintf(stderr, "%s: -c must have N x %d coefficients\n",
347     rop->inspec, rop->imx.ncomp);
348     return(0);
349     }
350     if (rop->preop.nsf > 0) { /* scale transform, instead */
351     if (rop->preop.nsf == 1) {
352     for (i = rop->preop.clen; i--; )
353     rop->preop.cmat[i] *= rop->preop.sca[0];
354     } else if (rop->preop.nsf*rop->imx.ncomp != rop->preop.clen) {
355     fprintf(stderr, "%s: -s must have one or %d factors\n",
356     rop->inspec,
357     rop->preop.clen/rop->imx.ncomp);
358     return(0);
359     } else {
360     for (i = rop->preop.nsf; i--; )
361     for (j = rop->imx.ncomp; j--; )
362     rop->preop.cmat[i*rop->imx.ncomp+j]
363     *= rop->preop.sca[i];
364     }
365     }
366     rop->preop.nsf = 0; /* now folded in */
367     if (!split_input(rop)) /* get our own struct */
368     return(0);
369     rop->rmp->ncomp = rop->preop.clen / rop->imx.ncomp;
370     if ((rop->rmp->ncomp > 3) & (rop->rmp->dtype <= DTspec)) {
371     rop->rmp->dtype = DTfloat; /* probably not actual spectrum */
372     memcpy(rop->rmp->wlpart, WLPART, sizeof(rop->rmp->wlpart));
373     }
374     } else if (rop->preop.nsf > 0) { /* else use scalar(s)? */
375     if (rop->preop.nsf == 1) {
376     for (i = rop->rmp->ncomp; --i; )
377     rop->preop.sca[i] = rop->preop.sca[0];
378     rop->preop.nsf = rop->rmp->ncomp;
379     } else if (rop->preop.nsf != rop->rmp->ncomp) {
380     fprintf(stderr, "%s: -s must have one or %d factors\n",
381     rop->inspec, rop->rmp->ncomp);
382     return(0);
383     }
384     }
385     return(1);
386     }
387
388 greg 2.34 /* Apply the given color transform and/or scaling operation */
389 greg 2.22 int
390 greg 2.1 apply_op(RMATRIX *dst, const RMATRIX *src, const RUNARYOP *ro)
391     {
392     if (ro->clen > 0) {
393     RMATRIX *res = rmx_transform(src, dst->ncomp, ro->cmat);
394     if (!res) {
395     fputs("Error in call to rmx_transform()\n", stderr);
396     return(0);
397     }
398     if (!rmx_transfer_data(dst, res, 0))
399     return(0);
400     rmx_free(res);
401     } else if (dst != src)
402 greg 2.9 memcpy(dst->mtx, src->mtx, rmx_array_size(dst));
403 greg 2.1 if (ro->nsf == dst->ncomp)
404     rmx_scale(dst, ro->sca);
405     return(1);
406     }
407
408 greg 2.34 /* Open the associated input file and load/check header */
409 greg 2.22 int
410 greg 2.1 open_input(ROPMAT *rop)
411     {
412     int outtype;
413
414     if (!rop || !rop->inspec || !rop->inspec[0])
415     return(0);
416     if (rop->inspec == stdin_name)
417     rop->infp = stdin;
418     else if (rop->inspec[0] == '!')
419     rop->infp = popen(rop->inspec+1, "r");
420     else
421     rop->infp = fopen(rop->inspec, "rb");
422
423     if (!rmx_load_header(&rop->imx, rop->infp)) {
424     fprintf(stderr, "Bad header from: %s\n", rop->inspec);
425     return(0);
426     }
427     return(get_component_xfm(rop));
428     }
429
430     /* Return nominal wavelength associated with input component (return nm) */
431 greg 2.22 double
432 greg 2.1 l_wavelength(char *nam)
433     {
434     double comp = argument(1);
435
436     if ((comp < -.5) | (comp >= in_ncomp+.5)) {
437     errno = EDOM;
438     return(.0);
439     }
440     if (comp < .5) /* asking for #components? */
441     return(in_ncomp);
442
443     if (in_ncomp == 3) { /* special case for RGB */
444     const int w0 = (int)(comp - .5);
445     return(mop[0].rmp->wlpart[w0] +
446     (comp-.5)*(mop[0].rmp->wlpart[w0+1] -
447     mop[0].rmp->wlpart[w0]));
448     }
449     return(mop[0].rmp->wlpart[0] + /* general case, even div. */
450     (comp-.5)/(double)in_ncomp *
451     (mop[0].rmp->wlpart[3] - mop[0].rmp->wlpart[0]));
452     }
453
454     /* Return ith input with optional channel selector */
455 greg 2.22 double
456 greg 2.1 l_chanin(char *nam)
457     {
458     double inp = argument(1);
459     int mi, chan;
460
461     if ((mi = (int)(inp-.5)) < 0 || mi >= nmats) {
462     errno = EDOM;
463     return(.0);
464     }
465     if (inp < .5) /* asking for #inputs? */
466     return(nmats);
467
468     if (nargum() >= 2) {
469     double cval = argument(2);
470     if (cval < .5 || (chan = (int)(cval-.5)) >= in_ncomp) {
471     errno = EDOM;
472     return(.0);
473     }
474     } else
475     chan = cur_chan;
476
477     return(mop[mi].rmp->mtx[cur_col*in_ncomp + chan]);
478     }
479
480 greg 2.34 /* Set up our operations and check consistency */
481 greg 2.22 int
482 greg 2.1 initialize(RMATRIX *imp)
483     {
484     int i;
485     /* XXX struct is zeroed coming in */
486     setcolor(imp->cexp, 1.f, 1.f, 1.f);
487     for (i = 0; i < nmats; i++) { /* open each input */
488     int restype;
489     if (!open_input(&mop[i]))
490     return(0);
491     restype = mop[i].rmp->dtype;
492     if (!imp->dtype || (restype = rmx_newtype(restype, imp->dtype)) > 0)
493     imp->dtype = restype;
494 greg 2.24 else if (!nowarn)
495 greg 2.1 fprintf(stderr, "%s: warning - data type mismatch\n",
496     mop[i].inspec);
497     if (!i) {
498     imp->ncols = mop[0].rmp->ncols;
499     imp->ncomp = mop[0].rmp->ncomp;
500     memcpy(imp->wlpart, mop[0].rmp->wlpart, sizeof(imp->wlpart));
501 greg 2.2 } else if ((mop[i].rmp->ncols != imp->ncols) |
502     (mop[i].rmp->ncomp != imp->ncomp) |
503     ((in_nrows > 0) & (mop[i].rmp->nrows > 0) &
504     (mop[i].rmp->nrows != in_nrows))) {
505 greg 2.1 fprintf(stderr, "%s: mismatch in size or #components\n",
506     mop[i].inspec);
507     return(0);
508     } /* XXX should check wlpart? */
509 greg 2.2 if (in_nrows <= 0)
510     in_nrows = imp->nrows = mop[i].rmp->nrows;
511 greg 2.1 } /* set up .cal environment */
512     esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
513     esupport &= ~(E_OUTCHAN|E_INCHAN);
514     varset("PI", ':', M_PI);
515     varset("nfiles", ':', nmats);
516     varset("nrows", ':', in_nrows);
517     varset("ncols", ':', in_ncols);
518     varset("ncomp", ':', in_ncomp);
519     varset("R", ':', 1.);
520     varset("G", ':', 2.);
521     varset("B", ':', 3.);
522     funset("wl", 1, ':', l_wavelength);
523     funset("ci", 1, '=', l_chanin);
524     scompile("ri(i)=ci(i,R);gi(i)=ci(i,G);bi(i)=ci(i,B)", NULL, 0);
525     return(1);
526     }
527
528 greg 2.34 /* Copy input header information to output header, indented */
529 greg 2.22 void
530 greg 2.1 output_headinfo(FILE *fp)
531     {
532     int i;
533
534     for (i = 0; i < nmats; i++) {
535     const char *cp = mop[i].imx.info;
536     fputs(mop[i].inspec, fp);
537     fputs(":\n", fp);
538     if (!cp) continue;
539     while (*cp) {
540     if (*cp == '\n') {
541     cp++; /* avoid inadvertant terminus */
542     continue;
543     }
544     fputc('\t', fp); /* indent this input's info */
545     do
546     putc(*cp, fp);
547     while (*cp++ != '\n');
548     }
549     }
550     }
551
552 greg 2.34 /* Spawn the indicated number of children and return 1 in parent */
553 greg 2.22 int
554 greg 2.10 spawned_children(int np)
555 greg 2.1 {
556 greg 2.10 int i, rv;
557
558     #if defined(_WIN32) || defined(_WIN64)
559     if (np > 1) {
560 greg 2.24 if (!nowarn)
561     fputs("Warning: only one process under Windows\n", stderr);
562 greg 2.10 np = 1;
563     } else
564     #endif
565 greg 2.18 if ((in_nrows > 0) & (np*4 > in_nrows))
566     np = in_nrows/4;
567 greg 2.10 /* we'll be doing a row at a time */
568 greg 2.1 for (i = 0; i < nmats; i++) {
569 greg 2.10 mop[i].imx.nrows = 1;
570 greg 2.1 if (!rmx_prepare(&mop[i].imx))
571     goto memerror;
572     if (mop[i].rmp != &mop[i].imx) {
573     mop[i].rmp->nrows = 1;
574     if (!rmx_prepare(mop[i].rmp))
575     goto memerror;
576     }
577     }
578 greg 2.20 /* prep output row buffer(s) */
579 greg 2.23 if (mop[nmats].preop.clen > 0) {
580 greg 2.10 if (!split_input(&mop[nmats])) /* need separate buffer */
581 greg 2.23 goto memerror;
582     mop[nmats].rmp->ncomp = mop[nmats].preop.clen /
583     mop[nmats].imx.ncomp;
584 greg 2.1 }
585 greg 2.10 mop[nmats].imx.nrows = 1;
586     if (!rmx_prepare(&mop[nmats].imx))
587     goto memerror;
588 greg 2.20 if (mop[nmats].rmp != &mop[nmats].imx) {
589     mop[nmats].rmp->nrows = 1;
590     if (!rmx_prepare(mop[nmats].rmp))
591     goto memerror;
592     }
593 greg 2.18 if (np <= 1) { /* single process return */
594 greg 2.10 #ifdef getc_unlocked
595     for (i = 0; i < nmats; i++)
596     flockfile(mop[i].infp);
597     flockfile(stdout);
598     #endif
599     return(0);
600     }
601     fflush(stdout); /* flush header & spawn children */
602 greg 2.20 nchildren = np + 1; /* extra child to sequence output */
603 greg 2.19 cproc = (SUBPROC *)malloc(sizeof(SUBPROC)*nchildren);
604 greg 2.10 if (!cproc)
605     goto memerror;
606 greg 2.20 for (i = nchildren; i--; ) cproc[i] = sp_inactive;
607     cproc[nchildren-1].flags |= PF_FILT_OUT;
608 greg 2.23 /* start each child from parent */
609     for (i = 0; i < nchildren; i++)
610     if ((rv = open_process(&cproc[i], NULL)) <= 0)
611     break; /* child breaks here */
612 greg 2.10 if (rv < 0) {
613 greg 2.23 perror("fork"); /* WTH? */
614 greg 2.17 close_processes(cproc, i);
615 greg 2.10 exit(1);
616     }
617 greg 2.23 if (i != nchildren-1) { /* last child is sole reader */
618     int j = i;
619     while (j-- > 0) {
620     close(cproc[j].r);
621     cproc[j].r = -1;
622 greg 2.21 }
623 greg 2.23 }
624     if (rv > 0)
625 greg 2.20 return(1); /* parent return value */
626 greg 2.23
627     inchild = i; /* else set our child index */
628 greg 2.20 while (i-- > 0) /* only parent writes siblings */
629 greg 2.11 close(cproc[i].w);
630 greg 2.20
631 greg 2.23 i = nmats; /* close matrix streams (carefully) */
632     while (i-- > 0) {
633     if (mop[i].infp != stdin) {
634     close(fileno(mop[i].infp)); /* avoid lseek() */
635     fclose(mop[i].infp); /* ! pclose() */
636     }
637     mop[i].infp = NULL;
638     }
639     fpurge(stdin); /* discard previously buffered input */
640
641 greg 2.22 if (inchild == nchildren-1)
642     return(-1); /* output process return value */
643 greg 2.20
644 greg 2.23 i = nmats; /* get matrix rows from parent */
645 greg 2.20 while (i-- > 0) {
646     mop[i].infp = stdin;
647     mop[i].imx.dtype = DTrmx_native;
648     mop[i].imx.pflags &= ~RMF_SWAPIN;
649     }
650 greg 2.10 #ifdef getc_unlocked
651     flockfile(stdin);
652     #endif
653 greg 2.20 mop[nmats].rmp->dtype = DTrmx_native;
654     return(0); /* worker child return value */
655 greg 2.10 memerror:
656     fputs("Out of memory in spawned_children()\n", stderr);
657     exit(1);
658     }
659
660 greg 2.34 /* Run parental feeder loop */
661 greg 2.22 int
662 greg 2.19 parent_loop(void)
663 greg 2.10 {
664     int i;
665
666 greg 2.20 rmx_reset(&mop[nmats].imx); /* not touching output side */
667     if (mop[nmats].rmp != &mop[nmats].imx) {
668     rmx_free(mop[nmats].rmp);
669     mop[nmats].rmp = &mop[nmats].imx;
670     }
671 greg 2.10 #ifdef getc_unlocked
672 greg 2.20 for (i = 0; i < nmats; i++) /* we handle matrix inputs */
673 greg 2.10 flockfile(mop[i].infp);
674     #endif
675 greg 2.19 /* load & send rows to kids */
676 greg 2.10 for (cur_row = 0; (in_nrows <= 0) | (cur_row < in_nrows); cur_row++) {
677 greg 2.20 int wfd = cproc[cur_row % (nchildren-1)].w;
678 greg 2.11 for (i = 0; i < nmats; i++)
679 greg 2.10 if (!rmx_load_row(mop[i].imx.mtx, &mop[i].imx, mop[i].infp)) {
680     if (cur_row > in_nrows) /* unknown #input rows? */
681     break;
682 greg 2.27 fprintf(stderr, "%s: load error at row %d\n",
683 greg 2.10 mop[i].inspec, cur_row);
684     return(0);
685     }
686 greg 2.11 if (i < nmats)
687     break;
688     for (i = 0; i < nmats; i++)
689 greg 2.19 if (writebuf(wfd, mop[i].imx.mtx, rmx_array_size(&mop[i].imx))
690 greg 2.23 != rmx_array_size(&mop[i].imx)) {
691 greg 2.27 fprintf(stderr, "%s: write error at row %d\n",
692 greg 2.23 mop[i].inspec, cur_row);
693 greg 2.19 return(0);
694 greg 2.23 }
695 greg 2.10 }
696 greg 2.23 i = close_processes(cproc, nchildren); /* collect family */
697 greg 2.20 free(cproc); cproc = NULL; nchildren = 0;
698 greg 2.10 if (i < 0) {
699 greg 2.24 if (!nowarn)
700 greg 2.27 fputs("Warning: lost child process\n", stderr);
701 greg 2.10 return(1);
702     }
703     if (i > 0) {
704     fprintf(stderr, "Child exited with status %d\n", i);
705     return(0);
706     }
707 greg 2.20 return(1); /* return success! */
708 greg 2.10 }
709
710 greg 2.34 /* Main operation loop, may be run in each child */
711 greg 2.22 int
712 greg 2.19 combine_input(void)
713 greg 2.10 {
714 greg 2.20 const int row0 = (inchild >= 0)*inchild;
715     const int rstep = nchildren ? nchildren-1 : 1;
716 greg 2.10 ROPMAT *res = &mop[nmats];
717     int set_r, set_c;
718     RMATRIX *tmp = NULL;
719     int co_set;
720     int i;
721
722 greg 2.23 if (mcat_last && !(tmp = rmx_alloc(1, res->imx.ncols, res->rmp->ncomp))) {
723     fputs("Out of buffer space in combine_input()\n", stderr);
724     return(0);
725     }
726 greg 2.1 /* figure out what the user set */
727     co_set = fundefined("co");
728     if (!co_set)
729     co_set = -vardefined("co");
730     if (!co_set & (in_ncomp == 3) && vardefined("ro") &&
731     vardefined("go") && vardefined("bo")) {
732     scompile("co(p)=select(p,ro,go,bo)", NULL, 0);
733     co_set = 1;
734     }
735     if (co_set) { /* set if user wants, didn't set */
736     set_r = varlookup("r") != NULL && !vardefined("r");
737     set_c = varlookup("c") != NULL && !vardefined("c");
738     } else /* save a little time */
739     set_r = set_c = 0;
740 greg 2.16 /* read/process row-by-row */
741 greg 2.10 for (cur_row = row0; (in_nrows <= 0) | (cur_row < in_nrows); cur_row += rstep) {
742 greg 2.1 RMATRIX *mres = NULL;
743 greg 2.14 for (i = 0; i < nmats; i++)
744 greg 2.1 if (!rmx_load_row(mop[i].imx.mtx, &mop[i].imx, mop[i].infp)) {
745 greg 2.5 if (cur_row > in_nrows) /* unknown #input rows? */
746 greg 2.10 break;
747 greg 2.27 fprintf(stderr, "%s: load error at row %d\n",
748 greg 2.1 mop[i].inspec, cur_row);
749     return(0);
750     }
751 greg 2.10 if (i < nmats)
752     break;
753     for (i = 0; i < nmats; i++)
754 greg 2.1 if (!apply_op(mop[i].rmp, &mop[i].imx, &mop[i].preop))
755     return(0);
756     if (set_r) varset("r", '=', cur_row);
757     for (cur_col = 0; cur_col < in_ncols; cur_col++) {
758     if (set_c) varset("c", '=', cur_col);
759     for (cur_chan = 0; cur_chan < in_ncomp; cur_chan++) {
760     const int ndx = cur_col*in_ncomp + cur_chan;
761     eclock++;
762     if (!co_set) { /* just summing elements? */
763     res->imx.mtx[ndx] = 0;
764     for (i = nmats; i--; )
765     res->imx.mtx[ndx] += mop[i].rmp->mtx[ndx];
766     } else if (co_set > 0) {
767     double dchan = cur_chan+1;
768     res->imx.mtx[ndx] = funvalue("co", 1, &dchan);
769     } else
770     res->imx.mtx[ndx] = varvalue("co");
771     }
772     } /* final conversions */
773     if (!mcat) {
774     if (!apply_op(res->rmp, &res->imx, &res->preop))
775     return(0);
776     } else if (mcat_last) {
777     if (!apply_op(tmp, &res->imx, &res->preop))
778     return(0);
779     mres = rmx_multiply(tmp, mcat);
780     if (!mres)
781     goto multerror;
782     if (!rmx_transfer_data(res->rmp, mres, 0))
783     return(0);
784     } else /* mcat && !mcat_last */ {
785     mres = rmx_multiply(&res->imx, mcat);
786     if (!mres)
787     goto multerror;
788     if (!apply_op(res->rmp, mres, &res->preop))
789     return(0);
790     }
791     rmx_free(mres); mres = NULL;
792     if (!rmx_write_data(res->rmp->mtx, res->rmp->ncomp,
793 greg 2.23 res->rmp->ncols, res->rmp->dtype, stdout) ||
794     (inchild >= 0 && fflush(stdout) == EOF)) {
795 greg 2.27 fprintf(stderr, "Conversion/write error at row %d\n",
796 greg 2.23 cur_row);
797 greg 2.16 return(0);
798 greg 2.23 }
799 greg 2.1 }
800 greg 2.20 return(inchild >= 0 || fflush(stdout) != EOF);
801 greg 2.1 multerror:
802 greg 2.27 fputs("Unexpected matrix multiply error\n", stderr);
803 greg 2.1 return(0);
804     }
805
806 greg 2.34 /* Run output process loop when #processes > 1 */
807 greg 2.22 int
808     output_loop(void)
809     {
810     const size_t row_size = rmx_array_size(mop[nmats].rmp);
811 greg 2.23 int cur_child = 0;
812 greg 2.22 int i = nmats;
813
814 greg 2.23 while (i-- > 0) { /* free input buffers */
815 greg 2.22 rmx_reset(&mop[i].imx);
816     if (mop[i].rmp != &mop[i].imx) {
817     rmx_free(mop[i].rmp);
818     mop[i].rmp = &mop[i].imx;
819     }
820     }
821 greg 2.23 if (mop[nmats].rmp != &mop[nmats].imx) /* output is split? */
822     rmx_reset(&mop[nmats].imx);
823 greg 2.22 #ifdef getc_unlocked
824     flockfile(stdout); /* we own this, now */
825     #endif
826     for ( ; ; ) { /* loop until no more */
827     ssize_t rv;
828     rv = readbuf(cproc[cur_child].r, mop[nmats].rmp->mtx, row_size);
829     if (!rv) /* out of rows? */
830     break;
831     if (rv != row_size) {
832 greg 2.27 fputs("Read error\n", stderr);
833 greg 2.22 return(0);
834     } /* do final conversion */
835     if (!rmx_write_data(mop[nmats].rmp->mtx, mop[nmats].rmp->ncomp,
836     mop[nmats].rmp->ncols, mop[nmats].rmp->dtype, stdout)) {
837 greg 2.27 fputs("Conversion/write error\n", stderr);
838 greg 2.22 return(0);
839     }
840     cur_child++;
841 greg 2.23 cur_child *= (cur_child < inchild); /* loop over workers */
842 greg 2.22 }
843     return(fflush(stdout) != EOF);
844     }
845
846 greg 2.34 /* Check/convert floating-point arguments following this */
847 greg 2.22 int
848 greg 2.1 get_factors(double da[], int n, char *av[])
849     {
850     int ac;
851
852     for (ac = 0; ac < n && isflt(av[ac]); ac++)
853     da[ac] = atof(av[ac]);
854     return(ac);
855     }
856
857 greg 2.34 /* Resize/reallocate the input array as requested */
858 greg 2.22 void
859 greg 2.1 resize_inparr(int n2alloc)
860     {
861     int i;
862
863 greg 2.6 if (n2alloc == nall)
864     return;
865 greg 2.26 for (i = nall; i-- > n2alloc; ) {
866 greg 2.1 rmx_reset(&mop[i].imx);
867     if (mop[i].rmp != &mop[i].imx)
868     rmx_free(mop[i].rmp);
869     }
870     mop = (ROPMAT *)realloc(mop, n2alloc*sizeof(ROPMAT));
871     if (mop == NULL) {
872     fputs("Out of memory in resize_inparr()\n", stderr);
873     exit(1);
874     }
875 greg 2.6 if (n2alloc > nall)
876     memset(mop+nall, 0, (n2alloc-nall)*sizeof(ROPMAT));
877 greg 2.1 nall = n2alloc;
878     }
879
880     /* Load one or more matrices and operate on them, sending results to stdout */
881     int
882     main(int argc, char *argv[])
883     {
884
885     int outfmt = DTfromHeader;
886     const char *defCsym = NULL;
887     int echoheader = 1;
888     int stdin_used = 0;
889 greg 2.10 int nproc = 1;
890 greg 2.1 const char *mcat_spec = NULL;
891 greg 2.32 int transpose_mcat = 0;
892 greg 2.1 int n2comp = 0;
893     uby8 comp_ndx[128];
894     int i;
895     /* get starting input array */
896     mop = (ROPMAT *)calloc(nall=2, sizeof(ROPMAT));
897     /* get options and arguments */
898     for (i = 1; i < argc; i++)
899     if (argv[i][0] != '-' || !argv[i][1]) {
900     if (argv[i][0] == '-') {
901     if (stdin_used++) goto stdin_error;
902     mop[nmats].inspec = stdin_name;
903     } else
904     mop[nmats].inspec = argv[i];
905     if (!mop[nmats].preop.csym)
906     mop[nmats].preop.csym = defCsym;
907     if (++nmats >= nall)
908     resize_inparr(nmats + (nmats>>2) + 2);
909     } else {
910     int n = argc-1 - i;
911     switch (argv[i][1]) { /* get option */
912     case 'w':
913     nowarn = !nowarn;
914     break;
915     case 'h':
916     echoheader = !echoheader;
917     break;
918 greg 2.10 case 'n':
919     nproc = atoi(argv[++i]);
920     if (nproc <= 0)
921     goto userr;
922     break;
923 greg 2.1 case 'e':
924     if (!n) goto userr;
925     comp_ndx[n2comp++] = i++;
926     break;
927     case 'f':
928     switch (argv[i][2]) {
929     case '\0':
930     if (!n) goto userr;
931     comp_ndx[n2comp++] = i++;
932     break;
933     case 'd':
934     outfmt = DTdouble;
935     break;
936     case 'f':
937     outfmt = DTfloat;
938     break;
939     case 'a':
940     outfmt = DTascii;
941     break;
942     case 'c':
943     outfmt = DTrgbe;
944     break;
945     default:
946     goto userr;
947     }
948     break;
949     case 's':
950     if (n > MAXCOMP) n = MAXCOMP;
951     i += mop[nmats].preop.nsf =
952     get_factors(mop[nmats].preop.sca,
953     n, argv+i+1);
954     if (mop[nmats].preop.nsf <= 0) {
955     fprintf(stderr, "%s: -s missing arguments\n",
956     argv[0]);
957     goto userr;
958     }
959     break;
960     case 'C':
961 greg 2.23 mcat_last = 0;
962 greg 2.1 if (!n || isflt(argv[i+1]))
963     goto userr;
964     defCsym = mop[nmats].preop.csym = argv[++i];
965     mop[nmats].preop.clen = 0;
966     break;
967     case 'c':
968 greg 2.23 mcat_last = 0;
969 greg 2.1 if (n && !isflt(argv[i+1])) {
970     mop[nmats].preop.csym = argv[++i];
971     mop[nmats].preop.clen = 0;
972     break;
973     }
974     if (n > MAXCOMP*MAXCOMP) n = MAXCOMP*MAXCOMP;
975     i += mop[nmats].preop.clen =
976     get_factors(mop[nmats].preop.cmat,
977     n, argv+i+1);
978     if (mop[nmats].preop.clen <= 0) {
979     fprintf(stderr, "%s: -c missing arguments\n",
980     argv[0]);
981     goto userr;
982     }
983     mop[nmats].preop.csym = NULL;
984     break;
985     case 'm':
986 greg 2.32 if (!n) goto userr;
987 greg 2.23 mcat_last = 1;
988 greg 2.32 transpose_mcat = (argv[i][2] == 't');
989 greg 2.1 if (argv[++i][0] == '-' && !argv[i][1]) {
990     if (stdin_used++) goto stdin_error;
991     mcat_spec = stdin_name;
992     } else
993     mcat_spec = argv[i];
994     break;
995     default:
996     fprintf(stderr, "%s: unknown option '%s'\n",
997     argv[0], argv[i]);
998     goto userr;
999     }
1000     }
1001     if (!nmats) {
1002     fprintf(stderr, "%s: need at least one input matrix\n", argv[0]);
1003     goto userr;
1004     }
1005     resize_inparr(nmats+1); /* extra matrix at end for result */
1006     mop[nmats].inspec = "trailing_ops";
1007 greg 2.32
1008     if (mcat_spec) { /* load final concatenation matrix? */
1009     mcat = rmx_load(mcat_spec);
1010     if (!mcat) {
1011     fprintf(stderr, "%s: error loading concatenation matrix: %s\n",
1012     argv[0], mcat_spec);
1013     return(1);
1014     }
1015     if (transpose_mcat && !rmx_transpose(mcat)) {
1016     fprintf(stderr, "%s: error transposing concatenation matrix: %s\n",
1017     argv[0], mcat_spec);
1018     return(1);
1019     }
1020 greg 2.1 }
1021     /* get/check inputs, set constants */
1022     if (!initialize(&mop[nmats].imx))
1023     return(1);
1024
1025     for (i = 0; i < n2comp; i++) /* user .cal files and expressions */
1026     if (argv[comp_ndx[i]][1] == 'f') {
1027     char *fpath = getpath(argv[comp_ndx[i]+1],
1028     getrlibpath(), 0);
1029     if (fpath == NULL) {
1030     fprintf(stderr, "%s: cannot find file '%s'\n",
1031     argv[0], argv[comp_ndx[i]+1]);
1032     return(1);
1033     }
1034     fcompile(fpath);
1035     } else /* (argv[comp_ndx[i]][1] == 'e') */
1036     scompile(argv[comp_ndx[i]+1], NULL, 0);
1037
1038     /* get trailing color transform */
1039     if (!get_component_xfm(&mop[nmats]))
1040     return(1);
1041     /* adjust output dimensions and #components */
1042     if (mcat) {
1043     if (mop[nmats].imx.ncols != mcat->nrows) {
1044     fprintf(stderr,
1045     "%s: number of input columns does not match number of rows in '%s'\n",
1046     argv[0], mcat_spec);
1047     return(1);
1048     }
1049     if (mcat->ncomp != (mcat_last ? mop[nmats].rmp->ncomp : mop[nmats].imx.ncomp)) {
1050     fprintf(stderr,
1051     "%s: number of components does not match those in '%s'\n",
1052     argv[0], mcat_spec);
1053     return(1);
1054     }
1055     if (!split_input(&mop[nmats]))
1056     return(1);
1057     mop[nmats].rmp->ncols = mcat->ncols;
1058     }
1059 greg 2.30 #if DTrmx_native==DTfloat
1060     if (outfmt == DTdouble)
1061     fprintf(stderr, "%s: warning - writing float result as double\n", argv[0]);
1062     #endif
1063 greg 2.1 newheader("RADIANCE", stdout); /* write output header */
1064     if (echoheader)
1065     output_headinfo(stdout);
1066     printargs(argc, argv, stdout);
1067     fputnow(stdout);
1068     mop[nmats].rmp->dtype = rmx_write_header(mop[nmats].rmp, outfmt, stdout);
1069     if (!mop[nmats].rmp->dtype) {
1070     fprintf(stderr, "%s: unsupported output format\n", argv[0]);
1071     return(1);
1072     }
1073 greg 2.7 doptimize(1); /* optimize definitions */
1074 greg 2.22 i = spawned_children(nproc); /* create multiple processes if requested */
1075     if (i > 0) /* running in parent process? */
1076 greg 2.10 return(parent_loop() ? 0 : 1);
1077 greg 2.22 if (i < 0) /* running in output process? */
1078     return(output_loop() ? 0 : 1);
1079     /* else we are a worker process */
1080 greg 2.10 return(combine_input() ? 0 : 1);
1081 greg 2.1 stdin_error:
1082     fprintf(stderr, "%s: %s used for more than one input\n",
1083     argv[0], stdin_name);
1084     return(1);
1085     userr:
1086     fprintf(stderr,
1087 greg 2.10 "Usage: %s [-h][-f{adfc}][-n nproc][-e expr][-f file][-s sf .. | -c ce ..] m1 .. -m mcat > mres\n",
1088 greg 2.1 argv[0]);
1089     return(1);
1090     }
