| 1 |
greg |
2.1 |
#ifndef lint |
| 2 |
greg |
2.9 |
static const char RCSid[] = "$Id: rcode_norm.c,v 2.8 2020/07/20 15:53:30 greg Exp $"; |
| 3 |
greg |
2.1 |
#endif |
| 4 |
| 5 |
* Encode and decode surface normal map using 32-bit integers |
| 6 |
| 7 |
| 8 |
#include "copyright.h" |
| 9 |
| 10 |
#include <stdlib.h> |
| 11 |
#include "platform.h" |
| 12 |
#include "rtio.h" |
| 13 |
#include "rtmath.h" |
| 14 |
#include "normcodec.h" |
| 15 |
| 16 |
char *progname; /* set in main() */ |
| 17 |
| 18 |
| 19 |
/* Report usage error and exit */ |
| 20 |
static void |
| 21 |
usage_exit(int code) |
| 22 |
| 23 |
fputs("Usage: ", stderr); |
| 24 |
fputs(progname, stderr); |
| 25 |
greg |
2.6 |
fputs(" [-h[io]][-H[io]][-f[afd]][-x xr -y yr] [input [output.nrm]]\n", stderr); |
| 26 |
greg |
2.1 |
fputs(" Or: ", stderr); |
| 27 |
| 28 |
greg |
2.2 |
fputs(" -r [-i][-u][-h[io]][-H[io]][-f[afd]] [input.nrm [output]]\n", |
| 29 |
greg |
2.1 |
stderr); |
| 30 |
exit(code); |
| 31 |
| 32 |
| 33 |
| 34 |
/* Encode normals from input stream */ |
| 35 |
static int |
| 36 |
encode_normals(NORMCODEC *ncp) |
| 37 |
| 38 |
long nexpected = (long)ncp->res.xr * ncp->res.yr; |
| 39 |
| 40 |
if (ncp->inpfmt[0]) { |
| 41 |
greg |
2.7 |
if (!strcmp(ncp->inpfmt, "ascii")) |
| 42 |
greg |
2.1 |
ncp->format = 'a'; |
| 43 |
greg |
2.7 |
else if (!strcmp(ncp->inpfmt, "float")) |
| 44 |
greg |
2.1 |
ncp->format = 'f'; |
| 45 |
greg |
2.7 |
else if (!strcmp(ncp->inpfmt, "double")) |
| 46 |
greg |
2.1 |
ncp->format = 'd'; |
| 47 |
else { |
| 48 |
fputs(ncp->inpname, stderr); |
| 49 |
fputs(": unsupported input format: ", stderr); |
| 50 |
fputs(ncp->inpfmt, stderr); |
| 51 |
fputc('\n', stderr); |
| 52 |
return 0; |
| 53 |
| 54 |
| 55 |
greg |
2.8 |
if (ncp->format == 'a') |
| 56 |
SET_FILE_TEXT(ncp->finp); |
| 57 |
greg |
2.1 |
| 58 |
do { |
| 59 |
int ok = 0; |
| 60 |
FVECT nrm; |
| 61 |
| 62 |
switch (ncp->format) { |
| 63 |
case 'a': |
| 64 |
ok = (fscanf(ncp->finp, FVFORMAT, |
| 65 |
&nrm[0], &nrm[1], &nrm[2]) == 3); |
| 66 |
break; |
| 67 |
#ifdef SMLFLT |
| 68 |
case 'f': |
| 69 |
ok = (getbinary(nrm, sizeof(*nrm), 3, ncp->finp) == 3); |
| 70 |
greg |
2.4 |
if (ncp->swapped) |
| 71 |
swap32((char *)nrm, 3); |
| 72 |
greg |
2.1 |
break; |
| 73 |
case 'd': { |
| 74 |
greg |
2.4 |
double nrmd[3]; |
| 75 |
ok = (getbinary(nrmd, sizeof(*nrmd), |
| 76 |
| 77 |
if (ncp->swapped) |
| 78 |
swap64((char *)nrmd, 3); |
| 79 |
if (ok) VCOPY(nrm, nrmd); |
| 80 |
} break; |
| 81 |
greg |
2.1 |
#else |
| 82 |
case 'f': { |
| 83 |
greg |
2.4 |
float nrmf[3]; |
| 84 |
ok = (getbinary(nrmf, sizeof(*nrmf), |
| 85 |
| 86 |
if (ncp->swapped) |
| 87 |
swap32((char *)nrmf, 3); |
| 88 |
if (ok) VCOPY(nrm, nrmf); |
| 89 |
} break; |
| 90 |
greg |
2.1 |
case 'd': |
| 91 |
| 92 |
greg |
2.4 |
if (ncp->swapped) |
| 93 |
swap64((char *)nrm, 3); |
| 94 |
greg |
2.1 |
break; |
| 95 |
#endif |
| 96 |
| 97 |
if (!ok) |
| 98 |
break; |
| 99 |
| 100 |
normalize(nrm); |
| 101 |
putint(encodedir(nrm), 4, stdout); |
| 102 |
| 103 |
} while (--nexpected); |
| 104 |
| 105 |
if (nexpected > 0) { |
| 106 |
| 107 |
fputs(": fewer normals than expected\n", stderr); |
| 108 |
return 0; |
| 109 |
| 110 |
return 1; |
| 111 |
| 112 |
| 113 |
| 114 |
/* Output the given normal to stdout */ |
| 115 |
static void |
| 116 |
output_normal(NORMCODEC *ncp, FVECT nrm) |
| 117 |
| 118 |
| 119 |
case 'a': |
| 120 |
printf("%.9f %.9f %.9f\n", nrm[0], nrm[1], nrm[2]); |
| 121 |
break; |
| 122 |
#ifdef SMLFLT |
| 123 |
case 'f': |
| 124 |
putbinary(nrm, sizeof(*nrm), 3, stdout); |
| 125 |
break; |
| 126 |
case 'd': { |
| 127 |
double nrmd[3]; |
| 128 |
VCOPY(nrmd, nrm); |
| 129 |
putbinary(nrmd, sizeof(*nrmd), 3, stdout); |
| 130 |
| 131 |
break; |
| 132 |
#else |
| 133 |
case 'f': { |
| 134 |
float nrmf[3]; |
| 135 |
VCOPY(nrmf, nrm); |
| 136 |
putbinary(nrmf, sizeof(*nrmf), 3, stdout); |
| 137 |
| 138 |
break; |
| 139 |
case 'd': |
| 140 |
| 141 |
break; |
| 142 |
#endif |
| 143 |
| 144 |
| 145 |
| 146 |
| 147 |
/* Decode normals from input stream */ |
| 148 |
static int |
| 149 |
decode_normals(NORMCODEC *ncp) |
| 150 |
| 151 |
| 152 |
| 153 |
if (!check_decode_normals(ncp)) |
| 154 |
return 0; |
| 155 |
| 156 |
do { |
| 157 |
FVECT nrm; |
| 158 |
| 159 |
if (decode_normal_next(nrm, ncp) < 0) |
| 160 |
break; |
| 161 |
| 162 |
output_normal(ncp, nrm); |
| 163 |
| 164 |
| 165 |
| 166 |
| 167 |
| 168 |
fputs(": unexpected EOF\n", stderr); |
| 169 |
return 0; |
| 170 |
| 171 |
return 1; |
| 172 |
| 173 |
| 174 |
| 175 |
/* Decode normals at particular pixels given on standard input */ |
| 176 |
static int |
| 177 |
pixel_normals(NORMCODEC *ncp, int unbuf) |
| 178 |
| 179 |
int x, y; |
| 180 |
FVECT nrm; |
| 181 |
| 182 |
if (ncp->finp == stdin) { |
| 183 |
| 184 |
fputs(": <stdin> used for encoded normals\n", stderr); |
| 185 |
return 0; |
| 186 |
| 187 |
| 188 |
return 0; |
| 189 |
if (ncp->res.rt != PIXSTANDARD) { |
| 190 |
| 191 |
fputs(": can only handle standard pixel ordering\n", stderr); |
| 192 |
return 0; |
| 193 |
| 194 |
greg |
2.8 |
| 195 |
greg |
2.1 |
while (scanf("%d %d", &x, &y) == 2) { |
| 196 |
| 197 |
y = ncp->res.yr-1 - y; |
| 198 |
| 199 |
if (decode_normal_pix(nrm, ncp, x, y) < 0) |
| 200 |
return 0; |
| 201 |
| 202 |
| 203 |
| 204 |
if (unbuf && fflush(stdout) == EOF) { |
| 205 |
| 206 |
fputs(": write error on output\n", stderr); |
| 207 |
return 0; |
| 208 |
| 209 |
| 210 |
if (!feof(stdin)) { |
| 211 |
| 212 |
fputs(": non-integer as pixel index\n", stderr); |
| 213 |
return 0; |
| 214 |
| 215 |
return 1; |
| 216 |
| 217 |
| 218 |
| 219 |
int |
| 220 |
main(int argc, char *argv[]) |
| 221 |
| 222 |
greg |
2.5 |
int xres=0, yres=0; |
| 223 |
greg |
2.1 |
int reverse = 0; |
| 224 |
int bypixel = 0; |
| 225 |
int unbuffered = 0; |
| 226 |
NORMCODEC nc; |
| 227 |
int a; |
| 228 |
| 229 |
progname = argv[0]; |
| 230 |
set_nc_defaults(&nc); |
| 231 |
nc.hdrflags = HF_ALL; |
| 232 |
for (a = 1; a < argc && argv[a][0] == '-'; a++) |
| 233 |
switch (argv[a][1]) { |
| 234 |
case 'r': |
| 235 |
reverse++; |
| 236 |
break; |
| 237 |
case 'f': |
| 238 |
switch (argv[a][2]) { |
| 239 |
case 'f': |
| 240 |
case 'd': |
| 241 |
case 'a': |
| 242 |
nc.format = argv[a][2]; |
| 243 |
break; |
| 244 |
default: |
| 245 |
| 246 |
fputs(": unsupported -f? format\n", stderr); |
| 247 |
usage_exit(1); |
| 248 |
| 249 |
break; |
| 250 |
case 'h': |
| 251 |
| 252 |
case '\0': |
| 253 |
nc.hdrflags &= ~(HF_HEADIN|HF_HEADOUT); |
| 254 |
break; |
| 255 |
case 'i': |
| 256 |
case 'I': |
| 257 |
nc.hdrflags &= ~HF_HEADIN; |
| 258 |
break; |
| 259 |
case 'o': |
| 260 |
case 'O': |
| 261 |
nc.hdrflags &= ~HF_HEADOUT; |
| 262 |
break; |
| 263 |
default: |
| 264 |
usage_exit(1); |
| 265 |
| 266 |
break; |
| 267 |
case 'H': |
| 268 |
| 269 |
case '\0': |
| 270 |
nc.hdrflags &= ~(HF_RESIN|HF_RESOUT); |
| 271 |
break; |
| 272 |
case 'i': |
| 273 |
case 'I': |
| 274 |
nc.hdrflags &= ~HF_RESIN; |
| 275 |
break; |
| 276 |
case 'o': |
| 277 |
case 'O': |
| 278 |
nc.hdrflags &= ~HF_RESOUT; |
| 279 |
break; |
| 280 |
default: |
| 281 |
usage_exit(1); |
| 282 |
| 283 |
break; |
| 284 |
greg |
2.5 |
case 'x': |
| 285 |
xres = atoi(argv[++a]); |
| 286 |
break; |
| 287 |
case 'y': |
| 288 |
yres = atoi(argv[++a]); |
| 289 |
break; |
| 290 |
greg |
2.1 |
case 'i': |
| 291 |
bypixel++; |
| 292 |
break; |
| 293 |
case 'u': |
| 294 |
unbuffered++; |
| 295 |
break; |
| 296 |
default: |
| 297 |
usage_exit(1); |
| 298 |
| 299 |
nc.hdrflags |= !reverse * HF_ENCODE; |
| 300 |
| 301 |
greg |
2.5 |
if ((xres > 0) & (yres > 0)) { |
| 302 |
| 303 |
nc.res.rt = PIXSTANDARD; |
| 304 |
nc.res.xr = xres; |
| 305 |
nc.res.yr = yres; |
| 306 |
} else if ((nc.hdrflags & (HF_RESIN|HF_RESOUT)) == HF_RESOUT) { |
| 307 |
greg |
2.1 |
| 308 |
fputs(": unknown resolution for output\n", stderr); |
| 309 |
return 1; |
| 310 |
| 311 |
if (bypixel) { |
| 312 |
if (!reverse) { |
| 313 |
| 314 |
fputs(": -i only supported with -r option\n", |
| 315 |
stderr); |
| 316 |
usage_exit(1); |
| 317 |
| 318 |
if (a >= argc) { |
| 319 |
| 320 |
fputs(": -i option requires input file\n", stderr); |
| 321 |
usage_exit(1); |
| 322 |
| 323 |
if (!(nc.hdrflags & HF_RESIN)) { |
| 324 |
| 325 |
fputs(": -i option requires input resolution\n", stderr); |
| 326 |
usage_exit(1); |
| 327 |
| 328 |
greg |
2.2 |
| 329 |
greg |
2.1 |
| 330 |
if (a < argc-2) { |
| 331 |
| 332 |
fputs(": too many file arguments\n", stderr); |
| 333 |
usage_exit(1); |
| 334 |
| 335 |
if (a < argc && !(nc.finp = fopen(nc.inpname=argv[a], "r"))) { |
| 336 |
fputs(nc.inpname, stderr); |
| 337 |
fputs(": cannot open for reading\n", stderr); |
| 338 |
return 1; |
| 339 |
| 340 |
if (a+1 < argc && !freopen(argv[a+1], "w", stdout)) { |
| 341 |
fputs(argv[a+1], stderr); |
| 342 |
fputs(": cannot open for writing\n", stderr); |
| 343 |
return 1; |
| 344 |
| 345 |
greg |
2.9 |
SET_FILE_BINARY(nc.finp); /* starting assumption */ |
| 346 |
greg |
2.8 |
SET_FILE_BINARY(stdout); |
| 347 |
greg |
2.1 |
#ifdef getc_unlocked /* avoid stupid semaphores */ |
| 348 |
flockfile(nc.finp); |
| 349 |
flockfile(stdout); |
| 350 |
#endif |
| 351 |
/* read/copy header */ |
| 352 |
if (!process_nc_header(&nc, a, argv)) |
| 353 |
return 1; |
| 354 |
greg |
2.8 |
| 355 |
if (reverse && nc.format == 'a') |
| 356 |
SET_FILE_TEXT(stdout); |
| 357 |
greg |
2.1 |
/* process data */ |
| 358 |
if (!reverse) { |
| 359 |
if (!encode_normals(&nc)) |
| 360 |
return 1; |
| 361 |
} else if (bypixel) { |
| 362 |
if (!pixel_normals(&nc, unbuffered)) |
| 363 |
return 1; |
| 364 |
} else if (!decode_normals(&nc)) |
| 365 |
return 1; |
| 366 |
| 367 |
if (fflush(stdout) == EOF) { |
| 368 |
| 369 |
fputs(": error writing output\n", stderr); |
| 370 |
return 1; |
| 371 |
| 372 |
return 0; |
| 373 |
