root/radiance/src/util/rcode_ident.c
Revision: 2.5
Committed: Wed Jul 24 00:17:22 2019 UTC (6 years, 2 months ago) by greg
Changes since 2.4: +6 -2 lines
Removed automatic array initialization of hash table
2 static const char RCSid[] = "$Id: rcode_ident.c,v 2.4 2019/07/23 17:23:25 greg Exp $";
5 * Create or read identifier index map
6 *
7 */
8
9 #include <stdlib.h>
10 #include <ctype.h>
11 #include "rtio.h"
12 #include "platform.h"
13 #include "lookup.h"
14 #include "idmap.h"
15
16 #ifndef MAXIDLEN
17 #define MAXIDLEN 256 /* longest ID length supported */
18 #endif
19
20 #define HF_TABLOUT 0x100 /* output ID table after header */
21
22 char *progname; /* global argv[0] */
23
24 static int unbuffered = 0;
25 static int numeric = 0;
26 static int sepc = '\n';
27
28
29 /* Report usage error and exit */
30 static void
31 usage_exit(int code)
32 {
33 fputs("Usage: ", stderr);
34 fputs(progname, stderr);
35 fputs(" [-8|-16|-24][-h][-tS][-x xr -y yr] [input.txt [output.idx]]\n",
36 stderr);
37 fputs(" Or: ", stderr);
38 fputs(progname, stderr);
39 fputs(" -r [-i][-u][-h][-H][-l][-n][-tS] input.idx [output.txt]\n",
40 stderr);
41 exit(code);
42 }
43
44
45 /* read identifier from input, trimming white space on either end */
46 static int
47 scan_ident(char ident[MAXIDLEN], FILE *fp)
48 {
49 char *cp = ident;
50 int c;
51
52 while ((c = getc(fp)) != EOF) {
53 if (cp == ident && isspace(c))
54 continue;
55 if (c == sepc) {
56 while (cp > ident && isspace(cp[-1]))
57 cp--;
58 *cp = '\0';
59 return cp - ident; /* return string length */
60 }
61 if (cp - ident >= MAXIDLEN-1) {
62 fputs(progname, stderr);
63 fputs(": identifier too long in scan_ident()\n", stderr);
64 return -1;
65 }
66 *cp++ = c;
67 }
68 return -1;
69 }
70
71
72 /* elide format from header lines */
73 static int
74 headline(char *s, void *p)
75 {
76 extern const char FMTSTR[];
77
78 if (strstr(s, FMTSTR) == s)
79 return 0;
80
81 fputs(s, stdout);
82 return 1;
83 }
84
85
86 /* Create an identifier index from the given input file (stdin if NULL) */
87 int
88 create_index(const char *fname, int hdrflags, int ndxbytes, int xres, int yres)
89 {
90 FILE *fp = stdin;
91 char **idmap;
92 int idmlen;
93 int nextID = 0;
94 LUTAB hashtab;
95 RESOLU rs;
96 long n;
97 int ndx;
98 /* open file if not stdin */
99 if (!fname)
100 fname = "<stdin>";
101 else if (!(fp = fopen(fname, "r"))) {
102 fputs(fname, stderr);
103 fputs(": cannot open for input\n", stderr);
104 return 0;
105 }
106 #ifdef getc_unlocked /* avoid stupid semaphores */
107 flockfile(fp);
108 #endif
109 /* load/copy header */
110 if (hdrflags & HF_HEADOUT && getheader(fp, headline, NULL) < 0) {
111 fputs(fname, stderr);
112 fputs(": bad header or wrong input format\n", stderr);
113 fclose(fp);
114 return 0;
115 }
116 if (!(hdrflags & HF_HEADOUT))
117 newheader("RADIANCE", stdout);
118 /* finish & allocate ID table */
119 switch (ndxbytes) {
120 case 1:
121 fputformat(IDMAP8FMT, stdout);
122 idmap = (char **)malloc((idmlen=256)*sizeof(char *));
123 break;
124 case 2:
125 fputformat(IDMAP16FMT, stdout);
126 idmap = (char **)malloc((idmlen=4096)*sizeof(char *));
127 break;
128 case 3:
129 fputformat(IDMAP24FMT, stdout);
130 idmap = (char **)malloc((idmlen=1L<<17)*sizeof(char *));
131 break;
132 default:
133 fputs(progname, stderr);
134 fputs(": unsupported bits/pixel\n", stderr);
135 return 0;
136 }
137 memset(&hashtab, 0, sizeof(hashtab));
138 hashtab.hashf = lu_shash;
139 hashtab.keycmp = strcmp;
140 hashtab.freek = free;
141 if (!idmap || !lu_init(&hashtab, idmlen))
142 goto memerr;
143 fputc('\n', stdout); /* end of info header */
144
145 rs.rt = PIXSTANDARD; /* get/write map resolution */
146 if (hdrflags & HF_RESOUT) {
147 if (!fgetsresolu(&rs, fp)) {
148 fputs(fname, stderr);
149 fputs(": bad resolution string\n", stderr);
150 return 0;
151 }
152 } else if (((rs.xr = xres) <= 0) | ((rs.yr = yres) <= 0)) {
153 fputs(fname, stderr);
154 fputs(": missing/illegal resolution\n", stderr);
155 return 0;
156 }
157 fputsresolu(&rs, stdout);
158 /* read/assign/write each ID */
159 for (n = (long)rs.xr*rs.yr; n-- > 0; ) {
160 LUENT *lep;
161 char ident[MAXIDLEN];
162 int len = scan_ident(ident, fp);
163 if (len < 0) {
164 if (feof(fp)) {
165 fputs(fname, stderr);
166 fputs(": unexpected EOF\n", stderr);
167 }
168 return 0;
169 }
170 lep = lu_find(&hashtab, ident);
171 if (!lep->key) { /* new entry */
172 if (nextID >= 1<<(ndxbytes<<3)) {
173 fputs(progname, stderr);
174 fputs(
175 ": too many unique identifiers for index size\n",
176 stderr);
177 return 0;
178 }
179 if (nextID >= idmlen) { /* reallocate? */
180 idmlen += idmlen>>2; /* +25% growth */
181 idmap = (char **)realloc(idmap, idmlen);
182 if (!idmap)
183 goto memerr;
184 }
185 lep->key = (char *)malloc(len+1);
186 if (!lep->key)
187 goto memerr;
188 idmap[nextID] = strcpy(lep->key, ident);
189 lep->data = (char *)nextID++;
190 }
191 /* write this id index */
192 putint((int)lep->data, ndxbytes, stdout);
193 }
194 while ((ndx = getc(fp)) != EOF) /* verify we got them all */
195 if (!isspace(ndx)) {
196 fputs(fname, stderr);
197 fputs(": warning - non-white characters past end\n",
198 stderr);
199 break;
200 }
201 if (fp != stdin) /* done with input */
202 fclose(fp);
203 for (ndx = 0; ndx < nextID; ndx++) { /* append string table */
204 fputs(idmap[ndx], stdout);
205 putchar('\0'); /* nul-terminated IDs */
206 }
207 free(idmap); /* clean up */
208 lu_done(&hashtab);
209 return 1;
210 memerr:
211 fputs(progname, stderr);
212 fputs(": out of memory!\n", stderr);
213 return 0;
214 }
215
216
217 /* print out table IDs */
218 void
219 print_IDs(IDMAP *idmp)
220 {
221 int i;
222
223 printf("============ %d IDs ============\n", idmp->nids);
224
225 for (i = 0; i < idmp->nids; i++)
226 puts(mapID(idmp, i));
227
228 puts("============= END =============");
229 }
230
231
232 /* Load selected pixels from identifier index file */
233 int
234 decode_select(const char *fname, int hdrflags)
235 {
236 IDMAP *idmp = idmap_ropen(fname, hdrflags);
237 int x, y;
238
239 if (!idmp)
240 return 0;
241
242 if (hdrflags & HF_TABLOUT)
243 print_IDs(idmp);
244
245 if (idmp->res.rt != PIXSTANDARD) {
246 fputs(progname, stderr);
247 fputs(": can only handle standard pixel ordering\n", stderr);
248 idmap_close(idmp);
249 return 0;
250 }
251 while (scanf("%d %d", &x, &y) == 2) {
252 x = idmap_seek(idmp, x, idmp->res.yr-1 - y);
253 if (!x) {
254 fputs(progname, stderr);
255 fputs(": warning - pixel index is off map\n", stderr);
256 continue;
257 }
258 if (x > 0)
259 x = idmap_next_i(idmp);
260 if (x < 0) {
261 fputs(fname, stderr);
262 fputs(": read/seek error in decode_select()\n", stderr);
263 idmap_close(idmp);
264 return 0;
265 }
266 if (numeric) {
267 printf("%d", x);
268 } else {
269 const char *id = mapID(idmp, x);
270 if (!id) {
271 fputs(fname, stderr);
272 fputs(": bad ID index in file\n", stderr);
273 idmap_close(idmp);
274 return 0;
275 }
276 fputs(id, stdout);
277 }
278 putchar(sepc);
279 if (unbuffered && fflush(stdout) == EOF) {
280 fputs(progname, stderr);
281 fputs(": write error on output\n", stderr);
282 idmap_close(idmp);
283 return 0;
284 }
285 }
286 idmap_close(idmp);
287
288 if (!feof(stdin)) {
289 fputs(progname, stderr);
290 fputs(": non-numeric input for pixel index\n", stderr);
291 return 0;
292 }
293 return 1;
294 }
295
296
297 /* Load and convert identifier index file to ASCII */
298 int
299 decode_all(const char *fname, int hdrflags)
300 {
301 IDMAP *idmp = idmap_ropen(fname, hdrflags);
302 long n;
303
304 if (!idmp)
305 return 0;
306
307 if (hdrflags & HF_TABLOUT)
308 print_IDs(idmp);
309
310 for (n = idmp->res.xr*idmp->res.yr; n-- > 0; ) {
311 int ndx = idmap_next_i(idmp);
312 if (ndx < 0) {
313 fputs(fname, stderr);
314 fputs(": unexpected EOF\n", stderr);
315 idmap_close(idmp);
316 return 0;
317 }
318 if (numeric) {
319 printf("%d", ndx);
320 } else {
321 const char *id = mapID(idmp, ndx);
322 if (!id) {
323 fputs(fname, stderr);
324 fputs(": bad ID index in file\n", stderr);
325 idmap_close(idmp);
326 return 0;
327 }
328 fputs(id, stdout);
329 }
330 putchar(sepc);
331 }
332 idmap_close(idmp);
333 return 1;
334 }
335
336
337 int
338 main(int argc, char *argv[])
339 {
340 char *inpfname = NULL;
341 int reverse = 0;
342 int bypixel = 0;
343 int hdrflags = HF_HEADOUT|HF_RESOUT;
344 int xres=0, yres=0;
345 int ndxbytes = 2;
346 int a;
347
348 progname = argv[0];
349 for (a = 1; a < argc && argv[a][0] == '-'; a++)
350 switch (argv[a][1]) {
351 case 'r':
352 reverse++;
353 break;
354 case 'i':
355 bypixel++;
356 break;
357 case 'u':
358 unbuffered++;
359 break;
360 case 'n':
361 numeric++;
362 break;
363 case 'l':
364 hdrflags |= HF_TABLOUT;
365 break;
366 case 'h':
367 hdrflags &= ~HF_HEADOUT;
368 break;
369 case 'H':
370 hdrflags &= ~HF_RESOUT;
371 break;
372 case 't':
373 if (!(sepc = argv[a][2]))
374 sepc = '\n';
375 break;
376 case 'x':
377 xres = atoi(argv[++a]);
378 break;
379 case 'y':
380 yres = atoi(argv[++a]);
381 break;
382 case '8':
383 case '1':
384 case '2':
385 switch (atoi(argv[a]+1)) {
386 case 8:
387 ndxbytes = 1;
388 break;
389 case 16:
390 ndxbytes = 2;
391 break;
392 case 24:
393 ndxbytes = 3;
394 break;
395 default:
396 usage_exit(1);
397 }
398 break;
399 default:
400 usage_exit(1);
401 }
402 if ((xres > 0) & (yres > 0)) /* user specified resolution? */
403 hdrflags &= ~HF_RESOUT;
404 if (reverse && a >= argc) {
405 fputs(progname, stderr);
406 fputs(": -r option requires named input file\n", stderr);
407 return 1;
408 }
409 if (a < argc-2) {
410 fputs(progname, stderr);
411 fputs(": too many file arguments\n", stderr);
412 return 1;
413 }
414 if (a < argc)
415 inpfname = argv[a];
416 if (a+1 < argc && !freopen(argv[a+1], "w", stdout)) {
417 fputs(argv[a+1], stderr);
418 fputs(": cannot open output\n", stderr);
419 return 1;
420 }
421 if (!reverse)
422 SET_FILE_BINARY(stdout);
423 #ifdef getc_unlocked /* avoid stupid semaphores */
424 flockfile(stdout);
425 #endif
426 if (reverse) {
427 if (!(bypixel ? decode_select(inpfname, hdrflags) :
428 decode_all(inpfname, hdrflags)))
429 return 1;
430 } else if (!create_index(inpfname, hdrflags, ndxbytes, xres, yres))
431 return 1;
432
433 if (fflush(stdout) == EOF) {
434 fputs(progname, stderr);
435 fputs(": error writing output\n", stderr);
436 return 1;
437 }
438 return 0;
439 }
