| 1 | /* RCSid $Id: ranimove.h,v 3.8 2012/09/28 22:20:49 greg Exp $ */ |
| 2 | /* |
| 3 | *  ranimove.h |
| 4 | * |
| 5 | * Radiance object animation program |
| 6 | * |
| 7 | * The main difference between this program and ranimate is that |
| 8 | * ranimove is optimized for object motion, and includes a complete |
| 9 | * blur simulation.  We also have a number of clever schemes |
| 10 | * for optimizing the computation, allowing rendering time |
| 11 | * per frame and noticeable difference threshold to be specified. |
| 12 | * Parallel rendering uses multiple processors on the local host, |
| 13 | * and network rendering is not directly supported.  (However, no |
| 14 | * one says you can't run ranimove on other machines at the |
| 15 | * same time; just be careful not to overlap frames.) |
| 16 | * |
| 17 | * See the ranimove(1) man page for further details. |
| 18 | */ |
| 19 | #ifndef _RAD_RANIMOVE_H_ |
| 20 | #define _RAD_RANIMOVE_H_ |
| 21 |  |
| 22 | #include "ray.h" |
| 23 | #include "view.h" |
| 24 | #include "vars.h" |
| 25 |  |
| 26 | #ifdef __cplusplus |
| 27 | extern "C" { |
| 28 | #endif |
| 29 |  |
| 30 | /* input variables (alphabetical by name) */ |
| 31 | #define BASENAME        0               /* output image base name */ |
| 32 | #define END             1               /* number of animation frames */ |
| 33 | #define EXPOSURE        2               /* how to compute exposure */ |
| 34 | #define HIGHQ           3               /* high quality setting */ |
| 35 | #define LOWQ            4               /* low quality setting */ |
| 36 | #define MBLUR           5               /* motion blur parameter */ |
| 37 | #define MNAME           6               /* motion vector file */ |
| 38 | #define MOVE            7               /* object movement */ |
| 39 | #define OCONV           8               /* oconv options */ |
| 40 | #define OCTREEF         9               /* octree file name */ |
| 41 | #define RATE            10              /* frame rate (fps) */ |
| 42 | #define RESOLUTION      11              /* desired final resolution */ |
| 43 | #define RIF             12              /* rad input file */ |
| 44 | #define VIEWFILE        13              /* animation frame views */ |
| 45 | #define ZNAME           14              /* depth file */ |
| 46 |  |
| 47 | #define NV_INIT         15              /* number of variables */ |
| 48 |  |
| 49 | #define VV_INIT { \ |
| 50 | {"BASENAME",    3,      0,      NULL,   onevalue}, \ |
| 51 | {"END",         3,      0,      NULL,   intvalue}, \ |
| 52 | {"EXPOSURE",    3,      0,      NULL,   onevalue}, \ |
| 53 | {"highq",       2,      0,      NULL,   catvalues}, \ |
| 54 | {"lowq",        2,      0,      NULL,   catvalues}, \ |
| 55 | {"MBLUR",       2,      0,      NULL,   fltvalue}, \ |
| 56 | {"MNAME",       2,      0,      NULL,   onevalue}, \ |
| 57 | {"move",        2,      0,      NULL,   NULL}, \ |
| 58 | {"oconv",       2,      0,      NULL,   catvalues}, \ |
| 59 | {"OCTREE",      3,      0,      NULL,   onevalue}, \ |
| 60 | {"RATE",        2,      0,      NULL,   fltvalue}, \ |
| 61 | {"RESOLUTION",  3,      0,      NULL,   onevalue}, \ |
| 62 | {"RIF",         3,      0,      NULL,   onevalue}, \ |
| 63 | {"VIEWFILE",    2,      0,      NULL,   onevalue}, \ |
| 64 | {"ZNAME",       2,      0,      NULL,   onevalue} \ |
| 65 | } |
| 66 |  |
| 67 | struct ObjMove { |
| 68 | int             parent;         /* parent object index */ |
| 69 | char            name[64];       /* object name */ |
| 70 | char            xf_file[128];   /* transform file name */ |
| 71 | char            spec[512];      /* object file or command */ |
| 72 | char            prio_file[128]; /* priority file name */ |
| 73 | int             cfm;            /* current frame number */ |
| 74 | char            xfs[512];       /* part transform arguments */ |
| 75 | MAT4            xfm;            /* part transform matrix */ |
| 76 | MAT4            cxfm;           /* combined transform matrix */ |
| 77 | MAT4            bxfm;           /* transform to previous frame */ |
| 78 | double          prio;           /* part priority */ |
| 79 | double          cprio;          /* combined priority */ |
| 80 | }; |
| 81 |  |
| 82 | extern int              silent;         /* run silently? */ |
| 83 |  |
| 84 | extern int              quickstart;     /* time initial frame as well? */ |
| 85 |  |
| 86 | extern int              nprocs;         /* number of rendering processes */ |
| 87 |  |
| 88 | extern int              rtperfrm;       /* seconds to spend per frame */ |
| 89 |  |
| 90 | extern double           ndthresh;       /* noticeable difference threshold */ |
| 91 | extern int              ndtset;         /* did user set ndthresh? */ |
| 92 |  |
| 93 | extern int              fbeg;           /* starting frame */ |
| 94 | extern int              fend;           /* ending frame */ |
| 95 | extern int              fcur;           /* current frame being rendered */ |
| 96 |  |
| 97 | extern char             lorendoptf[];   /* LQ options file */ |
| 98 | extern RAYPARAMS        lorendparams;   /* LQ rendering parameters */ |
| 99 | extern char             hirendoptf[];   /* HQ options file */ |
| 100 | extern RAYPARAMS        hirendparams;   /* HQ rendering parameters */ |
| 101 | extern RAYPARAMS        *curparams;     /* current parameter settings */ |
| 102 | extern int              twolevels;      /* low and high quality differ */ |
| 103 |  |
| 104 | extern double   mblur;                  /* vflt(MBLUR) */ |
| 105 | extern double   rate;                   /* vflt(RATE) */ |
| 106 |  |
| 107 | extern char             objtmpf[];      /* object temporary file */ |
| 108 |  |
| 109 | extern struct ObjMove   *obj_move;      /* object movements */ |
| 110 |  |
| 111 | extern int              haveprio;       /* high-level saliency specified */ |
| 112 |  |
| 113 | extern int              gargc;          /* global argc for printargs */ |
| 114 | extern char             **gargv;        /* global argv for printargs */ |
| 115 |  |
| 116 | /************************************************************************* |
| 117 | * Frame rendering stuff (defined in ranimove1.c and ranimove2.c) |
| 118 | */ |
| 119 | /* enumerated accuracy map values */ |
| 120 | #define ANOVAL          0       /* unevaluated pixel */ |
| 121 | #define ALOWQ           1       /* single low-quality sample */ |
| 122 | #define AHIGHQ          2       /* single high-quality sample */ |
| 123 | #define AMIN            3       /* start of error lookup table */ |
| 124 | #define ADISTANT        255     /* ray went off to infinity */ |
| 125 |  |
| 126 | extern double   acctab[256];    /* accuracy value table */ |
| 127 |  |
| 128 | extern int      hres, vres;     /* frame resolution (fcur) */ |
| 129 | extern double   pixaspect;      /* pixel aspect ratio */ |
| 130 |  |
| 131 | extern VIEW     vw;             /* view for this frame */ |
| 132 | extern COLOR    *cbuffer;       /* color at each pixel */ |
| 133 | extern float    *zbuffer;       /* depth at each pixel */ |
| 134 | extern OBJECT   *obuffer;       /* object id at each pixel */ |
| 135 | extern short    *xmbuffer;      /* x motion at each pixel */ |
| 136 | extern short    *ymbuffer;      /* y motion at each pixel */ |
| 137 | extern uby8     *abuffer;       /* accuracy at each pixel */ |
| 138 | extern uby8     *sbuffer;       /* sample count per pixel */ |
| 139 |  |
| 140 | extern VIEW     vwprev;         /* last frame's view */ |
| 141 | extern COLOR    *cprev;         /* last frame colors */ |
| 142 | extern float    *zprev;         /* last frame depth */ |
| 143 | extern OBJECT   *oprev;         /* last frame objects */ |
| 144 | extern uby8     *aprev;         /* last frame accuracy */ |
| 145 |  |
| 146 | extern float    *cerrmap;       /* conspicuous error map */ |
| 147 | extern int      cerrzero;       /* is all of cerrmap zero? */ |
| 148 | extern COLOR    *val2map;       /* value-squared map for variance */ |
| 149 |  |
| 150 | extern double   frm_stop;       /* when to stop rendering this frame */ |
| 151 |  |
| 152 | extern double   hlsmax;         /* maximum high-level saliency */ |
| 153 |  |
| 154 | #define CSF_SMN         (1./0.82)       /* 1/avg_tracking_efficacy */ |
| 155 |  |
| 156 | #define outbuffer       cprev   /* used to hold final output */ |
| 157 | #define wbuffer         zprev   /* used for final filtering */ |
| 158 |  |
| 159 | #define fndx(x,y)       ((y)*hres + (x)) |
| 160 |  |
| 161 | #define MO_UNK          -32768  /* unknown motion value */ |
| 162 |  |
| 163 | #define FOV_DEG         1.0     /* foveal radius (degrees) */ |
| 164 |  |
| 165 | #define LOG_E1          (-0.0233)       /* ln(0.977) */ |
| 166 | #define errorf(i)       exp(LOG_E1*((i)-AMIN)) |
| 167 | #define errori(e)       (int)(log(e)*(1./LOG_E1) + (AMIN+.5)) |
| 168 |  |
| 169 | #define NSAMPOK         5       /* samples enough for error estimation */ |
| 170 |  |
| 171 | #define NPINTERP        4       /* number of pixels to interpolate */ |
| 172 |  |
| 173 | #define ATIDIFF         7       /* error difference for time extrapolation */ |
| 174 |  |
| 175 | /* ranimove1.c */ |
| 176 | extern void     init_frame(void); |
| 177 | extern void filter_frame(void); |
| 178 | extern void send_frame(void); |
| 179 | extern void free_frame(void); |
| 180 | extern void write_map(float *mp, char *fn); |
| 181 | extern void sample_pos(double hv[2], int x, int y, int sn); |
| 182 | extern void comp_frame_error(void); |
| 183 | extern int      getclosest(int *iarr, int nc, int x, int y); |
| 184 | extern int getambcolor(COLOR clr, int obj); |
| 185 | extern double   sample_wt(int xo, int yo); |
| 186 | extern double estimaterr(COLOR cs, COLOR cs2, int ns, int ns0); |
| 187 | extern double comperr(int *neigh, int nc, int ns0); |
| 188 |  |
| 189 | /* ranimove2.c */ |
| 190 | extern int refine_first(); |
| 191 | extern void conspicuity(void); |
| 192 | extern int refine_frame(int pass); |
| 193 |  |
| 194 | /* ranimove.c */ |
| 195 | extern double getTime(void); |
| 196 | extern double obj_prio(OBJECT obj); |
| 197 | extern int getmove(OBJECT obj); |
| 198 | extern char * getoctspec(int n); |
| 199 | extern double expspec_val(char *s); |
| 200 | extern char *getexp(int n); /* XXX partly duplicated function */ |
| 201 | extern VIEW *getview(int n); /* XXX duplicated function */ |
| 202 | double  getTime(); |
| 203 | /* |
| 204 | int     countviews(); |
| 205 | void    setdefaults(), |
| 206 | void setmove(), |
| 207 | setrendparams(); |
| 208 | getradfile(), |
| 209 | animate(), |
| 210 | */ |
| 211 |  |
| 212 | #ifdef __cplusplus |
| 213 | } |
| 214 | #endif |
| 215 | #endif /* _RAD_RANIMOVE_H_ */ |
| 216 |  |
