root/radiance/src/util/radcompare.c
Revision: 2.28
Committed: Mon Sep 27 19:00:04 2021 UTC (4 years ago) by greg
perf(radcompare): minor improvement in handling of EXPOSURE header info
2 static const char RCSid[] = "$Id: radcompare.c,v 2.27 2021/02/18 23:16:35 greg Exp $";
5 * Compare Radiance files for significant differences
6 *
7 * G. Ward
8 */
9
10 #include <stdlib.h>
11 #include <ctype.h>
12 #include "rtmath.h"
13 #include "platform.h"
14 #include "rtio.h"
15 #include "resolu.h"
16 #include "color.h"
17 #include "depthcodec.h"
18 #include "normcodec.h"
19 #include "lookup.h"
20 /* Reporting levels */
21 #define REP_QUIET 0 /* no reporting */
22 #define REP_ERROR 1 /* report errors only */
23 #define REP_WARN 2 /* report warnings as well */
24 #define REP_VERBOSE 3 /* verbose reporting */
25
26 int report = REP_WARN; /* reporting level */
27
28 int ign_header = 0; /* ignore header differences? */
29
30 double rel_min = 1e-5; /* positive for relative comparisons */
31
32 double rms_lim = 0.01; /* RMS difference limit */
33
34 double max_lim = 0.25; /* difference limit if non-negative */
35
36 int lin1cnt=0, lin2cnt=0; /* file line position */
37
38 int comment_c = '\0'; /* comment delimiter for text files */
39
40 const char nsuffix[10][3] = { /* 1st, 2nd, 3rd, etc. */
41 "th","st","nd","rd","th","th","th","th","th","th"
42 };
43 #define num_sfx(n) nsuffix[(n)%10]
44
45 /* file types */
46 const char *file_type[] = {
47 "Unrecognized",
48 "TEXT_generic",
49 "ascii",
50 COLRFMT,
51 CIEFMT,
52 DEPTH16FMT,
53 NORMAL32FMT,
54 "float",
55 "double",
56 "BSDF_RBFmesh",
57 "Radiance_octree",
58 "Radiance_tmesh",
59 "8-bit_indexed_name",
60 "16-bit_indexed_name",
61 "24-bit_indexed_name",
62 "BINARY_unknown",
63 NULL /* terminator */
64 };
65 /* keep consistent with above */
66 enum {TYP_UNKNOWN, TYP_TEXT, TYP_ASCII, TYP_RGBE, TYP_XYZE,
67 TYP_DEPTH, TYP_NORM, TYP_FLOAT, TYP_DOUBLE,
68 TYP_RBFMESH, TYP_OCTREE, TYP_TMESH,
69 TYP_ID8, TYP_ID16, TYP_ID24, TYP_BINARY};
70
71 #define has_header(t) (!( 1L<<(t) & (1L<<TYP_TEXT | 1L<<TYP_BINARY) ))
72
73 /* header variables to always ignore */
74 const char *hdr_ignkey[] = {
75 "SOFTWARE",
76 "CAPDATE",
77 "GMT",
78 "FRAME",
79 NULL /* terminator */
80 };
81 /* header variable settings */
82 LUTAB hdr1 = LU_SINIT(free,free);
83 LUTAB hdr2 = LU_SINIT(free,free);
84
85 /* advance appropriate file line count */
86 #define adv_linecnt(htp) (lin1cnt += (htp == &hdr1), \
87 lin2cnt += (htp == &hdr2))
88
89 typedef struct { /* dynamic line buffer */
90 char *str;
91 int len;
92 int siz;
93 } LINEBUF;
94
95 #define init_line(bp) ((bp)->str = NULL, (bp)->siz = 0)
96 /* 100 MByte limit on line buffer */
97 #define MAXBUF (100L<<20)
98
99 /* input files */
100 char *progname = NULL;
101 const char stdin_name[] = "<stdin>";
102 const char *f1name=NULL, *f2name=NULL;
103 FILE *f1in=NULL, *f2in=NULL;
104 int f1swap=0, f2swap=0;
105
106 /* running real differences */
107 double diff2sum = 0;
108 long nsum = 0;
109
110 /* Report usage and exit */
111 static void
112 usage()
113 {
114 fputs("Usage: ", stderr);
115 fputs(progname, stderr);
116 fputs(" [-h][-c#][-s|-w|-v][-rel min_test][-rms epsilon][-max epsilon] reference test\n",
117 stderr);
118 exit(2);
119 }
120
121 /* Read a text line, increasing buffer size as necessary */
122 static int
123 read_line(LINEBUF *bp, FILE *fp)
124 {
125 static int doneWarn = 0;
126
127 bp->len = 0;
128 if (!bp->str) {
129 bp->str = (char *)malloc(bp->siz = 512);
130 if (!bp->str)
131 goto memerr;
132 }
133 while (fgets(bp->str + bp->len, bp->siz - bp->len, fp)) {
134 bp->len += strlen(bp->str + bp->len);
135 if (bp->str[bp->len-1] == '\n')
136 break; /* found EOL */
137 if (bp->len < bp->siz - 4)
138 continue; /* at EOF? */
139 if (bp->siz >= MAXBUF) {
140 if ((report >= REP_WARN) & !doneWarn) {
141 fprintf(stderr,
142 "%s: warning - input line(s) past %ld MByte limit\n",
143 progname, MAXBUF>>20);
144 doneWarn++;
145 }
146 break; /* return MAXBUF partial line */
147 }
148 if ((bp->siz += bp->siz/2) > MAXBUF)
149 bp->siz = MAXBUF;
150 bp->str = (char *)realloc(bp->str, bp->siz);
151 if (!bp->str)
152 goto memerr;
153 }
154 if (comment_c) { /* elide comment? */
155 char *cp = sskip2(bp->str,0);
156 if (*cp == comment_c) {
157 *cp++ = '\n';
158 *cp = '\0';
159 bp->len = cp - bp->str;
160 }
161 }
162 return(bp->len);
163 memerr:
164 fprintf(stderr,
165 "%s: out of memory in read_line() allocating %d byte buffer\n",
166 progname, bp->siz);
167 exit(2);
168 }
169
170 /* Free line buffer */
171 static void
172 free_line(LINEBUF *bp)
173 {
174 if (bp->str) free(bp->str);
175 init_line(bp);
176 }
177
178 /* Get type ID from name (or 0 if not found) */
179 static int
180 xlate_type(const char *nm)
181 {
182 int i;
183
184 if (!nm || !*nm)
185 return(TYP_UNKNOWN);
186 for (i = 1; file_type[i]; i++)
187 if (!strcmp(nm, file_type[i]))
188 return(i);
189 return(TYP_UNKNOWN);
190 }
191
192 /* Compare real values and keep track of differences */
193 static int
194 real_check(double r1, double r2)
195 {
196 double diff2 = (r1 - r2)*(r1 - r2);
197
198 if (rel_min > 0) { /* doing relative differences? */
199 double av2 = .25*(r1*r1 + 2.*fabs(r1*r2) + r2*r2);
200 if (av2 < rel_min*rel_min)
201 av2 = rel_min*rel_min;
202 diff2 /= av2;
203 }
204 if (max_lim >= 0 && diff2 > max_lim*max_lim) {
205 if (report != REP_QUIET)
206 printf(
207 "%s: %sdifference between %.8g and %.8g exceeds epsilon of %.8g\n",
208 progname,
209 (rel_min > 0) ? "relative " : "",
210 r1, r2, max_lim);
211 return(0);
212 }
213 diff2sum += diff2;
214 nsum++;
215 return(1);
216 }
217
218 /* Compare two color values for equivalence */
219 static int
220 color_check(COLOR c1, COLOR c2)
221 {
222 int p;
223
224 if (!real_check((colval(c1,RED)+colval(c1,GRN)+colval(c1,BLU))*(1./3.),
225 (colval(c2,RED)+colval(c2,GRN)+colval(c2,BLU))*(1./3.)))
226 return(0);
227
228 p = (colval(c1,GRN) > colval(c1,RED)) ? GRN : RED;
229 if (colval(c1,BLU) > colval(c1,p)) p = BLU;
230
231 return(real_check(colval(c1,p), colval(c2,p)));
232 }
233
234 /* Compare two normal directions for equivalence */
235 static int
236 norm_check(FVECT nv1, FVECT nv2)
237 {
238 double max2 = nv1[2]*nv2[2];
239 int imax = 2;
240 int i = 2;
241 /* identify largest component */
242 while (i--) {
243 double tm2 = nv1[i]*nv2[i];
244 if (tm2 > max2) {
245 imax = i;
246 max2 = tm2;
247 }
248 }
249 i = 3; /* compare smaller components */
250 while (i--) {
251 if (i == imax)
252 continue;
253 if (!real_check(nv1[i], nv2[i]))
254 return(0);
255 }
256 return(1);
257 }
258
259 /* Compare two strings for equivalence */
260 static int
261 equiv_string(char *s1, char *s2)
262 {
263 #define CLS_STR 0
264 #define CLS_INT 1
265 #define CLS_FLT 2
266 /* skip whitespace at beginning */
267 while (isspace(*s1)) s1++;
268 while (isspace(*s2)) s2++;
269 while (*s1) { /* check each word */
270 int inquote;
271 if (!*s2) /* unexpected EOL in s2? */
272 return(0);
273 inquote = *s1;
274 if ((inquote != '\'') & (inquote != '"'))
275 inquote = 0;
276 if (inquote) { /* quoted text must match exactly */
277 if (*s1++ != *s2++)
278 return(0);
279 while (*s1 != inquote) {
280 if (!*s1)
281 return(0);
282 if (*s1++ != *s2++)
283 return(0);
284 }
285 s1++;
286 if (*s2++ != inquote)
287 return(0);
288 } else { /* else classify word type */
289 char *s1s = s1;
290 char *s2s = s2;
291 int cls = CLS_STR;
292 s1 = sskip(s1);
293 s2 = sskip(s2);
294 if (iskip(s1s) == s1) {
295 if (iskip(s2s) == s2)
296 cls = CLS_INT;
297 else if (fskip(s2s) == s2)
298 cls = CLS_FLT;
299 } else if (fskip(s1s) == s1) {
300 if (fskip(s2s) != s2)
301 return(0);
302 cls = CLS_FLT;
303 }
304 switch (cls) {
305 case CLS_INT: /* strncmp() faster */
306 case CLS_STR:
307 if (s1 - s1s != s2 - s2s)
308 return(0);
309 if (strncmp(s1s, s2s, s1 - s1s))
310 return(0);
311 break;
312 case CLS_FLT:
313 if (!real_check(atof(s1s), atof(s2s)))
314 return(0);
315 break;
316 }
317 }
318 while (isspace(*s1)) s1++;
319 while (isspace(*s2)) s2++;
320 }
321 return(!*s2); /* match if we reached the end of s2, too */
322 #undef CLS_STR
323 #undef CLS_INT
324 #undef CLS_FLT
325 }
326
327 /* Check if string is var=value pair and set if not in ignore list */
328 static int
329 setheadvar(char *val, void *p)
330 {
331 char newval[128];
332 LUTAB *htp = (LUTAB *)p;
333 LUENT *tep;
334 char *key;
335 int kln, vln;
336 int n;
337
338 adv_linecnt(htp); /* side-effect is to count lines */
339 if (!isalpha(*val)) /* key must start line */
340 return(0);
341 /* check if we need to swap binary data */
342 if ((n = isbigendian(val)) >= 0) {
343 if (nativebigendian() == n)
344 return(0);
345 f1swap += (htp == &hdr1);
346 f2swap += (htp == &hdr2);
347 return(0);
348 }
349 key = val++;
350 while (*val && !isspace(*val) & (*val != '='))
351 val++;
352 kln = val - key;
353 while (isspace(*val)) /* check for value */
354 *val++ = '\0';
355 if (*val != '=')
356 return(0);
357 *val++ = '\0';
358 while (isspace(*val))
359 val++;
360 if (!*val) /* nothing set? */
361 return(0);
362 /* check if key to ignore */
363 for (n = 0; hdr_ignkey[n]; n++)
364 if (!strcmp(key, hdr_ignkey[n]))
365 return(0);
366 vln = strlen(val); /* eliminate space and newline at end */
367 while (isspace(val[--vln]))
368 ;
369 val[++vln] = '\0';
370 if (!(tep = lu_find(htp, key)))
371 return(-1); /* memory allocation error */
372 if (!tep->key)
373 tep->key = strcpy(malloc(kln+1), key);
374 if (tep->data) { /* check for special cases */
375 if (!strcmp(key, "EXPOSURE")) {
376 sprintf(newval, "%.6e", atof(tep->data)*atof(val));
377 vln = strlen(val = newval);
378 }
379 free(tep->data);
380 }
381 tep->data = strcpy(malloc(vln+1), val);
382 return(1);
383 }
384
385 /* Lookup correspondent in other header */
386 static int
387 match_val(const LUENT *ep1, void *p2)
388 {
389 const LUENT *ep2 = lu_find((LUTAB *)p2, ep1->key);
390 if (!ep2 || !ep2->data) {
391 if (report != REP_QUIET)
392 printf("%s: variable '%s' missing in '%s'\n",
393 progname, ep1->key, f2name);
394 return(-1);
395 }
396 if (!equiv_string((char *)ep1->data, (char *)ep2->data)) {
397 if (report != REP_QUIET) {
398 printf("%s: header variable '%s' has different values\n",
399 progname, ep1->key);
400 if (report >= REP_VERBOSE) {
401 printf("%s: %s=%s\n", f1name,
402 ep1->key, (char *)ep1->data);
403 printf("%s: %s=%s\n", f2name,
404 ep2->key, (char *)ep2->data);
405 }
406 }
407 return(-1);
408 }
409 return(1); /* good match */
410 }
411
412 /* Compare two sets of header variables */
413 static int
414 headers_match()
415 {
416 int ne = lu_doall(&hdr1, match_val, &hdr2);
417 if (ne < 0)
418 return(0); /* something didn't match! */
419 /* non-fatal if second header has extra */
420 if (report >= REP_WARN && (ne = lu_doall(&hdr2, NULL, NULL) - ne))
421 printf("%s: warning - '%s' has %d extra header setting(s)\n",
422 progname, f2name, ne);
423 return(1); /* good match */
424 }
425
426 /* Check generic input to determine if it is binary, -1 on error */
427 static int
428 input_is_binary(FILE *fin)
429 {
430 int n = 0;
431 int c = 0;
432
433 while ((c = getc(fin)) != EOF) {
434 ++n;
435 if (!c | (c > 127))
436 break; /* non-ascii character */
437 if (n >= 10240)
438 break; /* enough to be confident */
439 }
440 if (!n)
441 return(-1); /* first read failed */
442 if (fseek(fin, 0L, 0) < 0)
443 return(-1); /* rewind failed */
444 return(!c | (c > 127));
445 }
446
447 /* Identify and return data type from header (if one) */
448 static int
449 identify_type(const char *name, FILE *fin, LUTAB *htp)
450 {
451 extern const char HDRSTR[];
452 int c;
453 /* check magic header start */
454 if ((c = getc(fin)) != HDRSTR[0]) {
455 if (c == EOF) goto badeof;
456 ungetc(c, fin);
457 c = 0;
458 } else if ((c = getc(fin)) != HDRSTR[1]) {
459 if (c == EOF) goto badeof;
460 ungetc(c, fin); ungetc(HDRSTR[0], fin);
461 c = 0;
462 }
463 if (c) { /* appears to have a header */
464 char sbuf[32];
465 if (!fgets(sbuf, sizeof(sbuf), fin))
466 goto badeof;
467 adv_linecnt(htp); /* for #?ID string */
468 if (report >= REP_WARN && strncmp(sbuf, "RADIANCE", 8)) {
469 fputs(name, stdout);
470 fputs(": warning - unexpected header ID: ", stdout);
471 fputs(sbuf, stdout);
472 }
473 if (getheader(fin, setheadvar, htp) < 0) {
474 fputs(name, stderr);
475 fputs(": unknown error reading header\n", stderr);
476 return(-1);
477 }
478 adv_linecnt(htp); /* for trailing emtpy line */
479 return(xlate_type((const char *)lu_find(htp,"FORMAT")->data));
480 }
481 c = input_is_binary(fin); /* else peek to see if binary */
482 if (c < 0) {
483 fputs(name, stderr);
484 fputs(": read/seek error\n", stderr);
485 return(-1);
486 }
487 if (c)
488 return(TYP_BINARY);
489 return(TYP_TEXT);
490 badeof:
491 if (report != REP_QUIET) {
492 fputs(name, stdout);
493 fputs(": unexpected end-of-file\n", stdout);
494 }
495 return(-1);
496 }
497
498 /* Check that overall RMS error is below threshold */
499 static int
500 good_RMS()
501 {
502 if (!nsum)
503 return(1);
504 if (diff2sum/(double)nsum > rms_lim*rms_lim) {
505 if (report != REP_QUIET)
506 printf(
507 "%s: %sRMS difference between '%s' and '%s' of %.5g exceeds limit of %.5g\n",
508 progname,
509 (rel_min > 0) ? "relative " : "",
510 f1name, f2name,
511 sqrt(diff2sum/(double)nsum), rms_lim);
512 return(0);
513 }
514 if (report >= REP_VERBOSE)
515 printf("%s: %sRMS difference of reals in '%s' and '%s' is %.5g\n",
516 progname, (rel_min > 0) ? "relative " : "",
517 f1name, f2name, sqrt(diff2sum/(double)nsum));
518 return(1);
519 }
520
521 /* Compare two inputs as generic binary files */
522 static int
523 compare_binary()
524 {
525 int c1=0, c2=0;
526
527 if (report >= REP_VERBOSE) {
528 fputs(progname, stdout);
529 fputs(": comparing inputs as binary\n", stdout);
530 }
531 for ( ; ; ) { /* exact byte matching */
532 c1 = getc(f1in);
533 c2 = getc(f2in);
534 if (c1 == EOF) {
535 if (c2 == EOF)
536 return(1); /* success! */
537 if (report != REP_QUIET) {
538 fputs(f1name, stdout);
539 fputs(": unexpected end-of-file\n", stdout);
540 }
541 return(0);
542 }
543 if (c2 == EOF) {
544 if (report != REP_QUIET) {
545 fputs(f2name, stdout);
546 fputs(": unexpected end-of-file\n", stdout);
547 }
548 return(0);
549 }
550 if (c1 != c2)
551 break; /* quit and report difference */
552 }
553 if (report == REP_QUIET)
554 return(0);
555 printf("%s: binary files '%s' and '%s' differ at byte offset %ld|%ld\n",
556 progname, f1name, f2name, ftell(f1in), ftell(f2in));
557 if (report >= REP_VERBOSE)
558 printf("%s: byte in '%s' is 0x%X, byte in '%s' is 0x%X\n",
559 progname, f1name, c1, f2name, c2);
560 return(0);
561 }
562
563 /* Compare two inputs as generic text files */
564 static int
565 compare_text()
566 {
567 LINEBUF l1buf, l2buf;
568
569 if (report >= REP_VERBOSE) {
570 fputs(progname, stdout);
571 fputs(": comparing inputs as ASCII text", stdout);
572 if (comment_c) {
573 fputs(", ignoring comments starting with '", stdout);
574 fputc(comment_c, stdout);
575 fputc('\'', stdout);
576 }
577 fputc('\n', stdout);
578 }
579 SET_FILE_TEXT(f1in); /* originally set to binary */
580 SET_FILE_TEXT(f2in);
581 init_line(&l1buf); init_line(&l2buf); /* compare a line at a time */
582 while (read_line(&l1buf, f1in)) {
583 lin1cnt++;
584 if (!*sskip2(l1buf.str,0))
585 continue; /* ignore empty lines */
586
587 while (read_line(&l2buf, f2in)) {
588 lin2cnt++;
589 if (*sskip2(l2buf.str,0))
590 break; /* found other non-empty line */
591 }
592 if (!l2buf.len) { /* input 2 EOF? */
593 if (report != REP_QUIET) {
594 fputs(f2name, stdout);
595 fputs(": unexpected end-of-file\n", stdout);
596 }
597 free_line(&l1buf); free_line(&l2buf);
598 return(0);
599 }
600 /* compare non-empty lines */
601 if (!equiv_string(l1buf.str, l2buf.str)) {
602 if (report != REP_QUIET) {
603 printf("%s: inputs '%s' and '%s' differ at line %d|%d\n",
604 progname, f1name, f2name,
605 lin1cnt, lin2cnt);
606 if ( report >= REP_VERBOSE &&
607 (l1buf.len < 256) &
608 (l2buf.len < 256) ) {
609 fputs("------------- Mismatch -------------\n", stdout);
610 printf("%s@%d:\t%s", f1name,
611 lin1cnt, l1buf.str);
612 printf("%s@%d:\t%s", f2name,
613 lin2cnt, l2buf.str);
614 }
615 }
616 free_line(&l1buf); free_line(&l2buf);
617 return(0);
618 }
619 }
620 free_line(&l1buf); /* check for EOF on input 2 */
621 while (read_line(&l2buf, f2in)) {
622 if (!*sskip2(l2buf.str,0))
623 continue;
624 if (report != REP_QUIET) {
625 fputs(f1name, stdout);
626 fputs(": unexpected end-of-file\n", stdout);
627 }
628 free_line(&l2buf);
629 return(0);
630 }
631 free_line(&l2buf);
632 return(good_RMS()); /* final check for reals */
633 }
634
635 /* Check image/map resolutions */
636 static int
637 check_resolu(const char *class, RESOLU *r1p, RESOLU *r2p)
638 {
639 if (r1p->rt != r2p->rt) {
640 if (report != REP_QUIET)
641 printf(
642 "%s: %ss '%s' and '%s' have different pixel ordering\n",
643 progname, class, f1name, f2name);
644 return(0);
645 }
646 if ((r1p->xr != r2p->xr) | (r1p->yr != r2p->yr)) {
647 if (report != REP_QUIET)
648 printf(
649 "%s: %ss '%s' and '%s' are different sizes\n",
650 progname, class, f1name, f2name);
651 return(0);
652 }
653 return(1);
654 }
655
656 /* Compare two inputs that are known to be RGBE or XYZE images */
657 static int
658 compare_hdr()
659 {
660 RESOLU rs1, rs2;
661 COLOR *scan1, *scan2;
662 int x, y;
663
664 if (report >= REP_VERBOSE) {
665 fputs(progname, stdout);
666 fputs(": comparing inputs as HDR images\n", stdout);
667 }
668 fgetsresolu(&rs1, f1in);
669 fgetsresolu(&rs2, f2in);
670 if (!check_resolu("HDR image", &rs1, &rs2))
671 return(0);
672 scan1 = (COLOR *)malloc(scanlen(&rs1)*sizeof(COLOR));
673 scan2 = (COLOR *)malloc(scanlen(&rs2)*sizeof(COLOR));
674 if (!scan1 | !scan2) {
675 fprintf(stderr, "%s: out of memory in compare_hdr()\n", progname);
676 exit(2);
677 }
678 for (y = 0; y < numscans(&rs1); y++) {
679 if ((freadscan(scan1, scanlen(&rs1), f1in) < 0) |
680 (freadscan(scan2, scanlen(&rs2), f2in) < 0)) {
681 if (report != REP_QUIET)
682 printf("%s: unexpected end-of-file\n",
683 progname);
684 free(scan1);
685 free(scan2);
686 return(0);
687 }
688 for (x = 0; x < scanlen(&rs1); x++) {
689 if (color_check(scan1[x], scan2[x]))
690 continue;
691 if (report != REP_QUIET) {
692 printf(
693 "%s: pixels at scanline %d offset %d differ\n",
694 progname, y, x);
695 if (report >= REP_VERBOSE) {
696 printf("%s: (R,G,B)=(%g,%g,%g)\n",
697 f1name, colval(scan1[x],RED),
698 colval(scan1[x],GRN),
699 colval(scan1[x],BLU));
700 printf("%s: (R,G,B)=(%g,%g,%g)\n",
701 f2name, colval(scan2[x],RED),
702 colval(scan2[x],GRN),
703 colval(scan2[x],BLU));
704 }
705 }
706 free(scan1);
707 free(scan2);
708 return(0);
709 }
710 }
711 free(scan1);
712 free(scan2);
713 return(good_RMS()); /* final check of RMS */
714 }
715
716 /* Set reference depth based on header variable */
717 static int
718 set_refdepth(DEPTHCODEC *dcp, LUTAB *htp)
719 {
720 static char depthvar[] = DEPTHSTR;
721 const char *drval;
722
723 depthvar[LDEPTHSTR-1] = '\0';
724 drval = (const char *)lu_find(htp, depthvar)->data;
725 if (!drval)
726 return(0);
727 dcp->refdepth = atof(drval);
728 if (dcp->refdepth <= 0) {
729 if (report != REP_QUIET) {
730 fputs(dcp->inpname, stderr);
731 fputs(": bad reference depth '", stderr);
732 fputs(drval, stderr);
733 fputs("'\n", stderr);
734 }
735 return(-1);
736 }
737 return(1);
738 }
739
740 /* Compare two encoded depth maps */
741 static int
742 compare_depth()
743 {
744 long nread = 0;
745 DEPTHCODEC dc1, dc2;
746
747 if (report >= REP_VERBOSE) {
748 fputs(progname, stdout);
749 fputs(": comparing inputs as depth maps\n", stdout);
750 }
751 set_dc_defaults(&dc1);
752 dc1.hdrflags = HF_RESIN;
753 dc1.finp = f1in;
754 dc1.inpname = f1name;
755 set_dc_defaults(&dc2);
756 dc2.hdrflags = HF_RESIN;
757 dc2.finp = f2in;
758 dc2.inpname = f2name;
759 if (report != REP_QUIET) {
760 dc1.hdrflags |= HF_STDERR;
761 dc2.hdrflags |= HF_STDERR;
762 }
763 if (!process_dc_header(&dc1, 0, NULL))
764 return(0);
765 if (!process_dc_header(&dc2, 0, NULL))
766 return(0);
767 if (!check_resolu("Depth map", &dc1.res, &dc2.res))
768 return(0);
769 if (set_refdepth(&dc1, &hdr1) < 0)
770 return(0);
771 if (set_refdepth(&dc2, &hdr2) < 0)
772 return(0);
773 while (nread < dc1.res.xr*dc1.res.yr) {
774 double d1 = decode_depth_next(&dc1);
775 double d2 = decode_depth_next(&dc2);
776 if ((d1 < 0) | (d2 < 0)) {
777 if (report != REP_QUIET)
778 printf("%s: unexpected end-of-file\n",
779 progname);
780 return(0);
781 }
782 ++nread;
783 if (real_check(d1, d2))
784 continue;
785 if (report != REP_QUIET)
786 printf("%s: %ld%s depth values differ\n",
787 progname, nread, num_sfx(nread));
788 return(0);
789 }
790 return(good_RMS()); /* final check of RMS */
791 }
792
793 /* Compare two encoded normal maps */
794 static int
795 compare_norm()
796 {
797 long nread = 0;
798 NORMCODEC nc1, nc2;
799
800 if (report >= REP_VERBOSE) {
801 fputs(progname, stdout);
802 fputs(": comparing inputs as normal maps\n", stdout);
803 }
804 set_nc_defaults(&nc1);
805 nc1.hdrflags = HF_RESIN;
806 nc1.finp = f1in;
807 nc1.inpname = f1name;
808 set_nc_defaults(&nc2);
809 nc2.hdrflags = HF_RESIN;
810 nc2.finp = f2in;
811 nc2.inpname = f2name;
812 if (report != REP_QUIET) {
813 nc1.hdrflags |= HF_STDERR;
814 nc2.hdrflags |= HF_STDERR;
815 }
816 if (!process_nc_header(&nc1, 0, NULL))
817 return(0);
818 if (!process_nc_header(&nc2, 0, NULL))
819 return(0);
820 if (!check_resolu("Normal map", &nc1.res, &nc2.res))
821 return(0);
822 while (nread < nc1.res.xr*nc1.res.yr) {
823 FVECT nv1, nv2;
824 int rv1 = decode_normal_next(nv1, &nc1);
825 int rv2 = decode_normal_next(nv2, &nc2);
826 if ((rv1 < 0) | (rv2 < 0)) {
827 if (report != REP_QUIET)
828 printf("%s: unexpected end-of-file\n",
829 progname);
830 return(0);
831 }
832 ++nread;
833 if (rv1 == rv2 && (!rv1 || norm_check(nv1, nv2)))
834 continue;
835 if (report != REP_QUIET)
836 printf("%s: %ld%s normal vectors differ\n",
837 progname, nread, num_sfx(nread));
838 return(0);
839 }
840 return(good_RMS()); /* final check of RMS */
841 }
842
843 /* Compare two inputs that are known to be 32-bit floating-point data */
844 static int
845 compare_float()
846 {
847 long nread = 0;
848 float f1, f2;
849
850 if (report >= REP_VERBOSE) {
851 fputs(progname, stdout);
852 fputs(": comparing inputs as 32-bit IEEE floats\n", stdout);
853 }
854 while (getbinary(&f1, sizeof(f1), 1, f1in)) {
855 if (!getbinary(&f2, sizeof(f2), 1, f2in))
856 goto badeof;
857 ++nread;
858 if (f1swap) swap32((char *)&f1, 1);
859 if (f2swap) swap32((char *)&f2, 1);
860 if (real_check(f1, f2))
861 continue;
862 if (report != REP_QUIET)
863 printf("%s: %ld%s float values differ\n",
864 progname, nread, num_sfx(nread));
865 return(0);
866 }
867 if (!getbinary(&f2, sizeof(f2), 1, f2in))
868 return(good_RMS()); /* final check of RMS */
869 badeof:
870 if (report != REP_QUIET)
871 printf("%s: unexpected end-of-file\n", progname);
872 return(0);
873 }
874
875 /* Compare two inputs that are known to be 64-bit floating-point data */
876 static int
877 compare_double()
878 {
879 long nread = 0;
880 double f1, f2;
881
882 if (report >= REP_VERBOSE) {
883 fputs(progname, stdout);
884 fputs(": comparing inputs as 64-bit IEEE doubles\n", stdout);
885 }
886 while (getbinary(&f1, sizeof(f1), 1, f1in)) {
887 if (!getbinary(&f2, sizeof(f2), 1, f2in))
888 goto badeof;
889 ++nread;
890 if (f1swap) swap64((char *)&f1, 1);
891 if (f2swap) swap64((char *)&f2, 1);
892 if (real_check(f1, f2))
893 continue;
894 if (report != REP_QUIET)
895 printf("%s: %ld%s double values differ\n",
896 progname, nread, num_sfx(nread));
897 return(0);
898 }
899 if (!getbinary(&f2, sizeof(f2), 1, f2in))
900 return(good_RMS()); /* final check of RMS */
901 badeof:
902 if (report != REP_QUIET)
903 printf("%s: unexpected end-of-file\n", progname);
904 return(0);
905 }
906
907 /* Compare two Radiance files for equivalence */
908 int
909 main(int argc, char *argv[])
910 {
911 int typ1, typ2;
912 int a;
913
914 progname = argv[0];
915 for (a = 1; a < argc && argv[a][0] == '-'; a++) {
916 switch (argv[a][1]) {
917 case 'h': /* ignore header info. */
918 ign_header = !ign_header;
919 continue;
920 case 'c': /* ignore comments */
921 comment_c = argv[a][2];
922 continue;
923 case 's': /* silent operation */
924 report = REP_QUIET;
925 continue;
926 case 'w': /* turn off warnings */
927 if (report > REP_ERROR)
928 report = REP_ERROR;
929 continue;
930 case 'v': /* turn on verbose mode */
931 report = REP_VERBOSE;
932 continue;
933 case 'm': /* maximum epsilon */
934 max_lim = atof(argv[++a]);
935 continue;
936 case 'r':
937 if (argv[a][2] == 'e') /* relative difference */
938 rel_min = atof(argv[++a]);
939 else if (argv[a][2] == 'm') /* RMS limit */
940 rms_lim = atof(argv[++a]);
941 else
942 usage();
943 continue;
944 case '\0': /* first file from stdin */
945 f1in = stdin;
946 f1name = stdin_name;
947 break;
948 default:
949 usage();
950 }
951 break;
952 }
953 if (a != argc-2) /* make sure of two inputs */
954 usage();
955 if (!strcmp(argv[a], argv[a+1])) { /* inputs are same? */
956 if (report >= REP_WARN)
957 printf("%s: warning - identical inputs given\n",
958 progname);
959 return(0);
960 }
961 if (!f1name) f1name = argv[a];
962 if (!f2name) f2name = argv[a+1];
963 /* open inputs */
964 SET_FILE_BINARY(stdin); /* in case we're using it */
965 if (!f1in && !(f1in = fopen(f1name, "rb"))) {
966 fprintf(stderr, "%s: cannot open for reading\n", f1name);
967 return(2);
968 }
969 if (!strcmp(f2name, "-")) {
970 f2in = stdin;
971 f2name = stdin_name;
972 } else if (!(f2in = fopen(f2name, "rb"))) {
973 fprintf(stderr, "%s: cannot open for reading\n", f2name);
974 return(2);
975 }
976 /* load headers */
977 if ((typ1 = identify_type(f1name, f1in, &hdr1)) < 0)
978 return(2);
979 if ((typ2 = identify_type(f2name, f2in, &hdr2)) < 0)
980 return(2);
981 if (typ1 != typ2) {
982 if (report != REP_QUIET)
983 printf("%s: '%s' format is %s and '%s' is %s\n",
984 progname, f1name, file_type[typ1],
985 f2name, file_type[typ2]);
986 return(1);
987 }
988 ign_header |= !has_header(typ1); /* check headers if indicated */
989 if (!ign_header && !headers_match())
990 return(1);
991 if (!ign_header & (report >= REP_WARN)) {
992 if (lin1cnt != lin2cnt)
993 printf("%s: warning - headers are different lengths\n",
994 progname);
995 if (typ1 == TYP_UNKNOWN)
996 printf("%s: warning - unrecognized format\n",
997 progname);
998 }
999 if (report >= REP_VERBOSE) {
1000 printf("%s: data format is %s\n", progname, file_type[typ1]);
1001 if ((typ1 == TYP_FLOAT) | (typ1 == TYP_DOUBLE)) {
1002 if (f1swap)
1003 printf("%s: input '%s' is byte-swapped\n",
1004 progname, f1name);
1005 if (f2swap)
1006 printf("%s: input '%s' is byte-swapped\n",
1007 progname, f2name);
1008 }
1009 }
1010 switch (typ1) { /* compare based on type */
1011 case TYP_BINARY:
1012 case TYP_TMESH:
1013 case TYP_OCTREE:
1014 case TYP_RBFMESH:
1015 case TYP_ID8:
1016 case TYP_ID16:
1017 case TYP_ID24:
1018 case TYP_UNKNOWN:
1019 return( !compare_binary() );
1020 case TYP_TEXT:
1021 case TYP_ASCII:
1022 return( !compare_text() );
1023 case TYP_RGBE:
1024 case TYP_XYZE:
1025 return( !compare_hdr() );
1026 case TYP_DEPTH:
1027 return( !compare_depth() );
1028 case TYP_NORM:
1029 return( !compare_norm() );
1030 case TYP_FLOAT:
1031 return( !compare_float() );
1032 case TYP_DOUBLE:
1033 return( !compare_double() );
1034 }
1035 return(1);
1036 }
