root/radiance/src/util/radcompare.c
Revision: 2.36
Committed: Tue Jun 3 21:31:51 2025 UTC (4 months, 2 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.35: +3 -4 lines
Error occurred while calculating annotation data.
2 static const char RCSid[] = "$Id: radcompare.c,v 2.35 2024/12/09 00:29:30 greg Exp $";
5 * Compare Radiance files for significant differences
6 *
7 * G. Ward
8 */
9
10 #include <stdlib.h>
11 #include <ctype.h>
12 #include "rtmath.h"
13 #include "platform.h"
14 #include "rtio.h"
15 #include "resolu.h"
16 #include "color.h"
17 #include "depthcodec.h"
18 #include "normcodec.h"
19 #include "lookup.h"
20 /* Reporting levels */
21 #define REP_QUIET 0 /* no reporting */
22 #define REP_ERROR 1 /* report errors only */
23 #define REP_WARN 2 /* report warnings as well */
24 #define REP_VERBOSE 3 /* verbose reporting */
25
26 int report = REP_WARN; /* reporting level */
27
28 int ign_header = 0; /* ignore header differences? */
29
30 int escape_newlines = 0; /* allow backslash to skip newlines */
31
32 double rel_min = 1e-5; /* positive for relative comparisons */
33
34 double rms_lim = 0.01; /* RMS difference limit */
35
36 double max_lim = 0.25; /* difference limit if non-negative */
37
38 int lin1cnt=0, lin2cnt=0; /* file line position */
39
40 int comment_c = '\0'; /* comment delimiter for text files */
41
42 const char nsuffix[10][3] = { /* 1st, 2nd, 3rd, etc. */
43 "th","st","nd","rd","th","th","th","th","th","th"
44 };
45 #define num_sfx(n) nsuffix[(n)%10]
46
47 /* file types */
48 const char *file_type[] = {
49 "Unrecognized",
50 "TEXT_generic",
51 "ascii",
52 COLRFMT,
53 CIEFMT,
54 SPECFMT,
55 DEPTH16FMT,
56 NORMAL32FMT,
57 "float",
58 "double",
59 "BSDF_RBFmesh",
60 "Radiance_octree",
61 "Radiance_tmesh",
62 "8-bit_indexed_name",
63 "16-bit_indexed_name",
64 "24-bit_indexed_name",
65 "BINARY_unknown",
66 NULL /* terminator */
67 };
68 /* keep consistent with above */
69 enum {TYP_UNKNOWN, TYP_TEXT, TYP_ASCII, TYP_RGBE, TYP_XYZE, TYP_SPEC,
70 TYP_DEPTH, TYP_NORM, TYP_FLOAT, TYP_DOUBLE,
71 TYP_RBFMESH, TYP_OCTREE, TYP_TMESH,
72 TYP_ID8, TYP_ID16, TYP_ID24, TYP_BINARY};
73
74 #define has_header(t) (!( 1L<<(t) & (1L<<TYP_TEXT | 1L<<TYP_BINARY) ))
75
76 /* header variables to always ignore */
77 const char *hdr_ignkey[] = {
78 "SOFTWARE",
79 "CAPDATE",
80 "GMT",
81 "FRAME",
82 "TILED",
83 NULL /* terminator */
84 };
85 /* header variable settings */
86 LUTAB hdr1 = LU_SINIT(free,free);
87 LUTAB hdr2 = LU_SINIT(free,free);
88
89 /* advance appropriate file line count */
90 #define adv_linecnt(htp) (lin1cnt += (htp == &hdr1), \
91 lin2cnt += (htp == &hdr2))
92
93 typedef struct { /* dynamic line buffer */
94 char *str;
95 int len;
96 int siz;
97 } LINEBUF;
98
99 #define init_line(bp) ((bp)->str = NULL, (bp)->siz = 0)
100 /* 100 MByte limit on line buffer */
101 #define MAXBUF (100L<<20)
102
103 /* input files */
104 const char stdin_name[] = "<stdin>";
105 const char *f1name=NULL, *f2name=NULL;
106 FILE *f1in=NULL, *f2in=NULL;
107 int f1swap=0, f2swap=0;
108
109 /* running real differences */
110 double diff2sum = 0;
111 long nsum = 0;
112
113 /* Report usage and exit */
114 static void
115 usage()
116 {
117 fputs("Usage: ", stderr);
118 fputs(progname, stderr);
119 fputs(" [-h][-c#][-s|-w|-v][-rel min_test][-rms epsilon][-max epsilon] reference test\n",
120 stderr);
121 exit(2);
122 }
123
124 /* Read a text line, increasing buffer size as necessary */
125 static int
126 read_line(LINEBUF *bp, FILE *fp)
127 {
128 static int doneWarn = 0;
129
130 bp->len = 0;
131 if (!bp->str) {
132 bp->str = (char *)malloc(bp->siz = 512);
133 if (!bp->str)
134 goto memerr;
135 }
136 while (fgets(bp->str + bp->len, bp->siz - bp->len, fp)) {
137 bp->len += strlen(bp->str + bp->len);
138 if (bp->str[bp->len-1] == '\n') {
139 if (bp->len > 1 && bp->str[bp->len-2] == '\r') {
140 bp->str[--bp->len] = '\0';
141 bp->str[bp->len-1] = '\n';
142 }
143 if (escape_newlines && bp->len > 1 &&
144 bp->str[bp->len-2] == '\\') {
145 bp->str[--bp->len] = '\0';
146 bp->str[bp->len-1] = ' ';
147 continue;
148 }
149 break; /* found EOL */
150 }
151 if (bp->len < bp->siz - 4)
152 continue; /* at EOF? */
153 if (bp->siz >= MAXBUF) {
154 if ((report >= REP_WARN) & !doneWarn) {
155 fprintf(stderr,
156 "%s: warning - input line(s) past %ld MByte limit\n",
157 progname, MAXBUF>>20);
158 doneWarn++;
159 }
160 break; /* return MAXBUF partial line */
161 }
162 if ((bp->siz += bp->siz/2) > MAXBUF)
163 bp->siz = MAXBUF;
164 bp->str = (char *)realloc(bp->str, bp->siz);
165 if (!bp->str)
166 goto memerr;
167 }
168 if (comment_c) { /* elide comment? */
169 char *cp = sskip2(bp->str,0);
170 if (*cp == comment_c) {
171 *cp++ = '\n';
172 *cp = '\0';
173 bp->len = cp - bp->str;
174 }
175 }
176 return(bp->len);
177 memerr:
178 fprintf(stderr,
179 "%s: out of memory in read_line() allocating %d byte buffer\n",
180 progname, bp->siz);
181 exit(2);
182 }
183
184 /* Free line buffer */
185 static void
186 free_line(LINEBUF *bp)
187 {
188 if (bp->str) free(bp->str);
189 init_line(bp);
190 }
191
192 /* Get type ID from name (or 0 if not found) */
193 static int
194 xlate_type(const char *nm)
195 {
196 int i;
197
198 if (!nm || !*nm)
199 return(TYP_UNKNOWN);
200 for (i = 1; file_type[i]; i++)
201 if (!strcmp(nm, file_type[i]))
202 return(i);
203 return(TYP_UNKNOWN);
204 }
205
206 /* Compare real values and keep track of differences */
207 static int
208 real_check(double r1, double r2)
209 {
210 double diff2 = (r1 - r2)*(r1 - r2);
211
212 if (rel_min > 0) { /* doing relative differences? */
213 double av2 = .25*(r1*r1 + 2.*fabs(r1*r2) + r2*r2);
214 if (av2 < rel_min*rel_min)
215 av2 = rel_min*rel_min;
216 diff2 /= av2;
217 }
218 if (max_lim >= 0 && diff2 > max_lim*max_lim) {
219 if (report != REP_QUIET)
220 printf(
221 "%s: %sdifference between %.8g and %.8g exceeds epsilon of %.8g\n",
222 progname,
223 (rel_min > 0) ? "relative " : "",
224 r1, r2, max_lim);
225 return(0);
226 }
227 diff2sum += diff2;
228 nsum++;
229 return(1);
230 }
231
232 /* Compare two color values for equivalence */
233 static int
234 color_check(COLOR c1, COLOR c2)
235 {
236 int p;
237
238 if (!real_check((colval(c1,RED)+colval(c1,GRN)+colval(c1,BLU))*(1./3.),
239 (colval(c2,RED)+colval(c2,GRN)+colval(c2,BLU))*(1./3.)))
240 return(0);
241
242 p = (colval(c1,GRN) > colval(c1,RED)) ? GRN : RED;
243 if (colval(c1,BLU) > colval(c1,p)) p = BLU;
244
245 return(real_check(colval(c1,p), colval(c2,p)));
246 }
247
248 #if 1
249 /* Compare two color spectra for equivalence */
250 static int
251 spec_check(COLORV *sc1, COLORV *sc2)
252 {
253 int p, k;
254
255 if (!real_check(scolor_mean(sc1), scolor_mean(sc2)))
256 return(0);
257
258 p = 0; /* find max. component */
259 for (k = NCSAMP; --k; )
260 if (sc1[k] > sc1[p])
261 p = k;
262
263 return(real_check(sc1[p], sc2[p]));
264 }
265 #else
266 /* Compare two color spectra for equivalence */
267 static int
268 spec_check(COLORV *sc1, COLORV *sc2)
269 {
270 COLOR c1, c2;
271 int p;
272
273 if (!real_check(scolor_mean(sc1), scolor_mean(sc2)))
274 return(0);
275 /* do comparisons in RGB space */
276 scolor_rgb(c1, sc1);
277 scolor_rgb(c2, sc2);
278
279 p = (colval(c1,GRN) > colval(c1,RED)) ? GRN : RED;
280 if (colval(c1,BLU) > colval(c1,p)) p = BLU;
281
282 return(real_check(colval(c1,p), colval(c2,p)));
283 }
284 #endif
285
286 /* Compare two normal directions for equivalence */
287 static int
288 norm_check(FVECT nv1, FVECT nv2)
289 {
290 double max2 = nv1[2]*nv2[2];
291 int imax = 2;
292 int i = 2;
293 /* identify largest component */
294 while (i--) {
295 double tm2 = nv1[i]*nv2[i];
296 if (tm2 > max2) {
297 imax = i;
298 max2 = tm2;
299 }
300 }
301 i = 3; /* compare smaller components */
302 while (i--) {
303 if (i == imax)
304 continue;
305 if (!real_check(nv1[i], nv2[i]))
306 return(0);
307 }
308 return(1);
309 }
310
311 /* Compare two strings for equivalence */
312 static int
313 equiv_string(char *s1, char *s2)
314 {
315 #define CLS_STR 0
316 #define CLS_INT 1
317 #define CLS_FLT 2
318 /* skip whitespace at beginning */
319 while (isspace(*s1)) s1++;
320 while (isspace(*s2)) s2++;
321 while (*s1) { /* check each word */
322 int inquote;
323 if (!*s2) /* unexpected EOL in s2? */
324 return(0);
325 inquote = *s1;
326 if ((inquote != '\'') & (inquote != '"'))
327 inquote = 0;
328 if (inquote) { /* quoted text must match exactly */
329 if (*s1++ != *s2++)
330 return(0);
331 while (*s1 != inquote) {
332 if (!*s1)
333 return(0);
334 if (*s1++ != *s2++)
335 return(0);
336 }
337 s1++;
338 if (*s2++ != inquote)
339 return(0);
340 } else { /* else classify word type */
341 char *s1s = s1;
342 char *s2s = s2;
343 int cls = CLS_STR;
344 s1 = sskip(s1);
345 s2 = sskip(s2);
346 if (iskip(s1s) == s1) {
347 if (iskip(s2s) == s2)
348 cls = CLS_INT;
349 else if (fskip(s2s) == s2)
350 cls = CLS_FLT;
351 } else if (fskip(s1s) == s1) {
352 if (fskip(s2s) != s2)
353 return(0);
354 cls = CLS_FLT;
355 }
356 switch (cls) {
357 case CLS_INT: /* strncmp() faster */
358 case CLS_STR:
359 if (s1 - s1s != s2 - s2s)
360 return(0);
361 if (strncmp(s1s, s2s, s1 - s1s))
362 return(0);
363 break;
364 case CLS_FLT:
365 if (!real_check(atof(s1s), atof(s2s)))
366 return(0);
367 break;
368 }
369 }
370 while (isspace(*s1)) s1++;
371 while (isspace(*s2)) s2++;
372 }
373 return(!*s2); /* match if we reached the end of s2, too */
374 #undef CLS_STR
375 #undef CLS_INT
376 #undef CLS_FLT
377 }
378
379 /* Check if string is var=value pair and set if not in ignore list */
380 static int
381 setheadvar(char *val, void *p)
382 {
383 char newval[128];
384 LUTAB *htp = (LUTAB *)p;
385 LUENT *tep;
386 char *key;
387 int kln, vln;
388 int n;
389
390 adv_linecnt(htp); /* side-effect is to count lines */
391 if (!isalpha(*val)) /* key must start line */
392 return(0);
393 /* check if we need to swap binary data */
394 if ((n = isbigendian(val)) >= 0) {
395 if (nativebigendian() == n)
396 return(0);
397 f1swap += (htp == &hdr1);
398 f2swap += (htp == &hdr2);
399 return(0);
400 }
401 key = val++;
402 while (*val && !isspace(*val) & (*val != '='))
403 val++;
404 kln = val - key;
405 while (isspace(*val)) /* check for value */
406 *val++ = '\0';
407 if (*val != '=')
408 return(0);
409 *val++ = '\0';
410 while (isspace(*val))
411 val++;
412 if (!*val) /* nothing set? */
413 return(0);
414 /* check if key to ignore */
415 for (n = 0; hdr_ignkey[n]; n++)
416 if (!strcmp(key, hdr_ignkey[n]))
417 return(0);
418 vln = strlen(val); /* eliminate space and newline at end */
419 while (isspace(val[--vln]))
420 ;
421 val[++vln] = '\0';
422 if (!(tep = lu_find(htp, key)))
423 return(-1); /* memory allocation error */
424 if (!tep->key)
425 tep->key = strcpy(malloc(kln+1), key);
426 if (tep->data) { /* check for special cases */
427 if (!strcmp(key, "EXPOSURE")) {
428 sprintf(newval, "%.6e", atof(tep->data)*atof(val));
429 vln = strlen(val = newval);
430 }
431 free(tep->data);
432 }
433 tep->data = strcpy(malloc(vln+1), val);
434 return(1);
435 }
436
437 /* Lookup correspondent in other header */
438 static int
439 match_val(const LUENT *ep1, void *p2)
440 {
441 const LUENT *ep2 = lu_find((LUTAB *)p2, ep1->key);
442 if (!ep2 || !ep2->data) {
443 if (report != REP_QUIET)
444 printf("%s: variable '%s' missing in '%s'\n",
445 progname, ep1->key, f2name);
446 return(-1);
447 }
448 if (!equiv_string((char *)ep1->data, (char *)ep2->data)) {
449 if (report != REP_QUIET) {
450 printf("%s: header variable '%s' has different values\n",
451 progname, ep1->key);
452 if (report >= REP_VERBOSE) {
453 printf("%s: %s=%s\n", f1name,
454 ep1->key, (char *)ep1->data);
455 printf("%s: %s=%s\n", f2name,
456 ep2->key, (char *)ep2->data);
457 }
458 }
459 return(-1);
460 }
461 return(1); /* good match */
462 }
463
464 /* Compare two sets of header variables */
465 static int
466 headers_match()
467 {
468 int ne = lu_doall(&hdr1, match_val, &hdr2);
469 if (ne < 0)
470 return(0); /* something didn't match! */
471 /* non-fatal if second header has extra */
472 if (report >= REP_WARN && (ne = lu_doall(&hdr2, NULL, NULL) - ne))
473 printf("%s: warning - '%s' has %d extra header setting(s)\n",
474 progname, f2name, ne);
475 return(1); /* good match */
476 }
477
478 /* Check generic input to determine if it is binary, -1 on error */
479 static int
480 input_is_binary(FILE *fin)
481 {
482 int n = 0;
483 int c = 0;
484
485 while ((c = getc(fin)) != EOF) {
486 ++n;
487 if (!c | (c > 127))
488 break; /* non-ascii character */
489 if (n >= 10240)
490 break; /* enough to be confident */
491 }
492 if (!n)
493 return(-1); /* first read failed */
494 if (fseek(fin, 0L, 0) < 0)
495 return(-1); /* rewind failed */
496 return(!c | (c > 127));
497 }
498
499 /* Identify and return data type from header (if one) */
500 static int
501 identify_type(const char *name, FILE *fin, LUTAB *htp)
502 {
503 extern const char HDRSTR[];
504 int c;
505 /* check magic header start */
506 if ((c = getc(fin)) != HDRSTR[0]) {
507 if (c == EOF) goto badeof;
508 ungetc(c, fin);
509 c = 0;
510 } else if ((c = getc(fin)) != HDRSTR[1]) {
511 if (c == EOF) goto badeof;
512 ungetc(c, fin); ungetc(HDRSTR[0], fin);
513 c = 0;
514 }
515 if (c) { /* appears to have a header */
516 char sbuf[32];
517 if (!fgets(sbuf, sizeof(sbuf), fin))
518 goto badeof;
519 adv_linecnt(htp); /* for #?ID string */
520 if (report >= REP_WARN && strncmp(sbuf, "RADIANCE", 8)) {
521 fputs(name, stdout);
522 fputs(": warning - unexpected header ID: ", stdout);
523 fputs(sbuf, stdout);
524 }
525 if (getheader(fin, setheadvar, htp) < 0) {
526 fputs(name, stderr);
527 fputs(": unknown error reading header\n", stderr);
528 return(-1);
529 }
530 adv_linecnt(htp); /* for trailing emtpy line */
531 return(xlate_type((const char *)lu_find(htp,"FORMAT")->data));
532 }
533 c = input_is_binary(fin); /* else peek to see if binary */
534 if (c < 0) {
535 fputs(name, stderr);
536 fputs(": read/seek error\n", stderr);
537 return(-1);
538 }
539 if (c)
540 return(TYP_BINARY);
541 return(TYP_TEXT);
542 badeof:
543 if (report != REP_QUIET) {
544 fputs(name, stdout);
545 fputs(": unexpected end-of-file\n", stdout);
546 }
547 return(-1);
548 }
549
550 /* Check that overall RMS error is below threshold */
551 static int
552 good_RMS()
553 {
554 if (!nsum)
555 return(1);
556 if (diff2sum/(double)nsum > rms_lim*rms_lim) {
557 if (report != REP_QUIET)
558 printf(
559 "%s: %sRMS difference between '%s' and '%s' of %.5g exceeds limit of %.5g\n",
560 progname,
561 (rel_min > 0) ? "relative " : "",
562 f1name, f2name,
563 sqrt(diff2sum/(double)nsum), rms_lim);
564 return(0);
565 }
566 if (report >= REP_VERBOSE)
567 printf("%s: %sRMS difference of reals in '%s' and '%s' is %.5g\n",
568 progname, (rel_min > 0) ? "relative " : "",
569 f1name, f2name, sqrt(diff2sum/(double)nsum));
570 return(1);
571 }
572
573 /* Compare two inputs as generic binary files */
574 static int
575 compare_binary()
576 {
577 int c1=0, c2=0;
578
579 if (report >= REP_VERBOSE) {
580 fputs(progname, stdout);
581 fputs(": comparing inputs as binary\n", stdout);
582 }
583 for ( ; ; ) { /* exact byte matching */
584 c1 = getc(f1in);
585 c2 = getc(f2in);
586 if (c1 == EOF) {
587 if (c2 == EOF)
588 return(1); /* success! */
589 if (report != REP_QUIET) {
590 fputs(f1name, stdout);
591 fputs(": unexpected end-of-file\n", stdout);
592 }
593 return(0);
594 }
595 if (c2 == EOF) {
596 if (report != REP_QUIET) {
597 fputs(f2name, stdout);
598 fputs(": unexpected end-of-file\n", stdout);
599 }
600 return(0);
601 }
602 if (c1 != c2)
603 break; /* quit and report difference */
604 }
605 if (report == REP_QUIET)
606 return(0);
607 printf("%s: binary files '%s' and '%s' differ at byte offset %ld|%ld\n",
608 progname, f1name, f2name, ftell(f1in), ftell(f2in));
609 if (report >= REP_VERBOSE)
610 printf("%s: byte in '%s' is 0x%X, byte in '%s' is 0x%X\n",
611 progname, f1name, c1, f2name, c2);
612 return(0);
613 }
614
615 /* Compare two inputs as generic text files */
616 static int
617 compare_text()
618 {
619 LINEBUF l1buf, l2buf;
620
621 if (report >= REP_VERBOSE) {
622 fputs(progname, stdout);
623 fputs(": comparing inputs as ASCII text", stdout);
624 if (escape_newlines)
625 fputs(", allowing escaped newlines", stdout);
626 if (comment_c) {
627 fputs(", ignoring comments starting with '", stdout);
628 fputc(comment_c, stdout);
629 fputc('\'', stdout);
630 }
631 fputc('\n', stdout);
632 }
633 SET_FILE_TEXT(f1in); /* originally set to binary */
634 SET_FILE_TEXT(f2in);
635 init_line(&l1buf); init_line(&l2buf); /* compare a line at a time */
636 while (read_line(&l1buf, f1in)) {
637 lin1cnt++;
638 if (!*sskip2(l1buf.str,0))
639 continue; /* ignore empty lines */
640
641 while (read_line(&l2buf, f2in)) {
642 lin2cnt++;
643 if (*sskip2(l2buf.str,0))
644 break; /* found other non-empty line */
645 }
646 if (!l2buf.len) { /* input 2 EOF? */
647 if (report != REP_QUIET) {
648 fputs(f2name, stdout);
649 fputs(": unexpected end-of-file\n", stdout);
650 }
651 free_line(&l1buf); free_line(&l2buf);
652 return(0);
653 }
654 /* compare non-empty lines */
655 if (!equiv_string(l1buf.str, l2buf.str)) {
656 if (report != REP_QUIET) {
657 printf("%s: inputs '%s' and '%s' differ at line %d",
658 progname, f1name, f2name, lin1cnt);
659 if (lin1cnt != lin2cnt)
660 printf("|%d\n", lin2cnt);
661 else
662 putchar('\n');
663 if ( report >= REP_VERBOSE &&
664 (l1buf.len < 256) &
665 (l2buf.len < 256) ) {
666 fputs("------------- Mismatch -------------\n", stdout);
667 printf("%s@%d:\t%s", f1name,
668 lin1cnt, l1buf.str);
669 printf("%s@%d:\t%s", f2name,
670 lin2cnt, l2buf.str);
671 }
672 }
673 free_line(&l1buf); free_line(&l2buf);
674 return(0);
675 }
676 }
677 free_line(&l1buf); /* check for EOF on input 2 */
678 while (read_line(&l2buf, f2in)) {
679 if (!*sskip2(l2buf.str,0))
680 continue;
681 if (report != REP_QUIET) {
682 fputs(f1name, stdout);
683 fputs(": unexpected end-of-file\n", stdout);
684 }
685 free_line(&l2buf);
686 return(0);
687 }
688 free_line(&l2buf);
689 return(good_RMS()); /* final check for reals */
690 }
691
692 /* Set resolution based on NROWS, NCOLS in header */
693 static int
694 set_resolu(RESOLU *rs, LUTAB *htp)
695 {
696 const char *val;
697
698 rs->rt = PIXSTANDARD;
699 val = (const char *)lu_find(htp, "NROWS")->data;
700 if (!val) return(0);
701 rs->yr = atoi(val);
702 if (rs->yr <= 0) return(-1);
703 val = (const char *)lu_find(htp, "NCOLS")->data;
704 if (!val) return(0);
705 rs->xr = atoi(val);
706 if (rs->xr <= 0) return(-1);
707 return(1);
708 }
709
710 /* Check image/map resolutions */
711 static int
712 check_resolu(const char *class, RESOLU *r1p, RESOLU *r2p)
713 {
714 if (r1p->rt != r2p->rt) {
715 if (report != REP_QUIET)
716 printf(
717 "%s: %ss '%s' and '%s' have different pixel ordering\n",
718 progname, class, f1name, f2name);
719 return(0);
720 }
721 if ((r1p->xr != r2p->xr) | (r1p->yr != r2p->yr)) {
722 if (report != REP_QUIET)
723 printf(
724 "%s: %ss '%s' and '%s' are different sizes\n",
725 progname, class, f1name, f2name);
726 return(0);
727 }
728 return(1);
729 }
730
731 /* Compare two inputs that are known to be RGBE or XYZE images */
732 static int
733 compare_hdr()
734 {
735 RESOLU rs1, rs2;
736 COLOR *scan1, *scan2;
737 int x, y;
738
739 if (report >= REP_VERBOSE) {
740 fputs(progname, stdout);
741 fputs(": comparing inputs as HDR images\n", stdout);
742 }
743 fgetsresolu(&rs1, f1in);
744 fgetsresolu(&rs2, f2in);
745 if (!check_resolu("HDR image", &rs1, &rs2))
746 return(0);
747 scan1 = (COLOR *)malloc(scanlen(&rs1)*sizeof(COLOR));
748 scan2 = (COLOR *)malloc(scanlen(&rs2)*sizeof(COLOR));
749 if (!scan1 | !scan2) {
750 fprintf(stderr, "%s: out of memory in compare_hdr()\n", progname);
751 exit(2);
752 }
753 for (y = 0; y < numscans(&rs1); y++) {
754 if ((freadscan(scan1, scanlen(&rs1), f1in) < 0) |
755 (freadscan(scan2, scanlen(&rs2), f2in) < 0)) {
756 if (report != REP_QUIET)
757 printf("%s: unexpected end-of-file\n",
758 progname);
759 free(scan1);
760 free(scan2);
761 return(0);
762 }
763 for (x = 0; x < scanlen(&rs1); x++) {
764 if (color_check(scan1[x], scan2[x]))
765 continue;
766 if (report != REP_QUIET) {
767 printf("%s: pixels at scanline %d offset %d differ\n",
768 progname, y, x);
769 if (report >= REP_VERBOSE) {
770 printf("%s: (R,G,B)=(%g,%g,%g)\n",
771 f1name, colval(scan1[x],RED),
772 colval(scan1[x],GRN),
773 colval(scan1[x],BLU));
774 printf("%s: (R,G,B)=(%g,%g,%g)\n",
775 f2name, colval(scan2[x],RED),
776 colval(scan2[x],GRN),
777 colval(scan2[x],BLU));
778 }
779 }
780 free(scan1);
781 free(scan2);
782 return(0);
783 }
784 }
785 free(scan1);
786 free(scan2);
787 return(good_RMS()); /* final check of RMS */
788 }
789
790 /* Compare two inputs that are known to be spectral images */
791 static int
792 compare_spec()
793 {
794 static char NCstr[] = NCOMPSTR;
795 RESOLU rs1, rs2;
796 COLORV *scan1, *scan2;
797 const char *val;
798 int x, y;
799
800 if (report >= REP_VERBOSE) {
801 fputs(progname, stdout);
802 fputs(": comparing inputs as spectral images\n", stdout);
803 }
804 if (!(set_resolu(&rs1, &hdr1) || fgetsresolu(&rs1, f1in)))
805 return(0);
806 if (!(set_resolu(&rs2, &hdr2) || fgetsresolu(&rs2, f2in)))
807 return(0);
808 if (!check_resolu("Spectral image", &rs1, &rs2))
809 return(0);
810 NCstr[LNCOMPSTR-1] = '\0';
811 val = (const char *)lu_find(&hdr1, NCstr)->data;
812 if (!val || (NCSAMP = atoi(val)) < 3) {
813 if (report != REP_QUIET) {
814 if (val)
815 printf("%s: illegal # components (%d) for spectral image\n",
816 progname, NCSAMP);
817 else
818 printf("%s: missing %s in header for spectral image\n",
819 progname, NCstr);
820 }
821 return(0);
822 }
823 scan1 = (COLORV *)malloc(sizeof(COLORV)*NCSAMP*scanlen(&rs1));
824 scan2 = (COLORV *)malloc(sizeof(COLORV)*NCSAMP*scanlen(&rs2));
825 if (!scan1 | !scan2) {
826 fprintf(stderr, "%s: out of memory in compare_hdr()\n", progname);
827 exit(2);
828 }
829 for (y = 0; y < numscans(&rs1); y++) {
830 if ((freadsscan(scan1, NCSAMP, scanlen(&rs1), f1in) < 0) |
831 (freadsscan(scan2, NCSAMP, scanlen(&rs2), f2in) < 0)) {
832 if (report != REP_QUIET)
833 printf("%s: unexpected end-of-file\n", progname);
834 free(scan1);
835 free(scan2);
836 return(0);
837 }
838 for (x = 0; x < scanlen(&rs1); x++) {
839 if (spec_check(scan1+x*NCSAMP, scan2+x*NCSAMP))
840 continue;
841 if (report != REP_QUIET) {
842 int k;
843 printf("%s: spectra at scanline %d offset %d differ\n",
844 progname, y, x);
845 if (report >= REP_VERBOSE) {
846 printf("%s: spectrum =", f1name);
847 for (k = 0; k < NCSAMP; k++)
848 printf(" %g", scan1[x*NCSAMP+k]);
849 fputc('\n', stdout);
850 printf("%s: spectrum =", f2name);
851 for (k = 0; k < NCSAMP; k++)
852 printf(" %g", scan2[x*NCSAMP+k]);
853 fputc('\n', stdout);
854 }
855 }
856 free(scan1);
857 free(scan2);
858 return(0);
859 }
860 }
861 free(scan1);
862 free(scan2);
863 return(good_RMS()); /* final check of RMS */
864 }
865
866 /* Set reference depth based on header variable */
867 static int
868 set_refdepth(DEPTHCODEC *dcp, LUTAB *htp)
869 {
870 static char depthvar[] = DEPTHSTR;
871 const char *drval;
872
873 depthvar[LDEPTHSTR-1] = '\0';
874 drval = (const char *)lu_find(htp, depthvar)->data;
875 if (!drval)
876 return(0);
877 dcp->refdepth = atof(drval);
878 if (dcp->refdepth <= 0) {
879 if (report != REP_QUIET) {
880 fputs(dcp->inpname, stderr);
881 fputs(": bad reference depth '", stderr);
882 fputs(drval, stderr);
883 fputs("'\n", stderr);
884 }
885 return(-1);
886 }
887 return(1);
888 }
889
890 /* Compare two encoded depth maps */
891 static int
892 compare_depth()
893 {
894 long nread = 0;
895 DEPTHCODEC dc1, dc2;
896
897 if (report >= REP_VERBOSE) {
898 fputs(progname, stdout);
899 fputs(": comparing inputs as depth maps\n", stdout);
900 }
901 set_dc_defaults(&dc1);
902 dc1.hdrflags = HF_RESIN;
903 dc1.finp = f1in;
904 dc1.inpname = f1name;
905 set_dc_defaults(&dc2);
906 dc2.hdrflags = HF_RESIN;
907 dc2.finp = f2in;
908 dc2.inpname = f2name;
909 if (report != REP_QUIET) {
910 dc1.hdrflags |= HF_STDERR;
911 dc2.hdrflags |= HF_STDERR;
912 }
913 if (!process_dc_header(&dc1, 0, NULL))
914 return(0);
915 if (!process_dc_header(&dc2, 0, NULL))
916 return(0);
917 if (!check_resolu("Depth map", &dc1.res, &dc2.res))
918 return(0);
919 if (set_refdepth(&dc1, &hdr1) < 0)
920 return(0);
921 if (set_refdepth(&dc2, &hdr2) < 0)
922 return(0);
923 while (nread < dc1.res.xr*dc1.res.yr) {
924 double d1 = decode_depth_next(&dc1);
925 double d2 = decode_depth_next(&dc2);
926 if ((d1 < 0) | (d2 < 0)) {
927 if (report != REP_QUIET)
928 printf("%s: unexpected end-of-file\n",
929 progname);
930 return(0);
931 }
932 ++nread;
933 if (real_check(d1, d2))
934 continue;
935 if (report != REP_QUIET)
936 printf("%s: %ld%s depth values differ\n",
937 progname, nread, num_sfx(nread));
938 return(0);
939 }
940 return(good_RMS()); /* final check of RMS */
941 }
942
943 /* Compare two encoded normal maps */
944 static int
945 compare_norm()
946 {
947 long nread = 0;
948 NORMCODEC nc1, nc2;
949
950 if (report >= REP_VERBOSE) {
951 fputs(progname, stdout);
952 fputs(": comparing inputs as normal maps\n", stdout);
953 }
954 set_nc_defaults(&nc1);
955 nc1.hdrflags = HF_RESIN;
956 nc1.finp = f1in;
957 nc1.inpname = f1name;
958 set_nc_defaults(&nc2);
959 nc2.hdrflags = HF_RESIN;
960 nc2.finp = f2in;
961 nc2.inpname = f2name;
962 if (report != REP_QUIET) {
963 nc1.hdrflags |= HF_STDERR;
964 nc2.hdrflags |= HF_STDERR;
965 }
966 if (!process_nc_header(&nc1, 0, NULL))
967 return(0);
968 if (!process_nc_header(&nc2, 0, NULL))
969 return(0);
970 if (!check_resolu("Normal map", &nc1.res, &nc2.res))
971 return(0);
972 while (nread < nc1.res.xr*nc1.res.yr) {
973 FVECT nv1, nv2;
974 int rv1 = decode_normal_next(nv1, &nc1);
975 int rv2 = decode_normal_next(nv2, &nc2);
976 if ((rv1 < 0) | (rv2 < 0)) {
977 if (report != REP_QUIET)
978 printf("%s: unexpected end-of-file\n",
979 progname);
980 return(0);
981 }
982 ++nread;
983 if (rv1 == rv2 && (!rv1 || norm_check(nv1, nv2)))
984 continue;
985 if (report != REP_QUIET)
986 printf("%s: %ld%s normal vectors differ\n",
987 progname, nread, num_sfx(nread));
988 return(0);
989 }
990 return(good_RMS()); /* final check of RMS */
991 }
992
993 /* Compare two inputs that are known to be 32-bit floating-point data */
994 static int
995 compare_float()
996 {
997 long nread = 0;
998 float f1, f2;
999
1000 if (report >= REP_VERBOSE) {
1001 fputs(progname, stdout);
1002 fputs(": comparing inputs as 32-bit IEEE floats\n", stdout);
1003 }
1004 while (getbinary(&f1, sizeof(f1), 1, f1in)) {
1005 if (!getbinary(&f2, sizeof(f2), 1, f2in))
1006 goto badeof;
1007 ++nread;
1008 if (f1swap) swap32((char *)&f1, 1);
1009 if (f2swap) swap32((char *)&f2, 1);
1010 if (real_check(f1, f2))
1011 continue;
1012 if (report != REP_QUIET)
1013 printf("%s: %ld%s float values differ\n",
1014 progname, nread, num_sfx(nread));
1015 return(0);
1016 }
1017 if (!getbinary(&f2, sizeof(f2), 1, f2in))
1018 return(good_RMS()); /* final check of RMS */
1019 badeof:
1020 if (report != REP_QUIET)
1021 printf("%s: unexpected end-of-file\n", progname);
1022 return(0);
1023 }
1024
1025 /* Compare two inputs that are known to be 64-bit floating-point data */
1026 static int
1027 compare_double()
1028 {
1029 long nread = 0;
1030 double f1, f2;
1031
1032 if (report >= REP_VERBOSE) {
1033 fputs(progname, stdout);
1034 fputs(": comparing inputs as 64-bit IEEE doubles\n", stdout);
1035 }
1036 while (getbinary(&f1, sizeof(f1), 1, f1in)) {
1037 if (!getbinary(&f2, sizeof(f2), 1, f2in))
1038 goto badeof;
1039 ++nread;
1040 if (f1swap) swap64((char *)&f1, 1);
1041 if (f2swap) swap64((char *)&f2, 1);
1042 if (real_check(f1, f2))
1043 continue;
1044 if (report != REP_QUIET)
1045 printf("%s: %ld%s double values differ\n",
1046 progname, nread, num_sfx(nread));
1047 return(0);
1048 }
1049 if (!getbinary(&f2, sizeof(f2), 1, f2in))
1050 return(good_RMS()); /* final check of RMS */
1051 badeof:
1052 if (report != REP_QUIET)
1053 printf("%s: unexpected end-of-file\n", progname);
1054 return(0);
1055 }
1056
1057 /* Compare two Radiance files for equivalence */
1058 int
1059 main(int argc, char *argv[])
1060 {
1061 int typ1, typ2;
1062 int a;
1063 /* set global progname */
1064 fixargv0(argv[0]);
1065 for (a = 1; a < argc && argv[a][0] == '-'; a++) {
1066 switch (argv[a][1]) {
1067 case 'h': /* ignore header info. */
1068 ign_header = !ign_header;
1069 continue;
1070 case 'n': /* allow newline escapes */
1071 escape_newlines = !escape_newlines;
1072 continue;
1073 case 'c': /* ignore comments */
1074 comment_c = argv[a][2];
1075 continue;
1076 case 's': /* silent operation */
1077 report = REP_QUIET;
1078 continue;
1079 case 'w': /* turn off warnings */
1080 if (report > REP_ERROR)
1081 report = REP_ERROR;
1082 continue;
1083 case 'v': /* turn on verbose mode */
1084 report = REP_VERBOSE;
1085 continue;
1086 case 'm': /* maximum epsilon */
1087 max_lim = atof(argv[++a]);
1088 continue;
1089 case 'r':
1090 if (argv[a][2] == 'e') /* relative difference */
1091 rel_min = atof(argv[++a]);
1092 else if (argv[a][2] == 'm') /* RMS limit */
1093 rms_lim = atof(argv[++a]);
1094 else
1095 usage();
1096 continue;
1097 case '\0': /* first file from stdin */
1098 f1in = stdin;
1099 f1name = stdin_name;
1100 break;
1101 default:
1102 usage();
1103 }
1104 break;
1105 }
1106 if (a != argc-2) /* make sure of two inputs */
1107 usage();
1108 if (!strcmp(argv[a], argv[a+1])) { /* inputs are same? */
1109 if (report >= REP_WARN)
1110 printf("%s: warning - identical inputs given\n",
1111 progname);
1112 return(0);
1113 }
1114 if (!f1name) f1name = argv[a];
1115 if (!f2name) f2name = argv[a+1];
1116 /* open inputs */
1117 SET_FILE_BINARY(stdin); /* in case we're using it */
1118 if (!f1in && !(f1in = fopen(f1name, "rb"))) {
1119 fprintf(stderr, "%s: cannot open for reading\n", f1name);
1120 return(2);
1121 }
1122 if (!strcmp(f2name, "-")) {
1123 f2in = stdin;
1124 f2name = stdin_name;
1125 } else if (!(f2in = fopen(f2name, "rb"))) {
1126 fprintf(stderr, "%s: cannot open for reading\n", f2name);
1127 return(2);
1128 }
1129 /* load headers */
1130 if ((typ1 = identify_type(f1name, f1in, &hdr1)) < 0)
1131 return(2);
1132 if ((typ2 = identify_type(f2name, f2in, &hdr2)) < 0)
1133 return(2);
1134 if (typ1 != typ2) {
1135 if (report != REP_QUIET)
1136 printf("%s: '%s' format is %s and '%s' is %s\n",
1137 progname, f1name, file_type[typ1],
1138 f2name, file_type[typ2]);
1139 return(1);
1140 }
1141 ign_header |= !has_header(typ1); /* check headers if indicated */
1142 if (!ign_header && !headers_match())
1143 return(1);
1144 if (!ign_header & (report >= REP_WARN)) {
1145 if (lin1cnt != lin2cnt)
1146 printf("%s: warning - headers are different lengths\n",
1147 progname);
1148 if (typ1 == TYP_UNKNOWN)
1149 printf("%s: warning - unrecognized format\n",
1150 progname);
1151 }
1152 if (report >= REP_VERBOSE) {
1153 printf("%s: data format is %s\n", progname, file_type[typ1]);
1154 if ((typ1 == TYP_FLOAT) | (typ1 == TYP_DOUBLE)) {
1155 if (f1swap)
1156 printf("%s: input '%s' is byte-swapped\n",
1157 progname, f1name);
1158 if (f2swap)
1159 printf("%s: input '%s' is byte-swapped\n",
1160 progname, f2name);
1161 }
1162 }
1163 switch (typ1) { /* compare based on type */
1164 case TYP_BINARY:
1165 case TYP_TMESH:
1166 case TYP_OCTREE:
1167 case TYP_RBFMESH:
1168 case TYP_ID8:
1169 case TYP_ID16:
1170 case TYP_ID24:
1171 case TYP_UNKNOWN:
1172 return( !compare_binary() );
1173 case TYP_TEXT:
1174 case TYP_ASCII:
1175 return( !compare_text() );
1176 case TYP_RGBE:
1177 case TYP_XYZE:
1178 return( !compare_hdr() );
1179 case TYP_SPEC:
1180 return( !compare_spec() );
1181 case TYP_DEPTH:
1182 return( !compare_depth() );
1183 case TYP_NORM:
1184 return( !compare_norm() );
1185 case TYP_FLOAT:
1186 return( !compare_float() );
1187 case TYP_DOUBLE:
1188 return( !compare_double() );
1189 }
1190 return(1);
1191 }
