| 1 |
#ifndef lint |
| 2 |
static const char RCSid[] = "$Id: radcompare.c,v 2.35 2024/12/09 00:29:30 greg Exp $"; |
| 3 |
#endif |
| 4 |
| 5 |
* Compare Radiance files for significant differences |
| 6 |
| 7 |
* G. Ward |
| 8 |
| 9 |
| 10 |
#include <stdlib.h> |
| 11 |
#include <ctype.h> |
| 12 |
#include "rtmath.h" |
| 13 |
#include "platform.h" |
| 14 |
#include "rtio.h" |
| 15 |
#include "resolu.h" |
| 16 |
#include "color.h" |
| 17 |
#include "depthcodec.h" |
| 18 |
#include "normcodec.h" |
| 19 |
#include "lookup.h" |
| 20 |
/* Reporting levels */ |
| 21 |
#define REP_QUIET 0 /* no reporting */ |
| 22 |
#define REP_ERROR 1 /* report errors only */ |
| 23 |
#define REP_WARN 2 /* report warnings as well */ |
| 24 |
#define REP_VERBOSE 3 /* verbose reporting */ |
| 25 |
| 26 |
int report = REP_WARN; /* reporting level */ |
| 27 |
| 28 |
int ign_header = 0; /* ignore header differences? */ |
| 29 |
| 30 |
int escape_newlines = 0; /* allow backslash to skip newlines */ |
| 31 |
| 32 |
double rel_min = 1e-5; /* positive for relative comparisons */ |
| 33 |
| 34 |
double rms_lim = 0.01; /* RMS difference limit */ |
| 35 |
| 36 |
double max_lim = 0.25; /* difference limit if non-negative */ |
| 37 |
| 38 |
int lin1cnt=0, lin2cnt=0; /* file line position */ |
| 39 |
| 40 |
int comment_c = '\0'; /* comment delimiter for text files */ |
| 41 |
| 42 |
const char nsuffix[10][3] = { /* 1st, 2nd, 3rd, etc. */ |
| 43 |
"th","st","nd","rd","th","th","th","th","th","th" |
| 44 |
| 45 |
#define num_sfx(n) nsuffix[(n)%10] |
| 46 |
| 47 |
/* file types */ |
| 48 |
const char *file_type[] = { |
| 49 |
"Unrecognized", |
| 50 |
"TEXT_generic", |
| 51 |
"ascii", |
| 52 |
COLRFMT, |
| 53 |
CIEFMT, |
| 54 |
SPECFMT, |
| 55 |
DEPTH16FMT, |
| 56 |
NORMAL32FMT, |
| 57 |
"float", |
| 58 |
"double", |
| 59 |
"BSDF_RBFmesh", |
| 60 |
"Radiance_octree", |
| 61 |
"Radiance_tmesh", |
| 62 |
"8-bit_indexed_name", |
| 63 |
"16-bit_indexed_name", |
| 64 |
"24-bit_indexed_name", |
| 65 |
"BINARY_unknown", |
| 66 |
NULL /* terminator */ |
| 67 |
| 68 |
/* keep consistent with above */ |
| 69 |
enum {TYP_UNKNOWN, TYP_TEXT, TYP_ASCII, TYP_RGBE, TYP_XYZE, TYP_SPEC, |
| 70 |
TYP_DEPTH, TYP_NORM, TYP_FLOAT, TYP_DOUBLE, |
| 71 |
TYP_RBFMESH, TYP_OCTREE, TYP_TMESH, |
| 72 |
TYP_ID8, TYP_ID16, TYP_ID24, TYP_BINARY}; |
| 73 |
| 74 |
#define has_header(t) (!( 1L<<(t) & (1L<<TYP_TEXT | 1L<<TYP_BINARY) )) |
| 75 |
| 76 |
/* header variables to always ignore */ |
| 77 |
const char *hdr_ignkey[] = { |
| 78 |
"SOFTWARE", |
| 79 |
"CAPDATE", |
| 80 |
"GMT", |
| 81 |
"FRAME", |
| 82 |
"TILED", |
| 83 |
| 84 |
| 85 |
/* header variable settings */ |
| 86 |
LUTAB hdr1 = LU_SINIT(free,free); |
| 87 |
LUTAB hdr2 = LU_SINIT(free,free); |
| 88 |
| 89 |
/* advance appropriate file line count */ |
| 90 |
#define adv_linecnt(htp) (lin1cnt += (htp == &hdr1), \ |
| 91 |
lin2cnt += (htp == &hdr2)) |
| 92 |
| 93 |
typedef struct { /* dynamic line buffer */ |
| 94 |
char *str; |
| 95 |
int len; |
| 96 |
int siz; |
| 97 |
} LINEBUF; |
| 98 |
| 99 |
#define init_line(bp) ((bp)->str = NULL, (bp)->siz = 0) |
| 100 |
/* 100 MByte limit on line buffer */ |
| 101 |
#define MAXBUF (100L<<20) |
| 102 |
| 103 |
/* input files */ |
| 104 |
const char stdin_name[] = "<stdin>"; |
| 105 |
const char *f1name=NULL, *f2name=NULL; |
| 106 |
FILE *f1in=NULL, *f2in=NULL; |
| 107 |
int f1swap=0, f2swap=0; |
| 108 |
| 109 |
/* running real differences */ |
| 110 |
double diff2sum = 0; |
| 111 |
long nsum = 0; |
| 112 |
| 113 |
/* Report usage and exit */ |
| 114 |
static void |
| 115 |
usage() |
| 116 |
| 117 |
fputs("Usage: ", stderr); |
| 118 |
fputs(progname, stderr); |
| 119 |
fputs(" [-h][-c#][-s|-w|-v][-rel min_test][-rms epsilon][-max epsilon] reference test\n", |
| 120 |
stderr); |
| 121 |
exit(2); |
| 122 |
| 123 |
| 124 |
/* Read a text line, increasing buffer size as necessary */ |
| 125 |
static int |
| 126 |
read_line(LINEBUF *bp, FILE *fp) |
| 127 |
| 128 |
static int doneWarn = 0; |
| 129 |
| 130 |
bp->len = 0; |
| 131 |
if (!bp->str) { |
| 132 |
bp->str = (char *)malloc(bp->siz = 512); |
| 133 |
if (!bp->str) |
| 134 |
goto memerr; |
| 135 |
| 136 |
while (fgets(bp->str + bp->len, bp->siz - bp->len, fp)) { |
| 137 |
bp->len += strlen(bp->str + bp->len); |
| 138 |
if (bp->str[bp->len-1] == '\n') { |
| 139 |
if (bp->len > 1 && bp->str[bp->len-2] == '\r') { |
| 140 |
bp->str[--bp->len] = '\0'; |
| 141 |
bp->str[bp->len-1] = '\n'; |
| 142 |
| 143 |
if (escape_newlines && bp->len > 1 && |
| 144 |
bp->str[bp->len-2] == '\\') { |
| 145 |
| 146 |
bp->str[bp->len-1] = ' '; |
| 147 |
continue; |
| 148 |
| 149 |
break; /* found EOL */ |
| 150 |
| 151 |
if (bp->len < bp->siz - 4) |
| 152 |
continue; /* at EOF? */ |
| 153 |
if (bp->siz >= MAXBUF) { |
| 154 |
if ((report >= REP_WARN) & !doneWarn) { |
| 155 |
fprintf(stderr, |
| 156 |
"%s: warning - input line(s) past %ld MByte limit\n", |
| 157 |
progname, MAXBUF>>20); |
| 158 |
doneWarn++; |
| 159 |
| 160 |
break; /* return MAXBUF partial line */ |
| 161 |
| 162 |
if ((bp->siz += bp->siz/2) > MAXBUF) |
| 163 |
bp->siz = MAXBUF; |
| 164 |
bp->str = (char *)realloc(bp->str, bp->siz); |
| 165 |
if (!bp->str) |
| 166 |
goto memerr; |
| 167 |
| 168 |
if (comment_c) { /* elide comment? */ |
| 169 |
char *cp = sskip2(bp->str,0); |
| 170 |
if (*cp == comment_c) { |
| 171 |
*cp++ = '\n'; |
| 172 |
*cp = '\0'; |
| 173 |
bp->len = cp - bp->str; |
| 174 |
| 175 |
| 176 |
return(bp->len); |
| 177 |
memerr: |
| 178 |
fprintf(stderr, |
| 179 |
"%s: out of memory in read_line() allocating %d byte buffer\n", |
| 180 |
progname, bp->siz); |
| 181 |
exit(2); |
| 182 |
| 183 |
| 184 |
/* Free line buffer */ |
| 185 |
static void |
| 186 |
free_line(LINEBUF *bp) |
| 187 |
| 188 |
if (bp->str) free(bp->str); |
| 189 |
init_line(bp); |
| 190 |
| 191 |
| 192 |
/* Get type ID from name (or 0 if not found) */ |
| 193 |
static int |
| 194 |
xlate_type(const char *nm) |
| 195 |
| 196 |
int i; |
| 197 |
| 198 |
if (!nm || !*nm) |
| 199 |
return(TYP_UNKNOWN); |
| 200 |
for (i = 1; file_type[i]; i++) |
| 201 |
if (!strcmp(nm, file_type[i])) |
| 202 |
return(i); |
| 203 |
| 204 |
| 205 |
| 206 |
/* Compare real values and keep track of differences */ |
| 207 |
static int |
| 208 |
real_check(double r1, double r2) |
| 209 |
| 210 |
double diff2 = (r1 - r2)*(r1 - r2); |
| 211 |
| 212 |
if (rel_min > 0) { /* doing relative differences? */ |
| 213 |
double av2 = .25*(r1*r1 + 2.*fabs(r1*r2) + r2*r2); |
| 214 |
if (av2 < rel_min*rel_min) |
| 215 |
av2 = rel_min*rel_min; |
| 216 |
diff2 /= av2; |
| 217 |
| 218 |
if (max_lim >= 0 && diff2 > max_lim*max_lim) { |
| 219 |
if (report != REP_QUIET) |
| 220 |
printf( |
| 221 |
"%s: %sdifference between %.8g and %.8g exceeds epsilon of %.8g\n", |
| 222 |
progname, |
| 223 |
(rel_min > 0) ? "relative " : "", |
| 224 |
r1, r2, max_lim); |
| 225 |
return(0); |
| 226 |
| 227 |
diff2sum += diff2; |
| 228 |
nsum++; |
| 229 |
return(1); |
| 230 |
| 231 |
| 232 |
/* Compare two color values for equivalence */ |
| 233 |
static int |
| 234 |
color_check(COLOR c1, COLOR c2) |
| 235 |
| 236 |
int p; |
| 237 |
| 238 |
if (!real_check((colval(c1,RED)+colval(c1,GRN)+colval(c1,BLU))*(1./3.), |
| 239 |
(colval(c2,RED)+colval(c2,GRN)+colval(c2,BLU))*(1./3.))) |
| 240 |
return(0); |
| 241 |
| 242 |
p = (colval(c1,GRN) > colval(c1,RED)) ? GRN : RED; |
| 243 |
if (colval(c1,BLU) > colval(c1,p)) p = BLU; |
| 244 |
| 245 |
return(real_check(colval(c1,p), colval(c2,p))); |
| 246 |
| 247 |
| 248 |
#if 1 |
| 249 |
/* Compare two color spectra for equivalence */ |
| 250 |
static int |
| 251 |
spec_check(COLORV *sc1, COLORV *sc2) |
| 252 |
| 253 |
int p, k; |
| 254 |
| 255 |
if (!real_check(scolor_mean(sc1), scolor_mean(sc2))) |
| 256 |
return(0); |
| 257 |
| 258 |
p = 0; /* find max. component */ |
| 259 |
for (k = NCSAMP; --k; ) |
| 260 |
if (sc1[k] > sc1[p]) |
| 261 |
p = k; |
| 262 |
| 263 |
return(real_check(sc1[p], sc2[p])); |
| 264 |
| 265 |
#else |
| 266 |
| 267 |
static int |
| 268 |
| 269 |
| 270 |
COLOR c1, c2; |
| 271 |
int p; |
| 272 |
| 273 |
| 274 |
return(0); |
| 275 |
/* do comparisons in RGB space */ |
| 276 |
scolor_rgb(c1, sc1); |
| 277 |
scolor_rgb(c2, sc2); |
| 278 |
| 279 |
| 280 |
| 281 |
| 282 |
| 283 |
| 284 |
#endif |
| 285 |
| 286 |
/* Compare two normal directions for equivalence */ |
| 287 |
static int |
| 288 |
norm_check(FVECT nv1, FVECT nv2) |
| 289 |
| 290 |
double max2 = nv1[2]*nv2[2]; |
| 291 |
int imax = 2; |
| 292 |
int i = 2; |
| 293 |
/* identify largest component */ |
| 294 |
while (i--) { |
| 295 |
double tm2 = nv1[i]*nv2[i]; |
| 296 |
if (tm2 > max2) { |
| 297 |
imax = i; |
| 298 |
max2 = tm2; |
| 299 |
| 300 |
| 301 |
i = 3; /* compare smaller components */ |
| 302 |
while (i--) { |
| 303 |
if (i == imax) |
| 304 |
continue; |
| 305 |
if (!real_check(nv1[i], nv2[i])) |
| 306 |
return(0); |
| 307 |
| 308 |
return(1); |
| 309 |
| 310 |
| 311 |
/* Compare two strings for equivalence */ |
| 312 |
static int |
| 313 |
equiv_string(char *s1, char *s2) |
| 314 |
| 315 |
#define CLS_STR 0 |
| 316 |
#define CLS_INT 1 |
| 317 |
#define CLS_FLT 2 |
| 318 |
/* skip whitespace at beginning */ |
| 319 |
while (isspace(*s1)) s1++; |
| 320 |
while (isspace(*s2)) s2++; |
| 321 |
while (*s1) { /* check each word */ |
| 322 |
int inquote; |
| 323 |
if (!*s2) /* unexpected EOL in s2? */ |
| 324 |
return(0); |
| 325 |
inquote = *s1; |
| 326 |
if ((inquote != '\'') & (inquote != '"')) |
| 327 |
inquote = 0; |
| 328 |
if (inquote) { /* quoted text must match exactly */ |
| 329 |
if (*s1++ != *s2++) |
| 330 |
return(0); |
| 331 |
while (*s1 != inquote) { |
| 332 |
if (!*s1) |
| 333 |
return(0); |
| 334 |
| 335 |
return(0); |
| 336 |
| 337 |
s1++; |
| 338 |
if (*s2++ != inquote) |
| 339 |
return(0); |
| 340 |
} else { /* else classify word type */ |
| 341 |
char *s1s = s1; |
| 342 |
char *s2s = s2; |
| 343 |
int cls = CLS_STR; |
| 344 |
s1 = sskip(s1); |
| 345 |
s2 = sskip(s2); |
| 346 |
if (iskip(s1s) == s1) { |
| 347 |
if (iskip(s2s) == s2) |
| 348 |
cls = CLS_INT; |
| 349 |
else if (fskip(s2s) == s2) |
| 350 |
cls = CLS_FLT; |
| 351 |
} else if (fskip(s1s) == s1) { |
| 352 |
if (fskip(s2s) != s2) |
| 353 |
return(0); |
| 354 |
cls = CLS_FLT; |
| 355 |
| 356 |
switch (cls) { |
| 357 |
case CLS_INT: /* strncmp() faster */ |
| 358 |
case CLS_STR: |
| 359 |
if (s1 - s1s != s2 - s2s) |
| 360 |
return(0); |
| 361 |
if (strncmp(s1s, s2s, s1 - s1s)) |
| 362 |
return(0); |
| 363 |
break; |
| 364 |
case CLS_FLT: |
| 365 |
if (!real_check(atof(s1s), atof(s2s))) |
| 366 |
return(0); |
| 367 |
break; |
| 368 |
| 369 |
| 370 |
| 371 |
| 372 |
| 373 |
return(!*s2); /* match if we reached the end of s2, too */ |
| 374 |
#undef CLS_STR |
| 375 |
#undef CLS_INT |
| 376 |
#undef CLS_FLT |
| 377 |
| 378 |
| 379 |
/* Check if string is var=value pair and set if not in ignore list */ |
| 380 |
static int |
| 381 |
setheadvar(char *val, void *p) |
| 382 |
| 383 |
char newval[128]; |
| 384 |
LUTAB *htp = (LUTAB *)p; |
| 385 |
LUENT *tep; |
| 386 |
char *key; |
| 387 |
int kln, vln; |
| 388 |
int n; |
| 389 |
| 390 |
adv_linecnt(htp); /* side-effect is to count lines */ |
| 391 |
if (!isalpha(*val)) /* key must start line */ |
| 392 |
return(0); |
| 393 |
/* check if we need to swap binary data */ |
| 394 |
if ((n = isbigendian(val)) >= 0) { |
| 395 |
if (nativebigendian() == n) |
| 396 |
return(0); |
| 397 |
f1swap += (htp == &hdr1); |
| 398 |
f2swap += (htp == &hdr2); |
| 399 |
return(0); |
| 400 |
| 401 |
key = val++; |
| 402 |
while (*val && !isspace(*val) & (*val != '=')) |
| 403 |
val++; |
| 404 |
kln = val - key; |
| 405 |
while (isspace(*val)) /* check for value */ |
| 406 |
*val++ = '\0'; |
| 407 |
if (*val != '=') |
| 408 |
return(0); |
| 409 |
*val++ = '\0'; |
| 410 |
while (isspace(*val)) |
| 411 |
val++; |
| 412 |
if (!*val) /* nothing set? */ |
| 413 |
return(0); |
| 414 |
/* check if key to ignore */ |
| 415 |
for (n = 0; hdr_ignkey[n]; n++) |
| 416 |
if (!strcmp(key, hdr_ignkey[n])) |
| 417 |
return(0); |
| 418 |
vln = strlen(val); /* eliminate space and newline at end */ |
| 419 |
while (isspace(val[--vln])) |
| 420 |
| 421 |
val[++vln] = '\0'; |
| 422 |
if (!(tep = lu_find(htp, key))) |
| 423 |
return(-1); /* memory allocation error */ |
| 424 |
if (!tep->key) |
| 425 |
tep->key = strcpy(malloc(kln+1), key); |
| 426 |
if (tep->data) { /* check for special cases */ |
| 427 |
if (!strcmp(key, "EXPOSURE")) { |
| 428 |
sprintf(newval, "%.6e", atof(tep->data)*atof(val)); |
| 429 |
vln = strlen(val = newval); |
| 430 |
| 431 |
free(tep->data); |
| 432 |
| 433 |
tep->data = strcpy(malloc(vln+1), val); |
| 434 |
return(1); |
| 435 |
| 436 |
| 437 |
/* Lookup correspondent in other header */ |
| 438 |
static int |
| 439 |
match_val(const LUENT *ep1, void *p2) |
| 440 |
| 441 |
const LUENT *ep2 = lu_find((LUTAB *)p2, ep1->key); |
| 442 |
if (!ep2 || !ep2->data) { |
| 443 |
| 444 |
printf("%s: variable '%s' missing in '%s'\n", |
| 445 |
progname, ep1->key, f2name); |
| 446 |
return(-1); |
| 447 |
| 448 |
if (!equiv_string((char *)ep1->data, (char *)ep2->data)) { |
| 449 |
if (report != REP_QUIET) { |
| 450 |
printf("%s: header variable '%s' has different values\n", |
| 451 |
progname, ep1->key); |
| 452 |
if (report >= REP_VERBOSE) { |
| 453 |
printf("%s: %s=%s\n", f1name, |
| 454 |
ep1->key, (char *)ep1->data); |
| 455 |
printf("%s: %s=%s\n", f2name, |
| 456 |
ep2->key, (char *)ep2->data); |
| 457 |
| 458 |
| 459 |
return(-1); |
| 460 |
| 461 |
return(1); /* good match */ |
| 462 |
| 463 |
| 464 |
/* Compare two sets of header variables */ |
| 465 |
static int |
| 466 |
headers_match() |
| 467 |
| 468 |
int ne = lu_doall(&hdr1, match_val, &hdr2); |
| 469 |
if (ne < 0) |
| 470 |
return(0); /* something didn't match! */ |
| 471 |
/* non-fatal if second header has extra */ |
| 472 |
if (report >= REP_WARN && (ne = lu_doall(&hdr2, NULL, NULL) - ne)) |
| 473 |
printf("%s: warning - '%s' has %d extra header setting(s)\n", |
| 474 |
progname, f2name, ne); |
| 475 |
| 476 |
| 477 |
| 478 |
/* Check generic input to determine if it is binary, -1 on error */ |
| 479 |
static int |
| 480 |
input_is_binary(FILE *fin) |
| 481 |
| 482 |
int n = 0; |
| 483 |
int c = 0; |
| 484 |
| 485 |
while ((c = getc(fin)) != EOF) { |
| 486 |
++n; |
| 487 |
if (!c | (c > 127)) |
| 488 |
break; /* non-ascii character */ |
| 489 |
if (n >= 10240) |
| 490 |
break; /* enough to be confident */ |
| 491 |
| 492 |
if (!n) |
| 493 |
return(-1); /* first read failed */ |
| 494 |
if (fseek(fin, 0L, 0) < 0) |
| 495 |
return(-1); /* rewind failed */ |
| 496 |
return(!c | (c > 127)); |
| 497 |
| 498 |
| 499 |
/* Identify and return data type from header (if one) */ |
| 500 |
static int |
| 501 |
identify_type(const char *name, FILE *fin, LUTAB *htp) |
| 502 |
| 503 |
extern const char HDRSTR[]; |
| 504 |
int c; |
| 505 |
/* check magic header start */ |
| 506 |
if ((c = getc(fin)) != HDRSTR[0]) { |
| 507 |
if (c == EOF) goto badeof; |
| 508 |
ungetc(c, fin); |
| 509 |
c = 0; |
| 510 |
} else if ((c = getc(fin)) != HDRSTR[1]) { |
| 511 |
| 512 |
ungetc(c, fin); ungetc(HDRSTR[0], fin); |
| 513 |
c = 0; |
| 514 |
| 515 |
if (c) { /* appears to have a header */ |
| 516 |
char sbuf[32]; |
| 517 |
if (!fgets(sbuf, sizeof(sbuf), fin)) |
| 518 |
goto badeof; |
| 519 |
adv_linecnt(htp); /* for #?ID string */ |
| 520 |
if (report >= REP_WARN && strncmp(sbuf, "RADIANCE", 8)) { |
| 521 |
fputs(name, stdout); |
| 522 |
fputs(": warning - unexpected header ID: ", stdout); |
| 523 |
fputs(sbuf, stdout); |
| 524 |
| 525 |
if (getheader(fin, setheadvar, htp) < 0) { |
| 526 |
fputs(name, stderr); |
| 527 |
fputs(": unknown error reading header\n", stderr); |
| 528 |
return(-1); |
| 529 |
| 530 |
adv_linecnt(htp); /* for trailing emtpy line */ |
| 531 |
return(xlate_type((const char *)lu_find(htp,"FORMAT")->data)); |
| 532 |
| 533 |
c = input_is_binary(fin); /* else peek to see if binary */ |
| 534 |
if (c < 0) { |
| 535 |
| 536 |
fputs(": read/seek error\n", stderr); |
| 537 |
return(-1); |
| 538 |
| 539 |
if (c) |
| 540 |
return(TYP_BINARY); |
| 541 |
return(TYP_TEXT); |
| 542 |
badeof: |
| 543 |
| 544 |
| 545 |
fputs(": unexpected end-of-file\n", stdout); |
| 546 |
| 547 |
return(-1); |
| 548 |
| 549 |
| 550 |
/* Check that overall RMS error is below threshold */ |
| 551 |
static int |
| 552 |
good_RMS() |
| 553 |
| 554 |
if (!nsum) |
| 555 |
return(1); |
| 556 |
if (diff2sum/(double)nsum > rms_lim*rms_lim) { |
| 557 |
| 558 |
printf( |
| 559 |
"%s: %sRMS difference between '%s' and '%s' of %.5g exceeds limit of %.5g\n", |
| 560 |
progname, |
| 561 |
| 562 |
f1name, f2name, |
| 563 |
sqrt(diff2sum/(double)nsum), rms_lim); |
| 564 |
return(0); |
| 565 |
| 566 |
if (report >= REP_VERBOSE) |
| 567 |
printf("%s: %sRMS difference of reals in '%s' and '%s' is %.5g\n", |
| 568 |
progname, (rel_min > 0) ? "relative " : "", |
| 569 |
f1name, f2name, sqrt(diff2sum/(double)nsum)); |
| 570 |
return(1); |
| 571 |
| 572 |
| 573 |
/* Compare two inputs as generic binary files */ |
| 574 |
static int |
| 575 |
compare_binary() |
| 576 |
| 577 |
int c1=0, c2=0; |
| 578 |
| 579 |
| 580 |
fputs(progname, stdout); |
| 581 |
fputs(": comparing inputs as binary\n", stdout); |
| 582 |
| 583 |
for ( ; ; ) { /* exact byte matching */ |
| 584 |
c1 = getc(f1in); |
| 585 |
c2 = getc(f2in); |
| 586 |
if (c1 == EOF) { |
| 587 |
if (c2 == EOF) |
| 588 |
return(1); /* success! */ |
| 589 |
| 590 |
fputs(f1name, stdout); |
| 591 |
| 592 |
| 593 |
return(0); |
| 594 |
| 595 |
if (c2 == EOF) { |
| 596 |
| 597 |
fputs(f2name, stdout); |
| 598 |
| 599 |
| 600 |
return(0); |
| 601 |
| 602 |
if (c1 != c2) |
| 603 |
break; /* quit and report difference */ |
| 604 |
| 605 |
if (report == REP_QUIET) |
| 606 |
return(0); |
| 607 |
printf("%s: binary files '%s' and '%s' differ at byte offset %ld|%ld\n", |
| 608 |
progname, f1name, f2name, ftell(f1in), ftell(f2in)); |
| 609 |
| 610 |
printf("%s: byte in '%s' is 0x%X, byte in '%s' is 0x%X\n", |
| 611 |
progname, f1name, c1, f2name, c2); |
| 612 |
return(0); |
| 613 |
| 614 |
| 615 |
/* Compare two inputs as generic text files */ |
| 616 |
static int |
| 617 |
compare_text() |
| 618 |
| 619 |
LINEBUF l1buf, l2buf; |
| 620 |
| 621 |
| 622 |
| 623 |
fputs(": comparing inputs as ASCII text", stdout); |
| 624 |
if (escape_newlines) |
| 625 |
fputs(", allowing escaped newlines", stdout); |
| 626 |
if (comment_c) { |
| 627 |
fputs(", ignoring comments starting with '", stdout); |
| 628 |
fputc(comment_c, stdout); |
| 629 |
fputc('\'', stdout); |
| 630 |
| 631 |
fputc('\n', stdout); |
| 632 |
| 633 |
SET_FILE_TEXT(f1in); /* originally set to binary */ |
| 634 |
SET_FILE_TEXT(f2in); |
| 635 |
init_line(&l1buf); init_line(&l2buf); /* compare a line at a time */ |
| 636 |
while (read_line(&l1buf, f1in)) { |
| 637 |
lin1cnt++; |
| 638 |
if (!*sskip2(l1buf.str,0)) |
| 639 |
continue; /* ignore empty lines */ |
| 640 |
| 641 |
while (read_line(&l2buf, f2in)) { |
| 642 |
lin2cnt++; |
| 643 |
if (*sskip2(l2buf.str,0)) |
| 644 |
break; /* found other non-empty line */ |
| 645 |
| 646 |
if (!l2buf.len) { /* input 2 EOF? */ |
| 647 |
| 648 |
| 649 |
| 650 |
| 651 |
free_line(&l1buf); free_line(&l2buf); |
| 652 |
return(0); |
| 653 |
| 654 |
/* compare non-empty lines */ |
| 655 |
if (!equiv_string(l1buf.str, l2buf.str)) { |
| 656 |
| 657 |
printf("%s: inputs '%s' and '%s' differ at line %d", |
| 658 |
progname, f1name, f2name, lin1cnt); |
| 659 |
if (lin1cnt != lin2cnt) |
| 660 |
printf("|%d\n", lin2cnt); |
| 661 |
else |
| 662 |
putchar('\n'); |
| 663 |
if ( report >= REP_VERBOSE && |
| 664 |
(l1buf.len < 256) & |
| 665 |
(l2buf.len < 256) ) { |
| 666 |
fputs("------------- Mismatch -------------\n", stdout); |
| 667 |
printf("%s@%d:\t%s", f1name, |
| 668 |
lin1cnt, l1buf.str); |
| 669 |
printf("%s@%d:\t%s", f2name, |
| 670 |
lin2cnt, l2buf.str); |
| 671 |
| 672 |
| 673 |
| 674 |
return(0); |
| 675 |
| 676 |
| 677 |
free_line(&l1buf); /* check for EOF on input 2 */ |
| 678 |
| 679 |
if (!*sskip2(l2buf.str,0)) |
| 680 |
continue; |
| 681 |
| 682 |
| 683 |
| 684 |
| 685 |
| 686 |
return(0); |
| 687 |
| 688 |
| 689 |
return(good_RMS()); /* final check for reals */ |
| 690 |
| 691 |
| 692 |
/* Set resolution based on NROWS, NCOLS in header */ |
| 693 |
static int |
| 694 |
set_resolu(RESOLU *rs, LUTAB *htp) |
| 695 |
| 696 |
const char *val; |
| 697 |
| 698 |
rs->rt = PIXSTANDARD; |
| 699 |
val = (const char *)lu_find(htp, "NROWS")->data; |
| 700 |
if (!val) return(0); |
| 701 |
rs->yr = atoi(val); |
| 702 |
if (rs->yr <= 0) return(-1); |
| 703 |
val = (const char *)lu_find(htp, "NCOLS")->data; |
| 704 |
| 705 |
rs->xr = atoi(val); |
| 706 |
if (rs->xr <= 0) return(-1); |
| 707 |
return(1); |
| 708 |
| 709 |
| 710 |
/* Check image/map resolutions */ |
| 711 |
static int |
| 712 |
check_resolu(const char *class, RESOLU *r1p, RESOLU *r2p) |
| 713 |
| 714 |
if (r1p->rt != r2p->rt) { |
| 715 |
| 716 |
printf( |
| 717 |
"%s: %ss '%s' and '%s' have different pixel ordering\n", |
| 718 |
progname, class, f1name, f2name); |
| 719 |
return(0); |
| 720 |
| 721 |
if ((r1p->xr != r2p->xr) | (r1p->yr != r2p->yr)) { |
| 722 |
| 723 |
printf( |
| 724 |
"%s: %ss '%s' and '%s' are different sizes\n", |
| 725 |
| 726 |
return(0); |
| 727 |
| 728 |
return(1); |
| 729 |
| 730 |
| 731 |
/* Compare two inputs that are known to be RGBE or XYZE images */ |
| 732 |
static int |
| 733 |
compare_hdr() |
| 734 |
| 735 |
RESOLU rs1, rs2; |
| 736 |
COLOR *scan1, *scan2; |
| 737 |
int x, y; |
| 738 |
| 739 |
| 740 |
| 741 |
fputs(": comparing inputs as HDR images\n", stdout); |
| 742 |
| 743 |
fgetsresolu(&rs1, f1in); |
| 744 |
fgetsresolu(&rs2, f2in); |
| 745 |
if (!check_resolu("HDR image", &rs1, &rs2)) |
| 746 |
return(0); |
| 747 |
scan1 = (COLOR *)malloc(scanlen(&rs1)*sizeof(COLOR)); |
| 748 |
scan2 = (COLOR *)malloc(scanlen(&rs2)*sizeof(COLOR)); |
| 749 |
if (!scan1 | !scan2) { |
| 750 |
fprintf(stderr, "%s: out of memory in compare_hdr()\n", progname); |
| 751 |
exit(2); |
| 752 |
| 753 |
for (y = 0; y < numscans(&rs1); y++) { |
| 754 |
if ((freadscan(scan1, scanlen(&rs1), f1in) < 0) | |
| 755 |
(freadscan(scan2, scanlen(&rs2), f2in) < 0)) { |
| 756 |
| 757 |
printf("%s: unexpected end-of-file\n", |
| 758 |
progname); |
| 759 |
free(scan1); |
| 760 |
free(scan2); |
| 761 |
return(0); |
| 762 |
| 763 |
for (x = 0; x < scanlen(&rs1); x++) { |
| 764 |
if (color_check(scan1[x], scan2[x])) |
| 765 |
continue; |
| 766 |
| 767 |
printf("%s: pixels at scanline %d offset %d differ\n", |
| 768 |
progname, y, x); |
| 769 |
| 770 |
printf("%s: (R,G,B)=(%g,%g,%g)\n", |
| 771 |
f1name, colval(scan1[x],RED), |
| 772 |
colval(scan1[x],GRN), |
| 773 |
colval(scan1[x],BLU)); |
| 774 |
| 775 |
f2name, colval(scan2[x],RED), |
| 776 |
colval(scan2[x],GRN), |
| 777 |
colval(scan2[x],BLU)); |
| 778 |
| 779 |
| 780 |
free(scan1); |
| 781 |
free(scan2); |
| 782 |
return(0); |
| 783 |
| 784 |
| 785 |
free(scan1); |
| 786 |
free(scan2); |
| 787 |
return(good_RMS()); /* final check of RMS */ |
| 788 |
| 789 |
| 790 |
/* Compare two inputs that are known to be spectral images */ |
| 791 |
static int |
| 792 |
compare_spec() |
| 793 |
| 794 |
static char NCstr[] = NCOMPSTR; |
| 795 |
RESOLU rs1, rs2; |
| 796 |
COLORV *scan1, *scan2; |
| 797 |
const char *val; |
| 798 |
int x, y; |
| 799 |
| 800 |
| 801 |
| 802 |
fputs(": comparing inputs as spectral images\n", stdout); |
| 803 |
| 804 |
if (!(set_resolu(&rs1, &hdr1) || fgetsresolu(&rs1, f1in))) |
| 805 |
return(0); |
| 806 |
if (!(set_resolu(&rs2, &hdr2) || fgetsresolu(&rs2, f2in))) |
| 807 |
return(0); |
| 808 |
if (!check_resolu("Spectral image", &rs1, &rs2)) |
| 809 |
return(0); |
| 810 |
NCstr[LNCOMPSTR-1] = '\0'; |
| 811 |
val = (const char *)lu_find(&hdr1, NCstr)->data; |
| 812 |
if (!val || (NCSAMP = atoi(val)) < 3) { |
| 813 |
| 814 |
if (val) |
| 815 |
printf("%s: illegal # components (%d) for spectral image\n", |
| 816 |
progname, NCSAMP); |
| 817 |
else |
| 818 |
printf("%s: missing %s in header for spectral image\n", |
| 819 |
progname, NCstr); |
| 820 |
| 821 |
return(0); |
| 822 |
| 823 |
scan1 = (COLORV *)malloc(sizeof(COLORV)*NCSAMP*scanlen(&rs1)); |
| 824 |
scan2 = (COLORV *)malloc(sizeof(COLORV)*NCSAMP*scanlen(&rs2)); |
| 825 |
| 826 |
| 827 |
exit(2); |
| 828 |
| 829 |
| 830 |
if ((freadsscan(scan1, NCSAMP, scanlen(&rs1), f1in) < 0) | |
| 831 |
(freadsscan(scan2, NCSAMP, scanlen(&rs2), f2in) < 0)) { |
| 832 |
| 833 |
printf("%s: unexpected end-of-file\n", progname); |
| 834 |
free(scan1); |
| 835 |
free(scan2); |
| 836 |
return(0); |
| 837 |
| 838 |
| 839 |
if (spec_check(scan1+x*NCSAMP, scan2+x*NCSAMP)) |
| 840 |
continue; |
| 841 |
| 842 |
int k; |
| 843 |
printf("%s: spectra at scanline %d offset %d differ\n", |
| 844 |
progname, y, x); |
| 845 |
| 846 |
printf("%s: spectrum =", f1name); |
| 847 |
for (k = 0; k < NCSAMP; k++) |
| 848 |
printf(" %g", scan1[x*NCSAMP+k]); |
| 849 |
| 850 |
printf("%s: spectrum =", f2name); |
| 851 |
| 852 |
printf(" %g", scan2[x*NCSAMP+k]); |
| 853 |
| 854 |
| 855 |
| 856 |
free(scan1); |
| 857 |
free(scan2); |
| 858 |
return(0); |
| 859 |
| 860 |
| 861 |
free(scan1); |
| 862 |
free(scan2); |
| 863 |
| 864 |
| 865 |
| 866 |
/* Set reference depth based on header variable */ |
| 867 |
static int |
| 868 |
set_refdepth(DEPTHCODEC *dcp, LUTAB *htp) |
| 869 |
| 870 |
static char depthvar[] = DEPTHSTR; |
| 871 |
const char *drval; |
| 872 |
| 873 |
depthvar[LDEPTHSTR-1] = '\0'; |
| 874 |
drval = (const char *)lu_find(htp, depthvar)->data; |
| 875 |
if (!drval) |
| 876 |
return(0); |
| 877 |
dcp->refdepth = atof(drval); |
| 878 |
if (dcp->refdepth <= 0) { |
| 879 |
| 880 |
fputs(dcp->inpname, stderr); |
| 881 |
fputs(": bad reference depth '", stderr); |
| 882 |
fputs(drval, stderr); |
| 883 |
fputs("'\n", stderr); |
| 884 |
| 885 |
return(-1); |
| 886 |
| 887 |
return(1); |
| 888 |
| 889 |
| 890 |
/* Compare two encoded depth maps */ |
| 891 |
static int |
| 892 |
compare_depth() |
| 893 |
| 894 |
long nread = 0; |
| 895 |
DEPTHCODEC dc1, dc2; |
| 896 |
| 897 |
| 898 |
| 899 |
fputs(": comparing inputs as depth maps\n", stdout); |
| 900 |
| 901 |
set_dc_defaults(&dc1); |
| 902 |
dc1.hdrflags = HF_RESIN; |
| 903 |
dc1.finp = f1in; |
| 904 |
dc1.inpname = f1name; |
| 905 |
set_dc_defaults(&dc2); |
| 906 |
dc2.hdrflags = HF_RESIN; |
| 907 |
dc2.finp = f2in; |
| 908 |
dc2.inpname = f2name; |
| 909 |
| 910 |
dc1.hdrflags |= HF_STDERR; |
| 911 |
dc2.hdrflags |= HF_STDERR; |
| 912 |
| 913 |
if (!process_dc_header(&dc1, 0, NULL)) |
| 914 |
return(0); |
| 915 |
if (!process_dc_header(&dc2, 0, NULL)) |
| 916 |
return(0); |
| 917 |
if (!check_resolu("Depth map", &dc1.res, &dc2.res)) |
| 918 |
return(0); |
| 919 |
if (set_refdepth(&dc1, &hdr1) < 0) |
| 920 |
return(0); |
| 921 |
if (set_refdepth(&dc2, &hdr2) < 0) |
| 922 |
return(0); |
| 923 |
while (nread < dc1.res.xr*dc1.res.yr) { |
| 924 |
double d1 = decode_depth_next(&dc1); |
| 925 |
double d2 = decode_depth_next(&dc2); |
| 926 |
if ((d1 < 0) | (d2 < 0)) { |
| 927 |
| 928 |
| 929 |
progname); |
| 930 |
return(0); |
| 931 |
| 932 |
++nread; |
| 933 |
if (real_check(d1, d2)) |
| 934 |
continue; |
| 935 |
| 936 |
printf("%s: %ld%s depth values differ\n", |
| 937 |
progname, nread, num_sfx(nread)); |
| 938 |
return(0); |
| 939 |
| 940 |
| 941 |
| 942 |
| 943 |
/* Compare two encoded normal maps */ |
| 944 |
static int |
| 945 |
compare_norm() |
| 946 |
| 947 |
long nread = 0; |
| 948 |
NORMCODEC nc1, nc2; |
| 949 |
| 950 |
| 951 |
| 952 |
fputs(": comparing inputs as normal maps\n", stdout); |
| 953 |
| 954 |
set_nc_defaults(&nc1); |
| 955 |
nc1.hdrflags = HF_RESIN; |
| 956 |
nc1.finp = f1in; |
| 957 |
nc1.inpname = f1name; |
| 958 |
set_nc_defaults(&nc2); |
| 959 |
nc2.hdrflags = HF_RESIN; |
| 960 |
nc2.finp = f2in; |
| 961 |
nc2.inpname = f2name; |
| 962 |
| 963 |
nc1.hdrflags |= HF_STDERR; |
| 964 |
nc2.hdrflags |= HF_STDERR; |
| 965 |
| 966 |
if (!process_nc_header(&nc1, 0, NULL)) |
| 967 |
return(0); |
| 968 |
if (!process_nc_header(&nc2, 0, NULL)) |
| 969 |
return(0); |
| 970 |
if (!check_resolu("Normal map", &nc1.res, &nc2.res)) |
| 971 |
return(0); |
| 972 |
while (nread < nc1.res.xr*nc1.res.yr) { |
| 973 |
FVECT nv1, nv2; |
| 974 |
int rv1 = decode_normal_next(nv1, &nc1); |
| 975 |
int rv2 = decode_normal_next(nv2, &nc2); |
| 976 |
if ((rv1 < 0) | (rv2 < 0)) { |
| 977 |
| 978 |
| 979 |
progname); |
| 980 |
return(0); |
| 981 |
| 982 |
++nread; |
| 983 |
if (rv1 == rv2 && (!rv1 || norm_check(nv1, nv2))) |
| 984 |
continue; |
| 985 |
| 986 |
printf("%s: %ld%s normal vectors differ\n", |
| 987 |
| 988 |
return(0); |
| 989 |
| 990 |
| 991 |
| 992 |
| 993 |
/* Compare two inputs that are known to be 32-bit floating-point data */ |
| 994 |
static int |
| 995 |
compare_float() |
| 996 |
| 997 |
long nread = 0; |
| 998 |
float f1, f2; |
| 999 |
| 1000 |
| 1001 |
| 1002 |
fputs(": comparing inputs as 32-bit IEEE floats\n", stdout); |
| 1003 |
| 1004 |
while (getbinary(&f1, sizeof(f1), 1, f1in)) { |
| 1005 |
if (!getbinary(&f2, sizeof(f2), 1, f2in)) |
| 1006 |
goto badeof; |
| 1007 |
++nread; |
| 1008 |
if (f1swap) swap32((char *)&f1, 1); |
| 1009 |
if (f2swap) swap32((char *)&f2, 1); |
| 1010 |
if (real_check(f1, f2)) |
| 1011 |
continue; |
| 1012 |
| 1013 |
printf("%s: %ld%s float values differ\n", |
| 1014 |
| 1015 |
return(0); |
| 1016 |
| 1017 |
| 1018 |
| 1019 |
badeof: |
| 1020 |
| 1021 |
| 1022 |
return(0); |
| 1023 |
| 1024 |
| 1025 |
/* Compare two inputs that are known to be 64-bit floating-point data */ |
| 1026 |
static int |
| 1027 |
compare_double() |
| 1028 |
| 1029 |
long nread = 0; |
| 1030 |
double f1, f2; |
| 1031 |
| 1032 |
| 1033 |
| 1034 |
fputs(": comparing inputs as 64-bit IEEE doubles\n", stdout); |
| 1035 |
| 1036 |
| 1037 |
| 1038 |
goto badeof; |
| 1039 |
++nread; |
| 1040 |
if (f1swap) swap64((char *)&f1, 1); |
| 1041 |
if (f2swap) swap64((char *)&f2, 1); |
| 1042 |
| 1043 |
continue; |
| 1044 |
| 1045 |
printf("%s: %ld%s double values differ\n", |
| 1046 |
| 1047 |
return(0); |
| 1048 |
| 1049 |
| 1050 |
| 1051 |
badeof: |
| 1052 |
| 1053 |
| 1054 |
return(0); |
| 1055 |
| 1056 |
| 1057 |
/* Compare two Radiance files for equivalence */ |
| 1058 |
int |
| 1059 |
main(int argc, char *argv[]) |
| 1060 |
| 1061 |
int typ1, typ2; |
| 1062 |
int a; |
| 1063 |
/* set global progname */ |
| 1064 |
fixargv0(argv[0]); |
| 1065 |
for (a = 1; a < argc && argv[a][0] == '-'; a++) { |
| 1066 |
switch (argv[a][1]) { |
| 1067 |
case 'h': /* ignore header info. */ |
| 1068 |
ign_header = !ign_header; |
| 1069 |
continue; |
| 1070 |
case 'n': /* allow newline escapes */ |
| 1071 |
escape_newlines = !escape_newlines; |
| 1072 |
continue; |
| 1073 |
case 'c': /* ignore comments */ |
| 1074 |
comment_c = argv[a][2]; |
| 1075 |
continue; |
| 1076 |
case 's': /* silent operation */ |
| 1077 |
report = REP_QUIET; |
| 1078 |
continue; |
| 1079 |
case 'w': /* turn off warnings */ |
| 1080 |
if (report > REP_ERROR) |
| 1081 |
report = REP_ERROR; |
| 1082 |
continue; |
| 1083 |
case 'v': /* turn on verbose mode */ |
| 1084 |
report = REP_VERBOSE; |
| 1085 |
continue; |
| 1086 |
case 'm': /* maximum epsilon */ |
| 1087 |
max_lim = atof(argv[++a]); |
| 1088 |
continue; |
| 1089 |
case 'r': |
| 1090 |
if (argv[a][2] == 'e') /* relative difference */ |
| 1091 |
rel_min = atof(argv[++a]); |
| 1092 |
else if (argv[a][2] == 'm') /* RMS limit */ |
| 1093 |
rms_lim = atof(argv[++a]); |
| 1094 |
else |
| 1095 |
usage(); |
| 1096 |
continue; |
| 1097 |
case '\0': /* first file from stdin */ |
| 1098 |
f1in = stdin; |
| 1099 |
f1name = stdin_name; |
| 1100 |
break; |
| 1101 |
default: |
| 1102 |
usage(); |
| 1103 |
| 1104 |
break; |
| 1105 |
| 1106 |
if (a != argc-2) /* make sure of two inputs */ |
| 1107 |
usage(); |
| 1108 |
if (!strcmp(argv[a], argv[a+1])) { /* inputs are same? */ |
| 1109 |
if (report >= REP_WARN) |
| 1110 |
printf("%s: warning - identical inputs given\n", |
| 1111 |
progname); |
| 1112 |
return(0); |
| 1113 |
| 1114 |
if (!f1name) f1name = argv[a]; |
| 1115 |
if (!f2name) f2name = argv[a+1]; |
| 1116 |
/* open inputs */ |
| 1117 |
SET_FILE_BINARY(stdin); /* in case we're using it */ |
| 1118 |
if (!f1in && !(f1in = fopen(f1name, "rb"))) { |
| 1119 |
fprintf(stderr, "%s: cannot open for reading\n", f1name); |
| 1120 |
return(2); |
| 1121 |
| 1122 |
if (!strcmp(f2name, "-")) { |
| 1123 |
f2in = stdin; |
| 1124 |
f2name = stdin_name; |
| 1125 |
} else if (!(f2in = fopen(f2name, "rb"))) { |
| 1126 |
fprintf(stderr, "%s: cannot open for reading\n", f2name); |
| 1127 |
return(2); |
| 1128 |
| 1129 |
/* load headers */ |
| 1130 |
if ((typ1 = identify_type(f1name, f1in, &hdr1)) < 0) |
| 1131 |
return(2); |
| 1132 |
if ((typ2 = identify_type(f2name, f2in, &hdr2)) < 0) |
| 1133 |
return(2); |
| 1134 |
if (typ1 != typ2) { |
| 1135 |
| 1136 |
printf("%s: '%s' format is %s and '%s' is %s\n", |
| 1137 |
progname, f1name, file_type[typ1], |
| 1138 |
f2name, file_type[typ2]); |
| 1139 |
return(1); |
| 1140 |
| 1141 |
ign_header |= !has_header(typ1); /* check headers if indicated */ |
| 1142 |
if (!ign_header && !headers_match()) |
| 1143 |
return(1); |
| 1144 |
if (!ign_header & (report >= REP_WARN)) { |
| 1145 |
| 1146 |
printf("%s: warning - headers are different lengths\n", |
| 1147 |
progname); |
| 1148 |
if (typ1 == TYP_UNKNOWN) |
| 1149 |
printf("%s: warning - unrecognized format\n", |
| 1150 |
progname); |
| 1151 |
| 1152 |
| 1153 |
printf("%s: data format is %s\n", progname, file_type[typ1]); |
| 1154 |
if ((typ1 == TYP_FLOAT) | (typ1 == TYP_DOUBLE)) { |
| 1155 |
if (f1swap) |
| 1156 |
printf("%s: input '%s' is byte-swapped\n", |
| 1157 |
progname, f1name); |
| 1158 |
if (f2swap) |
| 1159 |
| 1160 |
progname, f2name); |
| 1161 |
| 1162 |
| 1163 |
switch (typ1) { /* compare based on type */ |
| 1164 |
case TYP_BINARY: |
| 1165 |
case TYP_TMESH: |
| 1166 |
case TYP_OCTREE: |
| 1167 |
case TYP_RBFMESH: |
| 1168 |
case TYP_ID8: |
| 1169 |
case TYP_ID16: |
| 1170 |
case TYP_ID24: |
| 1171 |
case TYP_UNKNOWN: |
| 1172 |
return( !compare_binary() ); |
| 1173 |
case TYP_TEXT: |
| 1174 |
case TYP_ASCII: |
| 1175 |
return( !compare_text() ); |
| 1176 |
case TYP_RGBE: |
| 1177 |
case TYP_XYZE: |
| 1178 |
return( !compare_hdr() ); |
| 1179 |
case TYP_SPEC: |
| 1180 |
return( !compare_spec() ); |
| 1181 |
case TYP_DEPTH: |
| 1182 |
return( !compare_depth() ); |
| 1183 |
case TYP_NORM: |
| 1184 |
return( !compare_norm() ); |
| 1185 |
case TYP_FLOAT: |
| 1186 |
return( !compare_float() ); |
| 1187 |
case TYP_DOUBLE: |
| 1188 |
return( !compare_double() ); |
| 1189 |
| 1190 |
return(1); |
| 1191 |
