root/radiance/src/util/pictool.c
Revision: 2.5
Committed: Wed Jan 24 04:39:52 2018 UTC (7 years, 8 months ago) by greg
2 static const char RCSid[] = "$Id: pictool.c,v 2.4 2017/05/18 02:25:27 greg Exp $";
4 #include "pictool.h"
5 #include "g3sphere.h"
6 #include <math.h>
7 #include <string.h>
8
9 #define index strchr
10
11
12
13 int pict_init(pict* p)
14 {
15 p->pic = NULL;
16 p->use_lut = 0;
17 p->lut = NULL;
18 p->pjitter = 0;
19 p->comment[0] = '\0';
20 #ifdef PICT_GLARE
21 p->pinfo = NULL;
22 p->glareinfo = g3fl_create(PICT_GLSIZE);
23 #endif
24 p->valid_view = 1;
25 p->view = stdview;
26 if (!pict_update_view(p))
27 return 0;
28 p->resol.rt = PIXSTANDARD;
29 return pict_resize(p,512,512);
30 }
31
32 void pict_new_gli(pict* p)
33 {
34 int i;
35
36 g3Float* gli;
37 gli = g3fl_append_new(p->glareinfo);
38 for(i=0;i<PICT_GLSIZE;i++)
39 gli[i] = 0.0;
40 }
41
42 void pict_set_comment(pict* p,const char* c)
43 {
44 strcpy(p->comment,c);
45 }
46
47 pict* pict_get_copy(pict* p)
48 {
49 pict* res;
50
51 if (p->use_lut) {
52 fprintf(stderr,"pict_get_copy: can't copy in lut mode");
53 return NULL;
54 }
55 res = pict_create();
56 pict_resize(res,pict_get_xsize(p),pict_get_ysize(p));
57 res->view = p->view;
58 res->resol = p->resol;
59 res->pjitter = p->pjitter;
60 return res;
61 }
62
63 pict* pict_create()
64 {
65 pict* p = (pict*) malloc(sizeof(pict));
66
67 if (!pict_init(p)) {
68 pict_free(p);
69 return NULL;
70 }
71 return p;
72 }
73
74 void pict_free(pict* p)
75 {
76 if (p->pic)
77 free(p->pic);
78 #ifdef PICT_GLARE
79 if (p->pinfo)
80 free(p->pinfo);
81 g3fl_free(p->glareinfo);
82 p->pinfo = NULL;
83 #endif
84 p->pic = NULL;
85 p->lut = NULL;
86 free(p);
87 }
88 static int exp_headline(char* s,void* exparg) {
89 double* exposure;
90 if(strstr(s, EXPOSSTR) != NULL ) {
91 fprintf(stderr,"EXP AND tab\n");
92 }
93
94 exposure = (double*) exparg;
95 if (isexpos(s)) {
96 (*exposure) *= exposval(s);
97 }
98 return 0;
99 }
100
101 static double read_exposure(FILE* fp)
102 {
103 double exposure = 1;
104
105
106 if ((getheader(fp, exp_headline, &exposure)) < 0) {
107 fprintf(stderr,"error reading header\n");
108 return 0;
109 }
110 return exposure;
111 }
112
113 int pict_update_view(pict* p)
114 {
115 char* ret;
116 if ((ret = setview(&(p->view)))) {
117 fprintf(stderr,"pict_update_view: %s\n",ret);
118 return 0;
119 }
120 return 1;
121 }
122
123 int pict_set_pj(pict* p,double pj)
124 {
125 if ((pj < 0) || (pj > 1))
126 fprintf(stderr,"pict_set_pj: warning jitter factor out of range\n");
127 p->pjitter = pj;
128 return 1;
129 }
130
131 int pict_setvup(pict* p,FVECT vup)
132 {
133 VCOPY(p->view.vup,vup);
134 return pict_update_view(p);
135 }
136
137 int pict_trans_cam(pict* p,g3ATrans t)
138 {
139 g3Vec o = g3v_create();
140 g3Vec d = g3v_create();
141 g3Vec u = g3v_create();
142
143 fprintf(stderr,"vdpre %f %f %f\n",p->view.vdir[0],p->view.vdir[1],p->view.vdir[2]);
144 fprintf(stderr,"vupre %f %f %f\n",p->view.vup[0],p->view.vup[1],p->view.vup[2]);
145 g3v_fromrad(o,p->view.vp);
146 g3v_fromrad(d,p->view.vdir);
147 g3v_fromrad(u,p->view.vup);
148
149 g3v_add(d,d,o);
150 g3v_add(u,u,o);
151 g3at_apply(t,o);
152 g3at_apply(t,u);
153 g3at_apply(t,d);
154 g3v_sub(d,d,o);
155 g3v_sub(u,u,o);
156 g3v_torad(p->view.vp,o);
157 g3v_torad(p->view.vdir,d);
158 g3v_torad(p->view.vup,u);
159 fprintf(stderr,"vd %f %f %f\n",p->view.vdir[0],p->view.vdir[1],p->view.vdir[2]);
160 fprintf(stderr,"vu %f %f %f\n",p->view.vup[0],p->view.vup[1],p->view.vup[2]);
161
162 g3v_free(o);
163 g3v_free(d);
164 g3v_free(u);
165 return pict_update_view(p);
166 }
167
168 int pict_resize(pict* p,int x,int y)
169 {
170 p->resol.xr = x;
171 p->resol.yr = y;
172
173 if (!(p->pic = (COLOR*) realloc(p->pic,(p->resol.xr)*(p->resol.yr)*sizeof(COLOR)))) {
174 fprintf(stderr,"Can't alloc picture\n");
175 return 0;
176 }
177 if (pict_lut_used(p)) {
178 if (!(p->lut = (COLOR*) realloc(p->lut,(p->resol.xr)*(p->resol.yr)*sizeof(COLOR)))) {
179 fprintf(stderr,"Can't alloc LUT\n");
180 return 0;
181 }
182 }
183 #ifdef PICT_GLARE
184 if (!(p->pinfo = (pixinfo*)
185 realloc(p->pinfo,(p->resol.xr)*p->resol.yr*sizeof(pixinfo)))) {
186 fprintf(stderr,"Can't alloc picture info\n");
187 return 0;
188 }
189 /* fprintf(stderr,"resize %d %d %d\n",p->resol.xr,p->resol.yr,sizeof(pixinfo));*/
190 #endif
191 return 1;
192 }
193
194
195 int pict_zero(pict* p)
196 {
197 int x,y,i;
198
199 for(x=0;x<pict_get_xsize(p);x++)
200 for(y=0;y<pict_get_ysize(p);y++)
201 for(i=0;i<3;i++)
202 pict_get_color(p,x,y)[i] = 0;
203 return 1;
204 }
205
206 struct hinfo {
207 VIEW *hv;
208 int ok;
209 double exposure;
210 };
211
212
213 static int
214 gethinfo( /* get view from header */
215 char *s,
216 void *v
217 )
218 {
219 if(strstr(s, EXPOSSTR) != NULL && strstr(s, "\t") != NULL) {
220
221 fprintf(stderr,"error: header contains invalid exposure entry!!!!\n");
222 fprintf(stderr,"check exposure and correct header setting !\n");
223
224
225 fprintf(stderr,"stopping !!!!\n");
226 exit(1);
227 }
228 if (isview(s) && sscanview(((struct hinfo*)v)->hv, s) > 0) {
229 ((struct hinfo*)v)->ok++;
230 } else if (isexpos(s)) {
231 /*fprintf(stderr,"readexp %f %f\n",((struct hinfo*)v)->exposure,exposval(s));*/
232 ((struct hinfo*)v)->exposure *= exposval(s);
233 }
234 return(0);
235 }
236
237 int pict_read_fp(pict* p,FILE* fp)
238 {
239 struct hinfo hi;
240 int x,y,yy;
241
242
243 hi.hv = &(p->view);
244 hi.ok = 0;
245 hi.exposure = 1;
246 getheader(fp, gethinfo, &hi);
247 /*fprintf(stderr,"expscale %f\n",hi.exposure);*/
248
249 if (!(pict_update_view(p)) || !(hi.ok))
250 p->valid_view = 0;
251 /* printf("dir %f %f %f\n",p->view.vdir[0],p->view.vdir[1],p->view.vdir[2]); */
252 if (fgetsresolu(&(p->resol),fp) < 0) {
253 fprintf(stderr,"No resolution given\n");
254 return 0;
255 }
256 if (!(p->resol.rt & YMAJOR)) {
257 x = p->resol.xr;
258 p->resol.xr = p->resol.yr;
259 p->resol.yr = x;
260 p->resol.rt |= YMAJOR;
261 }
262 if (!pict_resize(p,p->resol.xr,p->resol.yr))
263 return 0;
264 for(yy=0;yy<p->resol.yr;yy++) {
265 y = (p->resol.rt & YDECR) ? p->resol.yr - 1 - yy : yy;
266 if (freadscan((p->pic + y*p->resol.xr),p->resol.xr,fp) < 0) {
267 fprintf(stderr,"error reading line %d\n",y);
268 return 0;
269 }
270 for(x=0;x<p->resol.xr;x++) {
271 scalecolor(pict_get_color(p,x,y),1.0/hi.exposure);
272 }
273 }
274 #ifdef PICT_GLARE
275 pict_update_evalglare_caches(p);
276 #endif
277 return 1;
278 }
279
280 #ifdef PICT_GLARE
281 void pict_update_evalglare_caches(pict* p)
282 {
283 int x,y,yy;
284 float lum;
285 for(yy=0;yy<p->resol.yr;yy++) {
286 y = (p->resol.rt & YDECR) ? p->resol.yr - 1 - yy : yy;
287 for(x=0;x<p->resol.xr;x++) {
288 pict_get_omega(p,x,y) = pict_get_sangle(p,x,y);
289 pict_get_dir(p,x,y,pict_get_cached_dir(p,x,y));
290 pict_get_gsn(p,x,y) = 0;
291 pict_get_pgs(p,x,y) = 0;
292 /* make picture grey */
293 lum=luminance(pict_get_color(p,x,y))/179.0;
294 pict_get_color(p,x,y)[RED]=lum;
295 pict_get_color(p,x,y)[GRN]=lum;
296 pict_get_color(p,x,y)[BLU]=lum;
297 }
298 }
299 }
300
301 #endif
302
303 int pict_read(pict* p,char* fn)
304 {
305 FILE* fp;
306
307 if (!(fp = fopen(fn,"rb"))) {
308 fprintf(stderr,"Can't open %s\n",fn);
309 return 0;
310 }
311 if (!(pict_read_fp(p,fp)))
312 return 0;
313 fclose(fp);
314 return 1;
315 }
316
317 static void ch_pct(char* line)
318 {
319 char* pct;
320
321 while ((pct = index(line,',')))
322 *pct = '.';
323 }
324
325 char* nextline(FILE* fp)
326 {
327 static char* line = NULL;
328 static int lsize = 500;
329 int done;
330 long fpos;
331
332 if (!line) {
333 if (!(line = (char*) malloc((lsize + 1)*sizeof(char)))) {
334 fprintf(stderr,"allocation problem in nextline\n");
335 return NULL;
336 }
337 }
338 done = 0;
339 fpos = ftell(fp);
340 while(!done) {
341 if (!fgets(line,lsize,fp))
342 return NULL;
343 if (!index(line,'\n')) {
344 lsize *= 2;
345 if (!(line = (char*) realloc(line,(lsize + 1)*sizeof(char)))) {
346 fprintf(stderr,"allocation problem in nextline\n");
347 return NULL;
348 }
349 fseek(fp,fpos,SEEK_SET);
350 } else {
351 done = 1;
352 }
353 }
354 return line;
355 }
356
357 static int read_tt_txt(pict* p,int bufsel,int channel,char* fn)
358 {
359 FILE* fp;
360 char* line = NULL;
361 int x,y,vsize,hsize;
362 float* col;
363 float c;
364 char* curr;
365 char** endp;
366 COLOR* picbuf;
367
368 if (!(fp = fopen(fn,"r"))) {
369 fprintf(stderr,"pict_read_tt_txt: Can't open file %s\n",fn);
370 return 0;
371 }
372 if (!(line = nextline(fp))) {
373 fprintf(stderr,"pict_read_tt_txt: reading from file failed\n");
374 return 0;
375 }
376 if (strncmp(line,"float",strlen("float"))) {
377 fprintf(stderr,"pict_read_tt_txt: Unexpected format\n");
378 return 0;
379 }
380 if (!(line = nextline(fp))) {
381 fprintf(stderr,"pict_read_tt_txt: reading from file failed\n");
382 return 0;
383 }
384 sscanf(line,"%d %d %d %d",&x,&vsize,&y,&hsize);
385 vsize = vsize - x;
386 hsize = hsize - y;
387 if (!pict_resize(p,vsize,hsize))
388 return 0;
389 endp = malloc(sizeof(char*));
390 picbuf = (bufsel == PICT_LUT) ? p->lut : p->pic;
391 for(x=0;x<vsize;x++) {
392 if (!(line = nextline(fp))) {
393 fprintf(stderr,"pict_read_tt_txt: too few lines %d of %d\n",x,vsize);
394 free(endp);
395 return 0;
396 }
397 ch_pct(line);
398 curr = line;
399 for(y=0;y<hsize;y++) {
400 col = pict_colbuf(p,picbuf,x,y);
401 c = strtod(curr,endp);
402 if (channel & PICT_CH1)
403 col[0] = c;
404 if (channel & PICT_CH2)
405 col[1] = c;
406 if (channel & PICT_CH3)
407 col[2] = c;
408 if (curr == (*endp)) {
409 fprintf(stderr,"pict_read_tt_txt: too few values in line %d\n",x);
410 free(endp);
411 return 0;
412 }
413 curr = (*endp);
414 }
415 }
416 free(endp);
417 return 1;
418 }
419
420 int pict_read_tt_txt(pict* p,char* fn)
421 {
422 return read_tt_txt(p,PICT_VIEW,PICT_ALLCH,fn);
423 }
424
425 int pict_setup_lut(pict* p,char* theta_fn,char* phi_fn,char* omega_fn)
426 {
427 int xs,ys;
428
429 p->use_lut = 1;
430 if (!read_tt_txt(p,PICT_LUT,PICT_CH1,theta_fn)) {
431 fprintf(stderr,"pict_setup_lut: error reading theta file\n");
432 p->use_lut = 0;
433 return 0;
434 }
435 xs = pict_get_xsize(p);
436 ys = pict_get_ysize(p);
437 if (!read_tt_txt(p,PICT_LUT,PICT_CH2,phi_fn)) {
438 fprintf(stderr,"pict_setup_lut: error reading phi file\n");
439 p->use_lut = 0;
440 return 0;
441 }
442 if ((xs != pict_get_xsize(p)) || (ys != pict_get_ysize(p))) {
443 fprintf(stderr,"pict_setup_lut: different resolutions for lut files\n");
444 p->use_lut = 0;
445 return 0;
446 }
447 if (!read_tt_txt(p,PICT_LUT,PICT_CH3,omega_fn)) {
448 fprintf(stderr,"pict_setup_lut: error reading omega file\n");
449 p->use_lut = 0;
450 return 0;
451 }
452 if ((xs != pict_get_xsize(p)) || (ys != pict_get_ysize(p))) {
453 fprintf(stderr,"pict_setup_lut: different resolutions for lut files\n");
454 p->use_lut = 0;
455 return 0;
456 }
457 return 1;
458 }
459
460 int pict_update_lut(pict* p)
461 {
462 g3ATrans transf;
463 g3Vec d;
464 g3Vec u;
465 int x,y;
466
467 d = g3v_fromrad(g3v_create(),p->view.vdir);
468 u = g3v_fromrad(g3v_create(),p->view.vup);
469 g3at_ctrans(transf,d,u);
470 for(x=0;x<p->resol.xr;x++) {
471 for(y=0;y<p->resol.yr;y++) {
472 d[G3S_RAD] = 1.0;
473 d[G3S_THETA] = DEG2RAD(pict_colbuf(p,p->lut,x,y)[0]);
474 d[G3S_PHI] = DEG2RAD(pict_colbuf(p,p->lut,x,y)[1]);
475 g3s_sphtocc(d,d);
476 g3at_apply(transf,d);
477 g3s_cctosph(d,d);
478 pict_colbuf(p,p->lut,x,y)[0] = RAD2DEG(d[G3S_THETA]);
479 pict_colbuf(p,p->lut,x,y)[1] = RAD2DEG(d[G3S_PHI]);
480 }
481 }
482 g3v_free(d);
483 g3v_free(u);
484 return 1;
485 }
486
487
488 int pict_write_dir(pict* p,FILE* fp)
489 {
490 int x,y;
491 FVECT dir,orig;
492
493 for(y=0;y<p->resol.yr;y++) {
494 for(x=0;x<p->resol.xr;x++) {
495 if (!(pict_get_ray(p,x,y,orig,dir))) {
496 fprintf(fp,"%f %f %f 0.0 0.0 0.0\n",orig[0],orig[1],orig[2]);
497 } else {
498 fprintf(fp,"%f %f %f %f %f %f\n",orig[0],orig[1],orig[2],dir[0],dir[1],dir[2]);
499 }
500 }
501 }
502 return 1;
503 }
504
505 int pict_read_from_list(pict* p,FILE* fp)
506 {
507 int x,y,sz;
508 char ln[1024];
509 double val;
510
511 sz = 0;
512 for(y=0;y<p->resol.yr;y++) {
513 for(x=0;x<p->resol.xr;x++) {
514 if (!(fgets(ln,1023,fp))) {
515 fprintf(stderr,"pict_read_from_list: Read only %d values\n",sz);
516 return 0;
517 }
518 if (sscanf(ln,"%lg",&val) != 1) {
519 fprintf(stderr,"pict_read_from_list: errline %d\n",sz);
520 } else {
521 sz++;
522 setcolor(pict_get_color(p,x,y),val,val,val);
523 }
524 }
525 }
526 return 1;
527 }
528
529 int pict_write(pict* p,char* fn)
530 {
531 FILE* fp;
532
533 if (!(fp = fopen(fn,"wb"))) {
534 fprintf(stderr,"Can't open %s for writing\n",fn);
535 return 0;
536 }
537 if (!(pict_write_fp(p,fp))) {
538 fclose(fp);
539 return 0;
540 }
541 fclose(fp);
542 return 1;
543 }
544
545 int pict_write_fp(pict* p,FILE* fp)
546 {
547 char res[100];
548 int y,yy;
549 newheader("RADIANCE",fp);
550 fputnow(fp);
551 if (strlen(p->comment) > 0)
552 fputs(p->comment,fp);
553 fputs(VIEWSTR, fp);
554 fprintview(&(p->view), fp);
555 fprintf(fp,"\n");
556 fputformat(COLRFMT,fp);
557 fprintf(fp,"\n");
558
559 resolu2str(res,&(p->resol));
560 fprintf(fp,"%s",res);
561 for(y=0;y<p->resol.yr;y++) {
562 yy = (p->resol.rt & YDECR) ? p->resol.yr - 1 - y : y;
563 if (fwritescan((p->pic + yy*p->resol.xr),p->resol.xr,fp) < 0) {
564 fprintf(stderr,"writing pic-file failed\n");
565 return 0;
566 }
567 }
568 return 1;
569 }
570
571 int pict_get_dir(pict* p,int x,int y,FVECT dir)
572 {
573 FVECT orig;
574 if (pict_lut_used(p)) {
575 if (!(p->lut)) {
576 fprintf(stderr,"pict_get_dir: no lut defined\n");
577 return 0;
578 }
579 dir[G3S_RAD] = 1.0;
580 dir[G3S_THETA] = DEG2RAD(pict_colbuf(p,p->lut,x,y)[0]);
581 dir[G3S_PHI] = DEG2RAD(pict_colbuf(p,p->lut,x,y)[1]);
582 g3s_sphtocc(dir,dir);
583 return 1;
584 }
585 return pict_get_ray(p,x,y,orig,dir);
586 }
587
588 int pict_get_dir_ic(pict* p,double x,double y,FVECT dir)
589 {
590 FVECT orig;
591 if (pict_lut_used(p)) {
592 int res[2];
593 loc2pix(res,&(p->resol),x,y);
594 return pict_get_dir(p,res[0],res[1],dir);
595 }
596 return pict_get_ray_ic(p,x,y,orig,dir);
597 }
598
599 int pict_get_ray(pict* p,int x,int y,FVECT orig,FVECT dir)
600 {
601 RREAL pc[2];
602
603 pix2loc(pc,&(p->resol),x,p->resol.yr - 1 - y);
604 if (pict_lut_used(p)) {
605 if (viewray(orig,dir,&(p->view),pc[0],pc[1]) <= 0)
606 return 0;
607 return pict_get_dir(p,x,y,dir);
608 }
609 return pict_get_ray_ic(p,pc[0],pc[1],orig,dir);
610 }
611
612 int pict_get_ray_ic(pict* p,double x,double y,FVECT orig,FVECT dir)
613 {
614 if (pict_lut_used(p)) {
615 int res[2];
616 loc2pix(res,&(p->resol),x,y);
617 return pict_get_ray(p,res[0],res[1],orig,dir);
618 }
619 x = (x + (0.5*p->pjitter)*(0.5-gb_random())/p->resol.xr);
620 y = (y + (0.5*p->pjitter)*(0.5-gb_random())/p->resol.yr);
621 if (viewray(orig,dir,&(p->view),x,y) < 0)
622 return 0;
623 return 1;
624 }
625
626
627 static int splane_normal(pict* p,double e1x,double e1y,
628 double e2x,double e2y,FVECT n)
629 {
630 FVECT e1 = {0,0,0};
631 FVECT e2 = {0,0,0};
632
633 pict_get_dir_ic(p,e1x,e1y,e1);
634 pict_get_dir_ic(p,e2x,e2y,n);
635 VSUB(e2,n,e1);
636 VCROSS(n,e1,e2);
637 if (normalize(n) == 0.0) {
638 return 0;
639 }
640 return 1;
641 }
642
643 double pict_get_sangle(pict* p,int x,int y)
644 {
645 int i;
646 double ang,a,hpx,hpy;
647 RREAL pc[2];
648 FVECT n[4] = {{0,0,0},{0,0,0},{0,0,0},{0,0,0}};
649
650 if (pict_lut_used(p)) {
651 return pict_colbuf(p,p->lut,x,y)[2];
652 }
653 pix2loc(pc,&(p->resol),x,y);
654 hpx = (0.5/p->resol.xr);
655 hpy = (0.5/p->resol.yr);
656 pc[0] -= hpx;
657 pc[1] -= hpy;
658
659 i = splane_normal(p,pc[0],pc[1],pc[0],(pc[1]+2.0*hpy),n[0]);
660 i &= splane_normal(p,pc[0],(pc[1]+2.0*hpy),(pc[0]+2.0*hpx),(pc[1]+2.0*hpy),n[1]);
661 i &= splane_normal(p,(pc[0]+2.0*hpx),(pc[1]+2.0*hpy),(pc[0]+2.0*hpx),pc[1],n[2]);
662 i &= splane_normal(p,(pc[0]+2.0*hpx),pc[1],pc[0],pc[1],n[3]);
663
664 if (!i) {
665 return 0;
666 }
667 ang = 0;
668 for(i=0;i<4;i++) {
669 a = DOT(n[i],n[(i+1)%4]);
670 a = acos(a);
671 a = fabs(a);
672 ang += M_PI - a;
673 }
674 ang = ang - 2.0*M_PI;
675 if ((ang > (2.0*M_PI)) || ang < 0) {
676 fprintf(stderr,"Normal error in pict_get_sangle %f %d %d\n",ang,x,y);
677 return -1.0;
678 }
679 return ang;
680 }
681
682 int pict_locate(pict* p,FVECT pt,int* x,int* y)
683 {
684 FVECT pp;
685 int res[2];
686
687 if (pict_lut_used(p)) {
688 fprintf(stderr,"pict_locate: Not implemented for lut mode\n");
689 return 0;
690 }
691
692 if (viewloc(pp,&(p->view),pt) <= 0)
693 return 0;
694 loc2pix(res,&(p->resol),pp[0],pp[1]);
695 *x = res[0];
696 *y = res[1];
697 return 1;
698 }
699
700 int pict_get_sigma(pict* p,double x,double y,FVECT vdir,FVECT vup,double* s)
701 {
702 FVECT pvdir;
703
704 if (!pict_get_dir(p,x,y,pvdir))
705 return 0;
706 if (normalize(vdir) == 0.0) {
707 fprintf(stderr,"get_sigma: view dir is zero\n");
708 return 0;
709 }
710 if (normalize(vup) == 0.0) {
711 fprintf(stderr,"get_sigma: view up is zero\n");
712 return 0;
713 }
714 *s = acos(DOT(vdir,pvdir));
715 return 1;
716 }
717
718 int pict_get_tau(pict* p,double x,double y,FVECT vdir,FVECT vup,double* t)
719 {
720 FVECT hv,pvdir;
721 double s;
722 int i;
723 if (!pict_get_sigma(p,x,y,vdir,vup,&s))
724 return 0;
725 if (!pict_get_dir(p,x,y,pvdir))
726 return 0;
727 VCOPY(hv,pvdir);
728 normalize(hv);
729 for(i=0;i<3;i++){
730 hv[i] /= cos(s);
731 }
732 VSUB(hv,hv,vdir);
733 normalize(hv);
734 *t = acos(fdot(vup,hv));
735 return 1;
736 }
737
738 static int ortho_coord(FVECT vdir,FVECT vup,FVECT vv,FVECT hv)
739 {
740 if (normalize(vdir) == 0.0) {
741 fprintf(stderr,"ortho_coord: view direction is zero\n");
742 return 0;
743 }
744 if (normalize(vup) == 0.0) {
745 fprintf(stderr,"ortho_coord: view direction is zero\n");
746 return 0;
747 }
748 fcross(hv,vdir,vup);
749 fcross(vv,vdir,hv);
750 return 1;
751 }
752
753 int pict_get_vangle(pict* p,double x,double y,FVECT vdir,FVECT vup,double* a)
754 {
755 FVECT hv,vv,pvdir;
756 if (!ortho_coord(vdir,vup,vv,hv)) {
757 return 0;
758 }
759 if (!pict_get_dir(p,x,y,pvdir))
760 return 0;
761 *a = acos(fdot(vv,pvdir)) - (M_PI/2.0) ;
762 return 1;
763 }
764
765 int pict_get_hangle(pict* p,double x,double y,FVECT vdir,FVECT vup,double* a)
766 {
767 FVECT hv,vv,pvdir;
768 if (!ortho_coord(vdir,vup,vv,hv)) {
769 return 0;
770 }
771 if (!pict_get_dir(p,x,y,pvdir)) {
772 return 0;
773 }
774 *a = ((M_PI/2.0) - acos(fdot(hv,pvdir)));
775 return 1;
776 }
777
778 int pict_setorigin(pict* p,FVECT orig)
779 {
780 VCOPY(p->view.vp,orig);
781 return pict_update_view(p);
782 }
783
784 int pict_setdir(pict* p,FVECT dir)
785 {
786 VCOPY(p->view.vdir,dir);
787 return pict_update_view(p);
788 }
789
790 int pict_sethview(pict* p,double ha)
791 {
792 p->view.horiz = ha;
793 return pict_update_view(p);
794 }
795
796 int pict_setvview(pict* p,double va)
797 {
798 p->view.vert = va;
799 return pict_update_view(p);
800 }
801
802 int pict_setvtype(pict* p,char vt)
803 {
804 p->view.type = vt;
805 return pict_update_view(p);
806 }
807
808 #ifdef TEST_PICTTOOL
809
810 char* progname = "pictool";
811
812 int main(int argc,char** argv)
813 {
814 pict* p = pict_create();
815 FVECT dir = {0,-1,0};
816 FVECT vdir,edir;
817 FVECT up = {0,0,1};
818 int x,y,i;
819 double sang,h,v;
820
821 if (argc < 2) {
822 fprintf(stderr,"usage: %s <pic-file>\n",argv[0]);
823 return EXIT_FAILURE;
824 }
825 fprintf(stderr,"readdd\n");
826 pict_read(p,argv[1]);
827 pict_set_comment(p,"pictool test output\n");
828 /*
829 pict_get_dir(p,100,100,edir); // YDECR
830 for(y=0;y<p->resol.yr;y++) {
831 for(x=0;x<p->resol.xr;x++) {
832 pict_get_hangle(p,x,y,dir,up,&h);
833 pict_get_vangle(p,x,y,dir,up,&v);
834 pict_get_dir(p,x,y,vdir);
835 if (acos(DOT(vdir,edir)) < DEG2RAD(3))
836 setcolor(pict_get_color(p,x,y),h+M_PI/2,v+M_PI/2,1);
837 else
838 setcolor(pict_get_color(p,x,y),h+M_PI/2,v+M_PI/2,0);
839 }
840 }
841 */
842 printf("resolution: %dx%d\n",pict_get_xsize(p),pict_get_ysize(p));
843 sang = 0.0;
844
845 pict_new_gli(p);
846 for(x=0;x<pict_get_xsize(p);x++)
847 for(y=0;y<pict_get_ysize(p);y++) {
848 pict_get_dir(p,x,y,dir);
849 if (DOT(dir,p->view.vdir) >= 0.0) {
850 pict_get_av_omega(p,0) += pict_get_omega(p,x,y);
851 }
852 sang = pict_get_sangle(p,x,y);
853 for(i=0;i<3;i++)
854 if (sang <= 0 && pict_is_validpixel(p,x,y)) {
855 pict_get_color(p,x,y)[i] = 1;
856 } else {
857 pict_get_color(p,x,y)[i] =0;
858 }
859 }
860 printf("s %f\n",pict_get_av_omega(p,0));
861 pict_write(p,"test.pic");
862 while(1) {
863 printf("pos\n");
864 if (scanf("%d %d",&x,&y) != 2)
865 continue;
866 pict_get_dir(p,x,y,dir);
867 printf("dir: \t\t %f %f %f\n",dir[0],dir[1],dir[2]);
868 printf("solid angle: \t %f \n",pict_get_sangle(p,x,y));
869 }
870 return EXIT_SUCCESS;
871 }
872
873 #endif
