root/radiance/src/util/objview.csh
Revision: 2.12
Committed: Tue Jan 13 22:19:25 2009 UTC (16 years, 9 months ago) by greg
Content type: application/x-csh
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad6R0, rad4R1, rad4R0, rad4R2P1, rad4R2P2, HEAD
Added ambient file setting for rvu value sharing with -N > 1
# User Rev Content
1 greg 1.1 #!/bin/csh -f
2 greg 2.12 # RCSid: $Id: objview.csh,v 2.11 2008/11/21 01:30:17 greg Exp $
3 greg 1.1 #
4     # Make a nice view of an object
5 greg 2.2 # Arguments are scene input files
6 greg 1.1 #
7 greg 2.10 set tmpdir=/tmp
8 greg 1.1 set octree=$tmpdir/ov$$.oct
9 gwlarson 2.6 set lights=$tmpdir/lt$$.rad
10     set rif=$tmpdir/ov$$.rif
11 greg 2.12 set ambf=$tmpdir/af$$.amb
12     set tmpfiles="$octree $lights $rif $ambf"
13 gwlarson 2.7 set raddev="x11"
14 gwlarson 2.6 set up="Z"
15     set vw="XYZ"
16 gwlarson 2.7 set rendopts=""
17 gwlarson 2.6 set opts=""
18     while ($#argv > 0)
19     switch ($argv[1])
20 gwlarson 2.7 case -g*:
21 gwlarson 2.6 set usegl
22     breaksw
23     case -u:
24     shift argv
25     set up=$argv[1]
26     breaksw
27     case -s:
28     case -w:
29     set opts=($opts $argv[1])
30     breaksw
31 gwlarson 2.7 case -b*:
32     set rendopts=($rendopts -bv)
33     breaksw
34 gwlarson 2.6 case -v:
35     shift argv
36 greg 2.11 set vw="$argv[1]"
37     breaksw
38     case -N:
39     shift argv
40     set opts=($opts -N $argv[1])
41     set radopt
42 gwlarson 2.6 breaksw
43     case -o:
44     shift argv
45 gwlarson 2.7 set raddev="$argv[1]"
46 gwlarson 2.6 set radopt
47     breaksw
48     case -V:
49     case -e:
50     set opts=($opts $argv[1])
51     set radopt
52     breaksw
53     case -S:
54     set opts=($opts $argv[1])
55     set glradopt
56     breaksw
57     case -*:
58     echo "Bad option: $argv[1]"
59     exit 1
60     default:
61     break
62     endsw
63     shift argv
64     end
65     if ( $#argv == 0 ) then
66     echo "No input files specified"
67     exit 1
68     endif
69     if ( $?usegl ) then
70     if ( $?radopt ) then
71     echo "bad option for glrad"
72     glrad
73     exit 1
74     endif
75     else
76     if ( $?glradopt ) then
77     echo "bad option for rad"
78     rad
79     exit 1
80     endif
81     endif
82
83 greg 1.1 onintr quit
84
85 gwlarson 2.6 cat > $lights <<_EOF_
86 greg 2.2 void glow dim 0 0 4 .1 .1 .15 0
87     dim source background 0 0 4 0 0 1 360
88     void light bright 0 0 3 1000 1000 1000
89     bright source sun1 0 0 4 1 .2 1 5
90     bright source sun2 0 0 4 .3 1 1 5
91     bright source sun3 0 0 4 -1 -.7 1 5
92     _EOF_
93
94 gwlarson 2.6 cat > $rif <<_EOF_
95     scene= $argv[*]:q $lights
96     EXPOSURE= .5
97     UP= $up
98     view= $vw
99     OCTREE= $octree
100 greg 2.9 oconv= -f
101 greg 2.12 AMBF= $ambf
102 gwlarson 2.7 render= $rendopts
103 gwlarson 2.6 _EOF_
104 greg 2.5
105 gwlarson 2.6 if ( $?usegl ) then
106     glrad $opts $rif
107     else
108 gwlarson 2.7 rad -o $raddev $opts $rif
109 gwlarson 2.6 endif
110 greg 1.1
111     quit:
112     rm -f $tmpfiles
113     exit 0
