root/radiance/src/util/objpict.csh
Wed Jul 22 17:48:07 2009 UTC (16 years, 3 months ago) by greg
CVS Tags: HEAD, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4, rad6R0
Changes since 2.6: +11 -14 lines
Bug fix and changed to produce much better quality output
Wed Jul 22 17:35:06 2009 UTC (16 years, 3 months ago) by greg
Changes since 2.5: +48 -12 lines
Removed dependency on library file "testroom"
Mon Nov 10 19:08:19 2008 UTC (16 years, 11 months ago) by greg
Changes since 2.4: +5 -5 lines
Wed Feb 16 05:40:12 2005 UTC (20 years, 8 months ago) by greg
Thu Jan 29 22:45:30 2004 UTC (21 years, 9 months ago) by greg
Changes since 2.2: +15 -5 lines
Changed behavior so model gets placed where it needs to be automatically
Sat Feb 22 02:07:30 2003 UTC (22 years, 8 months ago) by greg
Diff to previous 2.1
Tue Nov 12 17:19:26 1991 UTC (34 years ago) by greg
Changes since 1.1: +0 -0 lines
Diff to previous 1.1
Wed Apr 24 18:27:09 1991 UTC (34 years, 6 months ago) by greg
Links to HEAD: (view) (download) (as text) (annotate)
